Date/Time: Thu, 25 Apr 2024 23:19:48 +0000
[User Discussion] - please help convery easylanguage study to sierra chart Thanks
View Count: 2057
[2013-05-14 22:27:50] |
Did you need this part of it: if D_line > up and K_line cross under D_line then exitlong next bar at market; if D_line < down and K_line cross over D_line then buy next bar at market; if D_line > up and K_line cross under D_line then sell next bar at market; if D_line < down and K_line cross over D_line then exitshort next bar at market; Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-15 20:41:24] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/SierraChartStudyAndSystemProgrammers.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
