Date/Time: Thu, 08 Oct 2026 10:35:06 +0000
How to stop an alert from coloring the Display Study Name background?
View Count: 346
| [2025-11-10 16:32:03] |
| User357195 - Posts: 204 |
I have an alert set on a study. I also have a check on the Display Study Name box in the Subgraph tab for this example study. SC displays the Short Name on the specific Chart Region. When the alert is triggered, SC sets off the audio file, which is exactly what I want. SC also highlights the background of the Short Name in the Chart Region, for this example, Chart Region 2. How do I tell SC to not highlight the background of the Short Name? In my opinion, Sierra Charts are the best. |
| [2025-11-10 16:50:41] |
| John - SC Support - Posts: 48143 |
There is not a way to turn off the coloring of the Study Name in the header. The only option would be to not display that item, so then you will not see the coloring. To do this, turn off the "Display Study Name" in the Subgraphs Tab for the study. Refer to the following: Chart Studies: Subgraphs Tab >> Display Study Name For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
