Date/Time: Sat, 15 Aug 2026 01:20:50 +0000
Zig Zag Study
View Count: 208
[2026-05-21 15:29:10]
Profile Trader - Posts: 182
Could someone confirm that You cannot turn the text in this study vertically on the chart? It appears under subgraph those areas are greyed out and under settings I only see Horizontal alignment of left, right, center
If it is not an option would you consider adding it?
Doug
[2026-05-21 17:13:14]
John - SC Support - Posts: 47509
There is no support to make the text display vertically in the Zig Zag study.
There are no items in the subgraphs that relate to Vertical alignment, but we are wondering what items you may be referring to in your statement that "It appears under subgraph those areas are greyed out..."?
[2026-05-21 19:04:37]
See attached photo
I was basing this comment on selecting text labels in subgraph column and then the drop down boxes for name label or value label
imageTinyTake21-05-2026-03-00-30.png / V - Attached On 2026-05-21 19:02:25 UTC - Size: 54.07 KB - 95 views
[2026-05-21 20:23:15]
The "Labels" options do not give an option for Vertical text. It just sets the location of the text, not the orientation.
And those items are not selectable, as those items relate to subgraph values. The Subgraph for Text Labels does not contain any actual values, it is used to set the coloring of the text.
