Date/Time: Fri, 13 Mar 2026 20:54:48 +0000
GLOBAL ENABLE Order Allocation to Trade Accounts?
View Count: 188
| [2025-12-05 12:29:48] |
| tomas262 - Posts: 157 |
Would that be possible? Could you add this? I watch 20 symbols and it is a real pain to setup each one individually Then when SC is restarted another pain comes I need to re-enable for all symbols again I just want to copy all trades from all symbols to another account(s) Please... Date Time Of Last Edit: 2025-12-05 12:31:48
| [2025-12-05 14:29:35] |
| User135243 - Posts: 225 |
open a "trade window for chart" and there click M or Menu (depends which you've) and there go to Settings and click: Enable Order Allocation to Trade Accounts I guess you've to do it for each symbol, but after that, best to close SC and click save and it should work after the restart |
| [2025-12-05 15:50:08] |
| John - SC Support - Posts: 45103 |
Refer to the following: Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General) Also be aware of the following setting and the one after it that allow you to use the Order Allocation to Trade Accounts in Trade Window Linking and in the Trade Configurations: Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Linking For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-05 21:36:53] |
Also be aware of the following setting and the one after it that allow you to use the Order Allocation to Trade Accounts in Trade Window Linking and in the Trade Configurations: Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Linking John, not sure how to use this. Can you make an example? |
| [2025-12-05 22:04:51] |
Those options determine if the "Order Allocation to Trade Accounts" is included in Trade Window Linking or in Trade Configurations. For example, if you set the option for "Order Allocation to Trade Accounts Include in Linking" to "Yes", and you have the Trade Window being linked between charts A and B, then as the Order Allocation to Trade Accounts is changed in the Trade Window for Chart A, it will also change those settings for Chart B. If the "Order Allocation to Trade Accounts Include in Save Trade Window Configuration" is set to "Yes", then when you save a Trade Configuration, the settings for the Order Allocation will be saved in that Trade Configuration. This way, if you have different allocation setups you want to use, you can easily switch between them by changing your Trade Configuration selection. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
