Date/Time: Wed, 09 Sep 2026 10:30:18 +0000
VOLUME : TICKS
View Count: 299
| [2025-11-10 20:23:08] |
| rebeccaemme - Posts: 42 |
Hello, I’ve been trying for several days to obtain a simple numeric value of Volume : TICKS for each candlestick (for example, on a 5-minute chart). I would like this value to appear in the Numbers Bars Calculated Values, just like Delta, Volume, or other standard statistics. Is there an existing study or a straightforward way to display this ratio (Volume : Ticks) directly in the Numbers Bars Calculated Value Thank you for your help! |
| [2025-11-10 20:42:19] |
| John - SC Support - Posts: 47806 |
We just gave you a way to do this in the other post. Please do not post more than once for the same issue/question. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
