Date/Time: Fri, 29 Mar 2024 06:00:30 +0000
Numbers Bars V2 with IQfeed datas
View Count: 2215
[2013-05-15 17:33:07] |
TradingMarketProfile - Posts: 120 |
Hello, i have transact data and when i add the numbers bars v2 studies, no problem (see chart) When i use IQfeed datas i have big problem (see chart) Do you know why and can you tell me what to do please Thanks Transact : http://www.sierrachart.com/image.php?l=136863874928.png IQfeed : http://www.sierrachart.com/image.php?l=1368638846999.png |
[2013-05-15 19:43:50] |
Follow the instructions on this page: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-15 20:16:10] |
ok it works thanks
