Date/Time: Wed, 24 Apr 2024 09:05:02 +0000
is there a way to show % of min-max value of an indi
View Count: 833
[2015-02-20 18:51:22] |
Yes this is possible. You could use the Spreadsheet study to calculate this: http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
