Date/Time: Fri, 29 Mar 2024 07:00:52 +0000
Text Column in Trading DOM
View Count: 2266
[2014-12-09 16:39:57] |
AC95501 - Posts: 28 |
Dear SC Support Board, is it possible to have an additional column in the trading dom where I can write a text or mark important prices? Thanks in advance Max |
[2014-12-09 16:47:57] |
This is not supported or planned. Use a regular chart and the chart DOM: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM And the Text tool: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#TypeText Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-09 16:52:20] |
Ok, thank you for your fast reply. Have a nice day. |
[2014-12-10 22:50:23] |
User34947 - Posts: 42 |
You can write text on Trade DOM. Select Chart-->Studies-->Add Custom Study and under SC Custom Studies and Example you'll find the study called Line. Add it. In the Settings you can specify at what price you want to insert the text (or a line) and in the tab Subgraph select Draw Style: Subgraph Name and Value Labels only. Flag Name Label and write the text in Short Name. |
[2014-12-11 06:44:02] |
Hey, great and thank you for your reply! Is there anything else helpful in Custom Studies that I can use for order flow? Thanks anyway! |
[2022-05-18 14:22:05] |
User263711 - Posts: 11 |
Thanks for the guidance. I did it
