Date/Time: Thu, 25 Apr 2024 14:14:55 +0000
30yr bond data
View Count: 1488
[2013-05-23 20:33:49] |
M5amhan - Posts: 468 |
since the transact bridge server was put in I no longer receive bond data. it looked like it was resolved in the new 979 release but the constant range scale improvements werent working until I downloaded the 979 pre-release and now the bond data doesnt work again.
[2013-05-23 23:21:59] |
We tested this and do not observe this problem. We can get ZB data fine.
[2013-05-23 23:34:06] |
should i contact infinity about this?
[2013-05-23 23:39:06] |
Yes. We can see that your account is not authorized for that symbol.
[2013-05-23 23:41:24] |
my account is authorized for it, ive always gotten the data. but i think i got it fixed, i downgraded then upgraded again to the pre-release then disconnected and connected and it is working now you can disregard this |
