Date/Time: Tue, 17 May 2022 13:20:54 +0000
Multiple Instruments on the same chart
View Count: 1182
[2013-05-23 00:40:05] |
redduke2 - Posts: 2 |
Hello, Is is possible to display multiple instruments on the same chart? Thanks |
[2013-05-23 05:14:51] |
Yes, use this Overlay study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s100 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-24 00:16:58] |
Thanks for this info
