Date/Time: Fri, 09 Oct 2026 07:07:39 +0000
What packages and service do I need for stocks?
View Count: 602
| [2026-09-02 18:38:03] |
| User504586 - Posts: 10 |
Hello, I am looking to get Sierra Charts for my charting for day trading stocks. I am looking to use things such as footprint charts, volume profile and depth of market to trade tickers such as TSLA, SPCX, HOOD, etc. I don't necessarily need to execute the trade on Sierra Charts as I use something else for that but I do need to see all this info for the stocks. Which package and service do I need for this? My trading status would be non-professional as well. I believe I would go with package 11 correct? Then what data feed do I need and which one supports stocks if any? I've seen in some places that Sierra is mainly for futures and won't support for individual stocks or is that false? TLDR What package and data feed do I need to get for order flow charting for stocks as a non-professional user? Thanks! |
| [2026-09-02 20:24:38] |
| Sierra_Chart Engineering - Posts: 25111 |
I've seen in some places that Sierra is mainly for futures and won't support for individual stocks or is that false? Yes this is definitely false. Sierra Chart has an excellent stock data feed direct from NASDAQ and NYSE.You will need Service Package 11: Description of Service Packages and Pricing: Integrated Sierra Chart with Advanced Features (Service Package 11) You will want to use the US equities consolidated tape data feed and/or NASDAQ Totalview.: US Stock/Equities Consolidated Tape Data Feed For high accuracy with Numbers Bars we recommend using NASDAQ Totalview.: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-02 20:25:33
| [2026-09-02 20:50:41] |
Thanks for the reply. That cleared things up a bit. I just have a couple more questions if you don't mind. 1. If I do month to month for service package 11 it would be $46. Then I need to get NASDAQ Totalview for $17 a month. The US Equities Consolidated Tape which is $10 I don't need that as well or do I? I already use level 2 data with DAS. Is there anything else I would need besides the first two (If I don't need the The US Equities Consolidated Tape) 2. Do I need to connect Sierra Charts to my broker in order for it to work or I can use it without connecting? (I use Schwab as my broker) 3. For the non-professional prices on the datafeed, how do I verify I am non-professional? Do you need to connect to the broker? I am using Schwab and a lot of what I saw online people were saying you need Interactive Brokers? Thanks a lot for the help! |
| [2026-09-02 21:31:37] |
| John - SC Support - Posts: 48161 |
First, be aware that you also have a third option for the U.S. Stock data, which is to use both the "U.S. Equities Consolidated Tape" and the NASDAQ TotalView. Refer to the following: Denali Exchange Data Feed: U.S. Equities Consolidated Tape with NASDAQ TotalView 1. That is all you need if that is what you want. 2. You do not need to connect to a broker in order to get the U.S. Equities data. That requirement is only for the CME Group data. 3. You just need to fill out the agreements as a Non-Professional. Nothing else. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-04 00:41:10] |
Thanks for the help John. I have subscribed to package 11 and got the Nasdaq Totalview Data Feed. Just some last questions 1. In Sierra Chart do I need to select somewhere or make sure that it's connect to the Nasdaq feed I got or does it connect automatically? 2. Can I later on If I decide to, get the "U.S. Equities Consolidated Tape"? 3. From what I understand the Nasdaq feed I got gives me data from Nasdaq only but the U.S. Equities Consolidated Tape will get data from all exchanges so I will have more accurate data? Do I understand that correctly? Thanks again for all the help! |
| [2026-09-04 05:52:02] |
| TonyCipriani - Posts: 155 |
After you activate it for the first time, you should be connected to it after a few minutes. Then every time you open the platform, you'll be connected automatically. You can get US Consolidated Tape later too if you want. It gives you full traded volume across all exchanges. Nasdaq TotalView is good if you want level 2/market depth (strictly from NASDAQ exchange) |
