Date/Time: Fri, 09 Oct 2026 07:15:25 +0000
Delayed data after resuming sierra chart
View Count: 272
| [2026-09-02 12:41:10] |
| User558370 - Posts: 23 |
I am back from a 6 week break which coincided with Sierra expiring. After resigning up and getting the normal Denali Data feed, I am getting delayed data while connecting to Sierra Chart. Appears to be 13 minutes delayed - all it says is "delayed" in the title bar. I have attached screenshot |
| [2026-09-02 12:50:20] |
| User135243 - Posts: 321 |
not sure what you mean with "normal" Denali data? are you sure that you subscribed to real-time data, yesterday was the 1st, so a new period for real-time data
| [2026-09-02 13:00:19] |
The normal denali CME data feed under Activate Services. It has a green check mark next to it so it shows payment has been accepted. Please see attached picture.
| [2026-09-02 13:04:10] |
this just means that all agreements are signed, now click "activate" and watch which exchanges are active or not
| [2026-09-02 14:24:52] |
| John - SC Support - Posts: 48161 |
Your issue is that you have activated a Non-Professional exchange option for the CME Group, but you have not connected your Sierra Chart software to your live, funded, futures trading account in order to verify your non-professional standing. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges When you make a good connection to your live trading account, your "Verified Until" date will change to 30 days in the future. This date must be in the future in order to get the real-time non-professional data. Right now, your date is showing as "August 6, 2026". You can view this date at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges If you need help connecting to your live trading service, then let us know what Broker or Trading Service you use for your live trading account, and we will point you to the proper instructions to connect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-09-03 13:14:43] |
Thank you John. I previously connected it via Teton CME / Cunningham to EDGECLEAR, then closed the account as I did not like executing from Sierra (but I like the charting). Now I only have interactive brokers and ninjatrader for execution. I'd like to know the methods to connect to both. |
| [2026-09-03 14:24:55] |
You can connect your Sierra Chart to Interactive Brokers by following these instructions: Interactive Brokers Trading Service: Setup Instructions NinjaTrader does not allow for connectivity with Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-09-08 05:13:56
