Date/Time: Thu, 25 Apr 2024 23:51:04 +0000
Strange fills on sim account
View Count: 1501
[2013-05-15 20:40:51] |
Where in Sierra Chart are you seeing this: simultaneously closed another trade for a $5140 loss.
What Trading service are you using? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-16 03:45:46] |
Not necessarily, because if you are referring to an order fill, the problem resolved is unrelated to this.
