Date/Time: Thu, 25 Apr 2024 09:47:25 +0000
Custom columns for Trade DOM
View Count: 2645
[2013-05-26 05:21:12] |
WarEagle - Posts: 70 |
Hi, Is it possible for me to write a custom column for the Trade DOM the way the "Volume By Price" indicator is done? If so, can you point me to the ACSIL code in the VBP indicator that accesses the DOM? I can't seem to find it and it would be helpful to see an example. Thanks! |
[2013-05-26 22:11:55] |
It is possible to add a custom study to the Trade DOM through Chart >> Studies. Currently custom studies will not drawn, but in the next Sierra Chart release they will. there should be a new version out tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-30 03:10:44] |
Ok, so I downloaded the latest version that came out today (981). I tried adding some custom studies to a Trade DOM window. I didn't see many that would be a natural fit on a DOM but I tried the Initial Balance study thinking maybe it would draw lines at those price levels. I couldn't get anything to show up but maybe I am doing something wrong. Do you know of any custom studies that should display on the Trade DOM? I am just looking for some example code to see how it is done. I would like to have a column drawn next to the price column like the Volume By Price study where I could have it display my own values at each price level.
[2013-05-30 07:00:46] |
We see why you are not seeing any studies appearing and this will be resolved in the next release.
[2013-05-30 20:07:41] |
ganz - Posts: 1048 |
Hello SC Support. Does this mean one can use sc.UseTool() ? Thank you. |
[2013-05-30 20:15:47] |
Not now. But in the next release this will be supported.
