Date/Time: Thu, 10 Sep 2026 07:26:49 +0000
Managing Chart #
View Count: 1240
| [2015-01-15 16:36:56] |
| drywater0 - Posts: 85 |
SC Support, 1) Is there a limit to the number of charts or other elements (DOM, Quote Table, etc) that may be included in a single ChartBook File. 2) Is there a way to easily identify which Chart # is associated with each chart - other than clicking into each individual chart? For example, is there a page that summarizes the chart # with the associated chart name, which I have customized? 3) Is there a way to re-assign Chart #s? 4) How are Chart #s assigned to charts? Is it in the order that they are created? For example, if I have Chart #'s 1 - 10 and delete #5, will #5 be assigned to the next new chart created or will it be #11. I have built up a ChartBook File over time that has become a little unwieldy and disorganized. My aim is to reorganize it using logical chart # without painstakingly rebuilding it. Any guidance you can offer is very much appreciated. Thank you in advance. |
| [2015-01-15 17:30:32] |
1. No. 2. Look at the CW menu. 3. No. 4. I have Chart #'s 1 - 10 and delete #5, will #5 be assigned to the next new chart created It works like this.
| [2015-01-15 18:40:51] |
Thanks for quick response. I'm not clear on your answer for #4. Does that mean that the new chart gets assigned #5 because that was last to be deleted?
| [2015-01-15 19:50:41] |
| Sawtooth - Posts: 4351 |
If you want to reassign chart numbers, there is a workaround using Chart >> Duplicate Chart. This is possible because a new chart is assigned the lowest available vacant chart number.
| [2015-01-15 20:10:48] |
Tomgilb, Thanks so much for your suggestion. Duplicating only what I need to a new ChartBook will save a lot of time and produce logical Chart #'s. Time to get busy with some spring cleaning! |
