Date/Time: Fri, 19 Apr 2024 18:13:33 +0000
Problem installing compiler
View Count: 2077
[2013-05-16 12:40:29] |
maxpi - Posts: 175 |
I'm running Sierrachart under Linux installed on a live USB drive. Charts are running ok but when I install the compiler the log tells me it's been downloaded to the C: drive and nothing happens after that. The C: drive on the computer is encrypted so I know the file has not been dl'd to the C: drive. I can't find said file [SCCPPCompiler.exe] to copy it. Can I download it from somewhere else and make a folder and copy it to said folder?
[2013-05-16 14:54:30] |
ganz - Posts: 1048 |
maxpi hi It's possible to build ACSIL studies on Linux w a native g++ compiler. http://www.blogcompiler.com/2010/07/11/compile-for-windows-on-linux/ http://www.sierrachart.com/supportboard/showpost.php?p=234516 gd lck |
[2013-05-16 15:29:11] |
compile natively... Hadn't thought of that. Thanks much Ganz! |
[2013-05-16 17:48:40] |
Actually, once I found the files [they are in a hidden folder] I just ran the batch file with wine and it installed and runs fine.
[2013-05-16 21:54:26] |
This is good.
