Date/Time: Wed, 13 May 2026 09:52:05 +0000
freezing for long time during accurate trading system backtesting
View Count: 144
[2026-04-08 21:54:25]
User970210 - Posts: 102
Hi, I come across constant freezing for long time during accurate trading system backtesting. My system use 4 linked different time frame charts and 30days data. I have most latest update 2891 for sc. I would like to know anythings I can do to avoid this.
thx
[2026-04-09 14:10:37]
John - SC Support - Posts: 46104
When you run a replay with multiple charts, you are prompted for a "Processing Time in Seconds". This is the amount of data that will be processed in a batch. Therefore, depending on what this is set to and the "Replay Speed", your charts will stop updating during that time while the replay is running.
But, you should be able to interact with the program. Are you actually not able to interact with the system while this is occurring?
Also, we want to ensure that we understand how you are running the backtest. Please let us know if you are selecting one of the options in the "Trade" menu, or if you are doing this all from the Replay Control Panel window.
[2026-04-15 16:51:01]
thx john. I have used processing time in seconds 60s and replay speed 60. I can still interact with chart even backtesting seems frozen. I did all from replay control panel window. My issue is the freezing time was quite long as 1-2 hours even though the backtesting eventually finished.
Song
[2026-04-15 17:52:30]
Please tell us how exactly you are doing the backtesting, and what items you are setting on the Replay Control Panel.
