Date/Time: Thu, 10 Sep 2026 07:36:50 +0000
Having problems moving stop order
View Count: 1458
[2014-10-21 15:25:07]
Netz - Posts: 19
Hello.
I use cqg with AMP. For example if I trade 2 contracts in CL or TF. It is quite often when I move my stop to profit, that order would have issues. Please advise.
Here is the log:
There was an error with the order cancellation: Order Cancel Reject. Text: Cannot process order (error code 60). Please contact CQG if the problem persists.. Order Cancellation failed. Service order ID: 475215106 | 2014-10-21 09:39:00 *
There was an error with the order modification: Order Modification Reject. Text: TE_invalidBuyStopPrice ExchangeRejectCode = ctUserDefined[]. Service order ID: 475423670 | 2014-10-21 10:52:22 *
Unable to find order with service order ID when processing failed order modification. Service order ID: 475423670 | 2014-10-21 10:52:22 *
There was an error with the order modification: Order Modification Reject. Text: TE_invalidBuyStopPrice ExchangeRejectCode = ctUserDefined[]. Service order ID: 475423796 | 2014-10-21 10:53:29 *
Unable to find order with service order ID when processing failed order modification. Service order ID: 475423796 | 2014-10-21 10:53:29 *
There was an error with the order modification: Order Modification Reject. Text: TE_invalidBuyStopPrice ExchangeRejectCode = ctUserDefined[]. Service order ID: 475438252 | 2014-10-21 11:12:54 *
Unable to find order with service order ID when processing failed order modification. Service order ID: 475438252 | 2014-10-21 11:12:54 *
[2014-10-22 03:36:24]
The order modification is getting rejected as it should be.
However, there is a problem with the handling of the rejection execution report and we need to solve that.
For now, after the rejection, select Trade >> Refresh Trade Data from Service.
Date Time Of Last Edit: 2014-10-22 03:38:15
