Date/Time: Thu, 20 Aug 2026 00:02:15 +0000
dom settings
View Count: 264
[2026-05-18 20:07:13]
User570983 - Posts: 5
In ZN i am not able to correct the price to show the same in the dom as the charts, i have ZNM26 on both and the dom shows decimals while the charts shows inches, how do i change it, is ther a way to zync the dom with the chart or do i always have to use the chart dom???
[2026-05-18 21:37:02]
John - SC Support - Posts: 47554
This is due to have you have the charts set to display the data. Refer to the following setting that controls this:
Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
If you want to display the price in fractional format, then also be aware of the following setting:
General Settings Window: Display Fractions In Short Format (Global Settings >> General Settings >> Charts >> Charts)
[2026-05-18 21:41:51]
Thanks a lot, is it possible to add delta volume on any of the volume options in the chart dom (current present volume) or do i need to use a separate Dom
[2026-05-18 21:46:22]
Refer to the following and the item below it:
Global Trade Settings Windows: Current Traded Ask Minus Bid Volume - Left/Center/Right Aligned
If the above is not what you are asking for, then we need more information on what you are asking.
[2026-05-23 20:18:58]
In my "Customize dom settings" for "trading chart dom on" i do not have the following options :
[Link] - [Top]
The Current Traded Ask Minus Bid Volume column can be left, center or right aligned.
This column calculates and displays the difference between Ask Volume and Bid Volume at each price level from trades that have occurred.
This column resets when Trade >> Clear Current Traded Bid/Ask Volume on Chart DOM is selected, or you right-click on the price scale and select Clear Current Traded Bid/Ask Volume on the displayed menu.
Current Traded Diagonal Ask Minus Bid Volume - Left/Center/Right Aligned
[Link] - [Top]
The Current Traded Diagonal Ask Minus Bid Volume column can be left, center or right aligned.
This column calculates and displays the diagonal difference between Ask Volume and Bid Volume at each price level from trades that have occurred.
The calculation method for theDiagonal Ask Minus Bid Volume market data column is documented in the Ask Vol Bid Vol Diff Diagonal Dominant Side section.
[2026-05-23 20:50:43]
Sierra_Chart Engineering - Posts: 24606
You are running an older version of Sierra Chart. You must update. Instructions:
