Date/Time: Fri, 16 Jan 2026 00:32:46 +0000
denali data delayed
View Count: 244
| [2025-11-10 14:37:07] |
| Flowdity - Posts: 61 |
I have delayed denali data since last week, sometimes it delayed more than 1 min, I have to try multiple re-connect below are some message log 2025-11-10 09:17:16.097 | Trade activity files set size: 24 2025-11-10 09:17:16.126 | Reading Internal Order ID file. 2025-11-10 09:17:16.126 | Reading Trade Orders file. 2025-11-10 09:17:16.126 | Reading Trade Positions file. 2025-11-10 09:17:16.126 | Reading Trade Account Data files. 2025-11-10 09:17:16.127 | Software version: 2807 64-bit 2025-11-10 09:17:16.127 | Primary Thread ID: 7332 2025-11-10 09:17:16.127 | Usage end date: 2025-12-11 2025-11-10 09:17:16.127 | Enabled for: Advanced Features 2. 2025-11-10 09:17:16.127 | Enabled for: Sierra Chart Historical Data Service. 2025-11-10 09:17:16.127 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-11-10 09:17:16.127 | Enabled for: Delayed Denali Exchange Data Feed. 2025-11-10 09:17:16.127 | Enabled for exchange2: CME 2025-11-10 09:17:16.127 | Enabled for exchange2: CBOT (Trading Account Required) 2025-11-10 09:17:16.127 | Enabled for exchange2: COMEX (Trading Account Required) 2025-11-10 09:17:16.127 | Enabled for exchange2: NYMEX (Trading Account Required) 2025-11-10 09:17:16.127 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-11-10 09:17:16.127 | Current selected Data/Trading service: Teton CME Routing 2025-11-10 09:17:16.127 | Custom symbol settings values: enabled 2025-11-10 09:17:16.127 | Chart Update Interval: 500 2025-11-10 09:17:16.127 | Intraday Data Storage Time Unit: 0 2025-11-10 09:17:16.127 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-11-10 09:17:16.127 | 2025-11-10 14:17:16 Local computer time in UTC 2025-11-10 09:17:16.127 | 2025-11-10 09:17:16 Local computer time in SC Time Zone 2025-11-10 09:17:16.127 | 2025-11-10 14:16:47 Server time in UTC 2025-11-10 09:17:16.127 | Local computer UTC time and Server UTC time difference: 28 seconds. 2025-11-10 09:17:16.127 | Notice: Your computer's clock is off by 28 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes'. 2025-11-10 09:17:16.127 | NTP Client | Add Server: 0.pool.ntp.org Port: 123 2025-11-10 09:17:16.127 | Program path: C:\SierraChart\ 2025-11-10 09:17:16.127 | Data Files path: C:\SierraChart\Data\ 2025-11-10 09:17:16.127 | NTP Client | Add Server: 1.pool.ntp.org Port: 123 2025-11-10 09:17:16.127 | NTP Client | Add Server: 2.pool.ntp.org Port: 123 2025-11-10 09:17:16.127 | NTP Client | Add Server: 3.pool.ntp.org Port: 123 2025-11-10 09:17:16.127 | OS Version Number: 10.0 2025-11-10 09:17:16.127 | Locale Setting: C 2025-11-10 09:17:16.127 | Crash reporter started: true 2025-11-10 09:17:16.127 | 2025-11-10 09:17:16.127 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2025-11-10 09:17:16.127 | NTP Client | Service successfully started. 2025-11-10 09:17:16.129 | NTPClient (4) | Creating socket. 2025-11-10 09:17:16.129 | NTPClient (4) | New receive buffer size: 0 2025-11-10 09:17:16.129 | NTPClient (4) | Connecting to IP: 153.127.38.46. 2025-11-10 09:17:16.130 | NTPClient (6) | Creating socket. 2025-11-10 09:17:16.130 | NTPClient (6) | New receive buffer size: 0 2025-11-10 09:17:16.130 | NTPClient (6) | Connecting to IP: 202.181.103.212. 2025-11-10 09:17:16.132 | NTPClient (7) | Creating socket. 2025-11-10 09:17:16.132 | NTPClient (7) | New receive buffer size: 0 2025-11-10 09:17:16.132 | NTPClient (7) | Connecting to IP: 160.25.135.55. 2025-11-10 09:17:16.134 | NTPClient (8) | Creating socket. 2025-11-10 09:17:16.135 | NTPClient (8) | New receive buffer size: 0 2025-11-10 09:17:16.135 | NTPClient (8) | Connecting to IP: 172.104.124.149. 2025-11-10 09:17:16.177 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:16.178 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:16.178 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2025-11-10 09:17:17.127 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:17:17.127 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:17:17.127 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:17:17.127 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:17:17.235 | NTP Client | Received Packet | RoundTripDelay=0.1069803237915039, SystemClockOffset=0.02154827117919922 2025-11-10 09:17:17.238 | NTP Client | Received Packet | RoundTripDelay=0.11085748672485352, SystemClockOffset=0.030352354049682617 2025-11-10 09:17:17.329 | Received 5 login tokens. 2025-11-10 09:17:17.498 | NTP Client | Received Packet | RoundTripDelay=0.36997318267822266, SystemClockOffset=0.03912019729614258 2025-11-10 09:17:18.158 | NTP Client | Performed system clock adjustment of 30352.354049682617 microseconds. 2025-11-10 09:17:18.649 | Requested user files to download. 2025-11-10 09:17:20.413 | Symbol settings MD5 received. Request ID: 1. 2025-11-10 09:17:20.413 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2025-11-10 09:17:20.663 | 2025-11-10 09:17:20.664 | Teton CME Routing | Firm: Dorman 2025-11-10 09:17:20.666 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 2025-11-10 09:17:20.666 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2025-11-10 09:17:20.666 | DTC Client socket (2) | New receive buffer size: 0 2025-11-10 09:17:20.666 | DTC Client socket (2) | Connecting to IP: 208.185.224.130. 2025-11-10 09:17:20.667 | Teton CME Routing | Network connection to server complete. 2025-11-10 09:17:20.667 | Teton CME Routing | Starting socket receive thread. 2025-11-10 09:17:20.667 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-11-10 09:17:21.147 | File to download: OrderFlowLabs.com.free_64.dll. Action: 1 2025-11-10 09:17:21.151 | File to download: OrderFlowLabs.com.free_ARM64.dll. Action: 1 2025-11-10 09:17:21.178 | User files to download complete 2025-11-10 09:17:22.250 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-11-10 09:17:22.250 | Teton CME Routing | Sending logon request message. 2025-11-10 09:17:22.666 | Teton CME Routing | Received logon response. 2025-11-10 09:17:22.666 | Teton CME Routing | Server Name: SC DTC Server. Build=54268. 2025-11-10 09:17:22.666 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:17:22.666 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-11-10 09:17:22.666 | Teton CME Routing | Trading is supported. 2025-11-10 09:17:22.666 | Teton CME Routing | Order cancel and replace is supported. 2025-11-10 09:17:22.666 | Teton CME Routing | OCO Orders supported. 2025-11-10 09:17:22.666 | Teton CME Routing | Bracket Orders supported. 2025-11-10 09:17:22.666 | Teton CME Routing | MarketDepthIsSupported: 1 2025-11-10 09:17:22.666 | Teton CME Routing | Connection to server complete. 2025-11-10 09:17:22.667 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-11-10 09:17:22.667 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-11-10 09:17:22.670 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-11-07 17:29:53.976000 2025-11-10 09:17:22.979 | ESZ25_FUT_CME [CV] 240 Min #2 | Reloading chart. 2025-11-10 09:17:22.981 | Starting DelayedDownloadMonitoringTimer 2025-11-10 09:17:22.981 | Starting HDTimeoutTimer 2025-11-10 09:17:22.981 | Added historical Intraday data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:17:22.981 | Triggering next historical data download in queue. 2025-11-10 09:17:23.005 | ESZ25_FUT_CME [CV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2025-11-10 09:17:23.013 | ESZ25_FUT_CME [CV] 60 Min #3 | Reloading chart. 2025-11-10 09:17:23.029 | ESZ25_FUT_CME [CV] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 1, 2025-11-10 09:17:23.032 | Loading DLL: C:\SierraChart\Data\google_sheets_importer.dll (google_sheets_importer_64.dll). Handle: 66000000 2025-11-10 09:17:23.046 | ESZ25_FUT_CME [CV] 30 Min #10 | Reloading chart. 2025-11-10 09:17:23.062 | ESZ25_FUT_CME [CV] 30 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2025-11-10 09:17:23.074 | ESZ25_FUT_CME [CV] #4 | Reloading chart. 2025-11-10 09:17:23.080 | ESZ25_FUT_CME [CV] #4 | Waiting for historical downloads to complete with the IDs: 1, 2025-11-10 09:17:23.089 | ESZ25_FUT_CME [CV] Daily #5 | Reloading chart. 2025-11-10 09:17:23.248 | ESZ25_FUT_CME [CV] 1 Day #1 | Reloading chart. 2025-11-10 09:17:23.275 | ESZ25_FUT_CME [CV] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 1, 2025-11-10 09:17:23.280 | Mapping ESZ25_FUT_CME to ESZ25. Service code: cme 2025-11-10 09:17:23.280 | Using symbol data fast lookup vector 2025-11-10 09:17:23.280 | HD Request # 1 | Downloading Intraday chart data for ESZ25_FUT_CME to the file ESZ25_FUT_CME.scid. Service: cme 2025-11-10 09:17:23.281 | HD Request # 1 | Download start date-time: 2025-11-10 09:16:18.000000. File last date-time: 2025-11-10 09:16:18.206000 2025-11-10 09:17:23.281 | HD Request # 1 | Using server: ds32.sierracharts.com port 10149 2025-11-10 09:17:23.281 | Socket (1) | Creating socket. 2025-11-10 09:17:23.281 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:23.281 | Socket (1) | Connecting to IP: 69.39.70.248. 2025-11-10 09:17:23.292 | ESZ25_FUT_CME [CV] Daily #5 | Chart data loading complete. 2025-11-10 09:17:23.292 | Updated verified funded futures trading account ending date to: 2025-12-10 14:17:23 2025-11-10 09:17:23.588 | Denali Data Feed | Starting real-time market data updates for: ESZ25_FUT_CME (ESZ25). ID: 1 Service code: cme 2025-11-10 09:17:23.589 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2025-11-10 09:17:23.589 | Denali Data Feed | Requesting security definition data for: ESZ25_FUT_CME (ESZ25). ID: 1 2025-11-10 09:17:23.590 | DTC Client socket (3) | Creating socket. 2025-11-10 09:17:23.590 | DTC Client socket (3) | New receive buffer size: 0 2025-11-10 09:17:23.590 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2025-11-10 09:17:23.593 | Denali Data Feed | Network connection to server complete. 2025-11-10 09:17:23.593 | Denali Data Feed | Starting socket receive thread. 2025-11-10 09:17:23.593 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-11-10 09:17:24.096 | HD Request # 1 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:24.096 | HD Request # 1 | Sending historical data logon request message. 2025-11-10 09:17:24.096 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ25_FUT_CME 2025-11-10 09:17:24.096 | Teton CME Routing | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-11-10 09:17:24.096 | Teton CME Routing | Received security definition for symbol ESZ25_FUT_CME 2025-11-10 09:17:24.614 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:18. Record interval: 0. Symbol: ESZ25 2025-11-10 09:17:24.991 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-11-10 09:17:24.991 | Denali Data Feed | Sending logon request message. 2025-11-10 09:17:25.038 | HD Request # 1 | Decompressing data. 2025-11-10 09:17:25.285 | HD Request # 1 | Receiving Intraday data for ESZ25_FUT_CME starting at 2025-11-10 09:16:18.134000 2025-11-10 09:17:25.286 | Socket (1) | CloseSocket call. 2025-11-10 09:17:25.287 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:25.288 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:25.288 | Socket (1) | Closed. 2025-11-10 09:17:25.289 | Historical data download thread signaled to stop. 2025-11-10 09:17:25.290 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:19.219000. 2025-11-10 09:17:25.290 | HD Request # 1 | Received 450 Intraday data records from 2025-11-10 09:16:18.134000 to 2025-11-10 09:17:16.530000 (58.4 seconds. Delay: 8.8 seconds) and wrote 444 records for ESZ25_FUT_CME 2025-11-10 09:17:25.296 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:16.530000 2025-11-10 09:17:25.296 | HD Request # 1 | Completion time: 2s. 2025-11-10 09:17:25.297 | HD Request # 1 | Intraday data download complete for ESZ25_FUT_CME. Unique request ID: 1 2025-11-10 09:17:25.297 | Removing historical data download ID 1. 2025-11-10 09:17:25.297 | Real-time Intraday chart data file updates started for ESZ25_FUT_CME 2025-11-10 09:17:25.297 | Intraday chart data file opened for ESZ25_FUT_CME 2025-11-10 09:17:25.297 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:25.297 | 2025-11-10 09:17:25.297 | No download requests in the queue to start downloads for. 2025-11-10 09:17:25.297 | Historical data for ESZ25_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2025-11-10 09:17:25.503 | ESZ25_FUT_CME [CV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:25.504 | ESZ25_FUT_CME [CV] 240 Min #2 | Reloading chart. 2025-11-10 09:17:25.534 | ESZ25_FUT_CME [CV] 60 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:25.535 | ESZ25_FUT_CME [CV] 60 Min #3 | Reloading chart. 2025-11-10 09:17:25.549 | ESZ25_FUT_CME [CV] 30 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:25.550 | ESZ25_FUT_CME [CV] 30 Min #10 | Reloading chart. 2025-11-10 09:17:25.582 | ESZ25_FUT_CME [CV] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:25.582 | ESZ25_FUT_CME [CV] #4 | Reloading chart. 2025-11-10 09:17:25.756 | ESZ25_FUT_CME [CV] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:25.756 | ESZ25_FUT_CME [CV] 1 Day #1 | Reloading chart. 2025-11-10 09:17:26.078 | ESZ25_FUT_CME [CV] #4 | Reloading chart. 2025-11-10 09:17:26.396 | Denali Data Feed | Received logon response. 2025-11-10 09:17:26.396 | Denali Data Feed | Server Name: SC Realtime Server. 2025-11-10 09:17:26.396 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:17:26.396 | Denali Data Feed | Successfully connected. 2025-11-10 09:17:26.396 | Denali Data Feed | Trading is not supported. 2025-11-10 09:17:26.396 | Denali Data Feed | MarketDepthIsSupported: 1 2025-11-10 09:17:26.397 | Added historical Intraday data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:17:26.397 | Intraday data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:17:26.397 | Triggering next historical data download in queue. 2025-11-10 09:17:26.397 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ25_FUT_CME -> ESZ25 2025-11-10 09:17:26.397 | Delaying start of download for ESZ25_FUT_CME. 2025-11-10 09:17:26.440 | Loading DLL: C:\SierraChart\Data\market_pivots.dll (market_pivots_64.dll). Handle: f860000 2025-11-10 09:17:26.447 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Reloading chart. 2025-11-10 09:17:26.454 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:26.465 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Reloading chart. 2025-11-10 09:17:26.466 | Added historical Intraday data request for NQZ25_FUT_CME to the queue. 2025-11-10 09:17:26.466 | Triggering next historical data download in queue. 2025-11-10 09:17:26.466 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:26.471 | Loading DLL: C:\SierraChart\Data\AutoClear.dll (AutoClear_64.dll). Handle: 10bc0000 2025-11-10 09:17:26.475 | Loading DLL: C:\SierraChart\Data\OrderFlowLabs.com.free.dll (OrderFlowLabs.com.free_64.dll). Handle: 7ffc4c6a0000 2025-11-10 09:17:26.582 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Reloading chart. 2025-11-10 09:17:26.589 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:26.606 | Loading DLL: C:\SierraChart\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffc2cf90000 2025-11-10 09:17:26.636 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Reloading chart. 2025-11-10 09:17:26.636 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:26.657 | ESZ25_FUT_CME [C] 30 Sec #6 | Reloading chart. 2025-11-10 09:17:26.657 | ESZ25_FUT_CME [C] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:26.663 | ESZ25_FUT_CME [CV] Daily #7 | Reloading chart. 2025-11-10 09:17:27.477 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Reloading chart. 2025-11-10 09:17:27.484 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:27.526 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Reloading chart. 2025-11-10 09:17:27.526 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:27.537 | RTYZ25_FUT_CME [C] 30 Min #13 | Reloading chart. 2025-11-10 09:17:27.538 | Added historical Intraday data request for RTYZ25_FUT_CME to the queue. 2025-11-10 09:17:27.538 | RTYZ25_FUT_CME [C] 30 Min #13 | Waiting for historical downloads to complete with the IDs: 4, 2025-11-10 09:17:27.545 | ESZ25_FUT_CME [CV] 30 Sec #5 | Reloading chart. 2025-11-10 09:17:27.551 | ESZ25_FUT_CME [CV] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:27.561 | Loading DLL: C:\SierraChart\Data\pace_of_tape.dll (pace_of_tape_64.dll). Handle: 110a0000 2025-11-10 09:17:27.593 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Reloading chart. 2025-11-10 09:17:27.594 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:27.616 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Reloading chart. 2025-11-10 09:17:27.616 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:27.626 | NQZ25_FUT_CME [C] 30 Sec #14 | Reloading chart. 2025-11-10 09:17:27.627 | NQZ25_FUT_CME [C] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:27.631 | NQZ25_FUT_CME [CV] 30 Sec #12 | Reloading chart. 2025-11-10 09:17:27.638 | NQZ25_FUT_CME [CV] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:27.660 | ZNZ25_FUT_CME #15 | Reloading chart. 2025-11-10 09:17:27.677 | ZBZ25_FUT_CME #16 | Reloading chart. 2025-11-10 09:17:27.683 | ESZ25_FUT_CME [CV] 240 Min #2 | Reloading chart. 2025-11-10 09:17:27.727 | ESZ25_FUT_CME [CV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:27.729 | ESZ25_FUT_CME [CV] 60 Min #3 | Reloading chart. 2025-11-10 09:17:27.746 | ESZ25_FUT_CME [CV] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:27.747 | ESZ25_FUT_CME [CV] 30 Min #10 | Reloading chart. 2025-11-10 09:17:27.763 | ESZ25_FUT_CME [CV] 30 Min #10 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:27.774 | ESZ25_FUT_CME [CV] 1 Day #1 | Reloading chart. 2025-11-10 09:17:27.777 | ESZ25_FUT_CME [CV] 1 Day #1 | Performing continuous chart historical Daily data download for symbol ESZ25_FUT_CME starting at last date in file. 2025-11-10 09:17:27.777 | Starting DelayedDownloadMonitoringTimer 2025-11-10 09:17:27.777 | Starting HDTimeoutTimer 2025-11-10 09:17:27.777 | Added historical Daily data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:17:27.777 | Triggering next historical data download in queue. 2025-11-10 09:17:27.803 | ESZ25_FUT_CME [CV] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:27.812 | ESZ25_FUT_CME [CV] Daily #7 | Chart data loading complete. 2025-11-10 09:17:27.824 | Starting DelayedDownloadMonitoringTimer 2025-11-10 09:17:27.824 | Starting HDTimeoutTimer 2025-11-10 09:17:27.824 | Added historical Market Depth data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:17:27.824 | Market depth data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:17:27.824 | Triggering next historical data download in queue. 2025-11-10 09:17:27.824 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 144 2025-11-10 09:17:27.824 | Denali Data Feed | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-11-10 09:17:27.824 | Denali Data Feed | Received security definition for symbol ESZ25_FUT_CME 2025-11-10 09:17:27.846 | Requesting market depth updates for: ESZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:17:27.846 | Mapping NQZ25_FUT_CME to NQZ25. Service code: cme 2025-11-10 09:17:27.846 | Denali Data Feed | Starting real-time market data updates for: NQZ25_FUT_CME (NQZ25). ID: 2 Service code: cme 2025-11-10 09:17:27.846 | Denali Data Feed | Requesting security definition data for: NQZ25_FUT_CME (NQZ25). ID: 2 2025-11-10 09:17:27.846 | Requesting market depth updates for: NQZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:17:27.848 | ZBZ25_FUT_CME #16 | StartDateTimeForLoadingOrderFills: 2024-11-03 00:00:00 2025-11-10 09:17:27.858 | ZBZ25_FUT_CME #16 | Chart data loading complete. 2025-11-10 09:17:27.869 | ZNZ25_FUT_CME #15 | StartDateTimeForLoadingOrderFills: 2024-11-03 00:00:00 2025-11-10 09:17:27.871 | ZNZ25_FUT_CME #15 | Chart data loading complete. 2025-11-10 09:17:27.873 | HD Request # 2 | Downloading Historical Daily chart data for ESZ25_FUT_CME. Starting date: 2025-11-05. Service: sc_futures_direct.dtc.trading 2025-11-10 09:17:27.876 | HD Request # 3 | Downloading Market Depth data for ESZ25_FUT_CME. Service: cme.marketdepth. 2025-11-10 09:17:27.877 | HD Request # 3 | Download start date-time: 2025-11-10 09:16:39.111142. 2025-11-10 09:17:27.877 | HD Request # 3 | Using server: ds28.sierracharts.com port 10149 2025-11-10 09:17:27.877 | Socket (9) | Creating socket. 2025-11-10 09:17:27.877 | Socket (9) | New receive buffer size: 0 2025-11-10 09:17:27.877 | Socket (9) | Connecting to IP: 67.214.125.5. 2025-11-10 09:17:27.882 | Added historical Market Depth data request for NQZ25_FUT_CME to the queue. 2025-11-10 09:17:27.882 | Market depth data recording state for symbol NQZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:17:27.882 | Triggering next historical data download in queue. 2025-11-10 09:17:28.159 | Mapping ZNZ25_FUT_CME to ZNZ25. Service code: cbot 2025-11-10 09:17:28.159 | Denali Data Feed | Starting real-time market data updates for: ZNZ25_FUT_CME (ZNZ25). ID: 3 Service code: cbot 2025-11-10 09:17:28.159 | Denali Data Feed | Requesting security definition data for: ZNZ25_FUT_CME (ZNZ25). ID: 3 2025-11-10 09:17:28.159 | Added historical Intraday data request for ZNZ25_FUT_CME to the queue. 2025-11-10 09:17:28.159 | Intraday data recording state for symbol ZNZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:17:28.159 | Triggering next historical data download in queue. 2025-11-10 09:17:28.173 | Mapping ZBZ25_FUT_CME to ZBZ25. Service code: cbot 2025-11-10 09:17:28.173 | Denali Data Feed | Starting real-time market data updates for: ZBZ25_FUT_CME (ZBZ25). ID: 4 Service code: cbot 2025-11-10 09:17:28.173 | Denali Data Feed | Requesting security definition data for: ZBZ25_FUT_CME (ZBZ25). ID: 4 2025-11-10 09:17:28.173 | Added historical Intraday data request for ZBZ25_FUT_CME to the queue. 2025-11-10 09:17:28.173 | Intraday data recording state for symbol ZBZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:17:28.173 | Triggering next historical data download in queue. 2025-11-10 09:17:28.218 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQZ25_FUT_CME 2025-11-10 09:17:28.218 | Teton CME Routing | Setting external service identifier for symbol NQZ25_FUT_CME to 158704 2025-11-10 09:17:28.218 | Teton CME Routing | Received security definition for symbol NQZ25_FUT_CME 2025-11-10 09:17:28.393 | Denali Data Feed | Clearing market depth for ESZ25_FUT_CME 2025-11-10 09:17:28.393 | Denali Data Feed | Clearing market depth for NQZ25_FUT_CME 2025-11-10 09:17:28.393 | Denali Data Feed | Setting external service identifier for symbol NQZ25_FUT_CME to 158704 2025-11-10 09:17:28.393 | Denali Data Feed | Received security definition for symbol NQZ25_FUT_CME 2025-11-10 09:17:28.452 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNZ25_FUT_CME 2025-11-10 09:17:28.452 | Teton CME Routing | Setting external service identifier for symbol ZNZ25_FUT_CME to 42002111 2025-11-10 09:17:28.452 | Teton CME Routing | Received security definition for symbol ZNZ25_FUT_CME 2025-11-10 09:17:28.512 | HD Request # 3 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:28.512 | HD Request # 3 | Sending historical data logon request message. 2025-11-10 09:17:28.553 | Denali Data Feed | Setting external service identifier for symbol ZNZ25_FUT_CME to 42002111 2025-11-10 09:17:28.553 | Denali Data Feed | Received security definition for symbol ZNZ25_FUT_CME 2025-11-10 09:17:28.553 | Denali Data Feed | Setting external service identifier for symbol ZBZ25_FUT_CME to 42001597 2025-11-10 09:17:28.553 | Denali Data Feed | Received security definition for symbol ZBZ25_FUT_CME 2025-11-10 09:17:28.770 | ESZ25_FUT_CME [CV][M] #4 | StartDateTimeForLoadingOrderFills: 2024-11-03 00:00:00 2025-11-10 09:17:28.777 | ESZ25_FUT_CME [CV][M] #4 | Chart data loading complete. 2025-11-10 09:17:28.919 | HD Request # 3 | Requesting market depth data. Start date-time: 2025-11-10 09:16:39. Symbol: ESZ25 2025-11-10 09:17:29.323 | HD Request # 3 | Decompressing data. 2025-11-10 09:17:29.380 | HD Request # 3 | Receiving market depth data for ESZ25_FUT_CME starting at 2025-11-10 09:16:39.183000 2025-11-10 09:17:29.586 | Socket (9) | CloseSocket call. 2025-11-10 09:17:29.586 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:29.587 | Historical data download thread signaled to stop. 2025-11-10 09:17:29.587 | Socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:17:29.587 | Socket (9) | Closed. 2025-11-10 09:17:29.587 | HD Request # 3 | Timestamp of first market depth data file record written: 2025-11-10 09:16:39.183000. 2025-11-10 09:17:29.587 | HD Request # 3 | Received 3222 Market Depth data records from 2025-11-10 09:16:39.183000 to 2025-11-10 09:17:27.676000 (48.5 seconds. Delay: 1.9 seconds) and wrote 3222 records for ESZ25_FUT_CME 2025-11-10 09:17:29.587 | HD Request # 3 | Completion time: 2s. 2025-11-10 09:17:29.587 | HD Request # 3 | Market Depth data download complete for ESZ25_FUT_CME. Unique request ID: 6 2025-11-10 09:17:29.587 | Removing historical data download ID 6. 2025-11-10 09:17:29.587 | Real-time market depth file updates started for ESZ25_FUT_CME 2025-11-10 09:17:29.595 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV] 240 Min #2 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV] 60 Min #3 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV] 30 Min #10 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV][M] #4 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV] 1 Day #1 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [C] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:29.595 | 2025-11-10 09:17:29.595 | Triggering next historical data download in queue. 2025-11-10 09:17:29.595 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:17:29.602 | ESZ25_FUT_CME [CV][M] #4 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.602 | HD Request # 4 | Downloading Market Depth data for NQZ25_FUT_CME. Service: cme.marketdepth. 2025-11-10 09:17:29.603 | HD Request # 4 | Download start date-time: 2025-11-10 09:16:39.111203. 2025-11-10 09:17:29.603 | HD Request # 4 | Using server: ds26.sierracharts.com port 10150 2025-11-10 09:17:29.603 | Socket (1) | Creating socket. 2025-11-10 09:17:29.603 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:29.603 | Socket (1) | Connecting to IP: 64.152.155.17. 2025-11-10 09:17:29.633 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Reloading chart. 2025-11-10 09:17:29.633 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:29.657 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Reloading chart. 2025-11-10 09:17:29.664 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.665 | ESZ25_FUT_CME [C] 30 Sec #6 | Reloading chart. 2025-11-10 09:17:29.665 | ESZ25_FUT_CME [C] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:29.687 | ESZ25_FUT_CME [CV] 240 Min #2 | Reloading chart. 2025-11-10 09:17:29.714 | ESZ25_FUT_CME [CV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.735 | ESZ25_FUT_CME [CV] 30 Sec #5 | Reloading chart. 2025-11-10 09:17:29.741 | ESZ25_FUT_CME [CV] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.742 | ESZ25_FUT_CME [CV] 60 Min #3 | Reloading chart. 2025-11-10 09:17:29.758 | ESZ25_FUT_CME [CV] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.768 | ESZ25_FUT_CME [CV] 30 Min #10 | Reloading chart. 2025-11-10 09:17:29.786 | ESZ25_FUT_CME [CV] 30 Min #10 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.794 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:17:29.794 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Reloading chart. 2025-11-10 09:17:29.794 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 2, 2025-11-10 09:17:29.799 | ESZ25_FUT_CME [CV] 1 Day #1 | Reloading chart. 2025-11-10 09:17:29.827 | ESZ25_FUT_CME [CV] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:29.958 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Reloading chart. 2025-11-10 09:17:29.965 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 2, 5, 2025-11-10 09:17:30.308 | HD Request # 4 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:30.308 | HD Request # 4 | Sending historical data logon request message. 2025-11-10 09:17:31.029 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBZ25_FUT_CME 2025-11-10 09:17:31.029 | Teton CME Routing | Setting external service identifier for symbol ZBZ25_FUT_CME to 42001597 2025-11-10 09:17:31.029 | Teton CME Routing | Received security definition for symbol ZBZ25_FUT_CME 2025-11-10 09:17:31.785 | HD Request # 4 | Requesting market depth data. Start date-time: 2025-11-10 09:16:39. Symbol: NQZ25 2025-11-10 09:17:32.086 | HD Request # 4 | Decompressing data. 2025-11-10 09:17:32.668 | Requesting market depth updates for: ZBZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:17:32.668 | Requesting market depth updates for: ZNZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:17:32.785 | HD Request # 4 | Receiving market depth data for NQZ25_FUT_CME starting at 2025-11-10 09:16:39.229000 2025-11-10 09:17:33.001 | HD Request # 5 | Downloading Intraday chart data for ESZ25_FUT_CME to the file ESZ25_FUT_CME.scid. Service: cme 2025-11-10 09:17:33.002 | HD Request # 5 | Download start date-time: 2025-11-10 09:17:16.000000. File last date-time: 2025-11-10 09:17:16.530000 2025-11-10 09:17:33.002 | HD Request # 5 | Using server: ds32.sierracharts.com port 10150 2025-11-10 09:17:33.002 | Socket (9) | Creating socket. 2025-11-10 09:17:33.002 | Socket (9) | New receive buffer size: 0 2025-11-10 09:17:33.002 | Socket (9) | Connecting to IP: 69.39.70.248. 2025-11-10 09:17:33.117 | Denali Data Feed | Market Depth data has been rejected for symbol: ZBZ25_FUT_CME. Not authorized for market depth. 2025-11-10 09:17:33.117 | Denali Data Feed | Market Depth data has been rejected for symbol: ZNZ25_FUT_CME. Not authorized for market depth. 2025-11-10 09:17:33.709 | HD Request # 2 | Requesting historical Daily data for ESZ25 starting at 2025-11-04. SC External HD service. 2025-11-10 09:17:34.089 | ESZ25_FUT_CME [CV] 60 Min #3 | Chart data loading complete. 2025-11-10 09:17:34.611 | HD Request # 5 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:34.611 | HD Request # 5 | Sending historical data logon request message. 2025-11-10 09:17:34.960 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-11-10 09:17:16. Record interval: 0. Symbol: ESZ25 2025-11-10 09:17:35.495 | HD Request # 5 | Decompressing data. 2025-11-10 09:17:35.586 | HD Request # 2 | Receiving historical Daily data for ESZ25_FUT_CME starting at 2025-11-05. 2025-11-10 09:17:35.586 | HD Request # 2 | Writing historical Daily data to the file ESZ25_FUT_CME.dly. 2025-11-10 09:17:35.590 | HD Request # 2 | Bytes received: 287 2025-11-10 09:17:35.590 | HD Request # 2 | Received 5 Daily data records from 2025-11-05 00:00:00 to 2025-11-10 00:00:00 (6.0 days) and wrote 4 records for ESZ25_FUT_CME 2025-11-10 09:17:35.590 | HD Request # 2 | Completion time: 8s. 2025-11-10 09:17:35.590 | HD Request # 2 | Daily data download complete for ESZ25_FUT_CME. Unique request ID: 5 2025-11-10 09:17:35.590 | Removing historical data download ID 5. 2025-11-10 09:17:35.591 | 2025-11-10 09:17:35.591 | No download requests in the queue to start downloads for. 2025-11-10 09:17:35.599 | ESZ25_FUT_CME [CV][M] Daily #5 | Reloading chart. 2025-11-10 09:17:35.738 | HD Request # 5 | Receiving Intraday data for ESZ25_FUT_CME starting at 2025-11-10 09:17:16.530000 2025-11-10 09:17:35.739 | Socket (9) | CloseSocket call. 2025-11-10 09:17:35.739 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:35.739 | Socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:17:35.739 | Socket (9) | Closed. 2025-11-10 09:17:35.757 | ESZ25_FUT_CME [CV][M] Daily #7 | Reloading chart. 2025-11-10 09:17:36.354 | Historical data download thread signaled to stop. 2025-11-10 09:17:36.354 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-11-10 09:17:23.034000. 2025-11-10 09:17:36.354 | HD Request # 5 | Received 286 Intraday data records from 2025-11-10 09:17:16.530000 to 2025-11-10 09:17:32.609000 (16.1 seconds. Delay: 3.7 seconds) and wrote 285 records for ESZ25_FUT_CME 2025-11-10 09:17:36.362 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:32.609000 2025-11-10 09:17:36.362 | Added 14 Time and Sales records to Intraday data file for ESZ25_FUT_CME after download. 2025-11-10 09:17:36.362 | HD Request # 5 | Completion time: 3s. 2025-11-10 09:17:36.362 | HD Request # 5 | Intraday data download complete for ESZ25_FUT_CME. Unique request ID: 2 2025-11-10 09:17:36.362 | Removing historical data download ID 2. 2025-11-10 09:17:36.362 | Real-time Intraday chart data file updates started for ESZ25_FUT_CME 2025-11-10 09:17:36.362 | Intraday chart data file opened for ESZ25_FUT_CME 2025-11-10 09:17:36.362 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:36.368 | 2025-11-10 09:17:36.368 | Triggering next historical data download in queue. 2025-11-10 09:17:36.369 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.370 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Reloading chart. 2025-11-10 09:17:36.370 | ESZ25_FUT_CME [CV] 30 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.370 | ESZ25_FUT_CME [CV] 30 Min #10 | Reloading chart. 2025-11-10 09:17:36.378 | ESZ25_FUT_CME [CV][M] Daily #5 | Chart data loading complete. 2025-11-10 09:17:36.378 | ESZ25_FUT_CME [CV] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.378 | ESZ25_FUT_CME [CV] 1 Day #1 | Reloading chart. 2025-11-10 09:17:36.389 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.390 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Reloading chart. 2025-11-10 09:17:36.391 | ESZ25_FUT_CME [CV][M] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.392 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:17:36.395 | HD Request # 6 | Downloading Intraday chart data for NQZ25_FUT_CME to the file NQZ25_FUT_CME.scid. Service: cme 2025-11-10 09:17:36.395 | HD Request # 6 | Download start date-time: 2025-11-10 09:16:22.000000. File last date-time: 2025-11-10 09:16:22.572000 2025-11-10 09:17:36.395 | HD Request # 6 | Using server: ds28.sierracharts.com port 10149 2025-11-10 09:17:36.395 | Socket (5) | Creating socket. 2025-11-10 09:17:36.395 | Socket (5) | New receive buffer size: 0 2025-11-10 09:17:36.395 | Socket (5) | Connecting to IP: 67.214.125.5. 2025-11-10 09:17:36.441 | ESZ25_FUT_CME [CV][M] Daily #7 | Chart data loading complete. 2025-11-10 09:17:36.547 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.548 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Reloading chart. 2025-11-10 09:17:36.580 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Reloading chart. 2025-11-10 09:17:36.651 | Socket (1) | CloseSocket call. 2025-11-10 09:17:36.651 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:36.652 | Historical data download thread signaled to stop. 2025-11-10 09:17:36.652 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:36.652 | HD Request # 4 | Timestamp of first market depth data file record written: 2025-11-10 09:16:39.229000. 2025-11-10 09:17:36.652 | Socket (1) | Closed. 2025-11-10 09:17:36.652 | HD Request # 4 | Received 6860 Market Depth data records from 2025-11-10 09:16:39.229000 to 2025-11-10 09:17:28.995000 (49.8 seconds. Delay: 7.7 seconds) and wrote 6860 records for NQZ25_FUT_CME 2025-11-10 09:17:36.652 | HD Request # 4 | Completion time: 7s. 2025-11-10 09:17:36.652 | HD Request # 4 | Market Depth data download complete for NQZ25_FUT_CME. Unique request ID: 152 2025-11-10 09:17:36.652 | Removing historical data download ID 152. 2025-11-10 09:17:36.652 | Real-time market depth file updates started for NQZ25_FUT_CME 2025-11-10 09:17:36.659 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:17:36.659 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:36.659 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:36.659 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:36.659 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:36.659 | NQZ25_FUT_CME [C] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:36.659 | NQZ25_FUT_CME [CV] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:17:36.659 | 2025-11-10 09:17:36.659 | No download requests in the queue to start downloads for. 2025-11-10 09:17:36.662 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] #3 | Reloading chart. 2025-11-10 09:17:36.680 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.681 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Reloading chart. 2025-11-10 09:17:36.686 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2025-11-09 18:00:00 2025-11-10 09:17:36.689 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:36.721 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Chart data loading complete. 2025-11-10 09:17:36.749 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Reloading chart. 2025-11-10 09:17:36.756 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:36.761 | NQZ25_FUT_CME [CV] 30 Sec #12 | Reloading chart. 2025-11-10 09:17:36.767 | NQZ25_FUT_CME [CV] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:36.774 | Mapping MESZ25_FUT_CME to MESZ25. Service code: cme 2025-11-10 09:17:36.774 | Denali Data Feed | Starting real-time market data updates for: MESZ25_FUT_CME (MESZ25). ID: 5 Service code: cme 2025-11-10 09:17:36.774 | Denali Data Feed | Requesting security definition data for: MESZ25_FUT_CME (MESZ25). ID: 5 2025-11-10 09:17:36.785 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 30 Min #2 | Reloading chart. 2025-11-10 09:17:36.800 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Reloading chart. 2025-11-10 09:17:36.800 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:36.846 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:17:36.881 | ESZ25_FUT_CME [CV] 30 Min #10 | Reloading chart. 2025-11-10 09:17:36.905 | ESZ25_FUT_CME [CV] 1 Day #1 | Reloading chart. 2025-11-10 09:17:36.944 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV] 30 Min #1 | Reloading chart. 2025-11-10 09:17:36.952 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:17:36.961 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Reloading chart. 2025-11-10 09:17:36.961 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:36.965 | ESZ25_FUT_CME [CV] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:36.965 | ESZ25_FUT_CME [CV] 30 Sec #5 | Reloading chart. 2025-11-10 09:17:36.992 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Reloading chart. 2025-11-10 09:17:36.992 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:37.007 | ESZ25_FUT_CME/MESZ25_FUT_CME [C] 1 Min #4 | Reloading chart. 2025-11-10 09:17:37.042 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:37.042 | HD Request # 6 | Sending historical data logon request message. 2025-11-10 09:17:37.065 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ25_FUT_CME 2025-11-10 09:17:37.065 | Teton CME Routing | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-11-10 09:17:37.065 | Teton CME Routing | Received security definition for symbol MESZ25_FUT_CME 2025-11-10 09:17:37.133 | NQZ25_FUT_CME [C] 30 Sec #14 | Reloading chart. 2025-11-10 09:17:37.133 | NQZ25_FUT_CME [C] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 3, 2025-11-10 09:17:37.194 | ESZ25_FUT_CME [C] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:37.194 | ESZ25_FUT_CME [C] 30 Sec #6 | Reloading chart. 2025-11-10 09:17:37.195 | ESZ25_FUT_CME [CV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:37.196 | ESZ25_FUT_CME [CV] 240 Min #2 | Reloading chart. 2025-11-10 09:17:37.243 | ESZ25_FUT_CME [CV] 60 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:37.246 | ESZ25_FUT_CME [CV] 60 Min #3 | Reloading chart. 2025-11-10 09:17:37.257 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2025-11-09 18:00:00 2025-11-10 09:17:37.291 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Chart data loading complete. 2025-11-10 09:17:37.330 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:17:37.350 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Chart data loading complete. 2025-11-10 09:17:37.351 | ESZ25_FUT_CME [CV] 30 Sec #5 | Reloading chart. 2025-11-10 09:17:37.369 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:22. Record interval: 0. Symbol: NQZ25 2025-11-10 09:17:37.389 | Denali Data Feed | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-11-10 09:17:37.389 | Denali Data Feed | Received security definition for symbol MESZ25_FUT_CME 2025-11-10 09:17:37.480 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:37.480 | ESZ25_FUT_CME [C] 30 Sec #6 | Chart data loading complete. 2025-11-10 09:17:37.530 | + Loading additional symbol data. | Number times message added: 2 2025-11-10 09:17:37.623 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 6 Service code: statscalc 2025-11-10 09:17:37.624 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2025-11-10 09:17:37.624 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 6 2025-11-10 09:17:37.624 | Added historical Intraday data request for TICK-NYSE to the queue. 2025-11-10 09:17:37.624 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2025-11-10 09:17:37.624 | Triggering next historical data download in queue. 2025-11-10 09:17:37.624 | ESZ25_FUT_CME [CV] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 155 2025-11-10 09:17:37.624 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 7 Service code: statscalc 2025-11-10 09:17:37.624 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 7 2025-11-10 09:17:37.624 | DTC Client socket (9) | Creating socket. 2025-11-10 09:17:37.624 | Added historical Intraday data request for NISS-NYSE to the queue. 2025-11-10 09:17:37.624 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2025-11-10 09:17:37.624 | ESZ25_FUT_CME [CV] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 156 2025-11-10 09:17:37.624 | DTC Client socket (9) | New receive buffer size: 0 2025-11-10 09:17:37.624 | DTC Client socket (9) | Connecting to IP: 69.39.70.241. 2025-11-10 09:17:37.624 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 8 Service code: statscalc 2025-11-10 09:17:37.624 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 8 2025-11-10 09:17:37.624 | Added historical Intraday data request for TRIN-NYSE to the queue. 2025-11-10 09:17:37.624 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2025-11-10 09:17:37.624 | ESZ25_FUT_CME [CV] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 157 2025-11-10 09:17:37.625 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:37.625 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:37.625 | ESZ25_FUT_CME [CV] 30 Sec #5 | Chart data loading complete. 2025-11-10 09:17:37.626 | SC Data with Depth | Network connection to server complete. 2025-11-10 09:17:37.626 | SC Data with Depth | Starting socket receive thread. 2025-11-10 09:17:37.626 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2025-11-10 09:17:37.698 | HD Request # 6 | Decompressing data. 2025-11-10 09:17:37.703 | ESZ25_FUT_CME [C] 30 Sec #6 | Reloading chart. 2025-11-10 09:17:37.704 | ESZ25_FUT_CME [CV] 240 Min #2 | Reloading chart. 2025-11-10 09:17:37.750 | ESZ25_FUT_CME [CV] 60 Min #3 | Reloading chart. 2025-11-10 09:17:37.952 | HD Request # 6 | Receiving Intraday data for NQZ25_FUT_CME starting at 2025-11-10 09:16:22.572000 2025-11-10 09:17:37.953 | Socket (5) | CloseSocket call. 2025-11-10 09:17:37.953 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:37.953 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:17:37.953 | Socket (5) | Closed. 2025-11-10 09:17:37.954 | Historical data download thread signaled to stop. 2025-11-10 09:17:37.954 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:24.224000. 2025-11-10 09:17:37.954 | HD Request # 6 | Received 385 Intraday data records from 2025-11-10 09:16:22.572000 to 2025-11-10 09:17:34.206001 (71.6 seconds. Delay: 3.7 seconds) and wrote 384 records for NQZ25_FUT_CME 2025-11-10 09:17:37.964 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:34.206001 2025-11-10 09:17:37.964 | Added 2 Time and Sales records to Intraday data file for NQZ25_FUT_CME after download. 2025-11-10 09:17:37.964 | HD Request # 6 | Completion time: 1s. 2025-11-10 09:17:37.964 | HD Request # 6 | Intraday data download complete for NQZ25_FUT_CME. Unique request ID: 3 2025-11-10 09:17:37.964 | Removing historical data download ID 3. 2025-11-10 09:17:37.964 | Real-time Intraday chart data file updates started for NQZ25_FUT_CME 2025-11-10 09:17:37.964 | Intraday chart data file opened for NQZ25_FUT_CME 2025-11-10 09:17:37.964 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:37.971 | 2025-11-10 09:17:37.971 | Triggering next historical data download in queue. 2025-11-10 09:17:37.971 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:37.972 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Reloading chart. 2025-11-10 09:17:37.979 | Mapping RTYZ25_FUT_CME to RTYZ25. Service code: cme 2025-11-10 09:17:37.979 | HD Request # 7 | Downloading Intraday chart data for RTYZ25_FUT_CME to the file RTYZ25_FUT_CME.scid. Service: cme 2025-11-10 09:17:37.979 | HD Request # 7 | Download start date-time: 2025-11-10 09:15:17.000000. File last date-time: 2025-11-10 09:15:17.699000 2025-11-10 09:17:37.980 | HD Request # 7 | Using server: ds26.sierracharts.com port 10150 2025-11-10 09:17:37.980 | Socket (1) | Creating socket. 2025-11-10 09:17:37.980 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:37.980 | Socket (1) | Connecting to IP: 64.152.155.17. 2025-11-10 09:17:37.983 | ESZ25_FUT_CME [C] 30 Sec #6 | Chart data loading complete. 2025-11-10 09:17:38.041 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:38.042 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Reloading chart. 2025-11-10 09:17:38.044 | NQZ25_FUT_CME [CV] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:38.044 | NQZ25_FUT_CME [CV] 30 Sec #12 | Reloading chart. 2025-11-10 09:17:38.045 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:38.047 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Reloading chart. 2025-11-10 09:17:38.079 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV] #10 | Reloading chart. 2025-11-10 09:17:38.128 | NQZ25_FUT_CME [C] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:38.129 | NQZ25_FUT_CME [C] 30 Sec #14 | Reloading chart. 2025-11-10 09:17:38.203 | Mapping MNQZ25_FUT_CME to MNQZ25. Service code: cme 2025-11-10 09:17:38.203 | Denali Data Feed | Starting real-time market data updates for: MNQZ25_FUT_CME (MNQZ25). ID: 10 Service code: cme 2025-11-10 09:17:38.203 | Denali Data Feed | Requesting security definition data for: MNQZ25_FUT_CME (MNQZ25). ID: 10 2025-11-10 09:17:38.221 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:38.221 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Reloading chart. 2025-11-10 09:17:38.241 | SC Data with Depth | Setting DTC encoding to Binary VLS 2025-11-10 09:17:38.241 | SC Data with Depth | Sending logon request message. 2025-11-10 09:17:38.253 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Reloading chart. 2025-11-10 09:17:38.313 | NQZ25_FUT_CME [C] 30 Sec #14 | Chart data loading complete. 2025-11-10 09:17:38.355 | NQZ25_FUT_CME [CV] 30 Sec #12 | Chart data loading complete. 2025-11-10 09:17:38.362 | NQZ25_FUT_CME [CV] 30 Sec #12 | Reloading chart. 2025-11-10 09:17:38.383 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:38.401 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #9 | Chart data loading complete. 2025-11-10 09:17:38.488 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:17:38.503 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Chart data loading complete. 2025-11-10 09:17:38.518 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ25_FUT_CME 2025-11-10 09:17:38.518 | Teton CME Routing | Setting external service identifier for symbol MNQZ25_FUT_CME to 42001149 2025-11-10 09:17:38.518 | Teton CME Routing | Received security definition for symbol MNQZ25_FUT_CME 2025-11-10 09:17:38.538 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Reloading chart. 2025-11-10 09:17:38.553 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 30 Min #8 | Reloading chart. 2025-11-10 09:17:38.556 | + Loading additional symbol data. 2025-11-10 09:17:38.569 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:17:38.597 | Using Bid/Ask average for last trade price for VOLX 2025-11-10 09:17:38.597 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 11 Service code: fxcm 2025-11-10 09:17:38.597 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 11 2025-11-10 09:17:38.597 | Added historical Intraday data request for VOLX to the queue. 2025-11-10 09:17:38.597 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2025-11-10 09:17:38.597 | Triggering next historical data download in queue. 2025-11-10 09:17:38.597 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Started historical data download for additional symbol VOLX. Download ID: 158 2025-11-10 09:17:38.639 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Chart data loading complete. 2025-11-10 09:17:38.732 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:38.732 | NQZ25_FUT_CME [CV] 30 Sec #12 | Chart data loading complete. 2025-11-10 09:17:38.761 | NQZ25_FUT_CME [C] 30 Sec #14 | Reloading chart. 2025-11-10 09:17:38.868 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C] 1 Min #11 | Chart data loading complete. 2025-11-10 09:17:38.909 | Denali Data Feed | Setting external service identifier for symbol MNQZ25_FUT_CME to 42001149 2025-11-10 09:17:38.909 | Denali Data Feed | Received security definition for symbol MNQZ25_FUT_CME 2025-11-10 09:17:38.942 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:38.942 | NQZ25_FUT_CME [C] 30 Sec #14 | Chart data loading complete. 2025-11-10 09:17:39.333 | SC Data with Depth | Received logon response. 2025-11-10 09:17:39.333 | SC Data with Depth | Server Name: SC Realtime Server. 2025-11-10 09:17:39.333 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:17:39.333 | SC Data with Depth | Successfully connected. 2025-11-10 09:17:39.333 | SC Data with Depth | Trading is not supported. 2025-11-10 09:17:39.333 | SC Data with Depth | MarketDepthIsSupported: 1 2025-11-10 09:17:39.333 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2025-11-10 09:17:39.333 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2025-11-10 09:17:39.333 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2025-11-10 09:17:39.333 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2025-11-10 09:17:39.901 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2025-11-10 09:17:39.901 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2025-11-10 09:17:39.901 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2025-11-10 09:17:39.901 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2025-11-10 09:17:39.901 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2025-11-10 09:17:39.901 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2025-11-10 09:17:39.901 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2025-11-10 09:17:39.901 | SC Data with Depth | Received security definition for symbol VOLX 2025-11-10 09:17:40.002 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:40.007 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Chart data loading complete. 2025-11-10 09:17:40.338 | ESZ25_FUT_CME [CV][M] #4 | StartDateTimeForLoadingOrderFills: 2024-11-03 00:00:00 2025-11-10 09:17:40.346 | ESZ25_FUT_CME [CV][M] #4 | Chart data loading complete. 2025-11-10 09:17:41.212 | Opened cached Intraday file: C:\SierraChart\Data\ESZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:17:41.212 | Opened cached Intraday file: C:\SierraChart\Data\NQZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:17:41.652 | HD Request # 7 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:41.652 | HD Request # 7 | Sending historical data logon request message. 2025-11-10 09:17:42.206 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:42.207 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:42.258 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Chart data loading complete. 2025-11-10 09:17:42.540 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:17:42.963 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-11-10 09:15:17. Record interval: 0. Symbol: RTYZ25 2025-11-10 09:17:43.302 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2025-11-10 09:17:43.412 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:17:43.418 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:43.418 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:43.450 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Chart data loading complete. 2025-11-10 09:17:43.794 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Chart data loading complete. 2025-11-10 09:17:43.882 | HD Request # 7 | Decompressing data. 2025-11-10 09:17:44.110 | HD Request # 7 | Receiving Intraday data for RTYZ25_FUT_CME starting at 2025-11-10 09:15:17.699000 2025-11-10 09:17:44.110 | Socket (1) | CloseSocket call. 2025-11-10 09:17:44.110 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:44.111 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:44.111 | Socket (1) | Closed. 2025-11-10 09:17:44.112 | Historical data download thread signaled to stop. 2025-11-10 09:17:44.112 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-11-10 09:15:20.010000. 2025-11-10 09:17:44.113 | HD Request # 7 | Received 138 Intraday data records from 2025-11-10 09:15:17.699000 to 2025-11-10 09:17:41.750002 (2.4 minutes. Delay: 2.4 seconds) and wrote 137 records for RTYZ25_FUT_CME 2025-11-10 09:17:44.120 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:41.750002 2025-11-10 09:17:44.120 | HD Request # 7 | Completion time: 7s. 2025-11-10 09:17:44.120 | HD Request # 7 | Intraday data download complete for RTYZ25_FUT_CME. Unique request ID: 4 2025-11-10 09:17:44.120 | Removing historical data download ID 4. 2025-11-10 09:17:44.120 | Real-time Intraday chart data file updates started for RTYZ25_FUT_CME 2025-11-10 09:17:44.120 | Intraday chart data file opened for RTYZ25_FUT_CME 2025-11-10 09:17:44.120 | HD Request # 7 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:44.120 | 2025-11-10 09:17:44.120 | Triggering next historical data download in queue. 2025-11-10 09:17:44.122 | HD Request # 8 | Downloading Intraday chart data for ZNZ25_FUT_CME to the file ZNZ25_FUT_CME.scid. Service: cbot 2025-11-10 09:17:44.122 | HD Request # 8 | Download start date-time: 2025-11-10 09:16:24.000000. File last date-time: 2025-11-10 09:16:24.070000 2025-11-10 09:17:44.122 | HD Request # 8 | Using server: ds32.sierracharts.com port 10149 2025-11-10 09:17:44.122 | Socket (1) | Creating socket. 2025-11-10 09:17:44.122 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:44.122 | Socket (1) | Connecting to IP: 69.39.70.248. 2025-11-10 09:17:44.525 | RTYZ25_FUT_CME [C] 30 Min #13 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:17:44.525 | RTYZ25_FUT_CME [C] 30 Min #13 | Reloading chart. 2025-11-10 09:17:44.770 | HD Request # 8 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:44.770 | HD Request # 8 | Sending historical data logon request message. 2025-11-10 09:17:44.854 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-12-09"}. Success=true 2025-11-10 09:17:45.071 | RTYZ25_FUT_CME [C] 30 Min #13 | Chart data loading complete. 2025-11-10 09:17:45.072 | RTYZ25_FUT_CME [C] 30 Min #13 | Reloading chart. 2025-11-10 09:17:45.094 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:24. Record interval: 0. Symbol: ZNZ25 2025-11-10 09:17:45.438 | HD Request # 8 | Decompressing data. 2025-11-10 09:17:45.572 | Denali Data Feed | Starting real-time market data updates for: RTYZ25_FUT_CME (RTYZ25). ID: 9 Service code: cme 2025-11-10 09:17:45.572 | Denali Data Feed | Requesting security definition data for: RTYZ25_FUT_CME (RTYZ25). ID: 9 2025-11-10 09:17:45.621 | RTYZ25_FUT_CME [C][M] 30 Min #13 | Chart data loading complete. 2025-11-10 09:17:45.685 | HD Request # 8 | Receiving Intraday data for ZNZ25_FUT_CME starting at 2025-11-10 09:16:24.070000 2025-11-10 09:17:45.685 | Socket (1) | CloseSocket call. 2025-11-10 09:17:45.685 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:45.685 | Historical data download thread signaled to stop. 2025-11-10 09:17:45.685 | HD Request # 8 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:30.360000. 2025-11-10 09:17:45.685 | HD Request # 8 | Received 376 Intraday data records from 2025-11-10 09:16:24.070000 to 2025-11-10 09:17:36.233001 (72.2 seconds. Delay: 9.5 seconds) and wrote 375 records for ZNZ25_FUT_CME 2025-11-10 09:17:45.686 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:45.686 | Socket (1) | Closed. 2025-11-10 09:17:45.694 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:36.233001 2025-11-10 09:17:45.694 | Added 2 Time and Sales records to Intraday data file for ZNZ25_FUT_CME after download. 2025-11-10 09:17:45.694 | HD Request # 8 | Completion time: 1s. 2025-11-10 09:17:45.694 | HD Request # 8 | Intraday data download complete for ZNZ25_FUT_CME. Unique request ID: 153 2025-11-10 09:17:45.694 | Removing historical data download ID 153. 2025-11-10 09:17:45.694 | Real-time Intraday chart data file updates started for ZNZ25_FUT_CME 2025-11-10 09:17:45.694 | Intraday chart data file opened for ZNZ25_FUT_CME 2025-11-10 09:17:45.694 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:45.694 | 2025-11-10 09:17:45.694 | Triggering next historical data download in queue. 2025-11-10 09:17:45.694 | HD Request # 9 | Downloading Intraday chart data for ZBZ25_FUT_CME to the file ZBZ25_FUT_CME.scid. Service: cbot 2025-11-10 09:17:45.694 | HD Request # 9 | Download start date-time: 2025-11-10 09:15:17.000000. File last date-time: 2025-11-10 09:15:17.740000 2025-11-10 09:17:45.694 | HD Request # 9 | Using server: ds28.sierracharts.com port 10150 2025-11-10 09:17:45.694 | Socket (1) | Creating socket. 2025-11-10 09:17:45.694 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:45.694 | Socket (1) | Connecting to IP: 67.214.125.5. 2025-11-10 09:17:45.864 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYZ25_FUT_CME 2025-11-10 09:17:45.864 | Teton CME Routing | Setting external service identifier for symbol RTYZ25_FUT_CME to 42004289 2025-11-10 09:17:45.864 | Teton CME Routing | Received security definition for symbol RTYZ25_FUT_CME 2025-11-10 09:17:46.124 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Chart data loading complete. 2025-11-10 09:17:46.167 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:46.205 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:46.218 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:46.221 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:46.222 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:46.251 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:46.253 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:46.254 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:46.301 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:46.316 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Chart data loading complete. 2025-11-10 09:17:46.412 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:46.423 | HD Request # 9 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:46.423 | HD Request # 9 | Sending historical data logon request message. 2025-11-10 09:17:46.648 | Denali Data Feed | Setting external service identifier for symbol RTYZ25_FUT_CME to 42004289 2025-11-10 09:17:46.648 | Denali Data Feed | Received security definition for symbol RTYZ25_FUT_CME 2025-11-10 09:17:46.780 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-11-10 09:15:17. Record interval: 0. Symbol: ZBZ25 2025-11-10 09:17:46.941 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Chart data loading complete. 2025-11-10 09:17:47.648 | HD Request # 9 | Decompressing data. 2025-11-10 09:17:47.901 | HD Request # 9 | Receiving Intraday data for ZBZ25_FUT_CME starting at 2025-11-10 09:15:17.740000 2025-11-10 09:17:47.902 | Socket (1) | CloseSocket call. 2025-11-10 09:17:47.902 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:47.902 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:47.902 | Socket (1) | Closed. 2025-11-10 09:17:47.903 | Historical data download thread signaled to stop. 2025-11-10 09:17:47.903 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-11-10 09:15:24.828000. 2025-11-10 09:17:47.903 | HD Request # 9 | Received 738 Intraday data records from 2025-11-10 09:15:17.740000 to 2025-11-10 09:17:29.147001 (2.2 minutes. Delay: 18.8 seconds) and wrote 737 records for ZBZ25_FUT_CME 2025-11-10 09:17:47.910 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:29.147001 2025-11-10 09:17:47.910 | HD Request # 9 | Completion time: 2s. 2025-11-10 09:17:47.910 | HD Request # 9 | Intraday data download complete for ZBZ25_FUT_CME. Unique request ID: 154 2025-11-10 09:17:47.910 | Removing historical data download ID 154. 2025-11-10 09:17:47.910 | Real-time Intraday chart data file updates started for ZBZ25_FUT_CME 2025-11-10 09:17:47.910 | Intraday chart data file opened for ZBZ25_FUT_CME 2025-11-10 09:17:47.910 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:47.910 | 2025-11-10 09:17:47.910 | Triggering next historical data download in queue. 2025-11-10 09:17:47.910 | HD Request # 10 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2025-11-10 09:17:47.911 | HD Request # 10 | Download start date-time: 2025-11-10 09:16:38.000000. File last date-time: 2025-11-10 09:16:38.213000 2025-11-10 09:17:47.911 | HD Request # 10 | Using server: ds12.sierracharts.com port 10149 2025-11-10 09:17:47.911 | Socket (1) | Creating socket. 2025-11-10 09:17:47.911 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:47.911 | Socket (1) | Connecting to IP: 69.39.70.241. 2025-11-10 09:17:51.232 | Opened cached Intraday file: C:\SierraChart\Data\ZNZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:17:51.232 | Opened cached Intraday file: C:\SierraChart\Data\RTYZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:17:52.445 | HD Request # 10 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:52.445 | HD Request # 10 | Sending historical data logon request message. 2025-11-10 09:17:52.871 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:38. Record interval: 0. Symbol: TICK-NYSE 2025-11-10 09:17:53.501 | HD Request # 10 | Decompressing data. 2025-11-10 09:17:54.148 | HD Request # 10 | Receiving Intraday data for TICK-NYSE starting at 2025-11-10 09:16:38.000000 2025-11-10 09:17:54.148 | Socket (1) | CloseSocket call. 2025-11-10 09:17:54.148 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:54.149 | Historical data download thread signaled to stop. 2025-11-10 09:17:54.149 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:39.000000. 2025-11-10 09:17:54.149 | HD Request # 10 | Received 72 Intraday data records from 2025-11-10 09:16:38.000000 to 2025-11-10 09:17:49.000000 (71.0 seconds. Delay: 5.1 seconds) and wrote 71 records for TICK-NYSE 2025-11-10 09:17:54.149 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:54.149 | Socket (1) | Closed. 2025-11-10 09:17:54.156 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:49.000000 2025-11-10 09:17:54.156 | Added 28 Time and Sales records to Intraday data file for TICK-NYSE after download. 2025-11-10 09:17:54.156 | HD Request # 10 | Completion time: 7s. 2025-11-10 09:17:54.156 | HD Request # 10 | Intraday data download complete for TICK-NYSE. Unique request ID: 155 2025-11-10 09:17:54.156 | Removing historical data download ID 155. 2025-11-10 09:17:54.156 | Real-time Intraday chart data file updates started for TICK-NYSE 2025-11-10 09:17:54.156 | Intraday chart data file opened for TICK-NYSE 2025-11-10 09:17:54.156 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:54.156 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 155 has completed. 2025-11-10 09:17:54.156 | 2025-11-10 09:17:54.156 | Triggering next historical data download in queue. 2025-11-10 09:17:54.156 | HD Request # 11 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2025-11-10 09:17:54.156 | HD Request # 11 | Download start date-time: 2025-11-10 09:16:37.000000. File last date-time: 2025-11-10 09:16:37.963000 2025-11-10 09:17:54.156 | HD Request # 11 | Using server: ds4.sierracharts.com port 10150 2025-11-10 09:17:54.157 | Socket (1) | Creating socket. 2025-11-10 09:17:54.157 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:54.157 | Socket (1) | Connecting to IP: 64.152.155.113. 2025-11-10 09:17:54.274 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:54.274 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:54.274 | Chart #5 has tagged chart #4 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:54.411 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:54.475 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:54.479 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:54.481 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:54.644 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:54.845 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:54.962 | HD Request # 11 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:54.962 | HD Request # 11 | Sending historical data logon request message. 2025-11-10 09:17:55.273 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:37. Record interval: 0. Symbol: NISS-NYSE 2025-11-10 09:17:56.234 | Opened cached Intraday file: C:\SierraChart\Data\ZBZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:17:56.235 | Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 15288 2025-11-10 09:17:57.475 | HD Request # 11 | Decompressing data. 2025-11-10 09:17:57.688 | HD Request # 11 | Receiving Intraday data for NISS-NYSE starting at 2025-11-10 09:16:37.000000 2025-11-10 09:17:57.689 | Socket (1) | CloseSocket call. 2025-11-10 09:17:57.690 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:57.691 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:57.691 | Socket (1) | Closed. 2025-11-10 09:17:57.695 | Historical data download thread signaled to stop. 2025-11-10 09:17:57.695 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:38.000000. 2025-11-10 09:17:57.695 | HD Request # 11 | Received 81 Intraday data records from 2025-11-10 09:16:37.000000 to 2025-11-10 09:17:57.000000 (80.0 seconds. Delay: 0.7 seconds) and wrote 80 records for NISS-NYSE 2025-11-10 09:17:57.702 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:57.000000 2025-11-10 09:17:57.702 | HD Request # 11 | Completion time: 3s. 2025-11-10 09:17:57.702 | HD Request # 11 | Intraday data download complete for NISS-NYSE. Unique request ID: 156 2025-11-10 09:17:57.702 | Removing historical data download ID 156. 2025-11-10 09:17:57.702 | Real-time Intraday chart data file updates started for NISS-NYSE 2025-11-10 09:17:57.702 | Intraday chart data file opened for NISS-NYSE 2025-11-10 09:17:57.702 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:57.702 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 156 has completed. 2025-11-10 09:17:57.702 | 2025-11-10 09:17:57.702 | Triggering next historical data download in queue. 2025-11-10 09:17:57.704 | HD Request # 12 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2025-11-10 09:17:57.705 | HD Request # 12 | Download start date-time: 2025-11-10 09:16:37.000000. File last date-time: 2025-11-10 09:16:37.963001 2025-11-10 09:17:57.705 | HD Request # 12 | Using server: ds12.sierracharts.com port 10149 2025-11-10 09:17:57.705 | Socket (1) | Creating socket. 2025-11-10 09:17:57.705 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:57.705 | Socket (1) | Connecting to IP: 69.39.70.241. 2025-11-10 09:17:58.082 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:58.082 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:58.082 | Chart #5 has tagged chart #4 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:58.082 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:58.148 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:58.151 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:58.152 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:58.272 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:58.442 | HD Request # 12 | Setting DTC encoding to Binary VLS 2025-11-10 09:17:58.442 | HD Request # 12 | Sending historical data logon request message. 2025-11-10 09:17:58.583 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:58.776 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:37. Record interval: 0. Symbol: TRIN-NYSE 2025-11-10 09:17:59.109 | HD Request # 12 | Decompressing data. 2025-11-10 09:17:59.364 | HD Request # 12 | Receiving Intraday data for TRIN-NYSE starting at 2025-11-10 09:16:37.000000 2025-11-10 09:17:59.364 | Socket (1) | CloseSocket call. 2025-11-10 09:17:59.364 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:17:59.365 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:17:59.365 | Socket (1) | Closed. 2025-11-10 09:17:59.392 | Historical data download thread signaled to stop. 2025-11-10 09:17:59.392 | HD Request # 12 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:38.000000. 2025-11-10 09:17:59.392 | HD Request # 12 | Received 81 Intraday data records from 2025-11-10 09:16:37.000000 to 2025-11-10 09:17:57.000000 (80.0 seconds. Delay: 2.4 seconds) and wrote 80 records for TRIN-NYSE 2025-11-10 09:17:59.399 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:57.000000 2025-11-10 09:17:59.399 | Added 13 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2025-11-10 09:17:59.399 | HD Request # 12 | Completion time: 2s. 2025-11-10 09:17:59.399 | HD Request # 12 | Intraday data download complete for TRIN-NYSE. Unique request ID: 157 2025-11-10 09:17:59.399 | Removing historical data download ID 157. 2025-11-10 09:17:59.399 | Real-time Intraday chart data file updates started for TRIN-NYSE 2025-11-10 09:17:59.399 | Intraday chart data file opened for TRIN-NYSE 2025-11-10 09:17:59.399 | HD Request # 12 | Enabling Intraday chart updating for symbol. 2025-11-10 09:17:59.399 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 157 has completed. 2025-11-10 09:17:59.399 | 2025-11-10 09:17:59.399 | Triggering next historical data download in queue. 2025-11-10 09:17:59.407 | HD Request # 13 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2025-11-10 09:17:59.408 | HD Request # 13 | Download start date-time: 2025-11-10 09:16:09.000000. File last date-time: 2025-11-10 09:16:09.063000 2025-11-10 09:17:59.408 | HD Request # 13 | Using server: ds4.sierracharts.com port 10150 2025-11-10 09:17:59.408 | Socket (1) | Creating socket. 2025-11-10 09:17:59.408 | Socket (1) | New receive buffer size: 0 2025-11-10 09:17:59.408 | Socket (1) | Connecting to IP: 64.152.155.113. 2025-11-10 09:17:59.591 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:59.591 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:59.591 | Chart #5 has tagged chart #4 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:59.749 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:59.752 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:17:59.754 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:17:59.797 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:17:59.843 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:18:00.030 | HD Request # 13 | Setting DTC encoding to Binary VLS 2025-11-10 09:18:00.030 | HD Request # 13 | Sending historical data logon request message. 2025-11-10 09:18:00.333 | HD Request # 13 | Requesting Intraday data. Start date-time: 2025-11-10 09:16:09. Record interval: 0. Symbol: VOLX 2025-11-10 09:18:00.638 | HD Request # 13 | Decompressing data. 2025-11-10 09:18:01.238 | Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid. Thread ID: 15288 2025-11-10 09:18:01.238 | Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 15288 2025-11-10 09:18:01.924 | HD Request # 13 | Receiving Intraday data for VOLX starting at 2025-11-10 09:16:09.063000 2025-11-10 09:18:01.924 | Socket (1) | CloseSocket call. 2025-11-10 09:18:01.924 | Socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:18:01.925 | Historical data download thread signaled to stop. 2025-11-10 09:18:01.925 | HD Request # 13 | Timestamp of first Intraday data file record written: 2025-11-10 09:16:55.250000. 2025-11-10 09:18:01.925 | HD Request # 13 | Received 5 Intraday data records from 2025-11-10 09:16:09.063000 to 2025-11-10 09:17:50.636000 (101.6 seconds. Delay: 11.3 seconds) and wrote 4 records for VOLX 2025-11-10 09:18:01.925 | Socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:18:01.925 | Socket (1) | Closed. 2025-11-10 09:18:01.933 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:17:50.636000 2025-11-10 09:18:01.934 | HD Request # 13 | Completion time: 2s. 2025-11-10 09:18:01.934 | HD Request # 13 | Intraday data download complete for VOLX. Unique request ID: 158 2025-11-10 09:18:01.934 | Removing historical data download ID 158. 2025-11-10 09:18:01.934 | Real-time Intraday chart data file updates started for VOLX 2025-11-10 09:18:01.934 | Intraday chart data file opened for VOLX 2025-11-10 09:18:01.934 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2025-11-10 09:18:01.934 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Historical data download for additional symbol VOLX with ID 158 has completed. 2025-11-10 09:18:01.934 | 2025-11-10 09:18:01.934 | No download requests in the queue to start downloads for. 2025-11-10 09:18:16.272 | Opened cached Intraday file: C:\SierraChart\Data\VOLX.scid. Thread ID: 15288 2025-11-10 09:18:17.150 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:18:17.150 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:18:17.150 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:18:17.150 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:18:17.257 | NTP Client | Received Packet | RoundTripDelay=0.1059732437133789, SystemClockOffset=-0.009931564331054688 2025-11-10 09:18:17.260 | NTP Client | Received Packet | RoundTripDelay=0.10991430282592773, SystemClockOffset=-0.0014240741729736328 2025-11-10 09:18:17.271 | NTP Client | Received Packet | RoundTripDelay=0.11980438232421875, SystemClockOffset=-0.005705356597900391 2025-11-10 09:18:17.491 | NTP Client | Received Packet | RoundTripDelay=0.3399515151977539, SystemClockOffset=0.01146841049194336 2025-11-10 09:18:18.147 | NTP Client | Performed system clock adjustment of -3564.7153854370117 microseconds. 2025-11-10 09:19:17.150 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:19:17.150 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:19:17.150 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:19:17.150 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:19:17.257 | NTP Client | Received Packet | RoundTripDelay=0.1069793701171875, SystemClockOffset=-0.007880687713623047 2025-11-10 09:19:17.260 | NTP Client | Received Packet | RoundTripDelay=0.10992717742919922, SystemClockOffset=0.0012927055358886719 2025-11-10 09:19:17.270 | NTP Client | Received Packet | RoundTripDelay=0.11996030807495117, SystemClockOffset=-0.003205537796020508 2025-11-10 09:19:17.562 | NTP Client | Received Packet | RoundTripDelay=0.4119720458984375, SystemClockOffset=0.03240346908569336 2025-11-10 09:19:18.157 | NTP Client | Performed system clock adjustment of -956.416130065918 microseconds. 2025-11-10 09:19:59.806 | Saved Chartbook: Discipline.Cht. Time: 0.0285 seconds. 2025-11-10 09:20:17.172 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:20:17.172 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:20:17.172 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:20:17.172 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:20:17.283 | NTP Client | Received Packet | RoundTripDelay=0.10990047454833984, SystemClockOffset=0.0019006729125976562 2025-11-10 09:20:17.293 | NTP Client | Received Packet | RoundTripDelay=0.12085437774658203, SystemClockOffset=-0.0030527114868164062 2025-11-10 09:20:17.543 | NTP Client | Received Packet | RoundTripDelay=0.3709444999694824, SystemClockOffset=0.011964082717895508 2025-11-10 09:20:18.165 | NTP Client | Performed system clock adjustment of 1900.6729125976562 microseconds. 2025-11-10 09:21:17.183 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:21:17.183 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:21:17.183 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:21:17.183 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:21:17.290 | NTP Client | Received Packet | RoundTripDelay=0.10699033737182617, SystemClockOffset=-0.010343313217163086 2025-11-10 09:21:17.293 | NTP Client | Received Packet | RoundTripDelay=0.10988521575927734, SystemClockOffset=-0.0010075569152832031 2025-11-10 09:21:17.303 | NTP Client | Received Packet | RoundTripDelay=0.11994457244873047, SystemClockOffset=-0.005496501922607422 2025-11-10 09:21:17.561 | NTP Client | Received Packet | RoundTripDelay=0.3779640197753906, SystemClockOffset=0.010436534881591797 2025-11-10 09:21:18.188 | NTP Client | Performed system clock adjustment of -3252.0294189453125 microseconds. 2025-11-10 09:22:17.196 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:22:17.196 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:22:17.196 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:22:17.196 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:22:17.308 | NTP Client | Received Packet | RoundTripDelay=0.11190080642700195, SystemClockOffset=0.002820253372192383 2025-11-10 09:22:17.316 | NTP Client | Received Packet | RoundTripDelay=0.12092447280883789, SystemClockOffset=-0.0024635791778564453 2025-11-10 09:22:17.564 | NTP Client | Received Packet | RoundTripDelay=0.3689289093017578, SystemClockOffset=0.02191019058227539 2025-11-10 09:22:18.204 | NTP Client | Performed system clock adjustment of 2820.253372192383 microseconds. 2025-11-10 09:23:17.213 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:23:17.213 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:23:17.213 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:23:17.213 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:23:17.320 | NTP Client | Received Packet | RoundTripDelay=0.10698747634887695, SystemClockOffset=-0.010139703750610352 2025-11-10 09:23:17.323 | NTP Client | Received Packet | RoundTripDelay=0.10989093780517578, SystemClockOffset=-0.0009613037109375 2025-11-10 09:23:17.333 | NTP Client | Received Packet | RoundTripDelay=0.11988210678100586, SystemClockOffset=-0.0054056644439697266 2025-11-10 09:23:17.609 | NTP Client | Received Packet | RoundTripDelay=0.3959622383117676, SystemClockOffset=0.021441221237182617 2025-11-10 09:23:18.222 | NTP Client | Performed system clock adjustment of -3183.4840774536133 microseconds. 2025-11-10 09:24:17.212 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:24:17.212 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:24:17.212 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:24:17.212 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:24:17.319 | NTP Client | Received Packet | RoundTripDelay=0.10596990585327148, SystemClockOffset=-0.007992982864379883 2025-11-10 09:24:17.332 | NTP Client | Received Packet | RoundTripDelay=0.11996603012084961, SystemClockOffset=-0.0038564205169677734 2025-11-10 09:24:17.582 | NTP Client | Received Packet | RoundTripDelay=0.3689727783203125, SystemClockOffset=0.027313709259033203 2025-11-10 09:24:18.213 | NTP Client | Performed system clock adjustment of -3856.4205169677734 microseconds. 2025-11-10 09:25:17.234 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:25:17.234 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:25:17.234 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:25:17.234 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:25:17.341 | NTP Client | Received Packet | RoundTripDelay=0.10698556900024414, SystemClockOffset=-0.0049974918365478516 2025-11-10 09:25:17.616 | NTP Client | Received Packet | RoundTripDelay=0.3809800148010254, SystemClockOffset=0.02855849266052246 2025-11-10 09:25:18.253 | NTP Client | Performed system clock adjustment of 11780.500411987305 microseconds. 2025-11-10 09:26:17.248 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:26:17.248 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:26:17.248 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:26:17.248 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:26:17.359 | NTP Client | Received Packet | RoundTripDelay=0.10985231399536133, SystemClockOffset=-0.007204771041870117 2025-11-10 09:26:17.369 | NTP Client | Received Packet | RoundTripDelay=0.11996984481811523, SystemClockOffset=-0.011830568313598633 2025-11-10 09:26:17.655 | NTP Client | Received Packet | RoundTripDelay=0.40697193145751953, SystemClockOffset=0.019814014434814453 2025-11-10 09:26:18.248 | NTP Client | Performed system clock adjustment of -7204.771041870117 microseconds. 2025-11-10 09:27:17.263 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:27:17.263 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:27:17.263 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:27:17.263 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:27:17.371 | NTP Client | Received Packet | RoundTripDelay=0.10698843002319336, SystemClockOffset=-0.01022791862487793 2025-11-10 09:27:17.646 | NTP Client | Received Packet | RoundTripDelay=0.3819723129272461, SystemClockOffset=0.013991832733154297 2025-11-10 09:27:18.258 | NTP Client | Performed system clock adjustment of 1881.9570541381836 microseconds. 2025-11-10 09:28:17.251 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:28:17.251 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:28:17.251 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:28:17.251 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:28:17.358 | NTP Client | Received Packet | RoundTripDelay=0.10698747634887695, SystemClockOffset=-0.012704133987426758 2025-11-10 09:28:17.653 | NTP Client | Received Packet | RoundTripDelay=0.400972843170166, SystemClockOffset=0.021589994430541992 2025-11-10 09:28:18.275 | NTP Client | Performed system clock adjustment of 4442.930221557617 microseconds. 2025-11-10 09:29:17.275 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:29:17.275 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:29:17.275 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:29:17.275 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:29:17.382 | NTP Client | Received Packet | RoundTripDelay=0.10698890686035156, SystemClockOffset=-0.017110347747802734 2025-11-10 09:29:17.385 | NTP Client | Received Packet | RoundTripDelay=0.10991907119750977, SystemClockOffset=-0.00802922248840332 2025-11-10 09:29:18.271 | NTP Client | Performed system clock adjustment of -12569.785118103027 microseconds. 2025-11-10 09:30:17.260 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:30:17.260 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:30:17.260 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:30:17.260 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:30:17.371 | NTP Client | Received Packet | RoundTripDelay=0.1109156608581543, SystemClockOffset=0.0036780834197998047 2025-11-10 09:30:17.382 | NTP Client | Received Packet | RoundTripDelay=0.1219639778137207, SystemClockOffset=-0.0005519390106201172 2025-11-10 09:30:17.638 | NTP Client | Received Packet | RoundTripDelay=0.3779716491699219, SystemClockOffset=0.03292274475097656 2025-11-10 09:30:18.278 | NTP Client | Performed system clock adjustment of 3678.0834197998047 microseconds. 2025-11-10 09:31:13.883 | File >> Disconnect selected. 2025-11-10 09:31:13.905 | Teton CME Routing | Waiting for socket receive thread to end 2025-11-10 09:31:13.905 | DTC Client socket (2) | CloseSocket call. 2025-11-10 09:31:13.905 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:13.906 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-11-10 09:31:13.906 | DTC Client socket (2) | Closed. 2025-11-10 09:31:13.906 | Denali Data Feed | Waiting for socket receive thread to end 2025-11-10 09:31:13.906 | DTC Client socket (3) | CloseSocket call. 2025-11-10 09:31:13.906 | Denali Data Feed | Disconnected from the server. 2025-11-10 09:31:13.906 | SC Data with Depth | Waiting for socket receive thread to end 2025-11-10 09:31:13.906 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:13.906 | DTC Client socket (9) | CloseSocket call. 2025-11-10 09:31:13.906 | SC Data with Depth | Disconnected from the server. 2025-11-10 09:31:13.906 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:13.906 | Teton CME Routing | Disconnected. 2025-11-10 09:31:13.907 | DTC Client socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:31:13.907 | DTC Client socket (9) | Closed. 2025-11-10 09:31:13.907 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:31:13.907 | DTC Client socket (3) | Closed. 2025-11-10 09:31:14.662 | 2025-11-10 09:31:14.662 | Teton CME Routing | Firm: Dorman 2025-11-10 09:31:14.662 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 2025-11-10 09:31:14.663 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-11-10 09:31:14.663 | DTC Client socket (1) | New receive buffer size: 0 2025-11-10 09:31:14.663 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-11-10 09:31:14.667 | Teton CME Routing | Network connection to server complete. 2025-11-10 09:31:14.667 | Teton CME Routing | Starting socket receive thread. 2025-11-10 09:31:14.667 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-11-10 09:31:16.916 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-11-10 09:31:16.916 | Teton CME Routing | Sending logon request message. 2025-11-10 09:31:17.280 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:31:17.280 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:31:17.280 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:31:17.280 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:31:17.344 | Teton CME Routing | Received logon response. 2025-11-10 09:31:17.344 | Teton CME Routing | Server Name: SC DTC Server. Build=54268. 2025-11-10 09:31:17.344 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:31:17.344 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-11-10 09:31:17.344 | Teton CME Routing | Trading is supported. 2025-11-10 09:31:17.344 | Teton CME Routing | Order cancel and replace is supported. 2025-11-10 09:31:17.344 | Teton CME Routing | OCO Orders supported. 2025-11-10 09:31:17.344 | Teton CME Routing | Bracket Orders supported. 2025-11-10 09:31:17.344 | Teton CME Routing | MarketDepthIsSupported: 1 2025-11-10 09:31:17.344 | Teton CME Routing | Connection to server complete. 2025-11-10 09:31:17.344 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-11-10 09:31:17.344 | Updated verified funded futures trading account ending date to: 2025-12-10 14:31:17 2025-11-10 09:31:17.355 | Using Bid/Ask average for last trade price for VOLX 2025-11-10 09:31:17.355 | Using symbol data fast lookup vector 2025-11-10 09:31:17.355 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2025-11-10 09:31:17.355 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2025-11-10 09:31:17.355 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2025-11-10 09:31:17.355 | Added historical Intraday data request for VOLX to the queue. 2025-11-10 09:31:17.355 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2025-11-10 09:31:17.355 | Triggering next historical data download in queue. 2025-11-10 09:31:17.355 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Started historical data download for additional symbol VOLX. Download ID: 159 2025-11-10 09:31:17.355 | DTC Client socket (2) | Creating socket. 2025-11-10 09:31:17.355 | DTC Client socket (2) | New receive buffer size: 0 2025-11-10 09:31:17.355 | DTC Client socket (2) | Connecting to IP: 64.152.155.113. 2025-11-10 09:31:17.359 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2025-11-10 09:31:17.359 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2025-11-10 09:31:17.359 | Added historical Intraday data request for TICK-NYSE to the queue. 2025-11-10 09:31:17.359 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2025-11-10 09:31:17.359 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 160 2025-11-10 09:31:17.359 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2025-11-10 09:31:17.359 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2025-11-10 09:31:17.359 | Added historical Intraday data request for NISS-NYSE to the queue. 2025-11-10 09:31:17.359 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2025-11-10 09:31:17.359 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 161 2025-11-10 09:31:17.359 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2025-11-10 09:31:17.359 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2025-11-10 09:31:17.359 | Added historical Intraday data request for TRIN-NYSE to the queue. 2025-11-10 09:31:17.360 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2025-11-10 09:31:17.360 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 162 2025-11-10 09:31:17.363 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-11-10 09:31:17.363 | Delaying start of download for VOLX. 2025-11-10 09:31:17.363 | SC Data with Depth | Network connection to server complete. 2025-11-10 09:31:17.363 | SC Data with Depth | Starting socket receive thread. 2025-11-10 09:31:17.363 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2025-11-10 09:31:17.387 | NTP Client | Received Packet | RoundTripDelay=0.10598134994506836, SystemClockOffset=-0.009629964828491211 2025-11-10 09:31:17.388 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-11-07 17:29:53.976000 2025-11-10 09:31:17.391 | NTP Client | Received Packet | RoundTripDelay=0.11068010330200195, SystemClockOffset=-0.0011131763458251953 2025-11-10 09:31:17.441 | Mapping ESZ25_FUT_CME to ESZ25. Service code: cme 2025-11-10 09:31:17.441 | Denali Data Feed | Starting real-time market data updates for: ESZ25_FUT_CME (ESZ25). ID: 5 Service code: cme 2025-11-10 09:31:17.441 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443 2025-11-10 09:31:17.441 | Denali Data Feed | Requesting security definition data for: ESZ25_FUT_CME (ESZ25). ID: 5 2025-11-10 09:31:17.442 | DTC Client socket (3) | Creating socket. 2025-11-10 09:31:17.442 | DTC Client socket (3) | New receive buffer size: 0 2025-11-10 09:31:17.442 | DTC Client socket (3) | Connecting to IP: 64.152.155.20. 2025-11-10 09:31:17.442 | Mapping MESZ25_FUT_CME to MESZ25. Service code: cme 2025-11-10 09:31:17.442 | Denali Data Feed | Starting real-time market data updates for: MESZ25_FUT_CME (MESZ25). ID: 6 Service code: cme 2025-11-10 09:31:17.442 | Denali Data Feed | Requesting security definition data for: MESZ25_FUT_CME (MESZ25). ID: 6 2025-11-10 09:31:17.442 | Added historical Intraday data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:31:17.442 | Intraday data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:17.442 | Triggering next historical data download in queue. 2025-11-10 09:31:17.449 | Mapping NQZ25_FUT_CME to NQZ25. Service code: cme 2025-11-10 09:31:17.449 | Denali Data Feed | Starting real-time market data updates for: NQZ25_FUT_CME (NQZ25). ID: 7 Service code: cme 2025-11-10 09:31:17.449 | Denali Data Feed | Requesting security definition data for: NQZ25_FUT_CME (NQZ25). ID: 7 2025-11-10 09:31:17.449 | Mapping MNQZ25_FUT_CME to MNQZ25. Service code: cme 2025-11-10 09:31:17.449 | Denali Data Feed | Starting real-time market data updates for: MNQZ25_FUT_CME (MNQZ25). ID: 8 Service code: cme 2025-11-10 09:31:17.449 | Denali Data Feed | Requesting security definition data for: MNQZ25_FUT_CME (MNQZ25). ID: 8 2025-11-10 09:31:17.449 | Added historical Intraday data request for NQZ25_FUT_CME to the queue. 2025-11-10 09:31:17.449 | Intraday data recording state for symbol NQZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:17.456 | Denali Data Feed | Network connection to server complete. 2025-11-10 09:31:17.456 | Denali Data Feed | Starting socket receive thread. 2025-11-10 09:31:17.456 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-11-10 09:31:17.582 | Mapping ZNZ25_FUT_CME to ZNZ25. Service code: cbot 2025-11-10 09:31:17.582 | Denali Data Feed | Starting real-time market data updates for: ZNZ25_FUT_CME (ZNZ25). ID: 9 Service code: cbot 2025-11-10 09:31:17.582 | Denali Data Feed | Requesting security definition data for: ZNZ25_FUT_CME (ZNZ25). ID: 9 2025-11-10 09:31:17.582 | Added historical Intraday data request for ZNZ25_FUT_CME to the queue. 2025-11-10 09:31:17.582 | Intraday data recording state for symbol ZNZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:17.582 | Triggering next historical data download in queue. 2025-11-10 09:31:17.585 | Mapping ZBZ25_FUT_CME to ZBZ25. Service code: cbot 2025-11-10 09:31:17.585 | Denali Data Feed | Starting real-time market data updates for: ZBZ25_FUT_CME (ZBZ25). ID: 10 Service code: cbot 2025-11-10 09:31:17.585 | Denali Data Feed | Requesting security definition data for: ZBZ25_FUT_CME (ZBZ25). ID: 10 2025-11-10 09:31:17.585 | Added historical Intraday data request for ZBZ25_FUT_CME to the queue. 2025-11-10 09:31:17.585 | Intraday data recording state for symbol ZBZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:17.680 | NTP Client | Received Packet | RoundTripDelay=0.3989706039428711, SystemClockOffset=0.026407241821289062 2025-11-10 09:31:17.833 | Mapping RTYZ25_FUT_CME to RTYZ25. Service code: cme 2025-11-10 09:31:17.835 | Denali Data Feed | Starting real-time market data updates for: RTYZ25_FUT_CME (RTYZ25). ID: 11 Service code: cme 2025-11-10 09:31:17.835 | Denali Data Feed | Requesting security definition data for: RTYZ25_FUT_CME (RTYZ25). ID: 11 2025-11-10 09:31:17.835 | Added historical Intraday data request for RTYZ25_FUT_CME to the queue. 2025-11-10 09:31:17.835 | Intraday data recording state for symbol RTYZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:17.835 | Triggering next historical data download in queue. 2025-11-10 09:31:18.250 | Updated verified funded futures trading account ending date to: 2025-12-10 14:31:18 2025-11-10 09:31:18.250 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ25_FUT_CME 2025-11-10 09:31:18.250 | Teton CME Routing | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-11-10 09:31:18.250 | Teton CME Routing | Received security definition for symbol ESZ25_FUT_CME 2025-11-10 09:31:18.250 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ25_FUT_CME 2025-11-10 09:31:18.250 | Teton CME Routing | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-11-10 09:31:18.250 | Teton CME Routing | Received security definition for symbol MESZ25_FUT_CME 2025-11-10 09:31:18.288 | NTP Client | Performed system clock adjustment of -1113.1763458251953 microseconds. 2025-11-10 09:31:18.498 | SC Data with Depth | Setting DTC encoding to Binary VLS 2025-11-10 09:31:18.498 | SC Data with Depth | Sending logon request message. 2025-11-10 09:31:18.520 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-11-10 09:31:18.520 | Denali Data Feed | Sending logon request message. 2025-11-10 09:31:18.831 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQZ25_FUT_CME 2025-11-10 09:31:18.831 | Teton CME Routing | Setting external service identifier for symbol NQZ25_FUT_CME to 158704 2025-11-10 09:31:18.831 | Teton CME Routing | Received security definition for symbol NQZ25_FUT_CME 2025-11-10 09:31:18.831 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ25_FUT_CME 2025-11-10 09:31:18.831 | Teton CME Routing | Setting external service identifier for symbol MNQZ25_FUT_CME to 42001149 2025-11-10 09:31:18.831 | Teton CME Routing | Received security definition for symbol MNQZ25_FUT_CME 2025-11-10 09:31:18.831 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNZ25_FUT_CME 2025-11-10 09:31:18.831 | Teton CME Routing | Setting external service identifier for symbol ZNZ25_FUT_CME to 42002111 2025-11-10 09:31:18.831 | Teton CME Routing | Received security definition for symbol ZNZ25_FUT_CME 2025-11-10 09:31:18.831 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBZ25_FUT_CME 2025-11-10 09:31:18.831 | Teton CME Routing | Setting external service identifier for symbol ZBZ25_FUT_CME to 42001597 2025-11-10 09:31:18.831 | Teton CME Routing | Received security definition for symbol ZBZ25_FUT_CME 2025-11-10 09:31:18.831 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYZ25_FUT_CME 2025-11-10 09:31:18.831 | Teton CME Routing | Setting external service identifier for symbol RTYZ25_FUT_CME to 42004289 2025-11-10 09:31:18.831 | Teton CME Routing | Received security definition for symbol RTYZ25_FUT_CME 2025-11-10 09:31:20.550 | Denali Data Feed | Received logon response. 2025-11-10 09:31:20.550 | Denali Data Feed | Server Name: SC Realtime Server. 2025-11-10 09:31:20.550 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:31:20.550 | Denali Data Feed | Successfully connected. 2025-11-10 09:31:20.550 | Denali Data Feed | Trading is not supported. 2025-11-10 09:31:20.550 | Denali Data Feed | MarketDepthIsSupported: 1 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ25_FUT_CME -> ESZ25 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ25_FUT_CME -> MESZ25 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ25_FUT_CME -> MNQZ25 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ25_FUT_CME -> NQZ25 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: RTYZ25_FUT_CME -> RTYZ25 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: ZBZ25_FUT_CME -> ZBZ25 2025-11-10 09:31:20.550 | Denali Data Feed | Restarting real-time data updates for symbol: ZNZ25_FUT_CME -> ZNZ25 2025-11-10 09:31:20.673 | SC Data with Depth | Received logon response. 2025-11-10 09:31:20.673 | SC Data with Depth | Server Name: SC Realtime Server. 2025-11-10 09:31:20.673 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:31:20.673 | SC Data with Depth | Successfully connected. 2025-11-10 09:31:20.673 | SC Data with Depth | Trading is not supported. 2025-11-10 09:31:20.673 | SC Data with Depth | MarketDepthIsSupported: 1 2025-11-10 09:31:20.673 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2025-11-10 09:31:20.673 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2025-11-10 09:31:20.673 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2025-11-10 09:31:20.673 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2025-11-10 09:31:21.455 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2025-11-10 09:31:21.455 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2025-11-10 09:31:21.455 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2025-11-10 09:31:21.455 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2025-11-10 09:31:21.455 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2025-11-10 09:31:21.455 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2025-11-10 09:31:21.455 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2025-11-10 09:31:21.455 | SC Data with Depth | Received security definition for symbol VOLX 2025-11-10 09:31:22.339 | Requesting market depth updates for: ESZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:31:22.339 | Requesting market depth updates for: NQZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:31:22.339 | Requesting market depth updates for: ZBZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:31:22.339 | Requesting market depth updates for: ZNZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:31:22.339 | Added historical Market Depth data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:31:22.339 | Market depth data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:22.339 | Triggering next historical data download in queue. 2025-11-10 09:31:22.340 | Added historical Market Depth data request for NQZ25_FUT_CME to the queue. 2025-11-10 09:31:22.340 | Market depth data recording state for symbol NQZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:22.340 | HD Request # 14 | Downloading Market Depth data for ESZ25_FUT_CME. Service: cme.marketdepth. 2025-11-10 09:31:22.341 | HD Request # 14 | Download start date-time: 2025-11-10 09:31:13.905679. 2025-11-10 09:31:22.341 | HD Request # 14 | Using server: ds26.sierracharts.com port 10149 2025-11-10 09:31:22.341 | Socket (5) | Creating socket. 2025-11-10 09:31:22.341 | Socket (5) | New receive buffer size: 0 2025-11-10 09:31:22.341 | Socket (5) | Connecting to IP: 64.152.155.17. 2025-11-10 09:31:23.020 | HD Request # 14 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:23.020 | HD Request # 14 | Sending historical data logon request message. 2025-11-10 09:31:23.351 | HD Request # 14 | Requesting market depth data. Start date-time: 2025-11-10 09:31:13. Symbol: ESZ25 2025-11-10 09:31:23.654 | HD Request # 14 | Decompressing data. 2025-11-10 09:31:23.962 | HD Request # 14 | Receiving market depth data for ESZ25_FUT_CME starting at 2025-11-10 09:31:13.906000 2025-11-10 09:31:24.284 | Socket (5) | CloseSocket call. 2025-11-10 09:31:24.284 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:24.285 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:31:24.285 | Socket (5) | Closed. 2025-11-10 09:31:24.285 | Historical data download thread signaled to stop. 2025-11-10 09:31:24.286 | HD Request # 14 | Timestamp of first market depth data file record written: 2025-11-10 09:31:13.906000. 2025-11-10 09:31:24.286 | HD Request # 14 | Received 7460 Market Depth data records from 2025-11-10 09:31:13.906000 to 2025-11-10 09:31:20.890000 (7.0 seconds. Delay: 3.4 seconds) and wrote 7460 records for ESZ25_FUT_CME 2025-11-10 09:31:24.286 | HD Request # 14 | Completion time: 2s. 2025-11-10 09:31:24.286 | HD Request # 14 | Market Depth data download complete for ESZ25_FUT_CME. Unique request ID: 168 2025-11-10 09:31:24.286 | Removing historical data download ID 168. 2025-11-10 09:31:24.286 | Real-time market depth file updates started for ESZ25_FUT_CME 2025-11-10 09:31:24.295 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [CV][M] #4 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:24.295 | 2025-11-10 09:31:24.295 | Triggering next historical data download in queue. 2025-11-10 09:31:24.295 | HD Request # 15 | Downloading Market Depth data for NQZ25_FUT_CME. Service: cme.marketdepth. 2025-11-10 09:31:24.296 | HD Request # 15 | Download start date-time: 2025-11-10 09:31:13.905885. 2025-11-10 09:31:24.296 | HD Request # 15 | Using server: ds32.sierracharts.com port 10150 2025-11-10 09:31:24.296 | Socket (5) | Creating socket. 2025-11-10 09:31:24.297 | Socket (5) | New receive buffer size: 0 2025-11-10 09:31:24.297 | Socket (5) | Connecting to IP: 69.39.70.248. 2025-11-10 09:31:24.332 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Reloading chart. 2025-11-10 09:31:24.345 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.347 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:31:24.353 | ESZ25_FUT_CME [CV][M] #4 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.355 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Reloading chart. 2025-11-10 09:31:24.355 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.360 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Reloading chart. 2025-11-10 09:31:24.367 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.475 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Reloading chart. 2025-11-10 09:31:24.475 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.508 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Reloading chart. 2025-11-10 09:31:24.515 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.557 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Reloading chart. 2025-11-10 09:31:24.558 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.559 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Reloading chart. 2025-11-10 09:31:24.612 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.613 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Reloading chart. 2025-11-10 09:31:24.628 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.662 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Reloading chart. 2025-11-10 09:31:24.678 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:24.679 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Reloading chart. 2025-11-10 09:31:24.703 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 163, 2025-11-10 09:31:25.226 | HD Request # 15 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:25.226 | HD Request # 15 | Sending historical data logon request message. 2025-11-10 09:31:25.240 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol ESZ25_FUT_CME 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol MESZ25_FUT_CME 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol MNQZ25_FUT_CME to 42001149 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol MNQZ25_FUT_CME 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol NQZ25_FUT_CME to 158704 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol NQZ25_FUT_CME 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol RTYZ25_FUT_CME to 42004289 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol RTYZ25_FUT_CME 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol ZBZ25_FUT_CME to 42001597 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol ZBZ25_FUT_CME 2025-11-10 09:31:25.240 | Denali Data Feed | Setting external service identifier for symbol ZNZ25_FUT_CME to 42002111 2025-11-10 09:31:25.240 | Denali Data Feed | Received security definition for symbol ZNZ25_FUT_CME 2025-11-10 09:31:25.762 | HD Request # 15 | Requesting market depth data. Start date-time: 2025-11-10 09:31:13. Symbol: NQZ25 2025-11-10 09:31:26.112 | HD Request # 16 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2025-11-10 09:31:26.113 | HD Request # 16 | Download start date-time: 2025-11-10 09:31:01.000000. File last date-time: 2025-11-10 09:31:01.894000 2025-11-10 09:31:26.113 | HD Request # 16 | Using server: ds12.sierracharts.com port 10149 2025-11-10 09:31:26.114 | Socket (9) | Creating socket. 2025-11-10 09:31:26.114 | Socket (9) | New receive buffer size: 0 2025-11-10 09:31:26.114 | Socket (9) | Connecting to IP: 69.39.70.241. 2025-11-10 09:31:26.348 | HD Request # 15 | Decompressing data. 2025-11-10 09:31:26.471 | HD Request # 15 | Receiving market depth data for NQZ25_FUT_CME starting at 2025-11-10 09:31:13.906000 2025-11-10 09:31:27.067 | HD Request # 16 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:27.067 | HD Request # 16 | Sending historical data logon request message. 2025-11-10 09:31:27.731 | HD Request # 16 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:01. Record interval: 0. Symbol: VOLX 2025-11-10 09:31:28.245 | HD Request # 16 | Decompressing data. 2025-11-10 09:31:28.495 | HD Request # 16 | Receiving Intraday data for VOLX starting at 2025-11-10 09:31:01.337000 2025-11-10 09:31:28.496 | Socket (9) | CloseSocket call. 2025-11-10 09:31:28.496 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:28.497 | Socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:31:28.497 | Socket (9) | Closed. 2025-11-10 09:31:28.498 | Historical data download thread signaled to stop. 2025-11-10 09:31:28.498 | HD Request # 16 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:19.850000. 2025-11-10 09:31:28.498 | HD Request # 16 | Received 12 Intraday data records from 2025-11-10 09:31:01.337000 to 2025-11-10 09:31:23.371000 (22.0 seconds. Delay: 5.1 seconds) and wrote 10 records for VOLX 2025-11-10 09:31:28.508 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:23.371000 2025-11-10 09:31:28.508 | Added 2 Time and Sales records to Intraday data file for VOLX after download. 2025-11-10 09:31:28.509 | HD Request # 16 | Completion time: 2s. 2025-11-10 09:31:28.509 | HD Request # 16 | Intraday data download complete for VOLX. Unique request ID: 159 2025-11-10 09:31:28.509 | Removing historical data download ID 159. 2025-11-10 09:31:28.509 | Real-time Intraday chart data file updates started for VOLX 2025-11-10 09:31:28.509 | Intraday chart data file opened for VOLX 2025-11-10 09:31:28.509 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:28.509 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Historical data download for additional symbol VOLX with ID 159 has completed. 2025-11-10 09:31:28.509 | 2025-11-10 09:31:28.509 | Triggering next historical data download in queue. 2025-11-10 09:31:28.509 | HD Request # 17 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2025-11-10 09:31:28.510 | HD Request # 17 | Download start date-time: 2025-11-10 09:31:13.000000. File last date-time: 2025-11-10 09:31:13.462002 2025-11-10 09:31:28.510 | HD Request # 17 | Using server: ds4.sierracharts.com port 10150 2025-11-10 09:31:28.510 | Socket (9) | Creating socket. 2025-11-10 09:31:28.510 | Socket (9) | New receive buffer size: 0 2025-11-10 09:31:28.510 | Socket (9) | Connecting to IP: 64.152.155.113. 2025-11-10 09:31:30.436 | Denali Data Feed | Clearing market depth for ESZ25_FUT_CME 2025-11-10 09:31:30.436 | Denali Data Feed | Clearing market depth for NQZ25_FUT_CME 2025-11-10 09:31:30.436 | Denali Data Feed | Market Depth data has been rejected for symbol: ZBZ25_FUT_CME. Not authorized for market depth. 2025-11-10 09:31:30.436 | Denali Data Feed | Market Depth data has been rejected for symbol: ZNZ25_FUT_CME. Not authorized for market depth. 2025-11-10 09:31:32.119 | HD Request # 17 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:32.119 | HD Request # 17 | Sending historical data logon request message. 2025-11-10 09:31:32.468 | Opened cached Intraday file: C:\SierraChart\Data\VOLX.scid. Thread ID: 15288 2025-11-10 09:31:32.515 | HD Request # 17 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:13. Record interval: 0. Symbol: TICK-NYSE 2025-11-10 09:31:32.826 | HD Request # 17 | Decompressing data. 2025-11-10 09:31:33.461 | HD Request # 17 | Receiving Intraday data for TICK-NYSE starting at 2025-11-10 09:31:13.000000 2025-11-10 09:31:33.461 | Socket (9) | CloseSocket call. 2025-11-10 09:31:33.461 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:33.462 | Socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:31:33.462 | Socket (9) | Closed. 2025-11-10 09:31:33.463 | Historical data download thread signaled to stop. 2025-11-10 09:31:33.463 | HD Request # 17 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:14.000000. 2025-11-10 09:31:33.463 | HD Request # 17 | Received 19 Intraday data records from 2025-11-10 09:31:13.000000 to 2025-11-10 09:31:31.000000 (18.0 seconds. Delay: 2.5 seconds) and wrote 18 records for TICK-NYSE 2025-11-10 09:31:33.470 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:31.000000 2025-11-10 09:31:33.470 | Added 21 Time and Sales records to Intraday data file for TICK-NYSE after download. 2025-11-10 09:31:33.470 | HD Request # 17 | Completion time: 5s. 2025-11-10 09:31:33.470 | HD Request # 17 | Intraday data download complete for TICK-NYSE. Unique request ID: 160 2025-11-10 09:31:33.470 | Removing historical data download ID 160. 2025-11-10 09:31:33.470 | Real-time Intraday chart data file updates started for TICK-NYSE 2025-11-10 09:31:33.470 | Intraday chart data file opened for TICK-NYSE 2025-11-10 09:31:33.470 | HD Request # 17 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:33.470 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 160 has completed. 2025-11-10 09:31:33.470 | 2025-11-10 09:31:33.470 | Triggering next historical data download in queue. 2025-11-10 09:31:33.470 | HD Request # 18 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2025-11-10 09:31:33.470 | HD Request # 18 | Download start date-time: 2025-11-10 09:31:13.000000. File last date-time: 2025-11-10 09:31:13.212001 2025-11-10 09:31:33.470 | HD Request # 18 | Using server: ds12.sierracharts.com port 10149 2025-11-10 09:31:33.470 | Socket (9) | Creating socket. 2025-11-10 09:31:33.470 | Socket (9) | New receive buffer size: 0 2025-11-10 09:31:33.470 | Socket (9) | Connecting to IP: 69.39.70.241. 2025-11-10 09:31:34.308 | HD Request # 18 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:34.308 | HD Request # 18 | Sending historical data logon request message. 2025-11-10 09:31:34.641 | HD Request # 18 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:13. Record interval: 0. Symbol: NISS-NYSE 2025-11-10 09:31:34.833 | Socket (5) | CloseSocket call. 2025-11-10 09:31:34.833 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:34.835 | Historical data download thread signaled to stop. 2025-11-10 09:31:34.835 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:31:34.835 | Socket (5) | Closed. 2025-11-10 09:31:34.836 | HD Request # 15 | Timestamp of first market depth data file record written: 2025-11-10 09:31:13.906000. 2025-11-10 09:31:34.836 | HD Request # 15 | Received 19356 Market Depth data records from 2025-11-10 09:31:13.906000 to 2025-11-10 09:31:22.662000 (8.8 seconds. Delay: 12.2 seconds) and wrote 19356 records for NQZ25_FUT_CME 2025-11-10 09:31:34.838 | HD Request # 15 | Completion time: 10s. 2025-11-10 09:31:34.838 | HD Request # 15 | Market Depth data download complete for NQZ25_FUT_CME. Unique request ID: 169 2025-11-10 09:31:34.838 | Removing historical data download ID 169. 2025-11-10 09:31:34.838 | Real-time market depth file updates started for NQZ25_FUT_CME 2025-11-10 09:31:34.844 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:31:34.844 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:34.844 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:34.844 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:34.844 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:34.844 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:34.844 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:31:34.844 | 2025-11-10 09:31:34.844 | No download requests in the queue to start downloads for. 2025-11-10 09:31:34.845 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Reloading chart. 2025-11-10 09:31:34.845 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 164, 2025-11-10 09:31:34.849 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:31:34.849 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 164, 2025-11-10 09:31:34.879 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Reloading chart. 2025-11-10 09:31:34.891 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 164, 2025-11-10 09:31:34.943 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:31:34.962 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Reloading chart. 2025-11-10 09:31:34.962 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Waiting for historical downloads to complete with the IDs: 164, 2025-11-10 09:31:35.059 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Reloading chart. 2025-11-10 09:31:35.060 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 164, 2025-11-10 09:31:35.134 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Reloading chart. 2025-11-10 09:31:35.140 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 164, 2025-11-10 09:31:36.297 | HD Request # 18 | Decompressing data. 2025-11-10 09:31:36.548 | HD Request # 18 | Receiving Intraday data for NISS-NYSE starting at 2025-11-10 09:31:13.000000 2025-11-10 09:31:36.549 | Socket (9) | CloseSocket call. 2025-11-10 09:31:36.549 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:36.551 | Socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:31:36.551 | Socket (9) | Closed. 2025-11-10 09:31:36.551 | Historical data download thread signaled to stop. 2025-11-10 09:31:36.551 | HD Request # 18 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:14.000000. 2025-11-10 09:31:36.552 | HD Request # 18 | Received 22 Intraday data records from 2025-11-10 09:31:13.000000 to 2025-11-10 09:31:34.000000 (21.0 seconds. Delay: 2.6 seconds) and wrote 21 records for NISS-NYSE 2025-11-10 09:31:36.561 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:34.000000 2025-11-10 09:31:36.561 | Added 12 Time and Sales records to Intraday data file for NISS-NYSE after download. 2025-11-10 09:31:36.561 | HD Request # 18 | Completion time: 3s. 2025-11-10 09:31:36.561 | HD Request # 18 | Intraday data download complete for NISS-NYSE. Unique request ID: 161 2025-11-10 09:31:36.561 | Removing historical data download ID 161. 2025-11-10 09:31:36.561 | Real-time Intraday chart data file updates started for NISS-NYSE 2025-11-10 09:31:36.561 | Intraday chart data file opened for NISS-NYSE 2025-11-10 09:31:36.561 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:36.561 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 161 has completed. 2025-11-10 09:31:36.561 | 2025-11-10 09:31:36.561 | Triggering next historical data download in queue. 2025-11-10 09:31:36.561 | HD Request # 19 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2025-11-10 09:31:36.562 | HD Request # 19 | Download start date-time: 2025-11-10 09:31:13.000000. File last date-time: 2025-11-10 09:31:13.212002 2025-11-10 09:31:36.562 | HD Request # 19 | Using server: ds4.sierracharts.com port 10150 2025-11-10 09:31:36.562 | Socket (5) | Creating socket. 2025-11-10 09:31:36.562 | Socket (5) | New receive buffer size: 0 2025-11-10 09:31:36.562 | Socket (5) | Connecting to IP: 64.152.155.113. 2025-11-10 09:31:37.470 | Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 15288 2025-11-10 09:31:37.691 | HD Request # 19 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:37.691 | HD Request # 19 | Sending historical data logon request message. 2025-11-10 09:31:38.061 | HD Request # 19 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:13. Record interval: 0. Symbol: TRIN-NYSE 2025-11-10 09:31:38.683 | HD Request # 19 | Decompressing data. 2025-11-10 09:31:39.059 | HD Request # 19 | Receiving Intraday data for TRIN-NYSE starting at 2025-11-10 09:31:13.000000 2025-11-10 09:31:39.059 | Socket (5) | CloseSocket call. 2025-11-10 09:31:39.060 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:39.060 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:31:39.060 | Socket (5) | Closed. 2025-11-10 09:31:39.063 | Historical data download thread signaled to stop. 2025-11-10 09:31:39.063 | HD Request # 19 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:14.000000. 2025-11-10 09:31:39.063 | HD Request # 19 | Received 25 Intraday data records from 2025-11-10 09:31:13.000000 to 2025-11-10 09:31:37.000000 (24.0 seconds. Delay: 2.1 seconds) and wrote 24 records for TRIN-NYSE 2025-11-10 09:31:39.070 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:37.000000 2025-11-10 09:31:39.070 | Added 10 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2025-11-10 09:31:39.070 | HD Request # 19 | Completion time: 3s. 2025-11-10 09:31:39.070 | HD Request # 19 | Intraday data download complete for TRIN-NYSE. Unique request ID: 162 2025-11-10 09:31:39.070 | Removing historical data download ID 162. 2025-11-10 09:31:39.070 | Real-time Intraday chart data file updates started for TRIN-NYSE 2025-11-10 09:31:39.070 | Intraday chart data file opened for TRIN-NYSE 2025-11-10 09:31:39.070 | HD Request # 19 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:39.070 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 162 has completed. 2025-11-10 09:31:39.070 | 2025-11-10 09:31:39.070 | Triggering next historical data download in queue. 2025-11-10 09:31:39.070 | HD Request # 20 | Downloading Intraday chart data for ESZ25_FUT_CME to the file ESZ25_FUT_CME.scid. Service: cme 2025-11-10 09:31:39.070 | HD Request # 20 | Download start date-time: 2025-11-10 09:30:09.000000. File last date-time: 2025-11-10 09:30:09.980000 2025-11-10 09:31:39.070 | HD Request # 20 | Using server: ds28.sierracharts.com port 10149 2025-11-10 09:31:39.070 | Socket (5) | Creating socket. 2025-11-10 09:31:39.070 | Socket (5) | New receive buffer size: 0 2025-11-10 09:31:39.070 | Socket (5) | Connecting to IP: 67.214.125.5. 2025-11-10 09:31:40.271 | HD Request # 20 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:40.271 | HD Request # 20 | Sending historical data logon request message. 2025-11-10 09:31:40.833 | HD Request # 20 | Requesting Intraday data. Start date-time: 2025-11-10 09:30:09. Record interval: 0. Symbol: ESZ25 2025-11-10 09:31:41.155 | HD Request # 20 | Decompressing data. 2025-11-10 09:31:41.303 | HD Request # 20 | Receiving Intraday data for ESZ25_FUT_CME starting at 2025-11-10 09:30:09.010000 2025-11-10 09:31:42.477 | Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid. Thread ID: 15288 2025-11-10 09:31:42.478 | Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 15288 2025-11-10 09:31:45.094 | Socket (5) | CloseSocket call. 2025-11-10 09:31:45.095 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:45.096 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:31:45.096 | Socket (5) | Closed. 2025-11-10 09:31:45.097 | Historical data download thread signaled to stop. 2025-11-10 09:31:45.098 | HD Request # 20 | Timestamp of first Intraday data file record written: 2025-11-10 09:30:10.022000. 2025-11-10 09:31:45.099 | HD Request # 20 | Received 13213 Intraday data records from 2025-11-10 09:30:09.010000 to 2025-11-10 09:31:39.412003 (90.4 seconds. Delay: 5.7 seconds) and wrote 12987 records for ESZ25_FUT_CME 2025-11-10 09:31:45.111 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:39.412003 2025-11-10 09:31:45.111 | HD Request # 20 | Completion time: 6s. 2025-11-10 09:31:45.111 | HD Request # 20 | Intraday data download complete for ESZ25_FUT_CME. Unique request ID: 163 2025-11-10 09:31:45.111 | Removing historical data download ID 163. 2025-11-10 09:31:45.111 | Real-time Intraday chart data file updates started for ESZ25_FUT_CME 2025-11-10 09:31:45.111 | Intraday chart data file opened for ESZ25_FUT_CME 2025-11-10 09:31:45.111 | HD Request # 20 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:45.111 | 2025-11-10 09:31:45.111 | Triggering next historical data download in queue. 2025-11-10 09:31:45.111 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.112 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Reloading chart. 2025-11-10 09:31:45.112 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.113 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Reloading chart. 2025-11-10 09:31:45.124 | HD Request # 21 | Downloading Intraday chart data for NQZ25_FUT_CME to the file NQZ25_FUT_CME.scid. Service: cme 2025-11-10 09:31:45.124 | HD Request # 21 | Download start date-time: 2025-11-10 09:30:09.000000. File last date-time: 2025-11-10 09:30:09.965000 2025-11-10 09:31:45.124 | HD Request # 21 | Using server: ds26.sierracharts.com port 10150 2025-11-10 09:31:45.124 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.124 | Socket (5) | Creating socket. 2025-11-10 09:31:45.124 | Socket (5) | New receive buffer size: 0 2025-11-10 09:31:45.124 | Socket (5) | Connecting to IP: 64.152.155.17. 2025-11-10 09:31:45.125 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Reloading chart. 2025-11-10 09:31:45.133 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.133 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Reloading chart. 2025-11-10 09:31:45.179 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.181 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Reloading chart. 2025-11-10 09:31:45.182 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.183 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Reloading chart. 2025-11-10 09:31:45.192 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.192 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Reloading chart. 2025-11-10 09:31:45.203 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.204 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Reloading chart. 2025-11-10 09:31:45.373 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.373 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Reloading chart. 2025-11-10 09:31:45.374 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.375 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Reloading chart. 2025-11-10 09:31:45.378 | ESZ25_FUT_CME [CV][M] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:45.378 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:31:45.402 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Reloading chart. 2025-11-10 09:31:45.412 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Reloading chart. 2025-11-10 09:31:45.416 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:45.416 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Chart data loading complete. 2025-11-10 09:31:45.435 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Reloading chart. 2025-11-10 09:31:45.558 | + Loading additional symbol data. 2025-11-10 09:31:45.599 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2025-11-09 18:00:00 2025-11-10 09:31:45.602 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:31:45.603 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:45.612 | + Loading additional symbol data. 2025-11-10 09:31:45.634 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Chart data loading complete. 2025-11-10 09:31:45.635 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Reloading chart. 2025-11-10 09:31:45.637 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Reloading chart. 2025-11-10 09:31:45.641 | + Loading additional symbol data. 2025-11-10 09:31:45.751 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Reloading chart. 2025-11-10 09:31:45.792 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Reloading chart. 2025-11-10 09:31:45.830 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Reloading chart. 2025-11-10 09:31:45.892 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Reloading chart. 2025-11-10 09:31:45.896 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:45.896 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:45.896 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Chart data loading complete. 2025-11-10 09:31:45.936 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Reloading chart. 2025-11-10 09:31:45.943 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:31:45.954 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:45.954 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Chart data loading complete. 2025-11-10 09:31:45.971 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:31:45.986 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Chart data loading complete. 2025-11-10 09:31:46.852 | + Loading additional symbol data. 2025-11-10 09:31:46.896 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:31:46.967 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Chart data loading complete. 2025-11-10 09:31:47.017 | HD Request # 21 | Setting DTC encoding to Binary VLS 2025-11-10 09:31:47.017 | HD Request # 21 | Sending historical data logon request message. 2025-11-10 09:31:47.488 | Opened cached Intraday file: C:\SierraChart\Data\ESZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:31:48.132 | HD Request # 21 | Requesting Intraday data. Start date-time: 2025-11-10 09:30:09. Record interval: 0. Symbol: NQZ25 2025-11-10 09:31:48.511 | HD Request # 21 | Decompressing data. 2025-11-10 09:31:48.566 | HD Request # 21 | Receiving Intraday data for NQZ25_FUT_CME starting at 2025-11-10 09:30:09.011000 2025-11-10 09:31:48.697 | ESZ25_FUT_CME [CV][M] #4 | StartDateTimeForLoadingOrderFills: 2024-11-03 00:00:00 2025-11-10 09:31:48.704 | ESZ25_FUT_CME [CV][M] #4 | Chart data loading complete. 2025-11-10 09:31:49.195 | Socket (5) | CloseSocket call. 2025-11-10 09:31:49.195 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:49.195 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:31:49.195 | Socket (5) | Closed. 2025-11-10 09:31:49.196 | Historical data download thread signaled to stop. 2025-11-10 09:31:49.197 | HD Request # 21 | Timestamp of first Intraday data file record written: 2025-11-10 09:30:09.992000. 2025-11-10 09:31:49.197 | HD Request # 21 | Received 8628 Intraday data records from 2025-11-10 09:30:09.011000 to 2025-11-10 09:31:47.375001 (98.4 seconds. Delay: 1.8 seconds) and wrote 8478 records for NQZ25_FUT_CME 2025-11-10 09:31:49.208 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:47.375001 2025-11-10 09:31:49.208 | HD Request # 21 | Completion time: 4s. 2025-11-10 09:31:49.208 | HD Request # 21 | Intraday data download complete for NQZ25_FUT_CME. Unique request ID: 164 2025-11-10 09:31:49.208 | Removing historical data download ID 164. 2025-11-10 09:31:49.208 | Real-time Intraday chart data file updates started for NQZ25_FUT_CME 2025-11-10 09:31:49.208 | Intraday chart data file opened for NQZ25_FUT_CME 2025-11-10 09:31:49.208 | HD Request # 21 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:49.209 | 2025-11-10 09:31:49.209 | Triggering next historical data download in queue. 2025-11-10 09:31:49.209 | HD Request # 22 | Downloading Intraday chart data for ZNZ25_FUT_CME to the file ZNZ25_FUT_CME.scid. Service: cbot 2025-11-10 09:31:49.209 | HD Request # 22 | Download start date-time: 2025-11-10 09:30:07.000000. File last date-time: 2025-11-10 09:30:07.764000 2025-11-10 09:31:49.209 | HD Request # 22 | Using server: ds32.sierracharts.com port 10149 2025-11-10 09:31:49.209 | Socket (5) | Creating socket. 2025-11-10 09:31:49.209 | Socket (5) | New receive buffer size: 0 2025-11-10 09:31:49.209 | Socket (5) | Connecting to IP: 69.39.70.248. 2025-11-10 09:31:49.288 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:49.289 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Reloading chart. 2025-11-10 09:31:49.318 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:49.319 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Reloading chart. 2025-11-10 09:31:49.378 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:49.378 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:31:49.379 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:49.379 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Reloading chart. 2025-11-10 09:31:49.429 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Reloading chart. 2025-11-10 09:31:49.531 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Reloading chart. 2025-11-10 09:31:49.531 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:49.531 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Reloading chart. 2025-11-10 09:31:49.665 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:31:49.666 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:49.688 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Chart data loading complete. 2025-11-10 09:31:49.697 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Reloading chart. 2025-11-10 09:31:49.887 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Chart data loading complete. 2025-11-10 09:31:49.890 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:49.890 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:49.890 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Chart data loading complete. 2025-11-10 09:31:49.891 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Reloading chart. 2025-11-10 09:31:49.904 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:31:49.916 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Chart data loading complete. 2025-11-10 09:31:49.924 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:31:50.058 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:31:50.058 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Reloading chart. 2025-11-10 09:31:50.138 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:50.138 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Chart data loading complete. 2025-11-10 09:31:50.197 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:50.197 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Chart data loading complete. 2025-11-10 09:31:50.569 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Reloading chart. 2025-11-10 09:31:50.753 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Chart data loading complete. 2025-11-10 09:31:52.451 | File >> Disconnect selected. 2025-11-10 09:31:52.466 | Teton CME Routing | Waiting for socket receive thread to end 2025-11-10 09:31:52.466 | DTC Client socket (1) | CloseSocket call. 2025-11-10 09:31:52.466 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:52.467 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-11-10 09:31:52.467 | DTC Client socket (1) | Closed. 2025-11-10 09:31:52.467 | Opened cached Intraday file: C:\SierraChart\Data\NQZ25_FUT_CME.scid. Thread ID: 7332 2025-11-10 09:31:52.467 | Denali Data Feed | Waiting for socket receive thread to end 2025-11-10 09:31:52.467 | DTC Client socket (3) | CloseSocket call. 2025-11-10 09:31:52.467 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:52.467 | Denali Data Feed | Disconnected from the server. 2025-11-10 09:31:52.467 | SC Data with Depth | Waiting for socket receive thread to end 2025-11-10 09:31:52.468 | DTC Client socket (2) | CloseSocket call. 2025-11-10 09:31:52.468 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:52.468 | SC Data with Depth | Disconnected from the server. 2025-11-10 09:31:52.468 | Teton CME Routing | Disconnected. 2025-11-10 09:31:52.468 | Canceling queued historical data download request for ZBZ25_FUT_CME Intraday data. 2025-11-10 09:31:52.468 | Removing historical data download ID 166. 2025-11-10 09:31:52.468 | Real-time Intraday chart data file updates started for ZBZ25_FUT_CME 2025-11-10 09:31:52.468 | Intraday chart data file opened for ZBZ25_FUT_CME 2025-11-10 09:31:52.468 | Canceling queued historical data download request for RTYZ25_FUT_CME Intraday data. 2025-11-10 09:31:52.468 | Removing historical data download ID 167. 2025-11-10 09:31:52.468 | Real-time Intraday chart data file updates started for RTYZ25_FUT_CME 2025-11-10 09:31:52.468 | Intraday chart data file opened for RTYZ25_FUT_CME 2025-11-10 09:31:52.468 | HD Request # 22 | Active download canceled. 2025-11-10 09:31:52.468 | Historical data download thread signaled to stop. 2025-11-10 09:31:52.468 | Socket (5) | CloseSocket call. 2025-11-10 09:31:52.468 | HD Request # 22 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ZNZ25_FUT_CME 2025-11-10 09:31:52.468 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-11-10 09:31:52.468 | HD Request # 22 | Completion time: 3s. 2025-11-10 09:31:52.468 | HD Request # 22 | Intraday data download complete for ZNZ25_FUT_CME. Unique request ID: 165 2025-11-10 09:31:52.468 | Removing historical data download ID 165. 2025-11-10 09:31:52.468 | Real-time Intraday chart data file updates started for ZNZ25_FUT_CME 2025-11-10 09:31:52.468 | Intraday chart data file opened for ZNZ25_FUT_CME 2025-11-10 09:31:52.468 | HD Request # 22 | Enabling Intraday chart updating for symbol. 2025-11-10 09:31:52.468 | 2025-11-10 09:31:52.468 | No download requests in the queue to start downloads for. 2025-11-10 09:31:52.468 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:31:52.468 | DTC Client socket (3) | Closed. 2025-11-10 09:31:52.468 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-11-10 09:31:52.468 | DTC Client socket (2) | Closed. 2025-11-10 09:31:52.843 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:31:52.854 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:31:52.854 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:52.858 | Socket (5) | Socket gracefully closed by remote side. 2025-11-10 09:31:52.858 | Socket (5) | Closed. 2025-11-10 09:31:52.908 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Chart data loading complete. 2025-11-10 09:31:53.613 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:31:53.614 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:53.650 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Chart data loading complete. 2025-11-10 09:31:53.766 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:31:53.769 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:31:53.770 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:53.795 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:31:53.839 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:31:53.852 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:31:53.855 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:31:53.856 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:31:53.878 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:31:53.901 | 2025-11-10 09:31:53.901 | Teton CME Routing | Firm: Dorman 2025-11-10 09:31:53.901 | Teton CME Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 2025-11-10 09:31:53.901 | DTC Client socket (5) | Creating socket. Using TLS 1.2. 2025-11-10 09:31:53.901 | DTC Client socket (5) | New receive buffer size: 0 2025-11-10 09:31:53.901 | DTC Client socket (5) | Connecting to IP: 208.185.224.130. 2025-11-10 09:31:53.916 | Teton CME Routing | Network connection to server complete. 2025-11-10 09:31:53.916 | Teton CME Routing | Starting socket receive thread. 2025-11-10 09:31:53.916 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-11-10 09:31:54.042 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:31:54.937 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Chart data loading complete. 2025-11-10 09:31:58.646 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-11-10 09:31:58.646 | Teton CME Routing | Sending logon request message. 2025-11-10 09:31:58.943 | Teton CME Routing | Received logon response. 2025-11-10 09:31:58.943 | Teton CME Routing | Server Name: SC DTC Server. Build=54268. 2025-11-10 09:31:58.943 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:31:58.943 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-11-10 09:31:58.943 | Teton CME Routing | Trading is supported. 2025-11-10 09:31:58.943 | Teton CME Routing | Order cancel and replace is supported. 2025-11-10 09:31:58.943 | Teton CME Routing | OCO Orders supported. 2025-11-10 09:31:58.943 | Teton CME Routing | Bracket Orders supported. 2025-11-10 09:31:58.943 | Teton CME Routing | MarketDepthIsSupported: 1 2025-11-10 09:31:58.943 | Teton CME Routing | Connection to server complete. 2025-11-10 09:31:58.943 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-11-10 09:31:58.943 | Updated verified funded futures trading account ending date to: 2025-12-10 14:31:58 2025-11-10 09:31:58.950 | Using Bid/Ask average for last trade price for VOLX 2025-11-10 09:31:58.950 | Using symbol data fast lookup vector 2025-11-10 09:31:58.950 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2025-11-10 09:31:58.950 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 2025-11-10 09:31:58.950 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2025-11-10 09:31:58.951 | Added historical Intraday data request for VOLX to the queue. 2025-11-10 09:31:58.951 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2025-11-10 09:31:58.951 | Triggering next historical data download in queue. 2025-11-10 09:31:58.951 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Started historical data download for additional symbol VOLX. Download ID: 170 2025-11-10 09:31:58.951 | DTC Client socket (1) | Creating socket. 2025-11-10 09:31:58.951 | DTC Client socket (1) | New receive buffer size: 0 2025-11-10 09:31:58.951 | DTC Client socket (1) | Connecting to IP: 69.39.70.241. 2025-11-10 09:31:58.955 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2025-11-10 09:31:58.955 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2025-11-10 09:31:58.955 | Added historical Intraday data request for TICK-NYSE to the queue. 2025-11-10 09:31:58.955 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2025-11-10 09:31:58.955 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 171 2025-11-10 09:31:58.955 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2025-11-10 09:31:58.955 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2025-11-10 09:31:58.955 | Added historical Intraday data request for NISS-NYSE to the queue. 2025-11-10 09:31:58.955 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2025-11-10 09:31:58.955 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 172 2025-11-10 09:31:58.955 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2025-11-10 09:31:58.955 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2025-11-10 09:31:58.955 | Added historical Intraday data request for TRIN-NYSE to the queue. 2025-11-10 09:31:58.955 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2025-11-10 09:31:58.955 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 173 2025-11-10 09:31:58.959 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-11-10 09:31:58.959 | Delaying start of download for VOLX. 2025-11-10 09:31:58.959 | SC Data with Depth | Network connection to server complete. 2025-11-10 09:31:58.959 | SC Data with Depth | Starting socket receive thread. 2025-11-10 09:31:58.959 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2025-11-10 09:31:58.969 | Mapping ESZ25_FUT_CME to ESZ25. Service code: cme 2025-11-10 09:31:58.969 | Denali Data Feed | Starting real-time market data updates for: ESZ25_FUT_CME (ESZ25). ID: 5 Service code: cme 2025-11-10 09:31:58.969 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 443 2025-11-10 09:31:58.969 | Denali Data Feed | Requesting security definition data for: ESZ25_FUT_CME (ESZ25). ID: 5 2025-11-10 09:31:58.969 | DTC Client socket (2) | Creating socket. 2025-11-10 09:31:58.969 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-11-07 17:29:53.976000 2025-11-10 09:31:58.969 | DTC Client socket (2) | New receive buffer size: 0 2025-11-10 09:31:58.969 | DTC Client socket (2) | Connecting to IP: 69.39.70.248. 2025-11-10 09:31:58.970 | Denali Data Feed | Network connection to server complete. 2025-11-10 09:31:58.970 | Denali Data Feed | Starting socket receive thread. 2025-11-10 09:31:58.970 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-11-10 09:31:59.000 | Mapping NQZ25_FUT_CME to NQZ25. Service code: cme 2025-11-10 09:31:59.000 | Denali Data Feed | Starting real-time market data updates for: NQZ25_FUT_CME (NQZ25). ID: 6 Service code: cme 2025-11-10 09:31:59.000 | Denali Data Feed | Requesting security definition data for: NQZ25_FUT_CME (NQZ25). ID: 6 2025-11-10 09:31:59.000 | Added historical Intraday data request for NQZ25_FUT_CME to the queue. 2025-11-10 09:31:59.000 | Intraday data recording state for symbol NQZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:59.000 | Triggering next historical data download in queue. 2025-11-10 09:31:59.037 | Mapping MESZ25_FUT_CME to MESZ25. Service code: cme 2025-11-10 09:31:59.037 | Denali Data Feed | Starting real-time market data updates for: MESZ25_FUT_CME (MESZ25). ID: 7 Service code: cme 2025-11-10 09:31:59.037 | Denali Data Feed | Requesting security definition data for: MESZ25_FUT_CME (MESZ25). ID: 7 2025-11-10 09:31:59.037 | Added historical Intraday data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:31:59.037 | Intraday data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:59.037 | Triggering next historical data download in queue. 2025-11-10 09:31:59.082 | Mapping ZNZ25_FUT_CME to ZNZ25. Service code: cbot 2025-11-10 09:31:59.082 | Denali Data Feed | Starting real-time market data updates for: ZNZ25_FUT_CME (ZNZ25). ID: 8 Service code: cbot 2025-11-10 09:31:59.082 | Denali Data Feed | Requesting security definition data for: ZNZ25_FUT_CME (ZNZ25). ID: 8 2025-11-10 09:31:59.082 | Added historical Intraday data request for ZNZ25_FUT_CME to the queue. 2025-11-10 09:31:59.082 | Intraday data recording state for symbol ZNZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:59.082 | Triggering next historical data download in queue. 2025-11-10 09:31:59.085 | Mapping ZBZ25_FUT_CME to ZBZ25. Service code: cbot 2025-11-10 09:31:59.085 | Denali Data Feed | Starting real-time market data updates for: ZBZ25_FUT_CME (ZBZ25). ID: 9 Service code: cbot 2025-11-10 09:31:59.085 | Denali Data Feed | Requesting security definition data for: ZBZ25_FUT_CME (ZBZ25). ID: 9 2025-11-10 09:31:59.085 | Added historical Intraday data request for ZBZ25_FUT_CME to the queue. 2025-11-10 09:31:59.085 | Intraday data recording state for symbol ZBZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:59.149 | Mapping MNQZ25_FUT_CME to MNQZ25. Service code: cme 2025-11-10 09:31:59.149 | Denali Data Feed | Starting real-time market data updates for: MNQZ25_FUT_CME (MNQZ25). ID: 10 Service code: cme 2025-11-10 09:31:59.149 | Denali Data Feed | Requesting security definition data for: MNQZ25_FUT_CME (MNQZ25). ID: 10 2025-11-10 09:31:59.222 | Sending historical data logon request message. 2025-11-10 09:31:59.252 | Updated verified funded futures trading account ending date to: 2025-12-10 14:31:59 2025-11-10 09:31:59.327 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ25_FUT_CME 2025-11-10 09:31:59.327 | Teton CME Routing | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-11-10 09:31:59.327 | Teton CME Routing | Received security definition for symbol ESZ25_FUT_CME 2025-11-10 09:31:59.328 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQZ25_FUT_CME 2025-11-10 09:31:59.328 | Teton CME Routing | Setting external service identifier for symbol NQZ25_FUT_CME to 158704 2025-11-10 09:31:59.328 | Teton CME Routing | Received security definition for symbol NQZ25_FUT_CME 2025-11-10 09:31:59.350 | Mapping RTYZ25_FUT_CME to RTYZ25. Service code: cme 2025-11-10 09:31:59.351 | Denali Data Feed | Starting real-time market data updates for: RTYZ25_FUT_CME (RTYZ25). ID: 11 Service code: cme 2025-11-10 09:31:59.351 | Denali Data Feed | Requesting security definition data for: RTYZ25_FUT_CME (RTYZ25). ID: 11 2025-11-10 09:31:59.351 | Added historical Intraday data request for RTYZ25_FUT_CME to the queue. 2025-11-10 09:31:59.351 | Intraday data recording state for symbol RTYZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:31:59.351 | Triggering next historical data download in queue. 2025-11-10 09:31:59.404 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESZ25_FUT_CME 2025-11-10 09:31:59.404 | Teton CME Routing | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-11-10 09:31:59.404 | Teton CME Routing | Received security definition for symbol MESZ25_FUT_CME 2025-11-10 09:31:59.404 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNZ25_FUT_CME 2025-11-10 09:31:59.404 | Teton CME Routing | Setting external service identifier for symbol ZNZ25_FUT_CME to 42002111 2025-11-10 09:31:59.404 | Teton CME Routing | Received security definition for symbol ZNZ25_FUT_CME 2025-11-10 09:31:59.626 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-11-10 09:31:59.626 | Denali Data Feed | Sending logon request message. 2025-11-10 09:31:59.664 | SC Data with Depth | Setting DTC encoding to Binary VLS 2025-11-10 09:31:59.664 | SC Data with Depth | Sending logon request message. 2025-11-10 09:31:59.804 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBZ25_FUT_CME 2025-11-10 09:31:59.804 | Teton CME Routing | Setting external service identifier for symbol ZBZ25_FUT_CME to 42001597 2025-11-10 09:31:59.804 | Teton CME Routing | Received security definition for symbol ZBZ25_FUT_CME 2025-11-10 09:31:59.804 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQZ25_FUT_CME 2025-11-10 09:31:59.804 | Teton CME Routing | Setting external service identifier for symbol MNQZ25_FUT_CME to 42001149 2025-11-10 09:31:59.804 | Teton CME Routing | Received security definition for symbol MNQZ25_FUT_CME 2025-11-10 09:31:59.969 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYZ25_FUT_CME 2025-11-10 09:31:59.969 | Teton CME Routing | Setting external service identifier for symbol RTYZ25_FUT_CME to 42004289 2025-11-10 09:31:59.969 | Teton CME Routing | Received security definition for symbol RTYZ25_FUT_CME 2025-11-10 09:32:00.194 | SC Data with Depth | Received logon response. 2025-11-10 09:32:00.194 | SC Data with Depth | Server Name: SC Realtime Server. 2025-11-10 09:32:00.194 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:32:00.194 | SC Data with Depth | Successfully connected. 2025-11-10 09:32:00.194 | SC Data with Depth | Trading is not supported. 2025-11-10 09:32:00.194 | SC Data with Depth | MarketDepthIsSupported: 1 2025-11-10 09:32:00.194 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2025-11-10 09:32:00.194 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2025-11-10 09:32:00.194 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2025-11-10 09:32:00.194 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2025-11-10 09:32:00.369 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:32:00.375 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Chart data loading complete. 2025-11-10 09:32:00.563 | Denali Data Feed | Received logon response. 2025-11-10 09:32:00.563 | Denali Data Feed | Server Name: SC Realtime Server. 2025-11-10 09:32:00.563 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-11-10 09:32:00.563 | Denali Data Feed | Successfully connected. 2025-11-10 09:32:00.563 | Denali Data Feed | Trading is not supported. 2025-11-10 09:32:00.563 | Denali Data Feed | MarketDepthIsSupported: 1 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ25_FUT_CME -> ESZ25 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ25_FUT_CME -> MESZ25 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ25_FUT_CME -> MNQZ25 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ25_FUT_CME -> NQZ25 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: RTYZ25_FUT_CME -> RTYZ25 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: ZBZ25_FUT_CME -> ZBZ25 2025-11-10 09:32:00.563 | Denali Data Feed | Restarting real-time data updates for symbol: ZNZ25_FUT_CME -> ZNZ25 2025-11-10 09:32:00.725 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2025-11-10 09:32:00.725 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2025-11-10 09:32:00.725 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2025-11-10 09:32:00.725 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2025-11-10 09:32:00.725 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2025-11-10 09:32:00.725 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2025-11-10 09:32:00.725 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2025-11-10 09:32:00.725 | SC Data with Depth | Received security definition for symbol VOLX 2025-11-10 09:32:01.138 | Added historical Market Depth data request for ESZ25_FUT_CME to the queue. 2025-11-10 09:32:01.138 | Market depth data recording state for symbol ESZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:32:01.138 | Triggering next historical data download in queue. 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. 2025-11-10 09:32:01.138 | Added historical Market Depth data request for NQZ25_FUT_CME to the queue. 2025-11-10 09:32:01.138 | Market depth data recording state for symbol NQZ25_FUT_CME is set to download 'Pending'. 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 1 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 13 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 5 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 7 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 5 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 1 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 1 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 19 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol ESZ25_FUT_CME to 294973 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol ESZ25_FUT_CME 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol MESZ25_FUT_CME to 42004164 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol MESZ25_FUT_CME 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol MNQZ25_FUT_CME to 42001149 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol MNQZ25_FUT_CME 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol NQZ25_FUT_CME to 158704 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol NQZ25_FUT_CME 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol RTYZ25_FUT_CME to 42004289 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol RTYZ25_FUT_CME 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol ZBZ25_FUT_CME to 42001597 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol ZBZ25_FUT_CME 2025-11-10 09:32:01.138 | Denali Data Feed | Setting external service identifier for symbol ZNZ25_FUT_CME to 42002111 2025-11-10 09:32:01.138 | Denali Data Feed | Received security definition for symbol ZNZ25_FUT_CME 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 15 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 1 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 7 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 1 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 1 2025-11-10 09:32:01.138 | Historical Market Depth data request, start 00:00:00.000 , for ESZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 19 2025-11-10 09:32:01.139 | Historical Market Depth data request, start 00:00:00.000 , for NQZ25_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. | Number times message added: 69 2025-11-10 09:32:01.139 | HD Request # 23 | Downloading Market Depth data for ESZ25_FUT_CME. Service: cme.marketdepth. 2025-11-10 09:32:01.140 | HD Request # 23 | Download start date-time: 2025-11-10 09:31:52.466716. 2025-11-10 09:32:01.140 | HD Request # 23 | Using server: ds28.sierracharts.com port 10149 2025-11-10 09:32:01.140 | Socket (3) | Creating socket. 2025-11-10 09:32:01.140 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:01.140 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-11-10 09:32:02.161 | HD Request # 23 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:02.161 | HD Request # 23 | Sending historical data logon request message. 2025-11-10 09:32:03.163 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Chart data loading complete. 2025-11-10 09:32:03.390 | HD Request # 23 | Requesting market depth data. Start date-time: 2025-11-10 09:31:52. Symbol: ESZ25 2025-11-10 09:32:03.975 | Requesting market depth updates for: ESZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:32:03.975 | Requesting market depth updates for: NQZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:32:03.975 | Requesting market depth updates for: ZBZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:32:03.975 | Requesting market depth updates for: ZNZ25_FUT_CME if supported. NumLevels=200 2025-11-10 09:32:04.148 | HD Request # 23 | Decompressing data. 2025-11-10 09:32:04.234 | HD Request # 23 | Receiving market depth data for ESZ25_FUT_CME starting at 2025-11-10 09:31:52.506000 2025-11-10 09:32:05.111 | HD Request # 24 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2025-11-10 09:32:05.111 | HD Request # 24 | Download start date-time: 2025-11-10 09:31:51.000000. File last date-time: 2025-11-10 09:31:51.149000 2025-11-10 09:32:05.111 | HD Request # 24 | Using server: ds12.sierracharts.com port 10150 2025-11-10 09:32:05.111 | Socket (9) | Creating socket. 2025-11-10 09:32:05.111 | Socket (9) | New receive buffer size: 0 2025-11-10 09:32:05.111 | Socket (9) | Connecting to IP: 69.39.70.241. 2025-11-10 09:32:05.777 | Socket (3) | CloseSocket call. 2025-11-10 09:32:05.777 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:05.778 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:05.778 | Socket (3) | Closed. 2025-11-10 09:32:05.778 | Historical data download thread signaled to stop. 2025-11-10 09:32:05.779 | HD Request # 23 | Timestamp of first market depth data file record written: 2025-11-10 09:31:52.506000. 2025-11-10 09:32:05.779 | HD Request # 23 | Received 11097 Market Depth data records from 2025-11-10 09:31:52.506000 to 2025-11-10 09:32:02.508000 (10.0 seconds. Delay: 3.3 seconds) and wrote 11097 records for ESZ25_FUT_CME 2025-11-10 09:32:05.779 | HD Request # 23 | Completion time: 4s. 2025-11-10 09:32:05.779 | HD Request # 23 | Market Depth data download complete for ESZ25_FUT_CME. Unique request ID: 179 2025-11-10 09:32:05.779 | Removing historical data download ID 179. 2025-11-10 09:32:05.779 | Real-time market depth file updates started for ESZ25_FUT_CME 2025-11-10 09:32:05.786 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:32:05.786 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME [CV][M] #4 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.786 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.787 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.787 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:05.787 | 2025-11-10 09:32:05.787 | Triggering next historical data download in queue. 2025-11-10 09:32:05.787 | HD Request # 25 | Downloading Market Depth data for NQZ25_FUT_CME. Service: cme.marketdepth. 2025-11-10 09:32:05.787 | HD Request # 25 | Download start date-time: 2025-11-10 09:31:52.467444. 2025-11-10 09:32:05.788 | HD Request # 25 | Using server: ds26.sierracharts.com port 10150 2025-11-10 09:32:05.788 | Socket (3) | Creating socket. 2025-11-10 09:32:05.788 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:05.788 | Socket (3) | Connecting to IP: 64.152.155.17. 2025-11-10 09:32:05.862 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Reloading chart. 2025-11-10 09:32:05.869 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:05.871 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Reloading chart. 2025-11-10 09:32:05.887 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:05.887 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Reloading chart. 2025-11-10 09:32:05.913 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:05.937 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Reloading chart. 2025-11-10 09:32:05.938 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:05.962 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Reloading chart. 2025-11-10 09:32:05.968 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:05.971 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:32:05.978 | ESZ25_FUT_CME [CV][M] #4 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:06.008 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Reloading chart. 2025-11-10 09:32:06.008 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:06.081 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Reloading chart. 2025-11-10 09:32:06.087 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:06.175 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Reloading chart. 2025-11-10 09:32:06.175 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:06.176 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Reloading chart. 2025-11-10 09:32:06.202 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:06.272 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Reloading chart. 2025-11-10 09:32:06.288 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Waiting for historical downloads to complete with the IDs: 175, 2025-11-10 09:32:06.324 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Chart data loading complete. 2025-11-10 09:32:06.390 | HD Request # 25 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:06.390 | HD Request # 25 | Sending historical data logon request message. 2025-11-10 09:32:06.696 | HD Request # 25 | Requesting market depth data. Start date-time: 2025-11-10 09:31:52. Symbol: NQZ25 2025-11-10 09:32:07.001 | HD Request # 25 | Decompressing data. 2025-11-10 09:32:07.643 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:32:10.211 | HD Request # 25 | Receiving market depth data for NQZ25_FUT_CME starting at 2025-11-10 09:31:52.478000 2025-11-10 09:32:11.434 | Denali Data Feed | Clearing market depth for ESZ25_FUT_CME 2025-11-10 09:32:11.434 | Denali Data Feed | Market Depth data has been rejected for symbol: ZBZ25_FUT_CME. Not authorized for market depth. 2025-11-10 09:32:11.434 | Denali Data Feed | Clearing market depth for NQZ25_FUT_CME 2025-11-10 09:32:11.434 | Denali Data Feed | Market Depth data has been rejected for symbol: ZNZ25_FUT_CME. Not authorized for market depth. 2025-11-10 09:32:15.110 | HD Request # 24 | Sending historical data logon request message. 2025-11-10 09:32:17.280 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:32:17.280 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:32:17.280 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:32:17.280 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:32:17.387 | NTP Client | Received Packet | RoundTripDelay=0.10597753524780273, SystemClockOffset=-0.009048223495483398 2025-11-10 09:32:17.398 | Socket (3) | CloseSocket call. 2025-11-10 09:32:17.398 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:17.399 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:17.399 | Socket (3) | Closed. 2025-11-10 09:32:17.402 | NTP Client | Received Packet | RoundTripDelay=0.12079906463623047, SystemClockOffset=-0.004574775695800781 2025-11-10 09:32:17.411 | Historical data download thread signaled to stop. 2025-11-10 09:32:17.412 | HD Request # 25 | Timestamp of first market depth data file record written: 2025-11-10 09:31:52.478000. 2025-11-10 09:32:17.412 | HD Request # 25 | Received 27651 Market Depth data records from 2025-11-10 09:31:52.478000 to 2025-11-10 09:32:05.367000 (12.9 seconds. Delay: 12.0 seconds) and wrote 27651 records for NQZ25_FUT_CME 2025-11-10 09:32:17.412 | HD Request # 25 | Completion time: 12s. 2025-11-10 09:32:17.412 | HD Request # 25 | Market Depth data download complete for NQZ25_FUT_CME. Unique request ID: 181 2025-11-10 09:32:17.412 | Removing historical data download ID 181. 2025-11-10 09:32:17.412 | Real-time market depth file updates started for NQZ25_FUT_CME 2025-11-10 09:32:17.418 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:32:17.418 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:17.418 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:17.418 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:17.418 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:17.418 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:17.418 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2025-11-10 09:32:17.418 | 2025-11-10 09:32:17.418 | No download requests in the queue to start downloads for. 2025-11-10 09:32:17.455 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Reloading chart. 2025-11-10 09:32:17.456 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 174, 2025-11-10 09:32:17.459 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:32:17.460 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 174, 2025-11-10 09:32:17.468 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Reloading chart. 2025-11-10 09:32:17.474 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 174, 2025-11-10 09:32:17.478 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Reloading chart. 2025-11-10 09:32:17.484 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 174, 2025-11-10 09:32:17.582 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Reloading chart. 2025-11-10 09:32:17.582 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 174, 2025-11-10 09:32:17.689 | NTP Client | Received Packet | RoundTripDelay=0.40796375274658203, SystemClockOffset=0.02440643310546875 2025-11-10 09:32:17.880 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Reloading chart. 2025-11-10 09:32:17.880 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Waiting for historical downloads to complete with the IDs: 174, 2025-11-10 09:32:18.278 | NTP Client | Performed system clock adjustment of -4574.775695800781 microseconds. 2025-11-10 09:32:20.819 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NQZ25_FUT_CME.2025-11-10.depth 2025-11-10 09:32:21.699 | HD Request # 24 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:21.699 | HD Request # 24 | Sending historical data logon request message. 2025-11-10 09:32:21.699 | Socket (9) | CloseSocket call. 2025-11-10 09:32:21.699 | Socket (9) | Write in progress. Shutdown being delayed. PendingSize=0 2025-11-10 09:32:21.700 | Socket (9) | Write has completed. Shutdown being performed. 2025-11-10 09:32:21.700 | Socket (9) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:21.701 | Socket (9) | Socket gracefully closed by remote side. 2025-11-10 09:32:21.701 | Socket (9) | Closed. 2025-11-10 09:32:21.701 | HD Request # 24 | Error downloading historical Intraday data for VOLX. Historical data logon error: Unsupported protocol version 2025-11-10 09:32:21.702 | Historical data download thread signaled to stop. 2025-11-10 09:32:21.702 | HD Request # 24 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for VOLX 2025-11-10 09:32:21.702 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:51.149000 2025-11-10 09:32:21.702 | HD Request # 24 | Receiving Intraday data for VOLX starting at 2025-11-10 09:32:00.339000 2025-11-10 09:32:21.702 | Added 23 Time and Sales records to Intraday data file for VOLX after download. 2025-11-10 09:32:21.702 | HD Request # 24 | Timestamp of first Intraday data file record written: 2025-11-10 09:32:00.339000. 2025-11-10 09:32:21.702 | HD Request # 24 | Completion time: 16s. 2025-11-10 09:32:21.702 | HD Request # 24 | Intraday data download complete for VOLX. Unique request ID: 170 2025-11-10 09:32:21.702 | Removing historical data download ID 170. 2025-11-10 09:32:21.702 | Real-time Intraday chart data file updates started for VOLX 2025-11-10 09:32:21.702 | Intraday chart data file opened for VOLX 2025-11-10 09:32:21.702 | HD Request # 24 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:21.702 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Historical data download for additional symbol VOLX with ID 170 has completed. 2025-11-10 09:32:21.702 | 2025-11-10 09:32:21.702 | Triggering next historical data download in queue. 2025-11-10 09:32:21.702 | HD Request # 26 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2025-11-10 09:32:21.703 | HD Request # 26 | Download start date-time: 2025-11-10 09:31:51.000000. File last date-time: 2025-11-10 09:31:51.456001 2025-11-10 09:32:21.703 | HD Request # 26 | Using server: ds4.sierracharts.com port 10149 2025-11-10 09:32:21.703 | Socket (3) | Creating socket. 2025-11-10 09:32:21.703 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:21.703 | Socket (3) | Connecting to IP: 64.152.155.113. 2025-11-10 09:32:22.537 | Opened cached Intraday file: C:\SierraChart\Data\VOLX.scid. Thread ID: 15288 2025-11-10 09:32:25.374 | HD Request # 26 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:25.374 | HD Request # 26 | Sending historical data logon request message. 2025-11-10 09:32:25.703 | HD Request # 26 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:51. Record interval: 0. Symbol: TICK-NYSE 2025-11-10 09:32:26.080 | HD Request # 26 | Decompressing data. 2025-11-10 09:32:26.209 | HD Request # 26 | Receiving Intraday data for TICK-NYSE starting at 2025-11-10 09:31:51.000000 2025-11-10 09:32:26.210 | Socket (3) | CloseSocket call. 2025-11-10 09:32:26.210 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:26.211 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:26.211 | Socket (3) | Closed. 2025-11-10 09:32:26.213 | Historical data download thread signaled to stop. 2025-11-10 09:32:26.213 | HD Request # 26 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:52.000000. 2025-11-10 09:32:26.213 | HD Request # 26 | Received 33 Intraday data records from 2025-11-10 09:31:51.000000 to 2025-11-10 09:32:23.000000 (32.0 seconds. Delay: 3.2 seconds) and wrote 32 records for TICK-NYSE 2025-11-10 09:32:26.222 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:32:23.000000 2025-11-10 09:32:26.222 | Added 30 Time and Sales records to Intraday data file for TICK-NYSE after download. 2025-11-10 09:32:26.223 | HD Request # 26 | Completion time: 5s. 2025-11-10 09:32:26.223 | HD Request # 26 | Intraday data download complete for TICK-NYSE. Unique request ID: 171 2025-11-10 09:32:26.223 | Removing historical data download ID 171. 2025-11-10 09:32:26.223 | Real-time Intraday chart data file updates started for TICK-NYSE 2025-11-10 09:32:26.223 | Intraday chart data file opened for TICK-NYSE 2025-11-10 09:32:26.223 | HD Request # 26 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:26.223 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 171 has completed. 2025-11-10 09:32:26.223 | 2025-11-10 09:32:26.223 | Triggering next historical data download in queue. 2025-11-10 09:32:26.223 | HD Request # 27 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2025-11-10 09:32:26.223 | HD Request # 27 | Download start date-time: 2025-11-10 09:31:51.000000. File last date-time: 2025-11-10 09:31:51.456000 2025-11-10 09:32:26.223 | HD Request # 27 | Using server: ds12.sierracharts.com port 10150 2025-11-10 09:32:26.223 | Socket (3) | Creating socket. 2025-11-10 09:32:26.223 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:26.223 | Socket (3) | Connecting to IP: 69.39.70.241. 2025-11-10 09:32:27.553 | Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 15288 2025-11-10 09:32:28.414 | HD Request # 27 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:28.414 | HD Request # 27 | Sending historical data logon request message. 2025-11-10 09:32:28.764 | HD Request # 27 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:51. Record interval: 0. Symbol: NISS-NYSE 2025-11-10 09:32:29.098 | HD Request # 27 | Decompressing data. 2025-11-10 09:32:29.360 | HD Request # 27 | Receiving Intraday data for NISS-NYSE starting at 2025-11-10 09:31:51.000000 2025-11-10 09:32:29.360 | Socket (3) | CloseSocket call. 2025-11-10 09:32:29.360 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:29.360 | Historical data download thread signaled to stop. 2025-11-10 09:32:29.361 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:29.361 | HD Request # 27 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:52.000000. 2025-11-10 09:32:29.361 | Socket (3) | Closed. 2025-11-10 09:32:29.361 | HD Request # 27 | Received 36 Intraday data records from 2025-11-10 09:31:51.000000 to 2025-11-10 09:32:26.000000 (35.0 seconds. Delay: 3.4 seconds) and wrote 35 records for NISS-NYSE 2025-11-10 09:32:29.368 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:32:26.000000 2025-11-10 09:32:29.368 | Added 19 Time and Sales records to Intraday data file for NISS-NYSE after download. 2025-11-10 09:32:29.368 | HD Request # 27 | Completion time: 3s. 2025-11-10 09:32:29.368 | HD Request # 27 | Intraday data download complete for NISS-NYSE. Unique request ID: 172 2025-11-10 09:32:29.368 | Removing historical data download ID 172. 2025-11-10 09:32:29.368 | Real-time Intraday chart data file updates started for NISS-NYSE 2025-11-10 09:32:29.368 | Intraday chart data file opened for NISS-NYSE 2025-11-10 09:32:29.368 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:29.368 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 172 has completed. 2025-11-10 09:32:29.368 | 2025-11-10 09:32:29.368 | Triggering next historical data download in queue. 2025-11-10 09:32:29.369 | HD Request # 28 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2025-11-10 09:32:29.369 | HD Request # 28 | Download start date-time: 2025-11-10 09:31:51.000000. File last date-time: 2025-11-10 09:31:51.456001 2025-11-10 09:32:29.369 | HD Request # 28 | Using server: ds4.sierracharts.com port 10149 2025-11-10 09:32:29.369 | Socket (3) | Creating socket. 2025-11-10 09:32:29.369 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:29.369 | Socket (3) | Connecting to IP: 64.152.155.113. 2025-11-10 09:32:31.337 | HD Request # 28 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:31.337 | HD Request # 28 | Sending historical data logon request message. 2025-11-10 09:32:31.773 | HD Request # 28 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:51. Record interval: 0. Symbol: TRIN-NYSE 2025-11-10 09:32:32.109 | HD Request # 28 | Decompressing data. 2025-11-10 09:32:32.562 | Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid. Thread ID: 15288 2025-11-10 09:32:33.744 | HD Request # 28 | Receiving Intraday data for TRIN-NYSE starting at 2025-11-10 09:31:51.000000 2025-11-10 09:32:33.745 | Socket (3) | CloseSocket call. 2025-11-10 09:32:33.745 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:33.746 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:33.746 | Socket (3) | Closed. 2025-11-10 09:32:33.746 | Historical data download thread signaled to stop. 2025-11-10 09:32:33.747 | HD Request # 28 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:52.000000. 2025-11-10 09:32:33.747 | HD Request # 28 | Received 41 Intraday data records from 2025-11-10 09:31:51.000000 to 2025-11-10 09:32:31.000000 (40.0 seconds. Delay: 2.7 seconds) and wrote 40 records for TRIN-NYSE 2025-11-10 09:32:33.758 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:32:31.000000 2025-11-10 09:32:33.758 | Added 21 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2025-11-10 09:32:33.758 | HD Request # 28 | Completion time: 4s. 2025-11-10 09:32:33.758 | HD Request # 28 | Intraday data download complete for TRIN-NYSE. Unique request ID: 173 2025-11-10 09:32:33.758 | Removing historical data download ID 173. 2025-11-10 09:32:33.758 | Real-time Intraday chart data file updates started for TRIN-NYSE 2025-11-10 09:32:33.758 | Intraday chart data file opened for TRIN-NYSE 2025-11-10 09:32:33.758 | HD Request # 28 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:33.758 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 173 has completed. 2025-11-10 09:32:33.758 | 2025-11-10 09:32:33.758 | Triggering next historical data download in queue. 2025-11-10 09:32:33.758 | HD Request # 29 | Downloading Intraday chart data for NQZ25_FUT_CME to the file NQZ25_FUT_CME.scid. Service: cme 2025-11-10 09:32:33.758 | HD Request # 29 | Download start date-time: 2025-11-10 09:31:31.000000. File last date-time: 2025-11-10 09:31:31.432000 2025-11-10 09:32:33.758 | HD Request # 29 | Using server: ds32.sierracharts.com port 10150 2025-11-10 09:32:33.758 | Socket (3) | Creating socket. 2025-11-10 09:32:33.758 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:33.758 | Socket (3) | Connecting to IP: 69.39.70.248. 2025-11-10 09:32:37.574 | Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 15288 2025-11-10 09:32:43.755 | HD Request # 29 | Sending historical data logon request message. 2025-11-10 09:32:50.379 | HD Request # 29 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:50.379 | HD Request # 29 | Sending historical data logon request message. 2025-11-10 09:32:50.379 | Socket (3) | CloseSocket call. 2025-11-10 09:32:50.379 | Socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 2025-11-10 09:32:50.379 | Socket (3) | Write has completed. Shutdown being performed. 2025-11-10 09:32:50.379 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:50.380 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:50.380 | Socket (3) | Closed. 2025-11-10 09:32:50.413 | HD Request # 29 | Error downloading historical Intraday data for NQZ25_FUT_CME. Historical data logon error: Unsupported protocol version 2025-11-10 09:32:50.413 | Historical data download thread signaled to stop. 2025-11-10 09:32:50.413 | HD Request # 29 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQZ25_FUT_CME 2025-11-10 09:32:50.414 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:31:31.432000 2025-11-10 09:32:50.414 | HD Request # 29 | Receiving Intraday data for NQZ25_FUT_CME starting at 2025-11-10 09:32:19.535000 2025-11-10 09:32:50.414 | Added 34 Time and Sales records to Intraday data file for NQZ25_FUT_CME after download. 2025-11-10 09:32:50.414 | HD Request # 29 | Timestamp of first Intraday data file record written: 2025-11-10 09:32:19.535000. 2025-11-10 09:32:50.414 | HD Request # 29 | Completion time: 17s. 2025-11-10 09:32:50.414 | HD Request # 29 | Intraday data download complete for NQZ25_FUT_CME. Unique request ID: 174 2025-11-10 09:32:50.414 | Removing historical data download ID 174. 2025-11-10 09:32:50.414 | Real-time Intraday chart data file updates started for NQZ25_FUT_CME 2025-11-10 09:32:50.414 | Intraday chart data file opened for NQZ25_FUT_CME 2025-11-10 09:32:50.414 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:50.422 | 2025-11-10 09:32:50.422 | Triggering next historical data download in queue. 2025-11-10 09:32:50.422 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:50.422 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Reloading chart. 2025-11-10 09:32:50.423 | HD Request # 30 | Downloading Intraday chart data for ESZ25_FUT_CME to the file ESZ25_FUT_CME.scid. Service: cme 2025-11-10 09:32:50.423 | HD Request # 30 | Download start date-time: 2025-11-10 09:31:31.000000. File last date-time: 2025-11-10 09:31:31.432006 2025-11-10 09:32:50.423 | HD Request # 30 | Using server: ds28.sierracharts.com port 10149 2025-11-10 09:32:50.423 | Socket (3) | Creating socket. 2025-11-10 09:32:50.423 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:50.423 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-11-10 09:32:50.454 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:50.454 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Reloading chart. 2025-11-10 09:32:50.482 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:50.483 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:32:50.565 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Reloading chart. 2025-11-10 09:32:50.593 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:50.594 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Reloading chart. 2025-11-10 09:32:50.625 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:50.625 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Reloading chart. 2025-11-10 09:32:50.715 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:50.715 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Chart data loading complete. 2025-11-10 09:32:50.778 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Chart data loading complete. 2025-11-10 09:32:50.780 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:32:50.787 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Chart data loading complete. 2025-11-10 09:32:50.787 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:50.788 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Reloading chart. 2025-11-10 09:32:50.814 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:50.814 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:50.814 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Chart data loading complete. 2025-11-10 09:32:50.942 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Reloading chart. 2025-11-10 09:32:50.989 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Reloading chart. 2025-11-10 09:32:51.017 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:32:51.018 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:51.029 | HD Request # 30 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:51.029 | HD Request # 30 | Sending historical data logon request message. 2025-11-10 09:32:51.035 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Chart data loading complete. 2025-11-10 09:32:51.086 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Reloading chart. 2025-11-10 09:32:51.115 | NQZ25_FUT_CME [CV][M] 30 Sec #12 | Chart data loading complete. 2025-11-10 09:32:51.202 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:51.202 | NQZ25_FUT_CME [C][M] 30 Sec #14 | Chart data loading complete. 2025-11-10 09:32:51.357 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Reloading chart. 2025-11-10 09:32:51.423 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Reloading chart. 2025-11-10 09:32:51.669 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Chart data loading complete. 2025-11-10 09:32:51.708 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 1 Min #11 | Chart data loading complete. 2025-11-10 09:32:51.829 | HD Request # 30 | Requesting Intraday data. Start date-time: 2025-11-10 09:31:31. Record interval: 0. Symbol: ESZ25 2025-11-10 09:32:52.268 | HD Request # 30 | Decompressing data. 2025-11-10 09:32:52.329 | HD Request # 30 | Receiving Intraday data for ESZ25_FUT_CME starting at 2025-11-10 09:31:31.007000 2025-11-10 09:32:52.587 | Opened cached Intraday file: C:\SierraChart\Data\NQZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:32:52.772 | Socket (3) | CloseSocket call. 2025-11-10 09:32:52.772 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:52.773 | Historical data download thread signaled to stop. 2025-11-10 09:32:52.773 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:52.773 | Socket (3) | Closed. 2025-11-10 09:32:52.773 | HD Request # 30 | Timestamp of first Intraday data file record written: 2025-11-10 09:31:31.544000. 2025-11-10 09:32:52.773 | HD Request # 30 | Received 7309 Intraday data records from 2025-11-10 09:31:31.007000 to 2025-11-10 09:32:51.448000 (80.4 seconds. Delay: 1.3 seconds) and wrote 7249 records for ESZ25_FUT_CME 2025-11-10 09:32:52.781 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:32:51.448000 2025-11-10 09:32:52.781 | HD Request # 30 | Completion time: 2s. 2025-11-10 09:32:52.781 | HD Request # 30 | Intraday data download complete for ESZ25_FUT_CME. Unique request ID: 175 2025-11-10 09:32:52.781 | Removing historical data download ID 175. 2025-11-10 09:32:52.781 | Real-time Intraday chart data file updates started for ESZ25_FUT_CME 2025-11-10 09:32:52.781 | Intraday chart data file opened for ESZ25_FUT_CME 2025-11-10 09:32:52.781 | HD Request # 30 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:52.781 | 2025-11-10 09:32:52.781 | Triggering next historical data download in queue. 2025-11-10 09:32:52.781 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.781 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Reloading chart. 2025-11-10 09:32:52.787 | HD Request # 31 | Downloading Intraday chart data for ZNZ25_FUT_CME to the file ZNZ25_FUT_CME.scid. Service: cbot 2025-11-10 09:32:52.788 | HD Request # 31 | Download start date-time: 2025-11-10 09:30:07.000000. File last date-time: 2025-11-10 09:30:07.764000 2025-11-10 09:32:52.788 | HD Request # 31 | Using server: ds26.sierracharts.com port 10150 2025-11-10 09:32:52.788 | Socket (3) | Creating socket. 2025-11-10 09:32:52.788 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:52.788 | Socket (3) | Connecting to IP: 64.152.155.17. 2025-11-10 09:32:52.839 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.840 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Reloading chart. 2025-11-10 09:32:52.871 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.872 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Reloading chart. 2025-11-10 09:32:52.902 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.904 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Reloading chart. 2025-11-10 09:32:52.964 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.965 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Reloading chart. 2025-11-10 09:32:52.981 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.981 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Reloading chart. 2025-11-10 09:32:52.983 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Reloading chart. 2025-11-10 09:32:52.998 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:52.998 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Reloading chart. 2025-11-10 09:32:53.014 | ESZ25_FUT_CME [CV][M] #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:53.015 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:32:53.159 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Reloading chart. 2025-11-10 09:32:53.171 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:53.173 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Reloading chart. 2025-11-10 09:32:53.174 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:53.175 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Reloading chart. 2025-11-10 09:32:53.194 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Reloading chart. 2025-11-10 09:32:53.331 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Reloading chart. 2025-11-10 09:32:53.338 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2025-11-09 18:00:00 2025-11-10 09:32:53.342 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:32:53.343 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:53.375 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Chart data loading complete. 2025-11-10 09:32:53.451 | + Loading additional symbol data. 2025-11-10 09:32:53.453 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-11-10 09:32:53.454 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Reloading chart. 2025-11-10 09:32:53.464 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Reloading chart. 2025-11-10 09:32:53.504 | + Loading additional symbol data. | Number times message added: 1 2025-11-10 09:32:53.603 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Reloading chart. 2025-11-10 09:32:53.615 | ESZ25_FUT_CME [CV][M] #4 | Reloading chart. 2025-11-10 09:32:53.672 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:53.672 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Chart data loading complete. 2025-11-10 09:32:53.678 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:53.678 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:53.678 | ESZ25_FUT_CME [CV][M] 30 Sec #5 | Chart data loading complete. 2025-11-10 09:32:53.692 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Reloading chart. 2025-11-10 09:32:53.693 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Reloading chart. 2025-11-10 09:32:53.784 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Reloading chart. 2025-11-10 09:32:53.861 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:32:53.876 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Chart data loading complete. 2025-11-10 09:32:53.960 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Reloading chart. 2025-11-10 09:32:53.991 | ESZ25_FUT_CME [C][M] 30 Sec #6 | Chart data loading complete. 2025-11-10 09:32:54.266 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:32:54.267 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:32:54.303 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #8 | Chart data loading complete. 2025-11-10 09:32:54.621 | + Loading additional symbol data. 2025-11-10 09:32:54.658 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:32:54.707 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 1 Min #4 | Chart data loading complete. 2025-11-10 09:32:56.565 | ESZ25_FUT_CME [CV][M] #4 | StartDateTimeForLoadingOrderFills: 2024-11-03 00:00:00 2025-11-10 09:32:56.572 | ESZ25_FUT_CME [CV][M] #4 | Chart data loading complete. 2025-11-10 09:32:56.953 | HD Request # 31 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:56.953 | HD Request # 31 | Sending historical data logon request message. 2025-11-10 09:32:57.590 | Opened cached Intraday file: C:\SierraChart\Data\ESZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:32:57.840 | HD Request # 31 | Requesting Intraday data. Start date-time: 2025-11-10 09:30:07. Record interval: 0. Symbol: ZNZ25 2025-11-10 09:32:58.264 | HD Request # 31 | Decompressing data. 2025-11-10 09:32:58.508 | HD Request # 31 | Receiving Intraday data for ZNZ25_FUT_CME starting at 2025-11-10 09:30:07.764000 2025-11-10 09:32:58.707 | Socket (3) | CloseSocket call. 2025-11-10 09:32:58.707 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:32:58.708 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:32:58.708 | Socket (3) | Closed. 2025-11-10 09:32:58.716 | Historical data download thread signaled to stop. 2025-11-10 09:32:58.716 | HD Request # 31 | Timestamp of first Intraday data file record written: 2025-11-10 09:30:13.635000. 2025-11-10 09:32:58.716 | HD Request # 31 | Received 2147 Intraday data records from 2025-11-10 09:30:07.764000 to 2025-11-10 09:32:45.080000 (2.6 minutes. Delay: 13.6 seconds) and wrote 2146 records for ZNZ25_FUT_CME 2025-11-10 09:32:58.723 | HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:32:45.080000 2025-11-10 09:32:58.723 | HD Request # 31 | Completion time: 6s. 2025-11-10 09:32:58.723 | HD Request # 31 | Intraday data download complete for ZNZ25_FUT_CME. Unique request ID: 176 2025-11-10 09:32:58.723 | Removing historical data download ID 176. 2025-11-10 09:32:58.723 | Real-time Intraday chart data file updates started for ZNZ25_FUT_CME 2025-11-10 09:32:58.723 | Intraday chart data file opened for ZNZ25_FUT_CME 2025-11-10 09:32:58.723 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2025-11-10 09:32:58.723 | 2025-11-10 09:32:58.723 | Triggering next historical data download in queue. 2025-11-10 09:32:58.724 | HD Request # 32 | Downloading Intraday chart data for ZBZ25_FUT_CME to the file ZBZ25_FUT_CME.scid. Service: cbot 2025-11-10 09:32:58.724 | HD Request # 32 | Download start date-time: 2025-11-10 09:30:07.000000. File last date-time: 2025-11-10 09:30:07.358000 2025-11-10 09:32:58.724 | HD Request # 32 | Using server: ds32.sierracharts.com port 10149 2025-11-10 09:32:58.724 | Socket (3) | Creating socket. 2025-11-10 09:32:58.724 | Socket (3) | New receive buffer size: 0 2025-11-10 09:32:58.724 | Socket (3) | Connecting to IP: 69.39.70.248. 2025-11-10 09:32:59.694 | HD Request # 32 | Setting DTC encoding to Binary VLS 2025-11-10 09:32:59.694 | HD Request # 32 | Sending historical data logon request message. 2025-11-10 09:33:00.025 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2025-11-10 09:33:00.031 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:33:00.031 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:33:00.063 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] 30 Min #1 | Chart data loading complete. 2025-11-10 09:33:00.134 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:33:00.187 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:33:00.190 | ESZ25_FUT_CME/MESZ25_FUT_CME [C][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:33:00.191 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:33:00.251 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:33:00.254 | NQZ25_FUT_CME/MNQZ25_FUT_CME [C][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:33:00.255 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2025-11-10 09:33:00.271 | NQZ25_FUT_CME/MNQZ25_FUT_CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:33:00.328 | ESZ25_FUT_CME/MESZ25_FUT_CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2025-11-10 09:33:01.119 | HD Request # 32 | Requesting Intraday data. Start date-time: 2025-11-10 09:30:07. Record interval: 0. Symbol: ZBZ25 2025-11-10 09:33:01.739 | HD Request # 32 | Decompressing data. 2025-11-10 09:33:02.098 | ESZ25_FUT_CME [CV][M] 60 Min #3 | Chart data loading complete. 2025-11-10 09:33:03.598 | HD Request # 32 | Receiving Intraday data for ZBZ25_FUT_CME starting at 2025-11-10 09:30:07.358000 2025-11-10 09:33:03.599 | Socket (3) | CloseSocket call. 2025-11-10 09:33:03.599 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:33:03.599 | Historical data download thread signaled to stop. 2025-11-10 09:33:03.599 | HD Request # 32 | Timestamp of first Intraday data file record written: 2025-11-10 09:30:21.551000. 2025-11-10 09:33:03.599 | HD Request # 32 | Received 291 Intraday data records from 2025-11-10 09:30:07.358000 to 2025-11-10 09:32:48.506000 (2.7 minutes. Delay: 15.1 seconds) and wrote 290 records for ZBZ25_FUT_CME 2025-11-10 09:33:03.599 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:33:03.599 | Socket (3) | Closed. 2025-11-10 09:33:03.606 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:32:48.506000 2025-11-10 09:33:03.606 | HD Request # 32 | Completion time: 5s. 2025-11-10 09:33:03.606 | HD Request # 32 | Intraday data download complete for ZBZ25_FUT_CME. Unique request ID: 177 2025-11-10 09:33:03.606 | Removing historical data download ID 177. 2025-11-10 09:33:03.606 | Real-time Intraday chart data file updates started for ZBZ25_FUT_CME 2025-11-10 09:33:03.606 | Intraday chart data file opened for ZBZ25_FUT_CME 2025-11-10 09:33:03.606 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2025-11-10 09:33:03.606 | 2025-11-10 09:33:03.606 | Triggering next historical data download in queue. 2025-11-10 09:33:03.606 | HD Request # 33 | Downloading Intraday chart data for RTYZ25_FUT_CME to the file RTYZ25_FUT_CME.scid. Service: cme 2025-11-10 09:33:03.607 | HD Request # 33 | Download start date-time: 2025-11-10 09:30:09.000000. File last date-time: 2025-11-10 09:30:09.903001 2025-11-10 09:33:03.607 | HD Request # 33 | Using server: ds28.sierracharts.com port 10150 2025-11-10 09:33:03.607 | Socket (3) | Creating socket. 2025-11-10 09:33:03.607 | Socket (3) | New receive buffer size: 0 2025-11-10 09:33:03.607 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-11-10 09:33:05.058 | HD Request # 33 | Setting DTC encoding to Binary VLS 2025-11-10 09:33:05.058 | HD Request # 33 | Sending historical data logon request message. 2025-11-10 09:33:07.292 | HD Request # 33 | Requesting Intraday data. Start date-time: 2025-11-10 09:30:09. Record interval: 0. Symbol: RTYZ25 2025-11-10 09:33:08.137 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Study: Google Sheets Importer | Making HTTP request. 2025-11-10 09:33:08.143 | ESZ25_FUT_CME [CV][M] 30 Min #10 | Chart data loading complete. 2025-11-10 09:33:09.106 | HD Request # 33 | Decompressing data. 2025-11-10 09:33:09.157 | HD Request # 33 | Receiving Intraday data for RTYZ25_FUT_CME starting at 2025-11-10 09:30:09.026000 2025-11-10 09:33:10.466 | Socket (3) | CloseSocket call. 2025-11-10 09:33:10.466 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-11-10 09:33:10.467 | Historical data download thread signaled to stop. 2025-11-10 09:33:10.467 | Socket (3) | Socket gracefully closed by remote side. 2025-11-10 09:33:10.467 | Socket (3) | Closed. 2025-11-10 09:33:10.467 | HD Request # 33 | Timestamp of first Intraday data file record written: 2025-11-10 09:30:10.030000. 2025-11-10 09:33:10.467 | HD Request # 33 | Received 6136 Intraday data records from 2025-11-10 09:30:09.026000 to 2025-11-10 09:33:07.600000 (3.0 minutes. Delay: 2.9 seconds) and wrote 6057 records for RTYZ25_FUT_CME 2025-11-10 09:33:10.474 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2025-11-10 14:33:07.600000 2025-11-10 09:33:10.474 | HD Request # 33 | Completion time: 7s. 2025-11-10 09:33:10.474 | HD Request # 33 | Intraday data download complete for RTYZ25_FUT_CME. Unique request ID: 178 2025-11-10 09:33:10.474 | Removing historical data download ID 178. 2025-11-10 09:33:10.474 | Real-time Intraday chart data file updates started for RTYZ25_FUT_CME 2025-11-10 09:33:10.474 | Intraday chart data file opened for RTYZ25_FUT_CME 2025-11-10 09:33:10.474 | HD Request # 33 | Enabling Intraday chart updating for symbol. 2025-11-10 09:33:10.474 | 2025-11-10 09:33:10.474 | No download requests in the queue to start downloads for. 2025-11-10 09:33:11.225 | ESZ25_FUT_CME [CV][M] 240 Min #2 | Chart data loading complete. 2025-11-10 09:33:12.612 | Opened cached Intraday file: C:\SierraChart\Data\RTYZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:33:14.246 | ESZ25_FUT_CME [CV][M] 1 Day #1 | Chart data loading complete. 2025-11-10 09:33:17.274 | NTP Client | Sending packet to 0.pool.ntp.org:123 2025-11-10 09:33:17.274 | NTP Client | Sending packet to 1.pool.ntp.org:123 2025-11-10 09:33:17.274 | NTP Client | Sending packet to 2.pool.ntp.org:123 2025-11-10 09:33:17.274 | NTP Client | Sending packet to 3.pool.ntp.org:123 2025-11-10 09:33:17.381 | NTP Client | Received Packet | RoundTripDelay=0.10598325729370117, SystemClockOffset=-0.006062746047973633 2025-11-10 09:33:17.384 | NTP Client | Received Packet | RoundTripDelay=0.10877037048339844, SystemClockOffset=0.0031595230102539062 2025-11-10 09:33:17.394 | NTP Client | Received Packet | RoundTripDelay=0.1199641227722168, SystemClockOffset=-0.001996755599975586 2025-11-10 09:33:17.615 | Opened cached Intraday file: C:\SierraChart\Data\ZNZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:33:17.615 | Opened cached Intraday file: C:\SierraChart\Data\ZBZ25_FUT_CME.scid. Thread ID: 15288 2025-11-10 09:33:17.669 | NTP Client | Received Packet | RoundTripDelay=0.3939785957336426, SystemClockOffset=0.024756669998168945 2025-11-10 09:33:18.277 | NTP Client | Performed system clock adjustment of 581.3837051391602 microseconds. |
| [2025-11-10 16:37:05] |
| John - SC Support - Posts: 44021 |
You have multiple clock adjustments occurring. This should not be happening, as once your computer clock is set, it should not vary this much. We believe that you are having a problem with your system clock not staying correct. You would need to check with your computer manufacturer to find the best solution - this may require that you change the battery for your computer clock. Note that this will not affect your data, as those are timestamped from the exchange. The only place where you might have an issue is the time of trades that occurred, depending on the service you are using for your trading and whether the time of the trade is included with the trade information or not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-17 15:01:44] |
| Flowdity - Posts: 61 |
Hi John, I changed the battery, sometimes at market open I still see delayed data in the log I see many times"Socket gracefully closed by remote side." im not sure if this is my network issue or what? could you help please? im based in China, I tried China NTP server and sierr NTP server, which one would you suggest? 2025-12-17 09:56:36.406 | Triggering next historical data download in queue. 2025-12-17 09:56:36.406 | HD Request # 26 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2025-12-17 09:56:36.406 | HD Request # 26 | Download start date-time: 2025-12-17 09:55:15.000000. File last date-time: 2025-12-17 09:55:15.696002 2025-12-17 09:56:36.407 | HD Request # 26 | Using server: ds28.sierracharts.com port 10149 2025-12-17 09:56:36.407 | Socket (4) | Creating socket. 2025-12-17 09:56:36.407 | Socket (4) | New receive buffer size: 0 2025-12-17 09:56:36.407 | Socket (4) | Connecting to IP: 67.214.125.5. 2025-12-17 09:56:36.509 | Socket (9) | Socket gracefully closed by remote side. 2025-12-17 09:56:36.509 | Socket (9) | Closed. 2025-12-17 09:56:39.483 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 3544 2025-12-17 09:56:42.112 | HD Request # 26 | Setting DTC encoding to Binary VLS 2025-12-17 09:56:42.112 | HD Request # 26 | Sending historical data logon request message. 2025-12-17 09:56:42.564 | HD Request # 26 | Requesting Intraday data. Start date-time: 2025-12-17 09:55:15. Record interval: 0. Symbol: ESH26 2025-12-17 09:56:42.896 | HD Request # 26 | Decompressing data. 2025-12-17 09:56:43.632 | HD Request # 26 | Receiving Intraday data for ESH6.CME starting at 2025-12-17 09:55:15.037000 2025-12-17 09:56:44.055 | Socket (4) | CloseSocket call. 2025-12-17 09:56:44.055 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-12-17 09:56:44.055 | Historical data download thread signaled to stop. 2025-12-17 09:56:44.055 | HD Request # 26 | Timestamp of first Intraday data file record written: 2025-12-17 09:55:15.824000. 2025-12-17 09:56:44.056 | HD Request # 26 | Received 4728 Intraday data records from 2025-12-17 09:55:15.037000 to 2025-12-17 09:56:43.023005 (88.0 seconds. Delay: 1.0 seconds) and wrote 4685 records for ESH6.CME 2025-12-17 09:56:44.063 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2025-12-17 14:56:43.023005 2025-12-17 09:56:44.063 | HD Request # 26 | Completion time: 8s. 2025-12-17 09:56:44.063 | HD Request # 26 | Intraday data download complete for ESH6.CME. Unique request ID: 25 2025-12-17 09:56:44.063 | Removing historical data download ID 25. 2025-12-17 09:56:44.063 | Real-time Intraday chart data file updates started for ESH6.CME 2025-12-17 09:56:44.063 | Intraday chart data file opened for ESH6.CME 2025-12-17 09:56:44.063 | HD Request # 26 | Enabling Intraday chart updating for symbol. |
| [2025-12-17 15:42:34] |
| Sierra_Chart Engineering - Posts: 22386 |
We would recommend using a NTP server, in China or Asia. Sierra Chart does list NTP servers in China in current versions of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-12-17 15:43:37
| [2026-01-14 15:19:51] |
I still have data delay especially at the open, could you help to take a look please? 2026-01-14 09:29:33.298 | NTP Client | Received Packet | RoundTripDelay=0.17399835586547852, SystemClockOffset=0.0031468868255615234 2026-01-14 09:29:33.308 | NTP Client | Received Packet | RoundTripDelay=0.18296337127685547, SystemClockOffset=0.008251667022705078 2026-01-14 09:29:33.360 | NTP Client | Received Packet | RoundTripDelay=0.23496055603027344, SystemClockOffset=-0.026341915130615234 2026-01-14 09:29:34.135 | NTP Client | Performed system clock adjustment of 635.8623504638672 microseconds. 2026-01-14 09:30:03.138 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:30:03.138 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:30:03.138 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:30:03.138 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:30:03.378 | NTP Client | Received Packet | RoundTripDelay=0.2409687042236328, SystemClockOffset=-0.01732349395751953 2026-01-14 09:30:04.117 | NTP Client | Performed system clock adjustment of -17323.49395751953 microseconds. 2026-01-14 09:30:25.956 | File >> Disconnect selected. 2026-01-14 09:30:25.964 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:30:25.965 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:30:25.965 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:25.965 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:30:25.965 | DTC Client socket (1) | Closed. 2026-01-14 09:30:25.965 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:30:25.965 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:30:25.965 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:25.965 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:30:25.966 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:30:25.966 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:30:25.966 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:30:25.966 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:30:25.966 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:25.966 | DTC Client socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:30:25.966 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:30:25.966 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:30:25.966 | DTC Client socket (9) | Closed. 2026-01-14 09:30:25.966 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:30:25.966 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:25.967 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:30:25.967 | DTC Client socket (2) | Closed. 2026-01-14 09:30:25.970 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:30:25.970 | DTC Client socket (3) | Closed. 2026-01-14 09:30:27.066 | 2026-01-14 09:30:27.066 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:30:27.066 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:30:27.066 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:30:27.068 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:30:27.068 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:30:27.068 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:30:27.071 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:30:27.071 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:30:27.071 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:30:27.071 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:30:31.372 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:30:31.373 | No download requests in the queue to start downloads for. 2026-01-14 09:30:31.374 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:30:31.374 | Using symbol data fast lookup vector 2026-01-14 09:30:31.374 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:30:31.374 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:30:31.375 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:30:31.375 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:30:31.375 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:30:31.375 | Triggering next historical data download in queue. 2026-01-14 09:30:31.375 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 124 2026-01-14 09:30:31.376 | DTC Client socket (2) | Creating socket. 2026-01-14 09:30:31.376 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:30:31.376 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2026-01-14 09:30:31.378 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:30:31.378 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:30:31.378 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:30:31.378 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:30:31.378 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 125 2026-01-14 09:30:31.378 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:30:31.378 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:30:31.378 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:30:31.378 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:30:31.378 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 126 2026-01-14 09:30:31.378 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:30:31.378 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:30:31.378 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:30:31.378 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:30:31.378 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 127 2026-01-14 09:30:31.382 | Delaying start of download for VOLX. 2026-01-14 09:30:31.382 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:30:31.382 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:30:31.382 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:30:31.384 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:30:31.384 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:30:31.384 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 10048 2026-01-14 09:30:31.384 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:30:31.384 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:30:31.384 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:30:31.384 | Triggering next historical data download in queue. 2026-01-14 09:30:31.384 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:30:31.384 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 6 Service code: cme 2026-01-14 09:30:31.384 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 6 2026-01-14 09:30:31.386 | DTC Client socket (3) | Creating socket. 2026-01-14 09:30:31.386 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:30:31.386 | DTC Client socket (3) | Connecting to IP: 67.214.125.5. 2026-01-14 09:30:31.394 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:30:31.394 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:30:31.394 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:30:31.394 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:30:31.394 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:30:31.394 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:30:31.394 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:30:31.394 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:30:31.403 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:30:31.403 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:30:31.403 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:30:31.628 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:30:31.628 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:30:31.628 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:30:31.629 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:30:31.629 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:30:31.629 | Triggering next historical data download in queue. 2026-01-14 09:30:32.514 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:30:32.514 | SC Data with Depth | Sending logon request message. 2026-01-14 09:30:33.153 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:30:33.153 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:30:33.153 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:30:33.153 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:30:33.177 | SC Data with Depth | Received logon response. 2026-01-14 09:30:33.177 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:30:33.177 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:30:33.177 | SC Data with Depth | Successfully connected. 2026-01-14 09:30:33.177 | SC Data with Depth | Trading is not supported. 2026-01-14 09:30:33.177 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:30:33.177 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:30:33.177 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:30:33.177 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:30:33.177 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:30:33.195 | NTP Client | Received Packet | RoundTripDelay=0.04099321365356445, SystemClockOffset=-0.014420747756958008 2026-01-14 09:30:33.332 | NTP Client | Received Packet | RoundTripDelay=0.17899799346923828, SystemClockOffset=-0.015622138977050781 2026-01-14 09:30:33.386 | NTP Client | Received Packet | RoundTripDelay=0.23298120498657227, SystemClockOffset=-0.041376352310180664 2026-01-14 09:30:33.392 | NTP Client | Received Packet | RoundTripDelay=0.23895931243896484, SystemClockOffset=-0.03575277328491211 2026-01-14 09:30:34.010 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:30:34.010 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:30:34.010 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:30:34.010 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:30:34.010 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:30:34.010 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:30:34.010 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:30:34.010 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:30:34.139 | NTP Client | Performed system clock adjustment of -25687.456130981445 microseconds. 2026-01-14 09:30:36.347 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:30:36.347 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:30:36.348 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:30:36.348 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:30:36.349 | Triggering next historical data download in queue. 2026-01-14 09:30:36.349 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:30:36.349 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:30:36.350 | HD Request # 22 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:30:36.350 | HD Request # 22 | Download start date-time: 2026-01-14 09:30:25.965519. 2026-01-14 09:30:36.350 | HD Request # 22 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:30:36.350 | Socket (4) | Creating socket. 2026-01-14 09:30:36.350 | Socket (4) | New receive buffer size: 0 2026-01-14 09:30:36.350 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:30:37.301 | HD Request # 22 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:37.301 | HD Request # 22 | Sending historical data logon request message. 2026-01-14 09:30:37.675 | HD Request # 22 | Requesting market depth data. Start date-time: 2026-01-14 09:30:25. Symbol: ESH26 2026-01-14 09:30:38.015 | HD Request # 22 | Decompressing data. 2026-01-14 09:30:38.027 | HD Request # 22 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:30:25.971000 2026-01-14 09:30:38.670 | Socket (4) | CloseSocket call. 2026-01-14 09:30:38.670 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:38.671 | Historical data download thread signaled to stop. 2026-01-14 09:30:38.671 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:30:38.671 | Socket (4) | Closed. 2026-01-14 09:30:38.671 | HD Request # 22 | Timestamp of first market depth data file record written: 2026-01-14 09:30:25.971000. 2026-01-14 09:30:38.671 | HD Request # 22 | Received 11210 Market Depth data records from 2026-01-14 09:30:25.971000 to 2026-01-14 09:30:35.077000 (9.1 seconds. Delay: 3.6 seconds) and wrote 11210 records for ESH6.CME 2026-01-14 09:30:38.672 | HD Request # 22 | Completion time: 2s. 2026-01-14 09:30:38.672 | HD Request # 22 | Market Depth data download complete for ESH6.CME. Unique request ID: 131 2026-01-14 09:30:38.672 | Removing historical data download ID 131. 2026-01-14 09:30:38.672 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:30:38.680 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:30:38.680 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:38.680 | 2026-01-14 09:30:38.680 | Triggering next historical data download in queue. 2026-01-14 09:30:38.680 | HD Request # 23 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:30:38.681 | HD Request # 23 | Download start date-time: 2026-01-14 09:30:25.965398. 2026-01-14 09:30:38.681 | HD Request # 23 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:30:38.683 | Socket (4) | Creating socket. 2026-01-14 09:30:38.683 | Socket (4) | New receive buffer size: 0 2026-01-14 09:30:38.683 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:30:38.703 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:30:38.713 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:38.714 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:30:38.717 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:38.772 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:30:38.775 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:38.805 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:30:38.808 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:38.811 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:30:38.822 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:38.823 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:30:38.833 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:38.843 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:30:38.847 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 129, 2026-01-14 09:30:39.724 | HD Request # 24 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:30:39.725 | HD Request # 24 | Download start date-time: 2026-01-14 09:30:25.000000. File last date-time: 2026-01-14 09:30:25.183000 2026-01-14 09:30:39.725 | HD Request # 24 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:30:39.726 | Socket (9) | Creating socket. 2026-01-14 09:30:39.726 | Socket (9) | New receive buffer size: 0 2026-01-14 09:30:39.726 | Socket (9) | Connecting to IP: 69.39.70.241. 2026-01-14 09:30:41.642 | HD Request # 23 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:41.642 | HD Request # 23 | Sending historical data logon request message. 2026-01-14 09:30:43.739 | HD Request # 23 | Requesting market depth data. Start date-time: 2026-01-14 09:30:25. Symbol: NQH26 2026-01-14 09:30:44.440 | HD Request # 24 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:44.440 | HD Request # 24 | Sending historical data logon request message. 2026-01-14 09:30:44.520 | HD Request # 23 | Decompressing data. 2026-01-14 09:30:44.529 | HD Request # 23 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:30:25.968000 2026-01-14 09:30:46.042 | HD Request # 24 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:25. Record interval: 0. Symbol: VOLX 2026-01-14 09:30:47.056 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | Creating socket. Using TLS 1.2. 2026-01-14 09:30:47.056 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | New receive buffer size: 0 2026-01-14 09:30:47.056 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | Connecting to IP: 38.79.0.89. 2026-01-14 09:30:47.677 | HD Request # 24 | Decompressing data. 2026-01-14 09:30:47.677 | HD Request # 24 | Receiving Intraday data for VOLX starting at 2026-01-14 09:30:25.044000 2026-01-14 09:30:47.677 | Socket (9) | CloseSocket call. 2026-01-14 09:30:47.677 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:47.677 | Historical data download thread signaled to stop. 2026-01-14 09:30:47.678 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:30:47.678 | HD Request # 24 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:25.793000. 2026-01-14 09:30:47.678 | Socket (9) | Closed. 2026-01-14 09:30:47.678 | HD Request # 24 | Received 19 Intraday data records from 2026-01-14 09:30:25.044000 to 2026-01-14 09:30:43.202000 (18.2 seconds. Delay: 4.5 seconds) and wrote 17 records for VOLX 2026-01-14 09:30:47.685 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:30:43.202000 2026-01-14 09:30:47.685 | HD Request # 24 | Completion time: 8s. 2026-01-14 09:30:47.685 | HD Request # 24 | Intraday data download complete for VOLX. Unique request ID: 124 2026-01-14 09:30:47.685 | Removing historical data download ID 124. 2026-01-14 09:30:47.685 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:30:47.685 | Intraday chart data file opened for VOLX 2026-01-14 09:30:47.685 | HD Request # 24 | Enabling Intraday chart updating for symbol. 2026-01-14 09:30:47.685 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 124 has completed. 2026-01-14 09:30:47.685 | 2026-01-14 09:30:47.685 | Triggering next historical data download in queue. 2026-01-14 09:30:47.685 | HD Request # 25 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:30:47.685 | HD Request # 25 | Download start date-time: 2026-01-14 09:30:25.000000. File last date-time: 2026-01-14 09:30:25.464002 2026-01-14 09:30:47.685 | HD Request # 25 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:30:47.687 | Socket (9) | Creating socket. 2026-01-14 09:30:47.687 | Socket (9) | New receive buffer size: 0 2026-01-14 09:30:47.687 | Socket (9) | Connecting to IP: 64.152.155.113. 2026-01-14 09:30:49.700 | HD Request # 25 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:49.700 | HD Request # 25 | Sending historical data logon request message. 2026-01-14 09:30:49.847 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:30:49.847 | Denali Data Feed | Sending logon request message. 2026-01-14 09:30:50.042 | HD Request # 25 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:25. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:30:50.370 | HD Request # 25 | Decompressing data. 2026-01-14 09:30:50.641 | HD Request # 25 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:30:25.000000 2026-01-14 09:30:50.642 | Socket (9) | CloseSocket call. 2026-01-14 09:30:50.642 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:50.643 | Historical data download thread signaled to stop. 2026-01-14 09:30:50.643 | HD Request # 25 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:26.000000. 2026-01-14 09:30:50.643 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:30:50.643 | Socket (9) | Closed. 2026-01-14 09:30:50.643 | HD Request # 25 | Received 24 Intraday data records from 2026-01-14 09:30:25.000000 to 2026-01-14 09:30:48.000000 (23.0 seconds. Delay: 2.6 seconds) and wrote 23 records for TICK-NYSE 2026-01-14 09:30:50.651 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:30:48.000000 2026-01-14 09:30:50.651 | Added 20 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:30:50.651 | HD Request # 25 | Completion time: 3s. 2026-01-14 09:30:50.651 | HD Request # 25 | Intraday data download complete for TICK-NYSE. Unique request ID: 125 2026-01-14 09:30:50.651 | Removing historical data download ID 125. 2026-01-14 09:30:50.651 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:30:50.651 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:30:50.651 | HD Request # 25 | Enabling Intraday chart updating for symbol. 2026-01-14 09:30:50.651 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 125 has completed. 2026-01-14 09:30:50.651 | 2026-01-14 09:30:50.651 | Triggering next historical data download in queue. 2026-01-14 09:30:50.651 | HD Request # 26 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:30:50.651 | HD Request # 26 | Download start date-time: 2026-01-14 09:30:25.000000. File last date-time: 2026-01-14 09:30:25.214001 2026-01-14 09:30:50.651 | HD Request # 26 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:30:50.651 | Socket (9) | Creating socket. 2026-01-14 09:30:50.651 | Socket (9) | New receive buffer size: 0 2026-01-14 09:30:50.651 | Socket (9) | Connecting to IP: 69.39.70.241. 2026-01-14 09:30:50.860 | Denali Data Feed | Received logon response. 2026-01-14 09:30:50.860 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:30:50.860 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:30:50.860 | Denali Data Feed | Successfully connected. 2026-01-14 09:30:50.860 | Denali Data Feed | Trading is not supported. 2026-01-14 09:30:50.860 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:30:50.860 | Denali Data Feed (Market Orders Data) | Connecting to the server ds28.sierracharts.com. Port 10060 2026-01-14 09:30:50.860 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26. Market Depth data restarted. 2026-01-14 09:30:50.860 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:30:50.860 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:30:50.860 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26. Market Depth data restarted. 2026-01-14 09:30:50.860 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:30:50.862 | DTC Client socket (11) | Creating socket. 2026-01-14 09:30:50.862 | DTC Client socket (11) | New receive buffer size: 0 2026-01-14 09:30:50.862 | DTC Client socket (11) | Connecting to IP: 67.214.125.5. 2026-01-14 09:30:50.863 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:30:50.863 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:30:50.863 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:30:51.778 | HD Request # 26 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:51.778 | HD Request # 26 | Sending historical data logon request message. 2026-01-14 09:30:51.920 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:30:51.921 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:30:51.974 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:30:51.974 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:30:52.163 | HD Request # 26 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:25. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:30:52.180 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | CloseSocket call. 2026-01-14 09:30:52.180 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:52.180 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | Socket gracefully closed by remote side. 2026-01-14 09:30:52.180 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (10) | Closed. 2026-01-14 09:30:52.184 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:30:52.184 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:30:52.184 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:30:52.191 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:30:52.191 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:30:52.191 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:30:52.191 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:30:52.191 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:30:52.191 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:30:52.191 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:30:52.191 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:30:52.191 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:30:52.191 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:30:52.234 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:30:52.491 | HD Request # 26 | Decompressing data. 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:30:52.644 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:30:52.771 | HD Request # 26 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:30:25.000000 2026-01-14 09:30:52.771 | Socket (9) | CloseSocket call. 2026-01-14 09:30:52.771 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:52.771 | Historical data download thread signaled to stop. 2026-01-14 09:30:52.771 | HD Request # 26 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:26.000000. 2026-01-14 09:30:52.771 | HD Request # 26 | Received 25 Intraday data records from 2026-01-14 09:30:25.000000 to 2026-01-14 09:30:49.000000 (24.0 seconds. Delay: 3.8 seconds) and wrote 24 records for NISS-NYSE 2026-01-14 09:30:52.772 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:30:52.772 | Socket (9) | Closed. 2026-01-14 09:30:52.779 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:30:49.000000 2026-01-14 09:30:52.779 | Added 27 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:30:52.779 | HD Request # 26 | Completion time: 2s. 2026-01-14 09:30:52.779 | HD Request # 26 | Intraday data download complete for NISS-NYSE. Unique request ID: 126 2026-01-14 09:30:52.779 | Removing historical data download ID 126. 2026-01-14 09:30:52.779 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:30:52.779 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:30:52.779 | HD Request # 26 | Enabling Intraday chart updating for symbol. 2026-01-14 09:30:52.779 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 126 has completed. 2026-01-14 09:30:52.779 | 2026-01-14 09:30:52.779 | Triggering next historical data download in queue. 2026-01-14 09:30:52.779 | HD Request # 27 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:30:52.779 | HD Request # 27 | Download start date-time: 2026-01-14 09:30:25.000000. File last date-time: 2026-01-14 09:30:25.214002 2026-01-14 09:30:52.779 | HD Request # 27 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:30:52.779 | Socket (9) | Creating socket. 2026-01-14 09:30:52.779 | Socket (9) | New receive buffer size: 0 2026-01-14 09:30:52.779 | Socket (9) | Connecting to IP: 64.152.155.113. 2026-01-14 09:30:53.693 | HD Request # 27 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:53.693 | HD Request # 27 | Sending historical data logon request message. 2026-01-14 09:30:53.902 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:30:53.902 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:30:54.012 | HD Request # 23 | Timestamp of first market depth data file record written: 2026-01-14 09:30:25.968000. 2026-01-14 09:30:54.035 | HD Request # 27 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:25. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:30:54.375 | HD Request # 27 | Decompressing data. 2026-01-14 09:30:54.721 | HD Request # 27 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:30:25.000000 2026-01-14 09:30:54.722 | Socket (9) | CloseSocket call. 2026-01-14 09:30:54.722 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:54.722 | Historical data download thread signaled to stop. 2026-01-14 09:30:54.722 | HD Request # 27 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:26.000000. 2026-01-14 09:30:54.722 | HD Request # 27 | Received 28 Intraday data records from 2026-01-14 09:30:25.000000 to 2026-01-14 09:30:52.000000 (27.0 seconds. Delay: 2.7 seconds) and wrote 27 records for TRIN-NYSE 2026-01-14 09:30:54.723 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:30:54.723 | Socket (9) | Closed. 2026-01-14 09:30:54.732 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:30:52.000000 2026-01-14 09:30:54.732 | Added 26 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:30:54.732 | HD Request # 27 | Completion time: 2s. 2026-01-14 09:30:54.732 | HD Request # 27 | Intraday data download complete for TRIN-NYSE. Unique request ID: 127 2026-01-14 09:30:54.732 | Removing historical data download ID 127. 2026-01-14 09:30:54.732 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:30:54.732 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:30:54.732 | HD Request # 27 | Enabling Intraday chart updating for symbol. 2026-01-14 09:30:54.732 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 127 has completed. 2026-01-14 09:30:54.732 | 2026-01-14 09:30:54.732 | Triggering next historical data download in queue. 2026-01-14 09:30:54.732 | Delaying start of download for NQH6.CME. 2026-01-14 09:30:55.453 | Socket (4) | CloseSocket call. 2026-01-14 09:30:55.453 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:30:55.453 | Historical data download thread signaled to stop. 2026-01-14 09:30:55.453 | HD Request # 23 | Received 39658 Market Depth data records from 2026-01-14 09:30:25.968000 to 2026-01-14 09:30:41.141000 (15.2 seconds. Delay: 14.3 seconds) and wrote 39658 records for NQH6.CME 2026-01-14 09:30:55.453 | HD Request # 23 | Completion time: 17s. 2026-01-14 09:30:55.453 | HD Request # 23 | Market Depth data download complete for NQH6.CME. Unique request ID: 132 2026-01-14 09:30:55.453 | Removing historical data download ID 132. 2026-01-14 09:30:55.453 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:30:55.453 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:30:55.453 | Socket (4) | Closed. 2026-01-14 09:30:55.461 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:30:55.461 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:30:55.461 | 2026-01-14 09:30:55.461 | No download requests in the queue to start downloads for. 2026-01-14 09:30:55.462 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:30:55.473 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:55.475 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:30:55.478 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:55.504 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:30:55.507 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:55.545 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:30:55.548 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:55.553 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:30:55.564 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:55.624 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:30:55.656 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:30:55.668 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:55.688 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:30:55.692 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 128, 2026-01-14 09:30:57.235 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:30:57.235 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:30:57.751 | HD Request # 28 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:30:57.752 | HD Request # 28 | Download start date-time: 2026-01-14 09:30:02.000000. File last date-time: 2026-01-14 09:30:02.347000 2026-01-14 09:30:57.752 | HD Request # 28 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:30:57.753 | Socket (4) | Creating socket. 2026-01-14 09:30:57.753 | Socket (4) | New receive buffer size: 0 2026-01-14 09:30:57.753 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-01-14 09:30:58.653 | HD Request # 28 | Setting DTC encoding to Binary VLS 2026-01-14 09:30:58.653 | HD Request # 28 | Sending historical data logon request message. 2026-01-14 09:30:59.017 | HD Request # 28 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:02. Record interval: 0. Symbol: NQH26 2026-01-14 09:30:59.357 | HD Request # 28 | Decompressing data. 2026-01-14 09:30:59.368 | HD Request # 28 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:30:02.000000 2026-01-14 09:31:00.022 | Socket (4) | CloseSocket call. 2026-01-14 09:31:00.022 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:00.022 | Historical data download thread signaled to stop. 2026-01-14 09:31:00.023 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:31:00.023 | Socket (4) | Closed. 2026-01-14 09:31:00.023 | HD Request # 28 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:02.371000. 2026-01-14 09:31:00.024 | HD Request # 28 | Received 5188 Intraday data records from 2026-01-14 09:30:02.000000 to 2026-01-14 09:30:56.823000 (54.8 seconds. Delay: 3.2 seconds) and wrote 5060 records for NQH6.CME 2026-01-14 09:31:00.031 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:30:56.823000 2026-01-14 09:31:00.031 | Added 26 Time and Sales records to Intraday data file for NQH6.CME after download. 2026-01-14 09:31:00.031 | HD Request # 28 | Completion time: 3s. 2026-01-14 09:31:00.031 | HD Request # 28 | Intraday data download complete for NQH6.CME. Unique request ID: 128 2026-01-14 09:31:00.031 | Removing historical data download ID 128. 2026-01-14 09:31:00.031 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:31:00.031 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:31:00.031 | HD Request # 28 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:00.037 | 2026-01-14 09:31:00.037 | Triggering next historical data download in queue. 2026-01-14 09:31:00.037 | HD Request # 29 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:31:00.037 | HD Request # 29 | Download start date-time: 2026-01-14 09:30:03.000000. File last date-time: 2026-01-14 09:30:03.550005 2026-01-14 09:31:00.037 | HD Request # 29 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:31:00.037 | Socket (4) | Creating socket. 2026-01-14 09:31:00.037 | Socket (4) | New receive buffer size: 0 2026-01-14 09:31:00.037 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:31:00.078 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.078 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:31:00.079 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.079 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:31:00.084 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.084 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:31:00.088 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.089 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:31:00.090 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.090 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:31:00.167 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.167 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:31:00.182 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:00.183 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:31:00.198 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:31:00.222 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:31:00.228 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.228 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.228 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:31:00.278 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.278 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:31:00.326 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:31:00.364 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:31:00.403 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:00.415 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:31:00.416 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:31:00.420 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:31:00.587 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.587 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.587 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:31:00.587 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:31:00.709 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:31:00.710 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.710 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:31:00.784 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:00.789 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:00.790 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:00.814 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:31:00.987 | HD Request # 29 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:00.987 | HD Request # 29 | Sending historical data logon request message. 2026-01-14 09:31:01.076 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:31:01.163 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:31:01.282 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:01.282 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:31:01.291 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:01.294 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:01.294 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:01.336 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:31:01.338 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:31:01.352 | HD Request # 29 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:03. Record interval: 0. Symbol: ESH26 2026-01-14 09:31:01.375 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:31:01.375 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:01.471 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:01.478 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:01.539 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:01.740 | HD Request # 29 | Decompressing data. 2026-01-14 09:31:01.755 | HD Request # 29 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:30:03.001000 2026-01-14 09:31:02.240 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:31:03.145 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:31:03.145 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:31:03.145 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:31:03.145 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:31:03.188 | NTP Client | Received Packet | RoundTripDelay=0.04299211502075195, SystemClockOffset=-0.0071489810943603516 2026-01-14 09:31:03.319 | NTP Client | Received Packet | RoundTripDelay=0.17399835586547852, SystemClockOffset=-0.0051038265228271484 2026-01-14 09:31:03.369 | NTP Client | Received Packet | RoundTripDelay=0.22396039962768555, SystemClockOffset=-0.02050185203552246 2026-01-14 09:31:03.371 | NTP Client | Received Packet | RoundTripDelay=0.22498607635498047, SystemClockOffset=-0.029642105102539062 2026-01-14 09:31:03.812 | Socket (4) | CloseSocket call. 2026-01-14 09:31:03.812 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:03.813 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:31:03.813 | Socket (4) | Closed. 2026-01-14 09:31:03.817 | Historical data download thread signaled to stop. 2026-01-14 09:31:03.817 | HD Request # 29 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:03.553000. 2026-01-14 09:31:03.817 | HD Request # 29 | Received 7975 Intraday data records from 2026-01-14 09:30:03.001000 to 2026-01-14 09:31:00.667003 (57.7 seconds. Delay: 3.2 seconds) and wrote 7748 records for ESH6.CME 2026-01-14 09:31:03.825 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:00.667003 2026-01-14 09:31:03.825 | HD Request # 29 | Completion time: 3s. 2026-01-14 09:31:03.825 | HD Request # 29 | Intraday data download complete for ESH6.CME. Unique request ID: 129 2026-01-14 09:31:03.825 | Removing historical data download ID 129. 2026-01-14 09:31:03.825 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:31:03.825 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:31:03.825 | HD Request # 29 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:03.825 | 2026-01-14 09:31:03.825 | Triggering next historical data download in queue. 2026-01-14 09:31:03.825 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.826 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:31:03.827 | HD Request # 30 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:31:03.827 | HD Request # 30 | Download start date-time: 2026-01-14 09:30:02.000000. File last date-time: 2026-01-14 09:30:02.348001 2026-01-14 09:31:03.827 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.827 | HD Request # 30 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:31:03.827 | Socket (4) | Creating socket. 2026-01-14 09:31:03.827 | Socket (4) | New receive buffer size: 0 2026-01-14 09:31:03.827 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:31:03.827 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:31:03.864 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.865 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:31:03.871 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.871 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:31:03.879 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.880 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:31:03.903 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.904 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:31:03.915 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:03.917 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:31:04.085 | + Loading additional symbol data. 2026-01-14 09:31:04.119 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:04.119 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:31:04.120 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:31:04.126 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:31:04.132 | + Loading additional symbol data. 2026-01-14 09:31:04.148 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:31:04.140 | NTP Client | Performed system clock adjustment of -13825.416564941406 microseconds. 2026-01-14 09:31:04.153 | + Loading additional symbol data. 2026-01-14 09:31:04.199 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:31:04.202 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:04.202 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:04.202 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:31:04.312 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:31:04.325 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:04.338 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:31:04.357 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:31:04.382 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:31:04.582 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:31:04.600 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:31:04.604 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:04.607 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:04.635 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:31:04.991 | HD Request # 30 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:04.991 | HD Request # 30 | Sending historical data logon request message. 2026-01-14 09:31:05.044 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:05.044 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:31:05.169 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:05.171 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:31:05.189 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:31:05.189 | Socket (4) | CloseSocket call. 2026-01-14 09:31:05.189 | Socket (0) | CloseSocket call. 2026-01-14 09:31:05.189 | Socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:31:05.189 | Socket (4) | Closed. 2026-01-14 09:31:05.195 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:31:05.195 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:31:05.196 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:31:05.196 | DTC Client socket (1) | Closed. 2026-01-14 09:31:05.196 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:31:05.196 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:31:05.196 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:31:05.196 | DTC Client socket (2) | Closed. 2026-01-14 09:31:05.196 | HD Request # 30 | Error downloading historical Intraday data for RTYH6.CME. The network socket has been closed. Retrying download. 2026-01-14 09:31:05.196 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:31:05.196 | Triggering next historical data download in queue. 2026-01-14 09:31:05.196 | Historical data download thread signaled to stop. 2026-01-14 09:31:05.196 | HD Request # 30 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for RTYH6.CME 2026-01-14 09:31:05.196 | HD Request # 30 | Completion time: 2s. 2026-01-14 09:31:05.196 | 2026-01-14 09:31:05.196 | Connection to the external service has been lost. 2026-01-14 09:31:05.214 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:31:05.214 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:31:05.214 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-01-14 09:31:05.214 | HD Request # 31 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:31:05.214 | HD Request # 31 | Download start date-time: 2026-01-14 09:30:02.000000. File last date-time: 2026-01-14 09:30:02.348001 2026-01-14 09:31:05.214 | HD Request # 31 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:31:05.214 | Socket (1) | Creating socket. 2026-01-14 09:31:05.214 | Socket (1) | New receive buffer size: 0 2026-01-14 09:31:05.214 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-01-14 09:31:05.218 | + Loading additional symbol data. 2026-01-14 09:31:05.235 | DTC Client socket (11) | Socket gracefully closed by remote side. 2026-01-14 09:31:05.240 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:31:05.240 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:31:05.241 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 5404 2026-01-14 09:31:05.241 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:31:05.241 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-14 09:31:05.257 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:05.317 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:31:05.317 | DTC Client socket (11) | CloseSocket call. 2026-01-14 09:31:05.317 | DTC Client socket (11) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:31:05.317 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:31:05.317 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:31:05.317 | DTC Client socket (11) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:31:05.317 | DTC Client socket (11) | Closed. 2026-01-14 09:31:05.318 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:31:05.318 | DTC Client socket (3) | Closed. 2026-01-14 09:31:05.411 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:31:05.412 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:31:05.412 | Denali Data Feed (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. 2026-01-14 09:31:05.412 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:31:05.412 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:31:05.412 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:31:05.412 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:31:05.412 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-01-14 09:31:05.906 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:05.908 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:05.908 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:05.938 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:31:05.951 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:05.955 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:05.986 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:06.014 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:06.036 | HD Request # 31 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:06.036 | HD Request # 31 | Sending historical data logon request message. 2026-01-14 09:31:06.349 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:06.356 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:06.395 | HD Request # 31 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:02. Record interval: 0. Symbol: RTYH26 2026-01-14 09:31:06.411 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:06.710 | HD Request # 31 | Decompressing data. 2026-01-14 09:31:06.936 | HD Request # 31 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:30:02.013000 2026-01-14 09:31:07.145 | Socket (1) | CloseSocket call. 2026-01-14 09:31:07.145 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:07.145 | Socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:07.146 | Socket (1) | Closed. 2026-01-14 09:31:07.160 | Historical data download thread signaled to stop. 2026-01-14 09:31:07.160 | HD Request # 31 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:02.360000. 2026-01-14 09:31:07.160 | HD Request # 31 | Received 2487 Intraday data records from 2026-01-14 09:30:02.013000 to 2026-01-14 09:31:04.788005 (62.8 seconds. Delay: 2.4 seconds) and wrote 2449 records for RTYH6.CME 2026-01-14 09:31:07.160 | HD Request # 31 | Completion time: 2s. 2026-01-14 09:31:07.160 | HD Request # 31 | Intraday data download complete for RTYH6.CME. Unique request ID: 130 2026-01-14 09:31:07.160 | Removing historical data download ID 130. 2026-01-14 09:31:07.160 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:31:07.160 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:31:07.160 | HD Request # 31 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:07.160 | 2026-01-14 09:31:07.160 | No download requests in the queue to start downloads for. 2026-01-14 09:31:07.221 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-01-14 09:31:07.224 | DTC Client socket (1) | Creating socket. 2026-01-14 09:31:07.224 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:31:07.224 | DTC Client socket (1) | Connecting to IP: 64.152.155.113. 2026-01-14 09:31:07.255 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:31:07.255 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:31:07.255 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:31:08.415 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2026-01-14 09:31:08.415 | DTC Client socket (2) | Creating socket. 2026-01-14 09:31:08.415 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:31:08.415 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2026-01-14 09:31:08.421 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:31:08.421 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:31:08.421 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:31:08.482 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:31:08.482 | SC Data with Depth | Sending logon request message. 2026-01-14 09:31:09.008 | 2026-01-14 09:31:09.008 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:31:09.008 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:31:09.008 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:31:09.010 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2026-01-14 09:31:09.010 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:31:09.010 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2026-01-14 09:31:09.015 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:31:09.015 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:31:09.015 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:31:09.015 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:31:09.340 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:31:09.340 | Denali Data Feed | Sending logon request message. 2026-01-14 09:31:09.448 | SC Data with Depth | Received logon response. 2026-01-14 09:31:09.448 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:31:09.448 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:09.448 | SC Data with Depth | Successfully connected. 2026-01-14 09:31:09.448 | SC Data with Depth | Trading is not supported. 2026-01-14 09:31:09.448 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:31:09.448 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:31:09.448 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:31:09.448 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:31:09.448 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:31:10.340 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:31:10.340 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:31:10.340 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:31:10.340 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:31:10.340 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:31:10.340 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:31:10.340 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:31:10.340 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:31:10.367 | Denali Data Feed | Received logon response. 2026-01-14 09:31:10.367 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:31:10.367 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:10.367 | Denali Data Feed | Successfully connected. 2026-01-14 09:31:10.367 | Denali Data Feed | Trading is not supported. 2026-01-14 09:31:10.367 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:31:10.367 | Denali Data Feed (Market Orders Data) | Connecting to the server ds28.sierracharts.com. Port 10060 2026-01-14 09:31:10.367 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26. Market Depth data restarted. 2026-01-14 09:31:10.367 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:31:10.367 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:31:10.367 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26. Market Depth data restarted. 2026-01-14 09:31:10.367 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:31:10.367 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:31:10.367 | Triggering next historical data download in queue. 2026-01-14 09:31:10.367 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:31:10.367 | HD Request # 32 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:31:10.367 | HD Request # 32 | Download start date-time: 2026-01-14 09:31:04.000000. File last date-time: 2026-01-14 09:31:04.788005 2026-01-14 09:31:10.367 | HD Request # 32 | Using server: ds28.sierracharts.com port 10149 2026-01-14 09:31:10.367 | DTC Client socket (4) | Creating socket. 2026-01-14 09:31:10.367 | DTC Client socket (4) | New receive buffer size: 0 2026-01-14 09:31:10.367 | DTC Client socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:31:10.368 | Socket (9) | Creating socket. 2026-01-14 09:31:10.368 | Socket (9) | New receive buffer size: 0 2026-01-14 09:31:10.368 | Socket (9) | Connecting to IP: 67.214.125.5. 2026-01-14 09:31:10.401 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:31:10.401 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:31:10.401 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:31:10.936 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:31:10.936 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:31:11.379 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:31:11.379 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:31:11.380 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:31:11.380 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:31:11.380 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:31:11.380 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:31:11.380 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:31:11.380 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:31:11.380 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:31:11.380 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:31:11.380 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:31:11.380 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:31:11.662 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:31:12.010 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:31:12.011 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:31:12.012 | DTC Client socket (4) | CloseSocket call. 2026-01-14 09:31:12.012 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:12.012 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:31:12.012 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:31:12.013 | DTC Client socket (4) | Closed. 2026-01-14 09:31:12.013 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:31:12.013 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:31:12.013 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:12.013 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:31:12.013 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:31:12.013 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:31:12.013 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:12.014 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:31:12.014 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:31:12.014 | No download requests in the queue to start downloads for. 2026-01-14 09:31:12.014 | DTC Client socket (2) | Closed. 2026-01-14 09:31:12.014 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:12.014 | DTC Client socket (1) | Closed. 2026-01-14 09:31:12.019 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:31:12.019 | Using symbol data fast lookup vector 2026-01-14 09:31:12.019 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:31:12.019 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:31:12.019 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:31:12.019 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:31:12.019 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:31:12.019 | Triggering next historical data download in queue. 2026-01-14 09:31:12.019 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 134 2026-01-14 09:31:12.021 | DTC Client socket (1) | Creating socket. 2026-01-14 09:31:12.021 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:31:12.021 | DTC Client socket (1) | Connecting to IP: 69.39.70.241. 2026-01-14 09:31:12.022 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:31:12.022 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:31:12.022 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:31:12.022 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:31:12.022 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 135 2026-01-14 09:31:12.022 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:31:12.022 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:31:12.022 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:31:12.022 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:31:12.022 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 136 2026-01-14 09:31:12.022 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:31:12.022 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:31:12.022 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:31:12.022 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:31:12.022 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 137 2026-01-14 09:31:12.027 | SC Data with Depth | Failed connections: 1 2026-01-14 09:31:12.027 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:31:12.027 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:12.027 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:31:12.027 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-01-14 09:31:12.027 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:31:12.027 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 5 Service code: cme 2026-01-14 09:31:12.027 | Denali Data Feed | Connecting to the server ds25-2.sierracharts.com. Port 443 2026-01-14 09:31:12.027 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 5 2026-01-14 09:31:12.060 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:31:12.060 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 6 Service code: cme 2026-01-14 09:31:12.060 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 6 2026-01-14 09:31:12.060 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:31:12.060 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 7 Service code: cme 2026-01-14 09:31:12.060 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 7 2026-01-14 09:31:12.060 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:31:12.060 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:31:12.060 | Triggering next historical data download in queue. 2026-01-14 09:31:12.102 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:31:12.102 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 8 Service code: cme 2026-01-14 09:31:12.102 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 8 2026-01-14 09:31:12.102 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:31:12.102 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 9 Service code: cme 2026-01-14 09:31:12.102 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 9 2026-01-14 09:31:12.102 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:31:12.102 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:31:12.102 | Triggering next historical data download in queue. 2026-01-14 09:31:12.598 | DTC Client socket (2) | Creating socket. 2026-01-14 09:31:12.598 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:31:12.599 | DTC Client socket (2) | Connecting to IP: 64.152.155.21. 2026-01-14 09:31:12.645 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:31:12.645 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:31:12.645 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:31:12.765 | HD Request # 32 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:12.765 | HD Request # 32 | Sending historical data logon request message. 2026-01-14 09:31:13.335 | HD Request # 32 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:04. Record interval: 0. Symbol: RTYH26 2026-01-14 09:31:13.947 | HD Request # 32 | Decompressing data. 2026-01-14 09:31:14.044 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-01-14 09:31:14.046 | DTC Client socket (4) | Creating socket. 2026-01-14 09:31:14.046 | DTC Client socket (4) | New receive buffer size: 0 2026-01-14 09:31:14.046 | DTC Client socket (4) | Connecting to IP: 64.152.155.113. 2026-01-14 09:31:14.047 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:31:14.047 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:31:14.047 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:31:14.681 | HD Request # 32 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:31:04.077000 2026-01-14 09:31:14.772 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:31:14.772 | Denali Data Feed | Sending logon request message. 2026-01-14 09:31:14.922 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:31:14.922 | SC Data with Depth | Sending logon request message. 2026-01-14 09:31:15.625 | SC Data with Depth | Received logon response. 2026-01-14 09:31:15.625 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:31:15.625 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:15.625 | SC Data with Depth | Successfully connected. 2026-01-14 09:31:15.625 | SC Data with Depth | Trading is not supported. 2026-01-14 09:31:15.625 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:31:15.625 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:31:15.625 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:31:15.625 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:31:15.625 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:31:16.159 | Socket (9) | CloseSocket call. 2026-01-14 09:31:16.159 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:16.160 | Historical data download thread signaled to stop. 2026-01-14 09:31:16.160 | HD Request # 32 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:04.868000. 2026-01-14 09:31:16.160 | HD Request # 32 | Received 207 Intraday data records from 2026-01-14 09:31:04.077000 to 2026-01-14 09:31:12.541000 (8.5 seconds. Delay: 3.6 seconds) and wrote 182 records for RTYH6.CME 2026-01-14 09:31:16.160 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:31:16.160 | Socket (9) | Closed. 2026-01-14 09:31:16.172 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:12.541000 2026-01-14 09:31:16.172 | HD Request # 32 | Completion time: 6s. 2026-01-14 09:31:16.172 | HD Request # 32 | Intraday data download complete for RTYH6.CME. Unique request ID: 133 2026-01-14 09:31:16.172 | Removing historical data download ID 133. 2026-01-14 09:31:16.172 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:31:16.172 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:31:16.172 | HD Request # 32 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:16.172 | 2026-01-14 09:31:16.172 | Triggering next historical data download in queue. 2026-01-14 09:31:16.172 | Delaying start of download for VOLX. 2026-01-14 09:31:16.172 | Denali Data Feed | Received logon response. 2026-01-14 09:31:16.172 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:31:16.172 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:16.172 | Denali Data Feed | Successfully connected. 2026-01-14 09:31:16.172 | Denali Data Feed | Trading is not supported. 2026-01-14 09:31:16.172 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:31:16.172 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:31:16.172 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:31:16.172 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:31:16.172 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:31:16.172 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:31:16.172 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:31:16.172 | Triggering next historical data download in queue. 2026-01-14 09:31:16.172 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:31:16.388 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:31:16.388 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:31:16.388 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:31:16.388 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:31:16.388 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:31:16.388 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:31:16.388 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:31:16.388 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:31:17.031 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:31:17.036 | Denali Data Feed (Market Orders Data) | Connecting to the server ds25-2.sierracharts.com. Port 10060 2026-01-14 09:31:17.036 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:31:17.036 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:31:17.036 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:31:17.036 | Triggering next historical data download in queue. 2026-01-14 09:31:17.036 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:31:17.036 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:31:17.036 | HD Request # 33 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:31:17.036 | DTC Client socket (9) | Creating socket. 2026-01-14 09:31:17.036 | DTC Client socket (9) | New receive buffer size: 0 2026-01-14 09:31:17.036 | DTC Client socket (9) | Connecting to IP: 64.152.155.21. 2026-01-14 09:31:17.036 | HD Request # 33 | Download start date-time: 2026-01-14 09:31:05.241495. 2026-01-14 09:31:17.036 | HD Request # 33 | Using server: ds32.sierracharts.com port 10150 2026-01-14 09:31:17.036 | Socket (10) | Creating socket. 2026-01-14 09:31:17.036 | Socket (10) | New receive buffer size: 0 2026-01-14 09:31:17.036 | Socket (10) | Connecting to IP: 69.39.70.248. 2026-01-14 09:31:17.062 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:31:17.062 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:31:17.062 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:31:17.389 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:31:17.389 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:31:17.389 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:31:17.389 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:31:17.389 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:31:17.389 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:31:17.389 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:31:17.389 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:31:17.389 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:31:17.389 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:31:17.836 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:31:17.836 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:31:17.874 | HD Request # 33 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:17.874 | HD Request # 33 | Sending historical data logon request message. 2026-01-14 09:31:18.113 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:18.113 | DTC Client socket (1) | Closed. 2026-01-14 09:31:18.375 | HD Request # 33 | Requesting market depth data. Start date-time: 2026-01-14 09:31:05. Symbol: ESH26 2026-01-14 09:31:18.481 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:31:18.481 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:31:18.638 | HD Request # 33 | Decompressing data. 2026-01-14 09:31:18.649 | HD Request # 33 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:31:05.242000 2026-01-14 09:31:19.029 | Socket (10) | CloseSocket call. 2026-01-14 09:31:19.030 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:19.030 | Historical data download thread signaled to stop. 2026-01-14 09:31:19.030 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:31:19.030 | Socket (10) | Closed. 2026-01-14 09:31:19.356 | HD Request # 33 | Timestamp of first market depth data file record written: 2026-01-14 09:31:05.242000. 2026-01-14 09:31:19.356 | HD Request # 33 | Received 14286 Market Depth data records from 2026-01-14 09:31:05.242000 to 2026-01-14 09:31:17.805000 (12.6 seconds. Delay: 1.6 seconds) and wrote 14286 records for ESH6.CME 2026-01-14 09:31:19.356 | HD Request # 33 | Completion time: 2s. 2026-01-14 09:31:19.356 | HD Request # 33 | Market Depth data download complete for ESH6.CME. Unique request ID: 141 2026-01-14 09:31:19.356 | Removing historical data download ID 141. 2026-01-14 09:31:19.356 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:31:19.362 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:31:19.362 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:19.362 | 2026-01-14 09:31:19.362 | Triggering next historical data download in queue. 2026-01-14 09:31:19.410 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:31:19.414 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.417 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:31:19.428 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.429 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:31:19.432 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.440 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:31:19.443 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.446 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:31:19.450 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.456 | HD Request # 34 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:31:19.457 | HD Request # 34 | Download start date-time: 2026-01-14 09:31:05.241401. 2026-01-14 09:31:19.457 | HD Request # 34 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:31:19.457 | Socket (1) | Creating socket. 2026-01-14 09:31:19.457 | Socket (1) | New receive buffer size: 0 2026-01-14 09:31:19.457 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-01-14 09:31:19.457 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:31:19.470 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.470 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:31:19.481 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 139, 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:31:19.483 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:31:20.147 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:31:20.147 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:31:20.389 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:31:21.236 | HD Request # 34 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:21.236 | HD Request # 34 | Sending historical data logon request message. 2026-01-14 09:31:21.606 | HD Request # 34 | Requesting market depth data. Start date-time: 2026-01-14 09:31:05. Symbol: NQH26 2026-01-14 09:31:21.752 | HD Request # 35 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:31:21.752 | HD Request # 35 | Download start date-time: 2026-01-14 09:31:04.000000. File last date-time: 2026-01-14 09:31:04.477000 2026-01-14 09:31:21.752 | HD Request # 35 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:31:21.753 | Socket (10) | Creating socket. 2026-01-14 09:31:21.753 | Socket (10) | New receive buffer size: 0 2026-01-14 09:31:21.753 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:31:22.001 | HD Request # 34 | Decompressing data. 2026-01-14 09:31:22.015 | HD Request # 34 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:31:05.242000 2026-01-14 09:31:22.635 | HD Request # 35 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:22.635 | HD Request # 35 | Sending historical data logon request message. 2026-01-14 09:31:23.008 | HD Request # 35 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:04. Record interval: 0. Symbol: VOLX 2026-01-14 09:31:23.576 | HD Request # 35 | Decompressing data. 2026-01-14 09:31:23.768 | HD Request # 35 | Receiving Intraday data for VOLX starting at 2026-01-14 09:31:04.477000 2026-01-14 09:31:23.768 | Socket (10) | CloseSocket call. 2026-01-14 09:31:23.768 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:23.768 | Historical data download thread signaled to stop. 2026-01-14 09:31:23.768 | HD Request # 35 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:05.235000. 2026-01-14 09:31:23.769 | HD Request # 35 | Received 18 Intraday data records from 2026-01-14 09:31:04.477000 to 2026-01-14 09:31:20.399000 (15.9 seconds. Delay: 3.4 seconds) and wrote 17 records for VOLX 2026-01-14 09:31:23.769 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:31:23.769 | Socket (10) | Closed. 2026-01-14 09:31:23.776 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:20.399000 2026-01-14 09:31:23.776 | Added 5 Time and Sales records to Intraday data file for VOLX after download. 2026-01-14 09:31:23.776 | HD Request # 35 | Completion time: 2s. 2026-01-14 09:31:23.776 | HD Request # 35 | Intraday data download complete for VOLX. Unique request ID: 134 2026-01-14 09:31:23.776 | Removing historical data download ID 134. 2026-01-14 09:31:23.776 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:31:23.776 | Intraday chart data file opened for VOLX 2026-01-14 09:31:23.776 | HD Request # 35 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:23.776 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 134 has completed. 2026-01-14 09:31:23.776 | 2026-01-14 09:31:23.776 | Triggering next historical data download in queue. 2026-01-14 09:31:23.776 | HD Request # 36 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:31:23.776 | HD Request # 36 | Download start date-time: 2026-01-14 09:31:04.000000. File last date-time: 2026-01-14 09:31:04.458002 2026-01-14 09:31:23.776 | HD Request # 36 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:31:23.776 | Socket (10) | Creating socket. 2026-01-14 09:31:23.776 | Socket (10) | New receive buffer size: 0 2026-01-14 09:31:23.776 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:31:26.273 | HD Request # 36 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:26.273 | HD Request # 36 | Sending historical data logon request message. 2026-01-14 09:31:26.664 | HD Request # 36 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:04. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:31:27.229 | HD Request # 36 | Decompressing data. 2026-01-14 09:31:27.289 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:31:27.601 | HD Request # 36 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:31:04.000000 2026-01-14 09:31:27.602 | Socket (10) | CloseSocket call. 2026-01-14 09:31:27.602 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:27.603 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:31:27.603 | Socket (10) | Closed. 2026-01-14 09:31:27.620 | Historical data download thread signaled to stop. 2026-01-14 09:31:27.620 | HD Request # 36 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:05.000000. 2026-01-14 09:31:27.620 | HD Request # 36 | Received 23 Intraday data records from 2026-01-14 09:31:04.000000 to 2026-01-14 09:31:26.000000 (22.0 seconds. Delay: 1.6 seconds) and wrote 22 records for TICK-NYSE 2026-01-14 09:31:27.627 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:26.000000 2026-01-14 09:31:27.627 | Added 12 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:31:27.628 | HD Request # 36 | Completion time: 4s. 2026-01-14 09:31:27.628 | HD Request # 36 | Intraday data download complete for TICK-NYSE. Unique request ID: 135 2026-01-14 09:31:27.628 | Removing historical data download ID 135. 2026-01-14 09:31:27.628 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:31:27.628 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:31:27.628 | HD Request # 36 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:27.628 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 135 has completed. 2026-01-14 09:31:27.628 | 2026-01-14 09:31:27.628 | Triggering next historical data download in queue. 2026-01-14 09:31:27.628 | HD Request # 37 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:31:27.628 | HD Request # 37 | Download start date-time: 2026-01-14 09:31:04.000000. File last date-time: 2026-01-14 09:31:04.208001 2026-01-14 09:31:27.628 | HD Request # 37 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:31:27.628 | Socket (10) | Creating socket. 2026-01-14 09:31:27.628 | Socket (10) | New receive buffer size: 0 2026-01-14 09:31:27.628 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:31:28.710 | HD Request # 37 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:28.710 | HD Request # 37 | Sending historical data logon request message. 2026-01-14 09:31:29.039 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | Creating socket. Using TLS 1.2. 2026-01-14 09:31:29.039 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | New receive buffer size: 0 2026-01-14 09:31:29.039 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | Connecting to IP: 216.66.0.130. 2026-01-14 09:31:29.504 | HD Request # 34 | Timestamp of first market depth data file record written: 2026-01-14 09:31:05.242000. 2026-01-14 09:31:30.570 | HD Request # 37 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:04. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:31:31.848 | Socket (1) | CloseSocket call. 2026-01-14 09:31:31.849 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:31.849 | Socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:31.849 | Socket (1) | Closed. 2026-01-14 09:31:31.849 | Historical data download thread signaled to stop. 2026-01-14 09:31:31.849 | HD Request # 34 | Received 36106 Market Depth data records from 2026-01-14 09:31:05.242000 to 2026-01-14 09:31:18.606000 (13.4 seconds. Delay: 13.2 seconds) and wrote 36106 records for NQH6.CME 2026-01-14 09:31:31.850 | HD Request # 34 | Completion time: 12s. 2026-01-14 09:31:31.850 | HD Request # 34 | Market Depth data download complete for NQH6.CME. Unique request ID: 142 2026-01-14 09:31:31.850 | Removing historical data download ID 142. 2026-01-14 09:31:31.850 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:31:31.856 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:31:31.856 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:31:31.856 | 2026-01-14 09:31:31.856 | No download requests in the queue to start downloads for. 2026-01-14 09:31:31.878 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:31:31.882 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:31.950 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:31:31.950 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:31:31.951 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:31:31.954 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:31.958 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:31:31.969 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:31.988 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:31:31.991 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:32.100 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:31:32.111 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:32.189 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:31:32.205 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:32.205 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | CloseSocket call. 2026-01-14 09:31:32.205 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:32.206 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | Socket gracefully closed by remote side. 2026-01-14 09:31:32.206 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (11) | Closed. 2026-01-14 09:31:32.234 | HD Request # 37 | Decompressing data. 2026-01-14 09:31:32.297 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:31:32.596 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:31:32.602 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 138, 2026-01-14 09:31:32.943 | HD Request # 37 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:31:04.000000 2026-01-14 09:31:32.943 | Socket (10) | CloseSocket call. 2026-01-14 09:31:32.943 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:32.943 | Historical data download thread signaled to stop. 2026-01-14 09:31:32.944 | HD Request # 37 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:05.000000. 2026-01-14 09:31:32.944 | HD Request # 37 | Received 26 Intraday data records from 2026-01-14 09:31:04.000000 to 2026-01-14 09:31:29.000000 (25.0 seconds. Delay: 3.9 seconds) and wrote 25 records for NISS-NYSE 2026-01-14 09:31:32.944 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:31:32.944 | Socket (10) | Closed. 2026-01-14 09:31:32.951 | HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:29.000000 2026-01-14 09:31:32.951 | Added 24 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:31:32.951 | HD Request # 37 | Completion time: 5s. 2026-01-14 09:31:32.951 | HD Request # 37 | Intraday data download complete for NISS-NYSE. Unique request ID: 136 2026-01-14 09:31:32.951 | Removing historical data download ID 136. 2026-01-14 09:31:32.951 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:31:32.951 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:31:32.951 | HD Request # 37 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:32.951 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 136 has completed. 2026-01-14 09:31:32.951 | 2026-01-14 09:31:32.951 | Triggering next historical data download in queue. 2026-01-14 09:31:32.951 | HD Request # 38 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:31:32.952 | HD Request # 38 | Download start date-time: 2026-01-14 09:31:04.000000. File last date-time: 2026-01-14 09:31:04.208002 2026-01-14 09:31:32.952 | HD Request # 38 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:31:32.952 | Socket (1) | Creating socket. 2026-01-14 09:31:32.952 | Socket (1) | New receive buffer size: 0 2026-01-14 09:31:32.952 | Socket (1) | Connecting to IP: 64.152.155.113. 2026-01-14 09:31:33.155 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:31:33.155 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:31:33.155 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:31:33.155 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:31:33.197 | NTP Client | Received Packet | RoundTripDelay=0.04199075698852539, SystemClockOffset=-0.013640165328979492 2026-01-14 09:31:33.329 | NTP Client | Received Packet | RoundTripDelay=0.1739969253540039, SystemClockOffset=-0.011633872985839844 2026-01-14 09:31:33.381 | NTP Client | Received Packet | RoundTripDelay=0.22490882873535156, SystemClockOffset=-0.03580522537231445 2026-01-14 09:31:33.695 | HD Request # 38 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:33.695 | HD Request # 38 | Sending historical data logon request message. 2026-01-14 09:31:34.133 | HD Request # 38 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:04. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:31:34.139 | NTP Client | Performed system clock adjustment of -13640.165328979492 microseconds. 2026-01-14 09:31:34.472 | HD Request # 38 | Decompressing data. 2026-01-14 09:31:35.045 | HD Request # 38 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:31:04.000000 2026-01-14 09:31:35.046 | Socket (1) | CloseSocket call. 2026-01-14 09:31:35.046 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:35.046 | Historical data download thread signaled to stop. 2026-01-14 09:31:35.046 | HD Request # 38 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:05.000000. 2026-01-14 09:31:35.046 | HD Request # 38 | Received 29 Intraday data records from 2026-01-14 09:31:04.000000 to 2026-01-14 09:31:32.000000 (28.0 seconds. Delay: 3.0 seconds) and wrote 28 records for TRIN-NYSE 2026-01-14 09:31:35.046 | Socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:35.047 | Socket (1) | Closed. 2026-01-14 09:31:35.054 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:32.000000 2026-01-14 09:31:35.054 | Added 24 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:31:35.054 | HD Request # 38 | Completion time: 3s. 2026-01-14 09:31:35.054 | HD Request # 38 | Intraday data download complete for TRIN-NYSE. Unique request ID: 137 2026-01-14 09:31:35.054 | Removing historical data download ID 137. 2026-01-14 09:31:35.054 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:31:35.054 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:31:35.054 | HD Request # 38 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:35.054 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 137 has completed. 2026-01-14 09:31:35.054 | 2026-01-14 09:31:35.054 | Triggering next historical data download in queue. 2026-01-14 09:31:35.054 | HD Request # 39 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:31:35.054 | HD Request # 39 | Download start date-time: 2026-01-14 09:30:59.000000. File last date-time: 2026-01-14 09:30:59.467007 2026-01-14 09:31:35.054 | HD Request # 39 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:31:35.055 | Socket (1) | Creating socket. 2026-01-14 09:31:35.055 | Socket (1) | New receive buffer size: 0 2026-01-14 09:31:35.055 | Socket (1) | Connecting to IP: 67.214.125.5. 2026-01-14 09:31:35.971 | HD Request # 39 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:35.971 | HD Request # 39 | Sending historical data logon request message. 2026-01-14 09:31:36.904 | HD Request # 39 | Requesting Intraday data. Start date-time: 2026-01-14 09:30:59. Record interval: 0. Symbol: NQH26 2026-01-14 09:31:37.286 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:31:37.286 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:31:37.395 | HD Request # 39 | Decompressing data. 2026-01-14 09:31:38.124 | HD Request # 39 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:30:59.023000 2026-01-14 09:31:38.629 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:31:39.003 | Socket (1) | CloseSocket call. 2026-01-14 09:31:39.003 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:39.003 | Historical data download thread signaled to stop. 2026-01-14 09:31:39.003 | HD Request # 39 | Timestamp of first Intraday data file record written: 2026-01-14 09:30:59.554000. 2026-01-14 09:31:39.003 | HD Request # 39 | Received 3704 Intraday data records from 2026-01-14 09:30:59.023000 to 2026-01-14 09:31:36.640006 (37.6 seconds. Delay: 2.4 seconds) and wrote 3675 records for NQH6.CME 2026-01-14 09:31:39.004 | Socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:39.004 | Socket (1) | Closed. 2026-01-14 09:31:39.010 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:36.640006 2026-01-14 09:31:39.010 | HD Request # 39 | Completion time: 4s. 2026-01-14 09:31:39.010 | HD Request # 39 | Intraday data download complete for NQH6.CME. Unique request ID: 138 2026-01-14 09:31:39.010 | Removing historical data download ID 138. 2026-01-14 09:31:39.010 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:31:39.010 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:31:39.010 | HD Request # 39 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:39.010 | 2026-01-14 09:31:39.010 | Triggering next historical data download in queue. 2026-01-14 09:31:39.010 | HD Request # 40 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:31:39.010 | HD Request # 40 | Download start date-time: 2026-01-14 09:31:00.000000. File last date-time: 2026-01-14 09:31:00.667003 2026-01-14 09:31:39.010 | HD Request # 40 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:31:39.010 | Socket (1) | Creating socket. 2026-01-14 09:31:39.011 | Socket (1) | New receive buffer size: 0 2026-01-14 09:31:39.011 | Socket (1) | Connecting to IP: 69.39.70.248. 2026-01-14 09:31:39.014 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.015 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:31:39.095 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.095 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:31:39.096 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.096 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:31:39.101 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.101 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:31:39.105 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.106 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:31:39.125 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:31:39.155 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.155 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:31:39.186 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:39.187 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:31:39.203 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:31:39.240 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:39.248 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:31:39.287 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.287 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.287 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:31:39.295 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.295 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:31:39.300 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:31:39.372 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:31:39.409 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:31:39.470 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:31:39.593 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.593 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.593 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:31:39.612 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:31:39.633 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:39.638 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:39.640 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.663 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:31:39.664 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:31:39.665 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.665 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:31:39.708 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:31:39.726 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.812 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:39.812 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:31:39.837 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:31:39.872 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:31:39.944 | HD Request # 40 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:39.944 | HD Request # 40 | Sending historical data logon request message. 2026-01-14 09:31:40.087 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:31:40.255 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:40.257 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:40.257 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:40.286 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:31:40.322 | HD Request # 40 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:00. Record interval: 0. Symbol: ESH26 2026-01-14 09:31:40.341 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:40.345 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:40.364 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:40.745 | HD Request # 40 | Decompressing data. 2026-01-14 09:31:41.045 | HD Request # 40 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:31:00.029000 2026-01-14 09:31:41.319 | Socket (1) | CloseSocket call. 2026-01-14 09:31:41.319 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:41.319 | Historical data download thread signaled to stop. 2026-01-14 09:31:41.319 | HD Request # 40 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:00.791000. 2026-01-14 09:31:41.320 | HD Request # 40 | Received 4964 Intraday data records from 2026-01-14 09:31:00.029000 to 2026-01-14 09:31:38.588012 (38.6 seconds. Delay: 2.7 seconds) and wrote 4847 records for ESH6.CME 2026-01-14 09:31:41.320 | Socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:41.320 | Socket (1) | Closed. 2026-01-14 09:31:41.328 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:38.588012 2026-01-14 09:31:41.328 | HD Request # 40 | Completion time: 2s. 2026-01-14 09:31:41.328 | HD Request # 40 | Intraday data download complete for ESH6.CME. Unique request ID: 139 2026-01-14 09:31:41.328 | Removing historical data download ID 139. 2026-01-14 09:31:41.328 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:31:41.328 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:31:41.328 | HD Request # 40 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:41.328 | 2026-01-14 09:31:41.328 | Triggering next historical data download in queue. 2026-01-14 09:31:41.328 | HD Request # 41 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:31:41.328 | HD Request # 41 | Download start date-time: 2026-01-14 09:31:12.000000. File last date-time: 2026-01-14 09:31:12.541000 2026-01-14 09:31:41.328 | HD Request # 41 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:31:41.329 | Socket (1) | Creating socket. 2026-01-14 09:31:41.329 | Socket (1) | New receive buffer size: 0 2026-01-14 09:31:41.329 | Socket (1) | Connecting to IP: 64.152.155.17. 2026-01-14 09:31:41.432 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.433 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:31:41.435 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.437 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:31:41.438 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.438 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:31:41.461 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.463 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:31:41.463 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.464 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:31:41.470 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.471 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:31:41.552 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:31:41.555 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:31:41.627 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:31:41.628 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:31:41.643 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:31:41.658 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:41.658 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:31:41.857 | + Loading additional symbol data. 2026-01-14 09:31:41.881 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:41.891 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:31:41.896 | + Loading additional symbol data. 2026-01-14 09:31:41.942 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:31:41.974 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:31:41.979 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:31:41.996 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:31:42.019 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:31:42.021 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:42.021 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:42.021 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:31:42.041 | HD Request # 41 | Setting DTC encoding to Binary VLS 2026-01-14 09:31:42.041 | HD Request # 41 | Sending historical data logon request message. 2026-01-14 09:31:42.143 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:31:42.149 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:42.153 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:42.177 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:31:42.209 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:42.209 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:31:42.451 | HD Request # 41 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:12. Record interval: 0. Symbol: RTYH26 2026-01-14 09:31:42.583 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:42.583 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:31:42.809 | + Loading additional symbol data. 2026-01-14 09:31:42.820 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:42.860 | HD Request # 41 | Decompressing data. 2026-01-14 09:31:42.866 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:31:43.065 | HD Request # 41 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:31:12.143000 2026-01-14 09:31:43.065 | Socket (1) | CloseSocket call. 2026-01-14 09:31:43.065 | Socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:31:43.066 | Historical data download thread signaled to stop. 2026-01-14 09:31:43.066 | HD Request # 41 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:12.928000. 2026-01-14 09:31:43.066 | HD Request # 41 | Received 709 Intraday data records from 2026-01-14 09:31:12.143000 to 2026-01-14 09:31:40.818001 (28.7 seconds. Delay: 2.2 seconds) and wrote 704 records for RTYH6.CME 2026-01-14 09:31:43.066 | Socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:31:43.066 | Socket (1) | Closed. 2026-01-14 09:31:43.073 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:31:40.818001 2026-01-14 09:31:43.073 | HD Request # 41 | Completion time: 2s. 2026-01-14 09:31:43.073 | HD Request # 41 | Intraday data download complete for RTYH6.CME. Unique request ID: 140 2026-01-14 09:31:43.073 | Removing historical data download ID 140. 2026-01-14 09:31:43.073 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:31:43.073 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:31:43.073 | HD Request # 41 | Enabling Intraday chart updating for symbol. 2026-01-14 09:31:43.073 | 2026-01-14 09:31:43.073 | No download requests in the queue to start downloads for. 2026-01-14 09:31:43.365 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:31:43.367 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:43.367 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:43.395 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:31:43.425 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:43.666 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:43.671 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:31:43.673 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:31:43.766 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:31:52.343 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:31:52.344 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:31:52.344 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:32:02.376 | File >> Disconnect selected. 2026-01-14 09:32:02.408 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:32:02.408 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:32:02.409 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:02.409 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:32:02.409 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:32:02.409 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:32:02.409 | DTC Client socket (3) | Closed. 2026-01-14 09:32:02.409 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:32:02.409 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:02.410 | DTC Client socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:32:02.410 | DTC Client socket (9) | Closed. 2026-01-14 09:32:02.410 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:32:02.410 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:32:02.410 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:32:02.410 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:32:02.410 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:02.411 | DTC Client socket (4) | CloseSocket call. 2026-01-14 09:32:02.411 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:02.411 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:32:02.411 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:32:02.411 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:32:02.411 | DTC Client socket (2) | Closed. 2026-01-14 09:32:02.412 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:32:02.412 | DTC Client socket (4) | Closed. 2026-01-14 09:32:03.156 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:32:03.156 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:32:03.156 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:32:03.156 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:32:03.203 | NTP Client | Received Packet | RoundTripDelay=0.04798460006713867, SystemClockOffset=-0.023305654525756836 2026-01-14 09:32:03.340 | NTP Client | Received Packet | RoundTripDelay=0.18499755859375, SystemClockOffset=-0.02379465103149414 2026-01-14 09:32:03.392 | NTP Client | Received Packet | RoundTripDelay=0.2369856834411621, SystemClockOffset=-0.04851508140563965 2026-01-14 09:32:03.537 | 2026-01-14 09:32:03.537 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:32:03.537 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:32:03.537 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:32:03.537 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:32:03.538 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:32:03.538 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:32:03.542 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:32:03.542 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:32:03.542 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:32:03.542 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:32:04.136 | NTP Client | Performed system clock adjustment of -23794.65103149414 microseconds. 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:32:05.995 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:32:05.996 | No download requests in the queue to start downloads for. 2026-01-14 09:32:05.997 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:32:05.997 | Using symbol data fast lookup vector 2026-01-14 09:32:05.997 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:32:05.997 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:32:05.997 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:32:05.998 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:32:05.998 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:32:05.998 | Triggering next historical data download in queue. 2026-01-14 09:32:05.998 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 143 2026-01-14 09:32:05.998 | DTC Client socket (2) | Creating socket. 2026-01-14 09:32:05.998 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:32:05.998 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2026-01-14 09:32:06.001 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:32:06.001 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:32:06.001 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:32:06.001 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:32:06.001 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 144 2026-01-14 09:32:06.001 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:32:06.001 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:32:06.001 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:32:06.001 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:32:06.001 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 145 2026-01-14 09:32:06.001 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:32:06.001 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:32:06.001 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:32:06.001 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:32:06.001 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 146 2026-01-14 09:32:06.004 | Delaying start of download for VOLX. 2026-01-14 09:32:06.004 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:32:06.004 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:32:06.004 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:32:06.023 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:32:06.023 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:32:06.023 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 443 2026-01-14 09:32:06.023 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:32:06.024 | DTC Client socket (3) | Creating socket. 2026-01-14 09:32:06.024 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:32:06.024 | DTC Client socket (3) | Connecting to IP: 69.39.70.248. 2026-01-14 09:32:06.024 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:32:06.024 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:32:06.024 | Triggering next historical data download in queue. 2026-01-14 09:32:06.025 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:32:06.025 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:32:06.025 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:32:06.077 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:32:06.077 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 6 Service code: cme 2026-01-14 09:32:06.077 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 6 2026-01-14 09:32:06.077 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:32:06.077 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:32:06.077 | Triggering next historical data download in queue. 2026-01-14 09:32:06.108 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:32:06.108 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:32:06.108 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:32:06.108 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:32:06.108 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:32:06.108 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:32:06.108 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:32:06.108 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:32:06.132 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:32:06.132 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 9 Service code: cme 2026-01-14 09:32:06.132 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 9 2026-01-14 09:32:06.848 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:32:06.848 | Denali Data Feed | Sending logon request message. 2026-01-14 09:32:07.720 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:32:07.720 | SC Data with Depth | Sending logon request message. 2026-01-14 09:32:07.814 | Denali Data Feed | Received logon response. 2026-01-14 09:32:07.814 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:32:07.814 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:07.814 | Denali Data Feed | Successfully connected. 2026-01-14 09:32:07.814 | Denali Data Feed | Trading is not supported. 2026-01-14 09:32:07.814 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:32:07.814 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:32:07.814 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:32:07.814 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:32:07.814 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:32:07.814 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:32:08.422 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:32:08.422 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:32:08.422 | Triggering next historical data download in queue. 2026-01-14 09:32:08.422 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.422 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:32:08.422 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:32:08.422 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.422 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.422 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.422 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.422 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:32:08.423 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:32:08.423 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:32:08.423 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:32:08.423 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:32:08.423 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:32:08.423 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:32:08.423 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:32:08.423 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:32:08.423 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.423 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:32:08.424 | HD Request # 42 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:32:08.424 | HD Request # 42 | Download start date-time: 2026-01-14 09:32:02.409227. 2026-01-14 09:32:08.424 | HD Request # 42 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:32:08.424 | Socket (4) | Creating socket. 2026-01-14 09:32:08.424 | Socket (4) | New receive buffer size: 0 2026-01-14 09:32:08.424 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:32:08.729 | SC Data with Depth | Received logon response. 2026-01-14 09:32:08.729 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:32:08.729 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:08.729 | SC Data with Depth | Successfully connected. 2026-01-14 09:32:08.729 | SC Data with Depth | Trading is not supported. 2026-01-14 09:32:08.729 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:32:08.729 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:32:08.729 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:32:08.729 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:32:08.729 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:32:10.994 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:32:10.994 | Denali Data Feed (Market Orders Data) | Connecting to the server ds32.sierracharts.com. Port 10060 2026-01-14 09:32:10.994 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:32:10.995 | DTC Client socket (9) | Creating socket. 2026-01-14 09:32:10.995 | DTC Client socket (9) | New receive buffer size: 0 2026-01-14 09:32:10.995 | DTC Client socket (9) | Connecting to IP: 69.39.70.248. 2026-01-14 09:32:10.996 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:32:10.996 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:32:10.996 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:32:11.247 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:32:11.247 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:32:11.247 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:32:11.247 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:32:11.247 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:32:11.247 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:32:11.247 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:32:11.247 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:32:11.807 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:32:11.807 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:32:13.270 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:32:13.958 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:32:13.958 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:32:13.990 | HD Request # 42 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:13.990 | HD Request # 42 | Sending historical data logon request message. 2026-01-14 09:32:14.523 | HD Request # 42 | Requesting market depth data. Start date-time: 2026-01-14 09:32:02. Symbol: ESH26 2026-01-14 09:32:14.914 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:32:14.914 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:32:14.916 | HD Request # 42 | Decompressing data. 2026-01-14 09:32:14.957 | HD Request # 42 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:32:02.410000 2026-01-14 09:32:15.363 | Socket (4) | CloseSocket call. 2026-01-14 09:32:15.363 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:15.364 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:32:15.364 | Socket (4) | Closed. 2026-01-14 09:32:15.365 | Historical data download thread signaled to stop. 2026-01-14 09:32:15.366 | HD Request # 42 | Timestamp of first market depth data file record written: 2026-01-14 09:32:02.410000. 2026-01-14 09:32:15.366 | HD Request # 42 | Received 12922 Market Depth data records from 2026-01-14 09:32:02.410000 to 2026-01-14 09:32:13.372000 (11.0 seconds. Delay: 2.0 seconds) and wrote 12922 records for ESH6.CME 2026-01-14 09:32:15.366 | HD Request # 42 | Completion time: 7s. 2026-01-14 09:32:15.366 | HD Request # 42 | Market Depth data download complete for ESH6.CME. Unique request ID: 150 2026-01-14 09:32:15.366 | Removing historical data download ID 150. 2026-01-14 09:32:15.366 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:32:15.375 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:32:15.375 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:32:15.375 | 2026-01-14 09:32:15.375 | Triggering next historical data download in queue. 2026-01-14 09:32:15.375 | HD Request # 43 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:32:15.375 | HD Request # 43 | Download start date-time: 2026-01-14 09:32:02.409127. 2026-01-14 09:32:15.375 | HD Request # 43 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:32:15.375 | Socket (4) | Creating socket. 2026-01-14 09:32:15.376 | Socket (4) | New receive buffer size: 0 2026-01-14 09:32:15.376 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:32:15.450 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:32:15.454 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.457 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:32:15.467 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.517 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:32:15.521 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.525 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:32:15.536 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.536 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:32:15.547 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.618 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:32:15.621 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.714 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:32:15.724 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 149, 2026-01-14 09:32:15.973 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:32:16.729 | HD Request # 44 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:32:16.729 | HD Request # 44 | Download start date-time: 2026-01-14 09:32:01.000000. File last date-time: 2026-01-14 09:32:01.639000 2026-01-14 09:32:16.730 | HD Request # 44 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:32:16.730 | Socket (10) | Creating socket. 2026-01-14 09:32:16.730 | Socket (10) | New receive buffer size: 0 2026-01-14 09:32:16.730 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:32:17.871 | HD Request # 44 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:17.871 | HD Request # 44 | Sending historical data logon request message. 2026-01-14 09:32:18.315 | HD Request # 44 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:01. Record interval: 0. Symbol: VOLX 2026-01-14 09:32:18.760 | HD Request # 44 | Decompressing data. 2026-01-14 09:32:19.018 | HD Request # 44 | Receiving Intraday data for VOLX starting at 2026-01-14 09:32:01.215000 2026-01-14 09:32:19.019 | Socket (10) | CloseSocket call. 2026-01-14 09:32:19.019 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:19.019 | Historical data download thread signaled to stop. 2026-01-14 09:32:19.019 | HD Request # 44 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:02.142000. 2026-01-14 09:32:19.020 | HD Request # 44 | Received 21 Intraday data records from 2026-01-14 09:32:01.215000 to 2026-01-14 09:32:14.546001 (13.3 seconds. Delay: 4.5 seconds) and wrote 18 records for VOLX 2026-01-14 09:32:19.020 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:32:19.020 | Socket (10) | Closed. 2026-01-14 09:32:19.030 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:14.546001 2026-01-14 09:32:19.030 | HD Request # 44 | Completion time: 3s. 2026-01-14 09:32:19.030 | HD Request # 44 | Intraday data download complete for VOLX. Unique request ID: 143 2026-01-14 09:32:19.030 | Removing historical data download ID 143. 2026-01-14 09:32:19.030 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:32:19.030 | Intraday chart data file opened for VOLX 2026-01-14 09:32:19.030 | HD Request # 44 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:19.030 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 143 has completed. 2026-01-14 09:32:19.030 | 2026-01-14 09:32:19.030 | Triggering next historical data download in queue. 2026-01-14 09:32:19.030 | HD Request # 45 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:32:19.030 | HD Request # 45 | Download start date-time: 2026-01-14 09:32:01.000000. File last date-time: 2026-01-14 09:32:01.707002 2026-01-14 09:32:19.030 | HD Request # 45 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:32:19.030 | Socket (10) | Creating socket. 2026-01-14 09:32:19.030 | Socket (10) | New receive buffer size: 0 2026-01-14 09:32:19.030 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:32:20.675 | HD Request # 45 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:20.675 | HD Request # 45 | Sending historical data logon request message. 2026-01-14 09:32:21.361 | HD Request # 45 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:01. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:32:22.134 | HD Request # 45 | Decompressing data. 2026-01-14 09:32:22.357 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:32:22.809 | HD Request # 45 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:32:01.000000 2026-01-14 09:32:22.809 | Socket (10) | CloseSocket call. 2026-01-14 09:32:22.809 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:22.809 | Historical data download thread signaled to stop. 2026-01-14 09:32:22.809 | HD Request # 45 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:02.000000. 2026-01-14 09:32:22.809 | HD Request # 45 | Received 20 Intraday data records from 2026-01-14 09:32:01.000000 to 2026-01-14 09:32:20.000000 (19.0 seconds. Delay: 2.8 seconds) and wrote 19 records for TICK-NYSE 2026-01-14 09:32:22.810 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:32:22.810 | Socket (10) | Closed. 2026-01-14 09:32:22.817 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:20.000000 2026-01-14 09:32:22.817 | Added 22 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:32:22.817 | HD Request # 45 | Completion time: 3s. 2026-01-14 09:32:22.817 | HD Request # 45 | Intraday data download complete for TICK-NYSE. Unique request ID: 144 2026-01-14 09:32:22.817 | Removing historical data download ID 144. 2026-01-14 09:32:22.817 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:32:22.817 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:32:22.817 | HD Request # 45 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:22.817 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 144 has completed. 2026-01-14 09:32:22.817 | 2026-01-14 09:32:22.817 | Triggering next historical data download in queue. 2026-01-14 09:32:22.817 | HD Request # 46 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:32:22.817 | HD Request # 46 | Download start date-time: 2026-01-14 09:32:01.000000. File last date-time: 2026-01-14 09:32:01.707001 2026-01-14 09:32:22.817 | HD Request # 46 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:32:22.817 | Socket (10) | Creating socket. 2026-01-14 09:32:22.817 | Socket (10) | New receive buffer size: 0 2026-01-14 09:32:22.817 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:32:23.514 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | Creating socket. Using TLS 1.2. 2026-01-14 09:32:23.514 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | New receive buffer size: 0 2026-01-14 09:32:23.514 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | Connecting to IP: 216.66.0.130. 2026-01-14 09:32:24.155 | HD Request # 46 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:24.155 | HD Request # 46 | Sending historical data logon request message. 2026-01-14 09:32:24.915 | HD Request # 46 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:01. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:32:25.375 | HD Request # 43 | Sending historical data logon request message. 2026-01-14 09:32:25.987 | HD Request # 46 | Decompressing data. 2026-01-14 09:32:26.190 | HD Request # 46 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:32:01.000000 2026-01-14 09:32:26.190 | Socket (10) | CloseSocket call. 2026-01-14 09:32:26.190 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:26.190 | Historical data download thread signaled to stop. 2026-01-14 09:32:26.191 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:32:26.191 | HD Request # 46 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:02.000000. 2026-01-14 09:32:26.191 | Socket (10) | Closed. 2026-01-14 09:32:26.191 | HD Request # 46 | Received 25 Intraday data records from 2026-01-14 09:32:01.000000 to 2026-01-14 09:32:25.000000 (24.0 seconds. Delay: 1.2 seconds) and wrote 24 records for NISS-NYSE 2026-01-14 09:32:26.198 | HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:25.000000 2026-01-14 09:32:26.198 | HD Request # 46 | Completion time: 4s. 2026-01-14 09:32:26.198 | HD Request # 46 | Intraday data download complete for NISS-NYSE. Unique request ID: 145 2026-01-14 09:32:26.198 | Removing historical data download ID 145. 2026-01-14 09:32:26.198 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:32:26.198 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:32:26.198 | HD Request # 46 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:26.198 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 145 has completed. 2026-01-14 09:32:26.198 | 2026-01-14 09:32:26.198 | Triggering next historical data download in queue. 2026-01-14 09:32:26.198 | HD Request # 47 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:32:26.198 | HD Request # 47 | Download start date-time: 2026-01-14 09:32:01.000000. File last date-time: 2026-01-14 09:32:01.707002 2026-01-14 09:32:26.198 | HD Request # 47 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:32:26.198 | Socket (10) | Creating socket. 2026-01-14 09:32:26.199 | Socket (10) | New receive buffer size: 0 2026-01-14 09:32:26.199 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:32:26.729 | HD Request # 43 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:26.729 | HD Request # 43 | Sending historical data logon request message. 2026-01-14 09:32:26.729 | Socket (4) | CloseSocket call. 2026-01-14 09:32:26.729 | Socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 2026-01-14 09:32:26.729 | Socket (4) | Write has completed. Shutdown being performed. 2026-01-14 09:32:26.729 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:26.730 | HD Request # 43 | Error downloading historical Market Depth data for NQH6.CME. Historical data logon error: Unsupported protocol version 2026-01-14 09:32:26.730 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:32:26.730 | Socket (4) | Closed. 2026-01-14 09:32:26.731 | Historical data download thread signaled to stop. 2026-01-14 09:32:26.731 | HD Request # 43 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NQH6.CME 2026-01-14 09:32:26.731 | HD Request # 43 | Completion time: 11s. 2026-01-14 09:32:26.731 | HD Request # 43 | Market Depth data download complete for NQH6.CME. Unique request ID: 152 2026-01-14 09:32:26.731 | Removing historical data download ID 152. 2026-01-14 09:32:26.731 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:32:26.731 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:32:26.731 | 2026-01-14 09:32:26.731 | No download requests in the queue to start downloads for. 2026-01-14 09:32:26.829 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:32:27.361 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:32:27.361 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:32:27.853 | HD Request # 47 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:27.853 | HD Request # 47 | Sending historical data logon request message. 2026-01-14 09:32:28.613 | HD Request # 47 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:01. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:32:29.395 | HD Request # 47 | Decompressing data. 2026-01-14 09:32:30.201 | HD Request # 47 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:32:01.000000 2026-01-14 09:32:30.202 | Socket (10) | CloseSocket call. 2026-01-14 09:32:30.202 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:30.202 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:32:30.202 | Historical data download thread signaled to stop. 2026-01-14 09:32:30.202 | Socket (10) | Closed. 2026-01-14 09:32:30.202 | HD Request # 47 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:02.000000. 2026-01-14 09:32:30.202 | HD Request # 47 | Received 28 Intraday data records from 2026-01-14 09:32:01.000000 to 2026-01-14 09:32:28.000000 (27.0 seconds. Delay: 2.2 seconds) and wrote 27 records for TRIN-NYSE 2026-01-14 09:32:30.212 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:28.000000 2026-01-14 09:32:30.212 | Added 3 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:32:30.212 | HD Request # 47 | Completion time: 4s. 2026-01-14 09:32:30.212 | HD Request # 47 | Intraday data download complete for TRIN-NYSE. Unique request ID: 146 2026-01-14 09:32:30.212 | Removing historical data download ID 146. 2026-01-14 09:32:30.212 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:32:30.212 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:32:30.212 | HD Request # 47 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:30.212 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 146 has completed. 2026-01-14 09:32:30.212 | 2026-01-14 09:32:30.212 | Triggering next historical data download in queue. 2026-01-14 09:32:30.223 | HD Request # 48 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:32:30.223 | HD Request # 48 | Download start date-time: 2026-01-14 09:31:20.000000. File last date-time: 2026-01-14 09:31:20.760000 2026-01-14 09:32:30.223 | HD Request # 48 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:32:30.223 | Socket (4) | Creating socket. 2026-01-14 09:32:30.223 | Socket (4) | New receive buffer size: 0 2026-01-14 09:32:30.223 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-01-14 09:32:31.010 | HD Request # 48 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:31.010 | HD Request # 48 | Sending historical data logon request message. 2026-01-14 09:32:31.581 | HD Request # 48 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:20. Record interval: 0. Symbol: NQH26 2026-01-14 09:32:31.994 | HD Request # 48 | Decompressing data. 2026-01-14 09:32:32.001 | HD Request # 48 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:31:20.037000 2026-01-14 09:32:32.371 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:32:32.532 | Socket (4) | CloseSocket call. 2026-01-14 09:32:32.532 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:32.533 | Historical data download thread signaled to stop. 2026-01-14 09:32:32.533 | HD Request # 48 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:20.791000. 2026-01-14 09:32:32.533 | HD Request # 48 | Received 5664 Intraday data records from 2026-01-14 09:31:20.037000 to 2026-01-14 09:32:28.631003 (68.6 seconds. Delay: 3.9 seconds) and wrote 5543 records for NQH6.CME 2026-01-14 09:32:32.539 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:32:32.539 | Socket (4) | Closed. 2026-01-14 09:32:32.541 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:28.631003 2026-01-14 09:32:32.541 | HD Request # 48 | Completion time: 2s. 2026-01-14 09:32:32.541 | HD Request # 48 | Intraday data download complete for NQH6.CME. Unique request ID: 147 2026-01-14 09:32:32.541 | Removing historical data download ID 147. 2026-01-14 09:32:32.541 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:32:32.541 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:32:32.541 | HD Request # 48 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:32.541 | 2026-01-14 09:32:32.541 | Triggering next historical data download in queue. 2026-01-14 09:32:32.541 | HD Request # 49 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:32:32.541 | HD Request # 49 | Download start date-time: 2026-01-14 09:31:20.000000. File last date-time: 2026-01-14 09:31:20.779004 2026-01-14 09:32:32.541 | HD Request # 49 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:32:32.541 | Socket (4) | Creating socket. 2026-01-14 09:32:32.541 | Socket (4) | New receive buffer size: 0 2026-01-14 09:32:32.541 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:32:32.569 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:32.609 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:32.612 | : Array is unallocated. 2026-01-14 09:32:32.614 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:32:32.615 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:32.640 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:32.674 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:32.725 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:32.725 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:32.743 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:32.835 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:32.973 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:32.976 | : Array is unallocated. 2026-01-14 09:32:32.979 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:33.050 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:33.157 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:32:33.157 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:32:33.157 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:32:33.157 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:32:33.202 | NTP Client | Received Packet | RoundTripDelay=0.044991493225097656, SystemClockOffset=-0.0025472640991210938 2026-01-14 09:32:33.331 | NTP Client | Received Packet | RoundTripDelay=0.17399835586547852, SystemClockOffset=0.0009920597076416016 2026-01-14 09:32:33.369 | NTP Client | Received Packet | RoundTripDelay=0.21196651458740234, SystemClockOffset=-0.008234500885009766 2026-01-14 09:32:33.382 | NTP Client | Received Packet | RoundTripDelay=0.22498273849487305, SystemClockOffset=-0.02327275276184082 2026-01-14 09:32:33.677 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:34.151 | NTP Client | Performed system clock adjustment of -5390.88249206543 microseconds. 2026-01-14 09:32:36.023 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:32:36.024 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:32:36.275 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | CloseSocket call. 2026-01-14 09:32:36.275 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:36.276 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | Socket gracefully closed by remote side. 2026-01-14 09:32:36.276 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (11) | Closed. 2026-01-14 09:32:36.417 | HD Request # 49 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:36.417 | HD Request # 49 | Sending historical data logon request message. 2026-01-14 09:32:37.215 | HD Request # 49 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:20. Record interval: 0. Symbol: RTYH26 2026-01-14 09:32:37.380 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:32:37.750 | HD Request # 49 | Decompressing data. 2026-01-14 09:32:37.945 | HD Request # 49 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:31:20.060000 2026-01-14 09:32:38.211 | Socket (4) | CloseSocket call. 2026-01-14 09:32:38.211 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:38.212 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:32:38.212 | Socket (4) | Closed. 2026-01-14 09:32:38.212 | Historical data download thread signaled to stop. 2026-01-14 09:32:38.212 | HD Request # 49 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:20.858000. 2026-01-14 09:32:38.212 | HD Request # 49 | Received 1733 Intraday data records from 2026-01-14 09:31:20.060000 to 2026-01-14 09:32:36.489002 (76.4 seconds. Delay: 1.7 seconds) and wrote 1716 records for RTYH6.CME 2026-01-14 09:32:38.220 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:36.489002 2026-01-14 09:32:38.220 | HD Request # 49 | Completion time: 6s. 2026-01-14 09:32:38.220 | HD Request # 49 | Intraday data download complete for RTYH6.CME. Unique request ID: 148 2026-01-14 09:32:38.220 | Removing historical data download ID 148. 2026-01-14 09:32:38.220 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:32:38.220 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:32:38.220 | HD Request # 49 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:38.220 | 2026-01-14 09:32:38.220 | Triggering next historical data download in queue. 2026-01-14 09:32:38.220 | HD Request # 50 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:32:38.220 | HD Request # 50 | Download start date-time: 2026-01-14 09:31:20.000000. File last date-time: 2026-01-14 09:31:20.859000 2026-01-14 09:32:38.220 | HD Request # 50 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:32:38.220 | Socket (4) | Creating socket. 2026-01-14 09:32:38.220 | Socket (4) | New receive buffer size: 0 2026-01-14 09:32:38.220 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:32:39.008 | HD Request # 50 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:39.008 | HD Request # 50 | Sending historical data logon request message. 2026-01-14 09:32:39.669 | HD Request # 50 | Requesting Intraday data. Start date-time: 2026-01-14 09:31:20. Record interval: 0. Symbol: ESH26 2026-01-14 09:32:39.929 | HD Request # 50 | Decompressing data. 2026-01-14 09:32:39.944 | HD Request # 50 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:31:20.043000 2026-01-14 09:32:40.354 | Socket (4) | CloseSocket call. 2026-01-14 09:32:40.354 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:40.354 | Historical data download thread signaled to stop. 2026-01-14 09:32:40.354 | HD Request # 50 | Timestamp of first Intraday data file record written: 2026-01-14 09:31:20.859001. 2026-01-14 09:32:40.355 | HD Request # 50 | Received 10176 Intraday data records from 2026-01-14 09:31:20.043000 to 2026-01-14 09:32:38.624001 (78.6 seconds. Delay: 1.7 seconds) and wrote 9935 records for ESH6.CME 2026-01-14 09:32:40.355 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:32:40.355 | Socket (4) | Closed. 2026-01-14 09:32:40.362 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:32:38.624001 2026-01-14 09:32:40.362 | HD Request # 50 | Completion time: 2s. 2026-01-14 09:32:40.362 | HD Request # 50 | Intraday data download complete for ESH6.CME. Unique request ID: 149 2026-01-14 09:32:40.362 | Removing historical data download ID 149. 2026-01-14 09:32:40.362 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:32:40.362 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:32:40.362 | HD Request # 50 | Enabling Intraday chart updating for symbol. 2026-01-14 09:32:40.362 | 2026-01-14 09:32:40.362 | No download requests in the queue to start downloads for. 2026-01-14 09:32:40.506 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.506 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:32:40.538 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.541 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:32:40.542 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.542 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:32:40.548 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.549 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:32:40.555 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.555 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:32:40.600 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.601 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:32:40.650 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:32:40.653 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:32:40.709 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:32:40.709 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:32:40.746 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:40.746 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:32:40.803 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:32:40.977 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:32:40.988 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:32:41.004 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:32:41.019 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:32:41.027 | + Loading additional symbol data. 2026-01-14 09:32:41.089 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:32:41.105 | + Loading additional symbol data. 2026-01-14 09:32:41.192 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:32:41.194 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:41.194 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:41.194 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:32:41.277 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:32:41.284 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:32:41.289 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:41.322 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:32:41.535 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:32:41.685 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:41.685 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:32:41.729 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:41.729 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:32:41.921 | + Loading additional symbol data. 2026-01-14 09:32:41.961 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:32:42.007 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:32:42.392 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:32:42.426 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:32:42.428 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:32:42.428 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:42.455 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:32:42.455 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:42.497 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:42.546 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:42.845 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:42.850 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:32:42.852 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:32:42.879 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:32:47.399 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:32:51.616 | File >> Disconnect selected. 2026-01-14 09:32:51.625 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:32:51.625 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:32:51.625 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:51.626 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:32:51.626 | DTC Client socket (1) | Closed. 2026-01-14 09:32:51.626 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:32:51.626 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:32:51.626 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:32:51.626 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:51.627 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:32:51.627 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:32:51.627 | DTC Client socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:32:51.627 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:32:51.627 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:32:51.627 | DTC Client socket (9) | Closed. 2026-01-14 09:32:51.627 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:51.627 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:32:51.627 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:32:51.627 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:32:51.627 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:32:51.628 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:32:51.628 | DTC Client socket (2) | Closed. 2026-01-14 09:32:51.630 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:32:51.630 | DTC Client socket (3) | Closed. 2026-01-14 09:32:52.589 | 2026-01-14 09:32:52.589 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:32:52.590 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:32:52.590 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:32:52.590 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:32:52.590 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:32:52.590 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:32:52.595 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:32:52.595 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:32:52.595 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:32:52.595 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:32:54.146 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:32:54.146 | No download requests in the queue to start downloads for. 2026-01-14 09:32:54.148 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:32:54.148 | Using symbol data fast lookup vector 2026-01-14 09:32:54.148 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:32:54.148 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-01-14 09:32:54.148 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:32:54.148 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:32:54.148 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:32:54.148 | Triggering next historical data download in queue. 2026-01-14 09:32:54.148 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 346 2026-01-14 09:32:54.148 | DTC Client socket (2) | Creating socket. 2026-01-14 09:32:54.149 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:32:54.149 | DTC Client socket (2) | Connecting to IP: 64.152.155.113. 2026-01-14 09:32:54.151 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:32:54.151 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:32:54.152 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:32:54.152 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:32:54.152 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 347 2026-01-14 09:32:54.152 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:32:54.152 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:32:54.152 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:32:54.152 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:32:54.152 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 348 2026-01-14 09:32:54.152 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:32:54.152 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:32:54.152 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:32:54.152 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:32:54.152 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 349 2026-01-14 09:32:54.154 | Delaying start of download for VOLX. 2026-01-14 09:32:54.154 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:32:54.154 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:32:54.154 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:32:54.161 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:32:54.161 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:32:54.161 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 2026-01-14 09:32:54.161 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:32:54.161 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:32:54.161 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:32:54.161 | Triggering next historical data download in queue. 2026-01-14 09:32:54.161 | DTC Client socket (3) | Creating socket. 2026-01-14 09:32:54.162 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:32:54.162 | DTC Client socket (3) | Connecting to IP: 64.152.155.17. 2026-01-14 09:32:54.184 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:32:54.184 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:32:54.184 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:32:54.184 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:32:54.184 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 6 Service code: cme 2026-01-14 09:32:54.184 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 6 2026-01-14 09:32:54.184 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:32:54.184 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:32:54.184 | Triggering next historical data download in queue. 2026-01-14 09:32:54.262 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:32:54.262 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 7 Service code: cme 2026-01-14 09:32:54.262 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 7 2026-01-14 09:32:54.287 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:32:54.287 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 8 Service code: cme 2026-01-14 09:32:54.287 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 8 2026-01-14 09:32:55.112 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:32:55.112 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:32:55.112 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:32:55.112 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:32:55.112 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:32:55.112 | Triggering next historical data download in queue. 2026-01-14 09:32:55.229 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:32:55.229 | SC Data with Depth | Sending logon request message. 2026-01-14 09:32:55.299 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:32:55.299 | Denali Data Feed | Sending logon request message. 2026-01-14 09:32:55.862 | SC Data with Depth | Received logon response. 2026-01-14 09:32:55.862 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:32:55.862 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:55.862 | SC Data with Depth | Successfully connected. 2026-01-14 09:32:55.862 | SC Data with Depth | Trading is not supported. 2026-01-14 09:32:55.862 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:32:55.862 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:32:55.862 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:32:55.862 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:32:55.862 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:32:56.314 | Denali Data Feed | Received logon response. 2026-01-14 09:32:56.314 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:32:56.314 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:32:56.314 | Denali Data Feed | Successfully connected. 2026-01-14 09:32:56.315 | Denali Data Feed | Trading is not supported. 2026-01-14 09:32:56.315 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:32:56.315 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:32:56.315 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:32:56.315 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:32:56.315 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:32:56.315 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:32:56.503 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:32:56.503 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:32:56.503 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:32:56.503 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:32:56.503 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:32:56.503 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:32:56.503 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:32:56.503 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:32:59.142 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:32:59.142 | Denali Data Feed (Market Orders Data) | Connecting to the server ds26.sierracharts.com. Port 10060 2026-01-14 09:32:59.142 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:32:59.142 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:32:59.142 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:32:59.142 | Triggering next historical data download in queue. 2026-01-14 09:32:59.142 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:32:59.142 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:32:59.142 | HD Request # 51 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:32:59.142 | HD Request # 51 | Download start date-time: 2026-01-14 09:32:51.626342. 2026-01-14 09:32:59.142 | DTC Client socket (4) | Creating socket. 2026-01-14 09:32:59.142 | DTC Client socket (4) | New receive buffer size: 0 2026-01-14 09:32:59.142 | DTC Client socket (4) | Connecting to IP: 64.152.155.17. 2026-01-14 09:32:59.142 | HD Request # 51 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:32:59.143 | Socket (9) | Creating socket. 2026-01-14 09:32:59.143 | Socket (9) | New receive buffer size: 0 2026-01-14 09:32:59.143 | Socket (9) | Connecting to IP: 64.152.155.17. 2026-01-14 09:32:59.164 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:32:59.164 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:32:59.164 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:32:59.799 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:32:59.799 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:32:59.953 | HD Request # 51 | Setting DTC encoding to Binary VLS 2026-01-14 09:32:59.953 | HD Request # 51 | Sending historical data logon request message. 2026-01-14 09:33:00.332 | HD Request # 51 | Requesting market depth data. Start date-time: 2026-01-14 09:32:51. Symbol: ESH26 2026-01-14 09:33:00.345 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:33:00.345 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:33:00.345 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:33:00.345 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:33:00.345 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:33:00.345 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:33:00.345 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:33:00.345 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:33:00.345 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:33:00.345 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:33:00.384 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:33:00.903 | HD Request # 51 | Decompressing data. 2026-01-14 09:33:00.942 | HD Request # 51 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:32:51.694000 2026-01-14 09:33:01.128 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:33:01.128 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:33:01.728 | HD Request # 52 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:33:01.728 | HD Request # 52 | Download start date-time: 2026-01-14 09:32:47.000000. File last date-time: 2026-01-14 09:32:47.761000 2026-01-14 09:33:01.728 | HD Request # 52 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:33:01.729 | Socket (10) | Creating socket. 2026-01-14 09:33:01.729 | Socket (10) | New receive buffer size: 0 2026-01-14 09:33:01.729 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:33:02.889 | Socket (9) | CloseSocket call. 2026-01-14 09:33:02.889 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:02.889 | Historical data download thread signaled to stop. 2026-01-14 09:33:02.889 | HD Request # 51 | Timestamp of first market depth data file record written: 2026-01-14 09:32:51.694000. 2026-01-14 09:33:02.889 | HD Request # 51 | Received 4524 Market Depth data records from 2026-01-14 09:32:51.694000 to 2026-01-14 09:32:56.873000 (5.2 seconds. Delay: 6.0 seconds) and wrote 4524 records for ESH6.CME 2026-01-14 09:33:02.889 | HD Request # 51 | Completion time: 3s. 2026-01-14 09:33:02.889 | HD Request # 51 | Market Depth data download complete for ESH6.CME. Unique request ID: 353 2026-01-14 09:33:02.889 | Removing historical data download ID 353. 2026-01-14 09:33:02.889 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:33:02.890 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:33:02.890 | Socket (9) | Closed. 2026-01-14 09:33:02.896 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:33:02.896 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:02.896 | 2026-01-14 09:33:02.896 | Triggering next historical data download in queue. 2026-01-14 09:33:02.896 | HD Request # 53 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:33:02.896 | HD Request # 53 | Download start date-time: 2026-01-14 09:32:51.626087. 2026-01-14 09:33:02.897 | HD Request # 53 | Using server: ds28.sierracharts.com port 10149 2026-01-14 09:33:02.897 | Socket (9) | Creating socket. 2026-01-14 09:33:02.897 | Socket (9) | New receive buffer size: 0 2026-01-14 09:33:02.897 | Socket (9) | Connecting to IP: 67.214.125.5. 2026-01-14 09:33:02.928 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:33:02.931 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:02.985 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:33:02.989 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:03.024 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:33:03.027 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:03.030 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:33:03.040 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:03.074 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:33:03.076 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:03.078 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:33:03.088 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:03.146 | HD Request # 52 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:03.146 | HD Request # 52 | Sending historical data logon request message. 2026-01-14 09:33:03.158 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:33:03.158 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:33:03.158 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:33:03.158 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:33:03.184 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:33:03.195 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 351, 2026-01-14 09:33:03.201 | NTP Client | Received Packet | RoundTripDelay=0.04198646545410156, SystemClockOffset=0.00048065185546875 2026-01-14 09:33:03.342 | NTP Client | Received Packet | RoundTripDelay=0.18396711349487305, SystemClockOffset=0.007299661636352539 2026-01-14 09:33:03.394 | NTP Client | Received Packet | RoundTripDelay=0.2349233627319336, SystemClockOffset=-0.026708602905273438 2026-01-14 09:33:03.518 | HD Request # 52 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:47. Record interval: 0. Symbol: VOLX 2026-01-14 09:33:03.591 | HD Request # 53 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:03.591 | HD Request # 53 | Sending historical data logon request message. 2026-01-14 09:33:03.997 | HD Request # 53 | Requesting market depth data. Start date-time: 2026-01-14 09:32:51. Symbol: NQH26 2026-01-14 09:33:04.053 | HD Request # 52 | Decompressing data. 2026-01-14 09:33:04.274 | HD Request # 53 | Decompressing data. 2026-01-14 09:33:04.307 | HD Request # 53 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:32:51.633000 2026-01-14 09:33:04.368 | HD Request # 52 | Receiving Intraday data for VOLX starting at 2026-01-14 09:32:47.761000 2026-01-14 09:33:04.368 | Socket (10) | CloseSocket call. 2026-01-14 09:33:04.368 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:04.368 | Historical data download thread signaled to stop. 2026-01-14 09:33:04.368 | HD Request # 52 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:51.814000. 2026-01-14 09:33:04.368 | HD Request # 52 | Received 14 Intraday data records from 2026-01-14 09:32:47.761000 to 2026-01-14 09:33:00.182000 (12.4 seconds. Delay: 4.2 seconds) and wrote 13 records for VOLX 2026-01-14 09:33:04.369 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:33:04.369 | Socket (10) | Closed. 2026-01-14 09:33:04.376 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:00.182000 2026-01-14 09:33:04.376 | Added 10 Time and Sales records to Intraday data file for VOLX after download. 2026-01-14 09:33:04.376 | HD Request # 52 | Completion time: 3s. 2026-01-14 09:33:04.376 | HD Request # 52 | Intraday data download complete for VOLX. Unique request ID: 346 2026-01-14 09:33:04.376 | Removing historical data download ID 346. 2026-01-14 09:33:04.376 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:33:04.376 | Intraday chart data file opened for VOLX 2026-01-14 09:33:04.376 | HD Request # 52 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:04.376 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 346 has completed. 2026-01-14 09:33:04.376 | 2026-01-14 09:33:04.376 | Triggering next historical data download in queue. 2026-01-14 09:33:04.376 | HD Request # 54 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:33:04.376 | HD Request # 54 | Download start date-time: 2026-01-14 09:32:50.000000. File last date-time: 2026-01-14 09:32:50.702002 2026-01-14 09:33:04.383 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:33:04.383 | HD Request # 54 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:33:04.383 | Socket (10) | Creating socket. 2026-01-14 09:33:04.383 | Socket (10) | New receive buffer size: 0 2026-01-14 09:33:04.383 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:33:04.884 | Socket (9) | CloseSocket call. 2026-01-14 09:33:04.884 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:04.885 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:33:04.885 | Socket (9) | Closed. 2026-01-14 09:33:04.897 | Historical data download thread signaled to stop. 2026-01-14 09:33:04.898 | HD Request # 53 | Timestamp of first market depth data file record written: 2026-01-14 09:32:51.633000. 2026-01-14 09:33:04.898 | HD Request # 53 | Received 23523 Market Depth data records from 2026-01-14 09:32:51.633000 to 2026-01-14 09:33:02.516000 (10.9 seconds. Delay: 2.4 seconds) and wrote 23523 records for NQH6.CME 2026-01-14 09:33:04.898 | HD Request # 53 | Completion time: 2s. 2026-01-14 09:33:04.898 | HD Request # 53 | Market Depth data download complete for NQH6.CME. Unique request ID: 354 2026-01-14 09:33:04.898 | Removing historical data download ID 354. 2026-01-14 09:33:04.898 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:33:04.905 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:33:04.905 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:04.905 | 2026-01-14 09:33:04.905 | No download requests in the queue to start downloads for. 2026-01-14 09:33:04.905 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:33:04.908 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:04.996 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:33:05.007 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:05.009 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:33:05.012 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:05.116 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:33:05.124 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:05.131 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:33:05.142 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:05.190 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:33:05.194 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:05.254 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:33:05.271 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 350, 2026-01-14 09:33:05.608 | HD Request # 54 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:05.608 | HD Request # 54 | Sending historical data logon request message. 2026-01-14 09:33:05.819 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:33:05.819 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:33:05.819 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:33:06.698 | HD Request # 54 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:50. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:33:07.275 | HD Request # 54 | Decompressing data. 2026-01-14 09:33:07.440 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:33:08.797 | HD Request # 54 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:32:50.000000 2026-01-14 09:33:08.798 | Socket (10) | CloseSocket call. 2026-01-14 09:33:08.798 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:08.798 | Historical data download thread signaled to stop. 2026-01-14 09:33:08.799 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:33:08.799 | HD Request # 54 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:51.000000. 2026-01-14 09:33:08.799 | Socket (10) | Closed. 2026-01-14 09:33:08.799 | HD Request # 54 | Received 17 Intraday data records from 2026-01-14 09:32:50.000000 to 2026-01-14 09:33:06.000000 (16.0 seconds. Delay: 2.8 seconds) and wrote 16 records for TICK-NYSE 2026-01-14 09:33:08.807 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:06.000000 2026-01-14 09:33:08.807 | Added 28 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:33:08.807 | HD Request # 54 | Completion time: 4s. 2026-01-14 09:33:08.807 | HD Request # 54 | Intraday data download complete for TICK-NYSE. Unique request ID: 347 2026-01-14 09:33:08.807 | Removing historical data download ID 347. 2026-01-14 09:33:08.807 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:33:08.807 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:33:08.807 | HD Request # 54 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:08.807 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 347 has completed. 2026-01-14 09:33:08.807 | 2026-01-14 09:33:08.807 | Triggering next historical data download in queue. 2026-01-14 09:33:08.807 | HD Request # 55 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:33:08.807 | HD Request # 55 | Download start date-time: 2026-01-14 09:32:50.000000. File last date-time: 2026-01-14 09:32:50.702001 2026-01-14 09:33:08.808 | HD Request # 55 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:33:08.808 | Socket (9) | Creating socket. 2026-01-14 09:33:08.808 | Socket (9) | New receive buffer size: 0 2026-01-14 09:33:08.808 | Socket (9) | Connecting to IP: 69.39.70.241. 2026-01-14 09:33:09.685 | HD Request # 55 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:09.685 | HD Request # 55 | Sending historical data logon request message. 2026-01-14 09:33:10.092 | HD Request # 55 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:50. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:33:10.500 | HD Request # 55 | Decompressing data. 2026-01-14 09:33:10.565 | HD Request # 55 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:32:50.000000 2026-01-14 09:33:10.565 | Socket (9) | CloseSocket call. 2026-01-14 09:33:10.565 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:10.565 | Historical data download thread signaled to stop. 2026-01-14 09:33:10.565 | HD Request # 55 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:51.000000. 2026-01-14 09:33:10.566 | HD Request # 55 | Received 20 Intraday data records from 2026-01-14 09:32:50.000000 to 2026-01-14 09:33:09.000000 (19.0 seconds. Delay: 1.6 seconds) and wrote 19 records for NISS-NYSE 2026-01-14 09:33:10.566 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:33:10.566 | Socket (9) | Closed. 2026-01-14 09:33:10.573 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:09.000000 2026-01-14 09:33:10.573 | Added 11 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:33:10.573 | HD Request # 55 | Completion time: 2s. 2026-01-14 09:33:10.573 | HD Request # 55 | Intraday data download complete for NISS-NYSE. Unique request ID: 348 2026-01-14 09:33:10.573 | Removing historical data download ID 348. 2026-01-14 09:33:10.573 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:33:10.573 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:33:10.573 | HD Request # 55 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:10.573 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 348 has completed. 2026-01-14 09:33:10.573 | 2026-01-14 09:33:10.573 | Triggering next historical data download in queue. 2026-01-14 09:33:10.573 | HD Request # 56 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:33:10.573 | HD Request # 56 | Download start date-time: 2026-01-14 09:32:50.000000. File last date-time: 2026-01-14 09:32:50.702002 2026-01-14 09:33:10.573 | HD Request # 56 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:33:10.574 | Socket (9) | Creating socket. 2026-01-14 09:33:10.574 | Socket (9) | New receive buffer size: 0 2026-01-14 09:33:10.574 | Socket (9) | Connecting to IP: 64.152.155.113. 2026-01-14 09:33:12.451 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:33:12.451 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:33:12.593 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Creating socket. Using TLS 1.2. 2026-01-14 09:33:12.593 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | New receive buffer size: 0 2026-01-14 09:33:12.593 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Connecting to IP: 216.66.0.130. 2026-01-14 09:33:14.793 | HD Request # 56 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:14.793 | HD Request # 56 | Sending historical data logon request message. 2026-01-14 09:33:15.718 | HD Request # 56 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:50. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:33:15.859 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:33:15.861 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:33:16.101 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | CloseSocket call. 2026-01-14 09:33:16.101 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:16.102 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Socket gracefully closed by remote side. 2026-01-14 09:33:16.102 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (10) | Closed. 2026-01-14 09:33:16.335 | HD Request # 56 | Decompressing data. 2026-01-14 09:33:16.843 | HD Request # 56 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:32:50.000000 2026-01-14 09:33:16.843 | Socket (9) | CloseSocket call. 2026-01-14 09:33:16.843 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:16.843 | Historical data download thread signaled to stop. 2026-01-14 09:33:16.843 | HD Request # 56 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:51.000000. 2026-01-14 09:33:16.843 | HD Request # 56 | Received 25 Intraday data records from 2026-01-14 09:32:50.000000 to 2026-01-14 09:33:14.000000 (24.0 seconds. Delay: 2.8 seconds) and wrote 24 records for TRIN-NYSE 2026-01-14 09:33:16.844 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:33:16.844 | Socket (9) | Closed. 2026-01-14 09:33:16.852 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:14.000000 2026-01-14 09:33:16.852 | Added 24 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:33:16.852 | HD Request # 56 | Completion time: 6s. 2026-01-14 09:33:16.852 | HD Request # 56 | Intraday data download complete for TRIN-NYSE. Unique request ID: 349 2026-01-14 09:33:16.852 | Removing historical data download ID 349. 2026-01-14 09:33:16.852 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:33:16.852 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:33:16.852 | HD Request # 56 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:16.852 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 349 has completed. 2026-01-14 09:33:16.852 | 2026-01-14 09:33:16.852 | Triggering next historical data download in queue. 2026-01-14 09:33:16.852 | HD Request # 57 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:33:16.852 | HD Request # 57 | Download start date-time: 2026-01-14 09:32:32.000000. File last date-time: 2026-01-14 09:32:32.957000 2026-01-14 09:33:16.852 | HD Request # 57 | Using server: ds32.sierracharts.com port 10150 2026-01-14 09:33:16.852 | Socket (9) | Creating socket. 2026-01-14 09:33:16.852 | Socket (9) | New receive buffer size: 0 2026-01-14 09:33:16.852 | Socket (9) | Connecting to IP: 69.39.70.248. 2026-01-14 09:33:17.380 | HD Request # 57 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:17.380 | HD Request # 57 | Sending historical data logon request message. 2026-01-14 09:33:17.464 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:33:17.672 | HD Request # 57 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:32. Record interval: 0. Symbol: NQH26 2026-01-14 09:33:17.949 | HD Request # 57 | Decompressing data. 2026-01-14 09:33:18.140 | HD Request # 57 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:32:32.056000 2026-01-14 09:33:18.338 | Socket (9) | CloseSocket call. 2026-01-14 09:33:18.338 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:18.338 | Historical data download thread signaled to stop. 2026-01-14 09:33:18.339 | HD Request # 57 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:32.975000. 2026-01-14 09:33:18.339 | HD Request # 57 | Received 2864 Intraday data records from 2026-01-14 09:32:32.056000 to 2026-01-14 09:33:14.762001 (42.7 seconds. Delay: 3.6 seconds) and wrote 2797 records for NQH6.CME 2026-01-14 09:33:18.339 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:33:18.339 | Socket (9) | Closed. 2026-01-14 09:33:18.346 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:14.762001 2026-01-14 09:33:18.346 | HD Request # 57 | Completion time: 2s. 2026-01-14 09:33:18.346 | HD Request # 57 | Intraday data download complete for NQH6.CME. Unique request ID: 350 2026-01-14 09:33:18.346 | Removing historical data download ID 350. 2026-01-14 09:33:18.346 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:33:18.346 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:33:18.346 | HD Request # 57 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:18.346 | 2026-01-14 09:33:18.346 | Triggering next historical data download in queue. 2026-01-14 09:33:18.346 | HD Request # 58 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:33:18.346 | HD Request # 58 | Download start date-time: 2026-01-14 09:32:32.000000. File last date-time: 2026-01-14 09:32:32.982001 2026-01-14 09:33:18.346 | HD Request # 58 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:33:18.346 | Socket (9) | Creating socket. 2026-01-14 09:33:18.346 | Socket (9) | New receive buffer size: 0 2026-01-14 09:33:18.346 | Socket (9) | Connecting to IP: 64.152.155.17. 2026-01-14 09:33:18.368 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.370 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:33:18.445 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.445 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:33:18.478 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:33:18.507 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.507 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:33:18.567 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:33:18.603 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:33:18.614 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:33:18.627 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.628 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:33:18.629 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.629 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:33:18.633 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.634 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:33:18.721 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:33:18.767 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:18.768 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:33:18.781 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:18.781 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:18.781 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:33:18.866 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:33:18.901 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:33:18.904 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:18.904 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:33:18.955 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:33:18.990 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:33:18.991 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:18.991 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:33:18.996 | HD Request # 58 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:18.996 | HD Request # 58 | Sending historical data logon request message. 2026-01-14 09:33:19.003 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:33:19.008 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:33:19.009 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:19.030 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:33:19.032 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:19.081 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:19.081 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:33:19.125 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:33:19.355 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:33:19.372 | HD Request # 58 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:32. Record interval: 0. Symbol: ESH26 2026-01-14 09:33:19.393 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:33:19.626 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:33:19.714 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:33:19.716 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:33:19.717 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:19.746 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:33:19.746 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:19.775 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:19.804 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:33:19.844 | HD Request # 58 | Decompressing data. 2026-01-14 09:33:19.923 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:19.923 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:33:19.943 | HD Request # 58 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:32:32.057000 2026-01-14 09:33:20.015 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:20.127 | Socket (9) | CloseSocket call. 2026-01-14 09:33:20.127 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:20.128 | Historical data download thread signaled to stop. 2026-01-14 09:33:20.128 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:33:20.128 | Socket (9) | Closed. 2026-01-14 09:33:20.128 | HD Request # 58 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:33.037000. 2026-01-14 09:33:20.129 | HD Request # 58 | Received 4307 Intraday data records from 2026-01-14 09:32:32.057000 to 2026-01-14 09:33:16.801001 (44.7 seconds. Delay: 3.3 seconds) and wrote 4155 records for ESH6.CME 2026-01-14 09:33:20.139 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:16.801001 2026-01-14 09:33:20.140 | HD Request # 58 | Completion time: 2s. 2026-01-14 09:33:20.140 | HD Request # 58 | Intraday data download complete for ESH6.CME. Unique request ID: 351 2026-01-14 09:33:20.140 | Removing historical data download ID 351. 2026-01-14 09:33:20.140 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:33:20.140 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:33:20.140 | HD Request # 58 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:20.140 | 2026-01-14 09:33:20.140 | Triggering next historical data download in queue. 2026-01-14 09:33:20.141 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:20.146 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:33:20.147 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:20.168 | HD Request # 59 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:33:20.168 | HD Request # 59 | Download start date-time: 2026-01-14 09:32:32.000000. File last date-time: 2026-01-14 09:32:32.945003 2026-01-14 09:33:20.168 | HD Request # 59 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:33:20.168 | Socket (12) | Creating socket. 2026-01-14 09:33:20.168 | Socket (12) | New receive buffer size: 0 2026-01-14 09:33:20.168 | Socket (12) | Connecting to IP: 67.214.125.5. 2026-01-14 09:33:20.206 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.206 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:33:20.212 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.214 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:33:20.233 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.235 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:33:20.265 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.266 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:33:20.331 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:33:20.434 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.435 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:33:20.450 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:33:20.468 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:33:20.571 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.573 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:33:20.574 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:33:20.574 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:33:20.586 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:33:20.600 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:33:20.660 | + Loading additional symbol data. 2026-01-14 09:33:20.721 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:33:20.746 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:33:20.759 | + Loading additional symbol data. 2026-01-14 09:33:20.786 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:20.786 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:33:20.804 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:33:20.806 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:20.806 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:20.806 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:33:20.850 | HD Request # 59 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:20.850 | HD Request # 59 | Sending historical data logon request message. 2026-01-14 09:33:20.900 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:33:20.905 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:33:20.908 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:20.932 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:33:21.101 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:33:21.104 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:33:21.301 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:21.301 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:33:21.337 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:21.337 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:33:21.467 | HD Request # 59 | Requesting Intraday data. Start date-time: 2026-01-14 09:32:32. Record interval: 0. Symbol: RTYH26 2026-01-14 09:33:21.828 | + Loading additional symbol data. 2026-01-14 09:33:21.854 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:33:21.903 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:33:22.049 | HD Request # 59 | Decompressing data. 2026-01-14 09:33:22.098 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:33:22.100 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:33:22.100 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:22.127 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:33:22.127 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:22.133 | HD Request # 59 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:32:32.095000 2026-01-14 09:33:22.134 | Socket (12) | CloseSocket call. 2026-01-14 09:33:22.134 | Socket (12) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:22.135 | Socket (12) | Socket gracefully closed by remote side. 2026-01-14 09:33:22.135 | Socket (12) | Closed. 2026-01-14 09:33:22.266 | Historical data download thread signaled to stop. 2026-01-14 09:33:22.266 | HD Request # 59 | Timestamp of first Intraday data file record written: 2026-01-14 09:32:32.982000. 2026-01-14 09:33:22.266 | HD Request # 59 | Received 1284 Intraday data records from 2026-01-14 09:32:32.095000 to 2026-01-14 09:33:20.151000 (48.1 seconds. Delay: 2.1 seconds) and wrote 1199 records for RTYH6.CME 2026-01-14 09:33:22.274 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:20.151000 2026-01-14 09:33:22.274 | HD Request # 59 | Completion time: 2s. 2026-01-14 09:33:22.274 | HD Request # 59 | Intraday data download complete for RTYH6.CME. Unique request ID: 352 2026-01-14 09:33:22.274 | Removing historical data download ID 352. 2026-01-14 09:33:22.274 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:33:22.274 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:33:22.274 | HD Request # 59 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:22.274 | 2026-01-14 09:33:22.274 | No download requests in the queue to start downloads for. 2026-01-14 09:33:22.297 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:22.349 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:22.353 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:33:22.356 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:33:22.468 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:33:22.468 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:33:22.517 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:33:27.476 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:33:33.190 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:33:33.190 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:33:33.190 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:33:33.190 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:33:33.235 | NTP Client | Received Packet | RoundTripDelay=0.04599285125732422, SystemClockOffset=0.0006690025329589844 2026-01-14 09:33:33.367 | NTP Client | Received Packet | RoundTripDelay=0.17699861526489258, SystemClockOffset=0.002836465835571289 2026-01-14 09:33:33.415 | NTP Client | Received Packet | RoundTripDelay=0.22597837448120117, SystemClockOffset=-0.020688295364379883 2026-01-14 09:33:33.432 | NTP Client | Received Packet | RoundTripDelay=0.24297046661376953, SystemClockOffset=-0.020647525787353516 2026-01-14 09:33:34.170 | NTP Client | Performed system clock adjustment of -9989.261627197266 microseconds. 2026-01-14 09:33:47.378 | File >> Disconnect selected. 2026-01-14 09:33:47.388 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:33:47.388 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:33:47.388 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:47.389 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:33:47.389 | DTC Client socket (1) | Closed. 2026-01-14 09:33:47.389 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:33:47.389 | DTC Client socket (4) | CloseSocket call. 2026-01-14 09:33:47.389 | DTC Client socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:47.389 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:33:47.389 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:33:47.389 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:33:47.389 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:47.389 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:33:47.389 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:33:47.390 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:33:47.390 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:33:47.390 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:47.390 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:33:47.390 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:33:47.390 | DTC Client socket (3) | Closed. 2026-01-14 09:33:47.391 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:33:47.391 | DTC Client socket (2) | Closed. 2026-01-14 09:33:47.394 | DTC Client socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:33:47.394 | DTC Client socket (4) | Closed. 2026-01-14 09:33:48.403 | 2026-01-14 09:33:48.403 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:33:48.403 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:33:48.403 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:33:48.404 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:33:48.404 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:33:48.404 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:33:48.409 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:33:48.409 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:33:48.409 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:33:48.409 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:33:50.232 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:33:50.233 | No download requests in the queue to start downloads for. 2026-01-14 09:33:50.234 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:33:50.235 | Using symbol data fast lookup vector 2026-01-14 09:33:50.235 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:33:50.235 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:33:50.235 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:33:50.235 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:33:50.235 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:33:50.235 | Triggering next historical data download in queue. 2026-01-14 09:33:50.235 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 355 2026-01-14 09:33:50.235 | DTC Client socket (2) | Creating socket. 2026-01-14 09:33:50.235 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:33:50.235 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2026-01-14 09:33:50.238 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:33:50.238 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:33:50.238 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:33:50.238 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:33:50.238 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 356 2026-01-14 09:33:50.238 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:33:50.238 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:33:50.238 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:33:50.238 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:33:50.238 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 357 2026-01-14 09:33:50.238 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:33:50.238 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:33:50.238 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:33:50.238 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:33:50.238 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 358 2026-01-14 09:33:50.241 | Delaying start of download for VOLX. 2026-01-14 09:33:50.241 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:33:50.241 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:33:50.241 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:33:50.243 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:33:50.243 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:33:50.243 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 10048 2026-01-14 09:33:50.243 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:33:50.243 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:33:50.243 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 6 Service code: cme 2026-01-14 09:33:50.243 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 6 2026-01-14 09:33:50.243 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:33:50.243 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:33:50.243 | Triggering next historical data download in queue. 2026-01-14 09:33:50.254 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:33:50.254 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:33:50.254 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:33:50.254 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:33:50.254 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:33:50.254 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:33:50.254 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:33:50.254 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:33:50.260 | DTC Client socket (3) | Creating socket. 2026-01-14 09:33:50.260 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:33:50.260 | DTC Client socket (3) | Connecting to IP: 216.200.108.154. 2026-01-14 09:33:50.290 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:33:50.290 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:33:50.290 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:33:50.557 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:33:50.557 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:33:50.557 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:33:50.557 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:33:50.557 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:33:50.557 | Triggering next historical data download in queue. 2026-01-14 09:33:50.931 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:33:50.931 | Denali Data Feed | Sending logon request message. 2026-01-14 09:33:50.931 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:33:50.931 | SC Data with Depth | Sending logon request message. 2026-01-14 09:33:51.599 | SC Data with Depth | Received logon response. 2026-01-14 09:33:51.599 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:33:51.599 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:33:51.599 | SC Data with Depth | Successfully connected. 2026-01-14 09:33:51.599 | SC Data with Depth | Trading is not supported. 2026-01-14 09:33:51.599 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:33:51.599 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:33:51.599 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:33:51.599 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:33:51.599 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:33:52.102 | Denali Data Feed | Received logon response. 2026-01-14 09:33:52.102 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:33:52.102 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:33:52.102 | Denali Data Feed | Successfully connected. 2026-01-14 09:33:52.102 | Denali Data Feed | Trading is not supported. 2026-01-14 09:33:52.102 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:33:52.102 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:33:52.102 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:33:52.102 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:33:52.102 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:33:52.102 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:33:52.263 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:33:52.263 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:33:52.263 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:33:52.263 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:33:52.263 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:33:52.263 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:33:52.263 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:33:52.263 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:33:52.719 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:33:52.719 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:33:52.719 | Triggering next historical data download in queue. 2026-01-14 09:33:52.719 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.721 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:33:52.721 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:33:52.721 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:33:52.721 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:33:52.721 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:33:52.721 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:33:52.721 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:33:52.721 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:33:52.721 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:33:52.721 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:33:52.721 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.721 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:33:52.721 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:33:52.721 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.722 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.723 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:33:52.724 | HD Request # 60 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:33:52.724 | HD Request # 60 | Download start date-time: 2026-01-14 09:33:47.389097. 2026-01-14 09:33:52.724 | HD Request # 60 | Using server: ds32.sierracharts.com port 10150 2026-01-14 09:33:52.724 | Socket (4) | Creating socket. 2026-01-14 09:33:52.724 | Socket (4) | New receive buffer size: 0 2026-01-14 09:33:52.724 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:33:53.697 | HD Request # 60 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:53.697 | HD Request # 60 | Sending historical data logon request message. 2026-01-14 09:33:54.136 | HD Request # 60 | Requesting market depth data. Start date-time: 2026-01-14 09:33:47. Symbol: ESH26 2026-01-14 09:33:54.450 | HD Request # 60 | Decompressing data. 2026-01-14 09:33:54.451 | HD Request # 60 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:33:47.390000 2026-01-14 09:33:54.970 | Socket (4) | CloseSocket call. 2026-01-14 09:33:54.970 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:54.971 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:33:54.971 | Socket (4) | Closed. 2026-01-14 09:33:54.971 | Historical data download thread signaled to stop. 2026-01-14 09:33:54.971 | HD Request # 60 | Timestamp of first market depth data file record written: 2026-01-14 09:33:47.390000. 2026-01-14 09:33:54.971 | HD Request # 60 | Received 5084 Market Depth data records from 2026-01-14 09:33:47.390000 to 2026-01-14 09:33:52.838000 (5.4 seconds. Delay: 2.1 seconds) and wrote 5084 records for ESH6.CME 2026-01-14 09:33:54.971 | HD Request # 60 | Completion time: 2s. 2026-01-14 09:33:54.971 | HD Request # 60 | Market Depth data download complete for ESH6.CME. Unique request ID: 362 2026-01-14 09:33:54.971 | Removing historical data download ID 362. 2026-01-14 09:33:54.971 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:33:54.979 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:33:54.979 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:33:54.979 | 2026-01-14 09:33:54.979 | Triggering next historical data download in queue. 2026-01-14 09:33:54.979 | HD Request # 61 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:33:54.979 | HD Request # 61 | Download start date-time: 2026-01-14 09:33:47.388835. 2026-01-14 09:33:54.979 | HD Request # 61 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:33:54.979 | Socket (4) | Creating socket. 2026-01-14 09:33:54.979 | Socket (4) | New receive buffer size: 0 2026-01-14 09:33:54.979 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-01-14 09:33:55.004 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:33:55.007 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.048 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:33:55.084 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:33:55.087 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.090 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:33:55.101 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.128 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:33:55.131 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.136 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:33:55.146 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.147 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:33:55.150 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.227 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:33:55.238 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 360, 2026-01-14 09:33:55.240 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:33:55.240 | Denali Data Feed (Market Orders Data) | Connecting to the server ds27.sierracharts.com. Port 10060 2026-01-14 09:33:55.240 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:33:55.240 | DTC Client socket (9) | Creating socket. 2026-01-14 09:33:55.240 | DTC Client socket (9) | New receive buffer size: 0 2026-01-14 09:33:55.240 | DTC Client socket (9) | Connecting to IP: 216.200.108.154. 2026-01-14 09:33:55.244 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:33:55.244 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:33:55.244 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:33:57.721 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:33:57.721 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:33:57.725 | HD Request # 62 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:33:57.725 | HD Request # 62 | Download start date-time: 2026-01-14 09:33:46.000000. File last date-time: 2026-01-14 09:33:46.300000 2026-01-14 09:33:57.725 | HD Request # 62 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:33:57.725 | Socket (10) | Creating socket. 2026-01-14 09:33:57.725 | Socket (10) | New receive buffer size: 0 2026-01-14 09:33:57.725 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:33:58.475 | HD Request # 62 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:58.476 | HD Request # 62 | Sending historical data logon request message. 2026-01-14 09:33:58.857 | HD Request # 62 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:46. Record interval: 0. Symbol: VOLX 2026-01-14 09:33:59.214 | HD Request # 61 | Setting DTC encoding to Binary VLS 2026-01-14 09:33:59.214 | HD Request # 61 | Sending historical data logon request message. 2026-01-14 09:33:59.221 | HD Request # 62 | Decompressing data. 2026-01-14 09:33:59.495 | HD Request # 62 | Receiving Intraday data for VOLX starting at 2026-01-14 09:33:46.300000 2026-01-14 09:33:59.495 | Socket (10) | CloseSocket call. 2026-01-14 09:33:59.495 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:33:59.496 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:33:59.496 | Socket (10) | Closed. 2026-01-14 09:33:59.496 | Historical data download thread signaled to stop. 2026-01-14 09:33:59.496 | HD Request # 62 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:47.122000. 2026-01-14 09:33:59.497 | HD Request # 62 | Received 16 Intraday data records from 2026-01-14 09:33:46.300000 to 2026-01-14 09:33:56.301000 (10.0 seconds. Delay: 3.2 seconds) and wrote 15 records for VOLX 2026-01-14 09:33:59.505 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:33:56.301000 2026-01-14 09:33:59.505 | Added 2 Time and Sales records to Intraday data file for VOLX after download. 2026-01-14 09:33:59.505 | HD Request # 62 | Completion time: 2s. 2026-01-14 09:33:59.505 | HD Request # 62 | Intraday data download complete for VOLX. Unique request ID: 355 2026-01-14 09:33:59.505 | Removing historical data download ID 355. 2026-01-14 09:33:59.505 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:33:59.505 | Intraday chart data file opened for VOLX 2026-01-14 09:33:59.505 | HD Request # 62 | Enabling Intraday chart updating for symbol. 2026-01-14 09:33:59.505 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 355 has completed. 2026-01-14 09:33:59.505 | 2026-01-14 09:33:59.505 | Triggering next historical data download in queue. 2026-01-14 09:33:59.505 | HD Request # 63 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:33:59.505 | HD Request # 63 | Download start date-time: 2026-01-14 09:33:46.000000. File last date-time: 2026-01-14 09:33:46.964001 2026-01-14 09:33:59.505 | HD Request # 63 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:33:59.505 | Socket (10) | Creating socket. 2026-01-14 09:33:59.505 | Socket (10) | New receive buffer size: 0 2026-01-14 09:33:59.505 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:34:00.309 | HD Request # 61 | Requesting market depth data. Start date-time: 2026-01-14 09:33:47. Symbol: NQH26 2026-01-14 09:34:00.388 | HD Request # 63 | Setting DTC encoding to Binary VLS 2026-01-14 09:34:00.388 | HD Request # 63 | Sending historical data logon request message. 2026-01-14 09:34:01.113 | HD Request # 63 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:46. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:34:01.113 | HD Request # 61 | Decompressing data. 2026-01-14 09:34:01.114 | HD Request # 61 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:33:47.391000 2026-01-14 09:34:01.227 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:34:01.227 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:34:01.504 | HD Request # 63 | Decompressing data. 2026-01-14 09:34:01.848 | HD Request # 63 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:33:46.000000 2026-01-14 09:34:01.848 | Socket (10) | CloseSocket call. 2026-01-14 09:34:01.848 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:01.849 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:34:01.849 | Historical data download thread signaled to stop. 2026-01-14 09:34:01.849 | Socket (10) | Closed. 2026-01-14 09:34:01.849 | HD Request # 63 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:47.000000. 2026-01-14 09:34:01.849 | HD Request # 63 | Received 16 Intraday data records from 2026-01-14 09:33:46.000000 to 2026-01-14 09:34:01.000000 (15.0 seconds. Delay: 0.8 seconds) and wrote 15 records for TICK-NYSE 2026-01-14 09:34:01.856 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:34:01.000000 2026-01-14 09:34:01.856 | Added 3 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:34:01.856 | HD Request # 63 | Completion time: 2s. 2026-01-14 09:34:01.856 | HD Request # 63 | Intraday data download complete for TICK-NYSE. Unique request ID: 356 2026-01-14 09:34:01.856 | Removing historical data download ID 356. 2026-01-14 09:34:01.856 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:34:01.856 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:34:01.856 | HD Request # 63 | Enabling Intraday chart updating for symbol. 2026-01-14 09:34:01.856 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 356 has completed. 2026-01-14 09:34:01.856 | 2026-01-14 09:34:01.856 | Triggering next historical data download in queue. 2026-01-14 09:34:01.856 | HD Request # 64 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:34:01.857 | HD Request # 64 | Download start date-time: 2026-01-14 09:33:46.000000. File last date-time: 2026-01-14 09:33:46.714001 2026-01-14 09:34:01.857 | HD Request # 64 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:34:01.857 | Socket (10) | Creating socket. 2026-01-14 09:34:01.857 | Socket (10) | New receive buffer size: 0 2026-01-14 09:34:01.857 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:34:02.019 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:34:02.509 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:34:02.510 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:34:02.736 | HD Request # 64 | Setting DTC encoding to Binary VLS 2026-01-14 09:34:02.736 | HD Request # 64 | Sending historical data logon request message. 2026-01-14 09:34:02.777 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:34:02.777 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:34:03.150 | HD Request # 64 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:46. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:34:03.180 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:34:03.180 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:34:03.180 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:34:03.180 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:34:03.223 | NTP Client | Received Packet | RoundTripDelay=0.04397439956665039, SystemClockOffset=0.006919145584106445 2026-01-14 09:34:03.359 | NTP Client | Received Packet | RoundTripDelay=0.17999839782714844, SystemClockOffset=0.0065975189208984375 2026-01-14 09:34:03.381 | NTP Client | Received Packet | RoundTripDelay=0.2009596824645996, SystemClockOffset=0.005636453628540039 2026-01-14 09:34:03.410 | NTP Client | Received Packet | RoundTripDelay=0.23097658157348633, SystemClockOffset=-0.018173933029174805 2026-01-14 09:34:03.511 | HD Request # 64 | Decompressing data. 2026-01-14 09:34:03.834 | HD Request # 64 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:33:46.000000 2026-01-14 09:34:03.834 | Socket (10) | CloseSocket call. 2026-01-14 09:34:03.834 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:03.835 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:34:03.835 | Socket (10) | Closed. 2026-01-14 09:34:03.850 | Historical data download thread signaled to stop. 2026-01-14 09:34:03.850 | HD Request # 64 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:47.000000. 2026-01-14 09:34:03.851 | HD Request # 64 | Received 16 Intraday data records from 2026-01-14 09:33:46.000000 to 2026-01-14 09:34:01.000000 (15.0 seconds. Delay: 2.9 seconds) and wrote 15 records for NISS-NYSE 2026-01-14 09:34:03.857 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:34:01.000000 2026-01-14 09:34:03.857 | Added 20 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:34:03.857 | HD Request # 64 | Completion time: 2s. 2026-01-14 09:34:03.857 | HD Request # 64 | Intraday data download complete for NISS-NYSE. Unique request ID: 357 2026-01-14 09:34:03.857 | Removing historical data download ID 357. 2026-01-14 09:34:03.857 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:34:03.857 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:34:03.857 | HD Request # 64 | Enabling Intraday chart updating for symbol. 2026-01-14 09:34:03.857 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 357 has completed. 2026-01-14 09:34:03.857 | 2026-01-14 09:34:03.857 | Triggering next historical data download in queue. 2026-01-14 09:34:03.857 | HD Request # 65 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:34:03.858 | HD Request # 65 | Download start date-time: 2026-01-14 09:33:46.000000. File last date-time: 2026-01-14 09:33:46.714002 2026-01-14 09:34:03.858 | HD Request # 65 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:34:03.858 | Socket (10) | Creating socket. 2026-01-14 09:34:03.858 | Socket (10) | New receive buffer size: 0 2026-01-14 09:34:03.858 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:34:04.180 | NTP Client | Performed system clock adjustment of 6116.986274719238 microseconds. 2026-01-14 09:34:07.530 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:34:08.400 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | Creating socket. Using TLS 1.2. 2026-01-14 09:34:08.401 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | New receive buffer size: 0 2026-01-14 09:34:08.401 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | Connecting to IP: 216.66.0.130. 2026-01-14 09:34:10.902 | HD Request # 65 | Setting DTC encoding to Binary VLS 2026-01-14 09:34:10.902 | HD Request # 65 | Sending historical data logon request message. 2026-01-14 09:34:11.339 | HD Request # 65 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:46. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:34:12.091 | HD Request # 65 | Decompressing data. 2026-01-14 09:34:12.094 | HD Request # 65 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:33:46.000000 2026-01-14 09:34:12.094 | Socket (10) | CloseSocket call. 2026-01-14 09:34:12.094 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:12.094 | Historical data download thread signaled to stop. 2026-01-14 09:34:12.094 | HD Request # 65 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:47.000000. 2026-01-14 09:34:12.094 | HD Request # 65 | Received 26 Intraday data records from 2026-01-14 09:33:46.000000 to 2026-01-14 09:34:11.000000 (25.0 seconds. Delay: 1.1 seconds) and wrote 25 records for TRIN-NYSE 2026-01-14 09:34:12.094 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:34:12.094 | Socket (10) | Closed. 2026-01-14 09:34:12.101 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:34:11.000000 2026-01-14 09:34:12.101 | Added 8 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:34:12.101 | HD Request # 65 | Completion time: 9s. 2026-01-14 09:34:12.101 | HD Request # 65 | Intraday data download complete for TRIN-NYSE. Unique request ID: 358 2026-01-14 09:34:12.101 | Removing historical data download ID 358. 2026-01-14 09:34:12.101 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:34:12.101 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:34:12.101 | HD Request # 65 | Enabling Intraday chart updating for symbol. 2026-01-14 09:34:12.101 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 358 has completed. 2026-01-14 09:34:12.101 | 2026-01-14 09:34:12.101 | Triggering next historical data download in queue. 2026-01-14 09:34:12.102 | HD Request # 66 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:34:12.102 | HD Request # 66 | Download start date-time: 2026-01-14 09:33:06.000000. File last date-time: 2026-01-14 09:33:06.875000 2026-01-14 09:34:12.102 | HD Request # 66 | Using server: ds28.sierracharts.com port 10149 2026-01-14 09:34:12.102 | Socket (10) | Creating socket. 2026-01-14 09:34:12.102 | Socket (10) | New receive buffer size: 0 2026-01-14 09:34:12.102 | Socket (10) | Connecting to IP: 67.214.125.5. 2026-01-14 09:34:12.281 | Socket (4) | CloseSocket call. 2026-01-14 09:34:12.281 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:12.281 | Historical data download thread signaled to stop. 2026-01-14 09:34:12.282 | HD Request # 61 | Timestamp of first market depth data file record written: 2026-01-14 09:33:47.391000. 2026-01-14 09:34:12.282 | HD Request # 61 | Received 20468 Market Depth data records from 2026-01-14 09:33:47.391000 to 2026-01-14 09:33:58.292000 (10.9 seconds. Delay: 14.0 seconds) and wrote 20468 records for NQH6.CME 2026-01-14 09:34:12.282 | HD Request # 61 | Completion time: 18s. 2026-01-14 09:34:12.282 | HD Request # 61 | Market Depth data download complete for NQH6.CME. Unique request ID: 460 2026-01-14 09:34:12.282 | Removing historical data download ID 460. 2026-01-14 09:34:12.282 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:34:12.282 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:34:12.282 | Socket (4) | Closed. 2026-01-14 09:34:12.289 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:34:12.289 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:34:12.289 | 2026-01-14 09:34:12.289 | No download requests in the queue to start downloads for. 2026-01-14 09:34:12.339 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:34:12.349 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.351 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:34:12.354 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.357 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:34:12.369 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.403 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:34:12.406 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.412 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:34:12.415 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.533 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:34:12.673 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:34:12.683 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.688 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:34:12.699 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 359, 2026-01-14 09:34:12.748 | HD Request # 66 | Setting DTC encoding to Binary VLS 2026-01-14 09:34:12.748 | HD Request # 66 | Sending historical data logon request message. 2026-01-14 09:34:13.058 | HD Request # 66 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:06. Record interval: 0. Symbol: NQH26 2026-01-14 09:34:13.184 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:34:13.424 | HD Request # 66 | Decompressing data. 2026-01-14 09:34:13.445 | HD Request # 66 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:33:06.054000 2026-01-14 09:34:13.958 | Socket (10) | CloseSocket call. 2026-01-14 09:34:13.958 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:13.958 | Historical data download thread signaled to stop. 2026-01-14 09:34:13.959 | HD Request # 66 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:06.954000. 2026-01-14 09:34:13.959 | HD Request # 66 | Received 5850 Intraday data records from 2026-01-14 09:33:06.054000 to 2026-01-14 09:34:12.674000 (66.6 seconds. Delay: 1.3 seconds) and wrote 5808 records for NQH6.CME 2026-01-14 09:34:13.959 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:34:13.959 | Socket (10) | Closed. 2026-01-14 09:34:13.966 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:34:12.674000 2026-01-14 09:34:13.966 | HD Request # 66 | Completion time: 1s. 2026-01-14 09:34:13.966 | HD Request # 66 | Intraday data download complete for NQH6.CME. Unique request ID: 359 2026-01-14 09:34:13.966 | Removing historical data download ID 359. 2026-01-14 09:34:13.966 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:34:13.966 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:34:13.966 | HD Request # 66 | Enabling Intraday chart updating for symbol. 2026-01-14 09:34:13.966 | 2026-01-14 09:34:13.967 | Triggering next historical data download in queue. 2026-01-14 09:34:13.967 | HD Request # 67 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:34:13.967 | HD Request # 67 | Download start date-time: 2026-01-14 09:33:06.000000. File last date-time: 2026-01-14 09:33:06.906000 2026-01-14 09:34:13.967 | HD Request # 67 | Using server: ds32.sierracharts.com port 10150 2026-01-14 09:34:13.967 | Socket (4) | Creating socket. 2026-01-14 09:34:13.967 | Socket (4) | New receive buffer size: 0 2026-01-14 09:34:13.967 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:34:13.983 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:13.983 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:34:13.987 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:13.988 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:34:13.999 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:14.002 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:34:14.042 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:14.043 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:34:14.117 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.117 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.117 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:34:14.165 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:14.165 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:34:14.180 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:14.181 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:34:14.196 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:34:14.214 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:34:14.227 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:34:14.236 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:34:14.244 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:34:14.306 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:34:14.352 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:14.355 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:34:14.398 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:34:14.437 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:34:14.488 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.488 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:34:14.490 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.490 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.490 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:34:14.523 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:34:14.524 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.524 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:34:14.532 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:34:14.536 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:34:14.538 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.560 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:34:14.596 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.628 | HD Request # 67 | Setting DTC encoding to Binary VLS 2026-01-14 09:34:14.628 | HD Request # 67 | Sending historical data logon request message. 2026-01-14 09:34:14.660 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:34:14.676 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:34:14.694 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:34:14.695 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:34:14.873 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:34:14.901 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:34:14.938 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:34:14.973 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | CloseSocket call. 2026-01-14 09:34:14.973 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:14.974 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | Socket gracefully closed by remote side. 2026-01-14 09:34:14.974 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (11) | Closed. 2026-01-14 09:34:14.979 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:14.979 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:34:15.116 | HD Request # 67 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:06. Record interval: 0. Symbol: ESH26 2026-01-14 09:34:15.267 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:34:15.270 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:34:15.270 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:15.299 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:34:15.299 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:15.303 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:34:15.328 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:15.356 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:15.446 | HD Request # 67 | Decompressing data. 2026-01-14 09:34:15.452 | HD Request # 67 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:33:06.019000 2026-01-14 09:34:15.661 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:15.667 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:15.849 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:15.945 | Socket (4) | CloseSocket call. 2026-01-14 09:34:15.945 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:15.945 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:34:15.945 | Socket (4) | Closed. 2026-01-14 09:34:15.972 | Historical data download thread signaled to stop. 2026-01-14 09:34:15.973 | HD Request # 67 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:06.985000. 2026-01-14 09:34:15.973 | HD Request # 67 | Received 7692 Intraday data records from 2026-01-14 09:33:06.019000 to 2026-01-14 09:34:14.716002 (68.7 seconds. Delay: 1.3 seconds) and wrote 7560 records for ESH6.CME 2026-01-14 09:34:15.983 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:34:14.716002 2026-01-14 09:34:15.983 | HD Request # 67 | Completion time: 2s. 2026-01-14 09:34:15.983 | HD Request # 67 | Intraday data download complete for ESH6.CME. Unique request ID: 360 2026-01-14 09:34:15.983 | Removing historical data download ID 360. 2026-01-14 09:34:15.983 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:34:15.983 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:34:15.983 | HD Request # 67 | Enabling Intraday chart updating for symbol. 2026-01-14 09:34:15.983 | 2026-01-14 09:34:15.983 | Triggering next historical data download in queue. 2026-01-14 09:34:15.983 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:15.984 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:34:16.025 | HD Request # 68 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:34:16.025 | HD Request # 68 | Download start date-time: 2026-01-14 09:33:06.000000. File last date-time: 2026-01-14 09:33:06.638000 2026-01-14 09:34:16.025 | HD Request # 68 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:34:16.025 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:16.025 | Socket (4) | Creating socket. 2026-01-14 09:34:16.025 | Socket (4) | New receive buffer size: 0 2026-01-14 09:34:16.025 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-01-14 09:34:16.028 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:34:16.029 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:16.029 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:34:16.100 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:16.100 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:34:16.115 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:16.119 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:34:16.130 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:34:16.161 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:16.162 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:34:16.238 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:34:16.243 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:34:16.251 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:34:16.366 | + Loading additional symbol data. 2026-01-14 09:34:16.371 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:16.371 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:34:16.378 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:34:16.409 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:34:16.419 | + Loading additional symbol data. 2026-01-14 09:34:16.471 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:34:16.503 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:34:16.585 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:34:16.591 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:16.591 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:16.591 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:34:16.615 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:34:16.733 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:34:16.768 | HD Request # 68 | Setting DTC encoding to Binary VLS 2026-01-14 09:34:16.768 | HD Request # 68 | Sending historical data logon request message. 2026-01-14 09:34:16.786 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:34:16.807 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:34:16.813 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:34:16.819 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:16.858 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:34:17.016 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:17.016 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:34:17.149 | HD Request # 68 | Requesting Intraday data. Start date-time: 2026-01-14 09:33:06. Record interval: 0. Symbol: RTYH26 2026-01-14 09:34:17.412 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:17.412 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:34:17.530 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:34:17.709 | HD Request # 68 | Decompressing data. 2026-01-14 09:34:17.728 | + Loading additional symbol data. 2026-01-14 09:34:17.775 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:34:17.835 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:34:17.849 | HD Request # 68 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:33:06.028000 2026-01-14 09:34:17.850 | Socket (4) | CloseSocket call. 2026-01-14 09:34:17.850 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:34:17.851 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:34:17.851 | Socket (4) | Closed. 2026-01-14 09:34:17.959 | Historical data download thread signaled to stop. 2026-01-14 09:34:17.959 | HD Request # 68 | Timestamp of first Intraday data file record written: 2026-01-14 09:33:07.037000. 2026-01-14 09:34:17.959 | HD Request # 68 | Received 1650 Intraday data records from 2026-01-14 09:33:06.028000 to 2026-01-14 09:34:16.494001 (70.5 seconds. Delay: 1.5 seconds) and wrote 1635 records for RTYH6.CME 2026-01-14 09:34:17.970 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:34:16.494001 2026-01-14 09:34:17.970 | HD Request # 68 | Completion time: 1s. 2026-01-14 09:34:17.970 | HD Request # 68 | Intraday data download complete for RTYH6.CME. Unique request ID: 361 2026-01-14 09:34:17.970 | Removing historical data download ID 361. 2026-01-14 09:34:17.970 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:34:17.970 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:34:17.970 | HD Request # 68 | Enabling Intraday chart updating for symbol. 2026-01-14 09:34:17.970 | 2026-01-14 09:34:17.970 | No download requests in the queue to start downloads for. 2026-01-14 09:34:18.408 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:34:18.410 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:34:18.410 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:18.434 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:34:18.534 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:18.610 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:18.615 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:34:18.618 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:34:18.819 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:34:22.534 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:34:22.534 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:34:33.184 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:34:33.184 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:34:33.184 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:34:33.184 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:34:33.226 | NTP Client | Received Packet | RoundTripDelay=0.04298877716064453, SystemClockOffset=0.005629539489746094 2026-01-14 09:34:33.368 | NTP Client | Received Packet | RoundTripDelay=0.1849970817565918, SystemClockOffset=0.0026772022247314453 2026-01-14 09:34:33.411 | NTP Client | Received Packet | RoundTripDelay=0.22698593139648438, SystemClockOffset=-0.017126083374023438 2026-01-14 09:34:33.449 | NTP Client | Received Packet | RoundTripDelay=0.26594972610473633, SystemClockOffset=-0.028063535690307617 2026-01-14 09:34:34.175 | NTP Client | Performed system clock adjustment of -7224.440574645996 microseconds. 2026-01-14 09:35:03.183 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:35:03.183 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:35:03.183 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:35:03.183 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:35:03.227 | NTP Client | Received Packet | RoundTripDelay=0.04399299621582031, SystemClockOffset=0.005746364593505859 2026-01-14 09:35:03.357 | NTP Client | Received Packet | RoundTripDelay=0.17399883270263672, SystemClockOffset=0.008793354034423828 2026-01-14 09:35:03.373 | NTP Client | Received Packet | RoundTripDelay=0.18873119354248047, SystemClockOffset=0.011308670043945312 2026-01-14 09:35:03.413 | NTP Client | Received Packet | RoundTripDelay=0.22898006439208984, SystemClockOffset=-0.01746368408203125 2026-01-14 09:35:04.192 | NTP Client | Performed system clock adjustment of 7269.859313964844 microseconds. 2026-01-14 09:35:32.409 | File >> Disconnect selected. 2026-01-14 09:35:32.417 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:35:32.417 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:35:32.417 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:32.418 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:35:32.418 | DTC Client socket (1) | Closed. 2026-01-14 09:35:32.418 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:35:32.418 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:35:32.418 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:35:32.418 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:32.418 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:35:32.418 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:35:32.418 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:32.418 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:35:32.418 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:35:32.419 | DTC Client socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:35:32.419 | DTC Client socket (9) | Closed. 2026-01-14 09:35:32.419 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:35:32.419 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:32.419 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:35:32.419 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:35:32.419 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:35:32.419 | DTC Client socket (2) | Closed. 2026-01-14 09:35:32.419 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:35:32.419 | DTC Client socket (3) | Closed. 2026-01-14 09:35:33.191 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:35:33.191 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:35:33.191 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:35:33.191 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:35:33.233 | NTP Client | Received Packet | RoundTripDelay=0.04196453094482422, SystemClockOffset=-0.008563518524169922 2026-01-14 09:35:33.364 | NTP Client | Received Packet | RoundTripDelay=0.1739978790283203, SystemClockOffset=-0.006748199462890625 2026-01-14 09:35:33.367 | 2026-01-14 09:35:33.367 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:35:33.367 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:35:33.367 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:35:33.369 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:35:33.369 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:35:33.369 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:35:33.373 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:35:33.373 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:35:33.373 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:35:33.373 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:35:33.396 | NTP Client | Received Packet | RoundTripDelay=0.20595407485961914, SystemClockOffset=-0.01324152946472168 2026-01-14 09:35:33.426 | NTP Client | Received Packet | RoundTripDelay=0.23597431182861328, SystemClockOffset=-0.03701591491699219 2026-01-14 09:35:34.191 | NTP Client | Performed system clock adjustment of -10902.5239944458 microseconds. 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:35:35.029 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:35:35.030 | No download requests in the queue to start downloads for. 2026-01-14 09:35:35.034 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:35:35.034 | Using symbol data fast lookup vector 2026-01-14 09:35:35.034 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:35:35.034 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-01-14 09:35:35.034 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:35:35.035 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:35:35.035 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:35:35.035 | Triggering next historical data download in queue. 2026-01-14 09:35:35.035 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 1170 2026-01-14 09:35:35.035 | DTC Client socket (2) | Creating socket. 2026-01-14 09:35:35.035 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:35:35.035 | DTC Client socket (2) | Connecting to IP: 64.152.155.113. 2026-01-14 09:35:35.038 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:35:35.038 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:35:35.038 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:35:35.038 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:35:35.038 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 1171 2026-01-14 09:35:35.038 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:35:35.038 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:35:35.038 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:35:35.038 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:35:35.038 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 1172 2026-01-14 09:35:35.038 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:35:35.038 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:35:35.038 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:35:35.038 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:35:35.038 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 1173 2026-01-14 09:35:35.041 | Delaying start of download for VOLX. 2026-01-14 09:35:35.041 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:35:35.041 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:35:35.041 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:35:35.075 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:35:35.075 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 5 Service code: cme 2026-01-14 09:35:35.075 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2026-01-14 09:35:35.075 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 5 2026-01-14 09:35:35.075 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:35:35.075 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:35:35.075 | Triggering next historical data download in queue. 2026-01-14 09:35:35.105 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:35:35.105 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 6 Service code: cme 2026-01-14 09:35:35.105 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 6 2026-01-14 09:35:35.105 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:35:35.105 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 7 Service code: cme 2026-01-14 09:35:35.105 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 7 2026-01-14 09:35:35.105 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:35:35.105 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:35:35.154 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:35:35.154 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 8 Service code: cme 2026-01-14 09:35:35.154 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 8 2026-01-14 09:35:35.154 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:35:35.154 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:35:35.154 | Triggering next historical data download in queue. 2026-01-14 09:35:35.154 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:35:35.154 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 9 Service code: cme 2026-01-14 09:35:35.154 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 9 2026-01-14 09:35:35.279 | DTC Client socket (3) | Creating socket. 2026-01-14 09:35:35.279 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:35:35.279 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2026-01-14 09:35:35.322 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:35:35.322 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:35:35.322 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:35:35.739 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:35:35.739 | SC Data with Depth | Sending logon request message. 2026-01-14 09:35:36.170 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:35:36.170 | Denali Data Feed | Sending logon request message. 2026-01-14 09:35:36.405 | SC Data with Depth | Received logon response. 2026-01-14 09:35:36.405 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:35:36.405 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:35:36.405 | SC Data with Depth | Successfully connected. 2026-01-14 09:35:36.405 | SC Data with Depth | Trading is not supported. 2026-01-14 09:35:36.405 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:35:36.405 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:35:36.405 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:35:36.405 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:35:36.405 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:35:37.040 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:35:37.040 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:35:37.040 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:35:37.040 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:35:37.040 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:35:37.040 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:35:37.040 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:35:37.040 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:35:37.087 | Denali Data Feed | Received logon response. 2026-01-14 09:35:37.087 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:35:37.087 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:35:37.087 | Denali Data Feed | Successfully connected. 2026-01-14 09:35:37.087 | Denali Data Feed | Trading is not supported. 2026-01-14 09:35:37.087 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:35:37.087 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:35:37.087 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:35:37.087 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:35:37.087 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:35:37.087 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:35:37.875 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:35:37.875 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:35:37.875 | Triggering next historical data download in queue. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:35:37.875 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:35:37.875 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:35:37.875 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:35:37.875 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:35:37.875 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:35:37.875 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:35:37.875 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:35:37.875 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:35:37.875 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:35:37.875 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:35:37.875 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.875 | HD Request # 69 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:35:37.876 | HD Request # 69 | Download start date-time: 2026-01-14 09:35:32.418091. 2026-01-14 09:35:37.876 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.876 | HD Request # 69 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:35:37.876 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.876 | Socket (4) | Creating socket. 2026-01-14 09:35:37.876 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.876 | Socket (4) | New receive buffer size: 0 2026-01-14 09:35:37.876 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:37.876 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:35:37.876 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:35:38.847 | HD Request # 69 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:38.847 | HD Request # 69 | Sending historical data logon request message. 2026-01-14 09:35:39.295 | HD Request # 69 | Requesting market depth data. Start date-time: 2026-01-14 09:35:32. Symbol: ESH26 2026-01-14 09:35:39.690 | HD Request # 69 | Decompressing data. 2026-01-14 09:35:40.043 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:35:40.043 | Denali Data Feed (Market Orders Data) | Connecting to the server ds28-2.sierracharts.com. Port 10060 2026-01-14 09:35:40.043 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:35:40.044 | DTC Client socket (9) | Creating socket. 2026-01-14 09:35:40.044 | DTC Client socket (9) | New receive buffer size: 0 2026-01-14 09:35:40.044 | DTC Client socket (9) | Connecting to IP: 67.214.125.6. 2026-01-14 09:35:40.065 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:35:40.065 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:35:40.065 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:35:40.552 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:35:40.552 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:35:41.036 | HD Request # 69 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:35:32.437000 2026-01-14 09:35:41.037 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:35:41.037 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:35:41.625 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:35:42.304 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:35:42.304 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:35:42.728 | HD Request # 70 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:35:42.728 | HD Request # 70 | Download start date-time: 2026-01-14 09:35:28.000000. File last date-time: 2026-01-14 09:35:28.939000 2026-01-14 09:35:42.729 | HD Request # 70 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:35:42.729 | Socket (10) | Creating socket. 2026-01-14 09:35:42.729 | Socket (10) | New receive buffer size: 0 2026-01-14 09:35:42.729 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:35:47.538 | Socket (4) | CloseSocket call. 2026-01-14 09:35:47.538 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:47.539 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:35:47.539 | Socket (4) | Closed. 2026-01-14 09:35:47.540 | Historical data download thread signaled to stop. 2026-01-14 09:35:47.540 | HD Request # 69 | Timestamp of first market depth data file record written: 2026-01-14 09:35:32.437000. 2026-01-14 09:35:47.540 | HD Request # 69 | Received 5572 Market Depth data records from 2026-01-14 09:35:32.437000 to 2026-01-14 09:35:38.184000 (5.7 seconds. Delay: 9.4 seconds) and wrote 5572 records for ESH6.CME 2026-01-14 09:35:47.540 | HD Request # 69 | Completion time: 10s. 2026-01-14 09:35:47.540 | HD Request # 69 | Market Depth data download complete for ESH6.CME. Unique request ID: 1177 2026-01-14 09:35:47.540 | Removing historical data download ID 1177. 2026-01-14 09:35:47.540 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:35:47.547 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:35:47.547 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:47.547 | 2026-01-14 09:35:47.547 | Triggering next historical data download in queue. 2026-01-14 09:35:47.547 | HD Request # 71 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:35:47.547 | HD Request # 71 | Download start date-time: 2026-01-14 09:35:32.417853. 2026-01-14 09:35:47.547 | HD Request # 71 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:35:47.547 | Socket (4) | Creating socket. 2026-01-14 09:35:47.547 | Socket (4) | New receive buffer size: 0 2026-01-14 09:35:47.547 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:35:47.669 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:35:47.672 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:47.675 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:35:47.685 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:47.714 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:35:47.717 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:47.751 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:35:47.813 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:35:47.824 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:48.040 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:35:48.043 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:48.167 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:35:48.170 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:48.349 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:35:48.356 | HD Request # 70 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:48.356 | HD Request # 70 | Sending historical data logon request message. 2026-01-14 09:35:48.361 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 1175, 2026-01-14 09:35:48.693 | HD Request # 70 | Requesting Intraday data. Start date-time: 2026-01-14 09:35:28. Record interval: 0. Symbol: VOLX 2026-01-14 09:35:48.805 | HD Request # 71 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:48.805 | HD Request # 71 | Sending historical data logon request message. 2026-01-14 09:35:48.948 | HD Request # 70 | Decompressing data. 2026-01-14 09:35:49.131 | HD Request # 71 | Requesting market depth data. Start date-time: 2026-01-14 09:35:32. Symbol: NQH26 2026-01-14 09:35:49.147 | HD Request # 70 | Receiving Intraday data for VOLX starting at 2026-01-14 09:35:28.937000 2026-01-14 09:35:49.147 | Socket (10) | CloseSocket call. 2026-01-14 09:35:49.147 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:49.148 | Historical data download thread signaled to stop. 2026-01-14 09:35:49.148 | HD Request # 70 | Timestamp of first Intraday data file record written: 2026-01-14 09:35:32.450000. 2026-01-14 09:35:49.148 | HD Request # 70 | Received 26 Intraday data records from 2026-01-14 09:35:28.937000 to 2026-01-14 09:35:48.077000 (19.1 seconds. Delay: 1.1 seconds) and wrote 24 records for VOLX 2026-01-14 09:35:49.148 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:35:49.148 | Socket (10) | Closed. 2026-01-14 09:35:49.155 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:35:48.077000 2026-01-14 09:35:49.155 | HD Request # 70 | Completion time: 7s. 2026-01-14 09:35:49.155 | HD Request # 70 | Intraday data download complete for VOLX. Unique request ID: 1170 2026-01-14 09:35:49.155 | Removing historical data download ID 1170. 2026-01-14 09:35:49.155 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:35:49.155 | Intraday chart data file opened for VOLX 2026-01-14 09:35:49.155 | HD Request # 70 | Enabling Intraday chart updating for symbol. 2026-01-14 09:35:49.155 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 1170 has completed. 2026-01-14 09:35:49.155 | 2026-01-14 09:35:49.155 | Triggering next historical data download in queue. 2026-01-14 09:35:49.155 | HD Request # 72 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:35:49.155 | HD Request # 72 | Download start date-time: 2026-01-14 09:35:31.000000. File last date-time: 2026-01-14 09:35:31.706002 2026-01-14 09:35:49.155 | HD Request # 72 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:35:49.155 | Socket (10) | Creating socket. 2026-01-14 09:35:49.155 | Socket (10) | New receive buffer size: 0 2026-01-14 09:35:49.155 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:35:49.478 | HD Request # 71 | Decompressing data. 2026-01-14 09:35:49.479 | HD Request # 71 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:35:32.428000 2026-01-14 09:35:49.710 | HD Request # 72 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:49.710 | HD Request # 72 | Sending historical data logon request message. 2026-01-14 09:35:50.125 | HD Request # 72 | Requesting Intraday data. Start date-time: 2026-01-14 09:35:31. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:35:50.255 | HD Request # 71 | Timestamp of first market depth data file record written: 2026-01-14 09:35:32.428000. 2026-01-14 09:35:50.489 | Socket (4) | CloseSocket call. 2026-01-14 09:35:50.489 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:50.490 | Historical data download thread signaled to stop. 2026-01-14 09:35:50.490 | HD Request # 71 | Received 33192 Market Depth data records from 2026-01-14 09:35:32.428000 to 2026-01-14 09:35:47.066000 (14.6 seconds. Delay: 3.4 seconds) and wrote 33192 records for NQH6.CME 2026-01-14 09:35:50.490 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:35:50.490 | Socket (4) | Closed. 2026-01-14 09:35:50.490 | HD Request # 71 | Completion time: 3s. 2026-01-14 09:35:50.490 | HD Request # 71 | Market Depth data download complete for NQH6.CME. Unique request ID: 1179 2026-01-14 09:35:50.490 | Removing historical data download ID 1179. 2026-01-14 09:35:50.490 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:35:50.491 | HD Request # 72 | Decompressing data. 2026-01-14 09:35:50.497 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:35:50.497 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:35:50.497 | 2026-01-14 09:35:50.497 | No download requests in the queue to start downloads for. 2026-01-14 09:35:50.498 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:35:50.508 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:50.510 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:35:50.513 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:50.635 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:35:50.638 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:50.723 | HD Request # 72 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:35:31.000000 2026-01-14 09:35:50.724 | Socket (10) | CloseSocket call. 2026-01-14 09:35:50.724 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:50.725 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:35:50.725 | Socket (10) | Closed. 2026-01-14 09:35:50.733 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:35:50.733 | Historical data download thread signaled to stop. 2026-01-14 09:35:50.733 | HD Request # 72 | Timestamp of first Intraday data file record written: 2026-01-14 09:35:32.000000. 2026-01-14 09:35:50.733 | HD Request # 72 | Received 19 Intraday data records from 2026-01-14 09:35:31.000000 to 2026-01-14 09:35:49.000000 (18.0 seconds. Delay: 1.7 seconds) and wrote 18 records for TICK-NYSE 2026-01-14 09:35:50.739 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:35:49.000000 2026-01-14 09:35:50.739 | Added 11 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:35:50.739 | HD Request # 72 | Completion time: 1s. 2026-01-14 09:35:50.739 | HD Request # 72 | Intraday data download complete for TICK-NYSE. Unique request ID: 1171 2026-01-14 09:35:50.739 | Removing historical data download ID 1171. 2026-01-14 09:35:50.739 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:35:50.739 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:35:50.739 | HD Request # 72 | Enabling Intraday chart updating for symbol. 2026-01-14 09:35:50.739 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 1171 has completed. 2026-01-14 09:35:50.739 | 2026-01-14 09:35:50.739 | Triggering next historical data download in queue. 2026-01-14 09:35:50.739 | HD Request # 73 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:35:50.740 | HD Request # 73 | Download start date-time: 2026-01-14 09:35:31.000000. File last date-time: 2026-01-14 09:35:31.706002 2026-01-14 09:35:50.740 | HD Request # 73 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:35:50.740 | Socket (4) | Creating socket. 2026-01-14 09:35:50.740 | Socket (4) | New receive buffer size: 0 2026-01-14 09:35:50.740 | Socket (4) | Connecting to IP: 69.39.70.241. 2026-01-14 09:35:50.757 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:35:50.768 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:50.836 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:35:50.841 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:50.912 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:35:50.923 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:51.207 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:35:51.213 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 1176, 2026-01-14 09:35:51.729 | HD Request # 73 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:51.729 | HD Request # 73 | Sending historical data logon request message. 2026-01-14 09:35:52.365 | HD Request # 73 | Requesting Intraday data. Start date-time: 2026-01-14 09:35:31. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:35:52.711 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:35:52.712 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:35:52.910 | HD Request # 73 | Decompressing data. 2026-01-14 09:35:53.225 | HD Request # 73 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:35:31.000000 2026-01-14 09:35:53.225 | Socket (4) | CloseSocket call. 2026-01-14 09:35:53.225 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:53.226 | Historical data download thread signaled to stop. 2026-01-14 09:35:53.226 | HD Request # 73 | Timestamp of first Intraday data file record written: 2026-01-14 09:35:32.000000. 2026-01-14 09:35:53.226 | HD Request # 73 | Received 19 Intraday data records from 2026-01-14 09:35:31.000000 to 2026-01-14 09:35:49.000000 (18.0 seconds. Delay: 4.2 seconds) and wrote 18 records for NISS-NYSE 2026-01-14 09:35:53.226 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:35:53.226 | Socket (4) | Closed. 2026-01-14 09:35:53.233 | HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:35:49.000000 2026-01-14 09:35:53.233 | Added 28 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:35:53.233 | HD Request # 73 | Completion time: 3s. 2026-01-14 09:35:53.233 | HD Request # 73 | Intraday data download complete for NISS-NYSE. Unique request ID: 1172 2026-01-14 09:35:53.233 | Removing historical data download ID 1172. 2026-01-14 09:35:53.233 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:35:53.233 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:35:53.233 | HD Request # 73 | Enabling Intraday chart updating for symbol. 2026-01-14 09:35:53.233 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 1172 has completed. 2026-01-14 09:35:53.233 | 2026-01-14 09:35:53.233 | Triggering next historical data download in queue. 2026-01-14 09:35:53.233 | HD Request # 74 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:35:53.233 | HD Request # 74 | Download start date-time: 2026-01-14 09:35:31.000000. File last date-time: 2026-01-14 09:35:31.706002 2026-01-14 09:35:53.233 | HD Request # 74 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:35:53.233 | Socket (4) | Creating socket. 2026-01-14 09:35:53.234 | Socket (4) | New receive buffer size: 0 2026-01-14 09:35:53.234 | Socket (4) | Connecting to IP: 64.152.155.113. 2026-01-14 09:35:53.391 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | Creating socket. Using TLS 1.2. 2026-01-14 09:35:53.391 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | New receive buffer size: 0 2026-01-14 09:35:53.391 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | Connecting to IP: 216.66.0.130. 2026-01-14 09:35:53.838 | HD Request # 74 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:53.838 | HD Request # 74 | Sending historical data logon request message. 2026-01-14 09:35:54.612 | HD Request # 74 | Requesting Intraday data. Start date-time: 2026-01-14 09:35:31. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:35:55.230 | HD Request # 74 | Decompressing data. 2026-01-14 09:35:55.230 | HD Request # 74 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:35:31.000000 2026-01-14 09:35:55.231 | Socket (4) | CloseSocket call. 2026-01-14 09:35:55.231 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:55.232 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:35:55.232 | Socket (4) | Closed. 2026-01-14 09:35:55.234 | Historical data download thread signaled to stop. 2026-01-14 09:35:55.234 | HD Request # 74 | Timestamp of first Intraday data file record written: 2026-01-14 09:35:32.000000. 2026-01-14 09:35:55.234 | HD Request # 74 | Received 23 Intraday data records from 2026-01-14 09:35:31.000000 to 2026-01-14 09:35:53.000000 (22.0 seconds. Delay: 2.2 seconds) and wrote 22 records for TRIN-NYSE 2026-01-14 09:35:55.243 | HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:35:53.000000 2026-01-14 09:35:55.243 | Added 14 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:35:55.243 | HD Request # 74 | Completion time: 2s. 2026-01-14 09:35:55.243 | HD Request # 74 | Intraday data download complete for TRIN-NYSE. Unique request ID: 1173 2026-01-14 09:35:55.243 | Removing historical data download ID 1173. 2026-01-14 09:35:55.243 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:35:55.243 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:35:55.243 | HD Request # 74 | Enabling Intraday chart updating for symbol. 2026-01-14 09:35:55.243 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 1173 has completed. 2026-01-14 09:35:55.243 | 2026-01-14 09:35:55.243 | Triggering next historical data download in queue. 2026-01-14 09:35:55.243 | HD Request # 75 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:35:55.243 | HD Request # 75 | Download start date-time: 2026-01-14 09:34:24.000000. File last date-time: 2026-01-14 09:34:24.469000 2026-01-14 09:35:55.243 | HD Request # 75 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:35:55.243 | Socket (4) | Creating socket. 2026-01-14 09:35:55.243 | Socket (4) | New receive buffer size: 0 2026-01-14 09:35:55.243 | Socket (4) | Connecting to IP: 64.152.155.17. 2026-01-14 09:35:57.725 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:35:57.725 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:35:58.132 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:35:58.134 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:35:58.384 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | CloseSocket call. 2026-01-14 09:35:58.384 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:35:58.385 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | Socket gracefully closed by remote side. 2026-01-14 09:35:58.385 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (10) | Closed. 2026-01-14 09:35:59.393 | HD Request # 75 | Setting DTC encoding to Binary VLS 2026-01-14 09:35:59.393 | HD Request # 75 | Sending historical data logon request message. 2026-01-14 09:36:00.100 | HD Request # 75 | Requesting Intraday data. Start date-time: 2026-01-14 09:34:24. Record interval: 0. Symbol: RTYH26 2026-01-14 09:36:00.652 | HD Request # 75 | Decompressing data. 2026-01-14 09:36:01.025 | HD Request # 75 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:34:24.023000 2026-01-14 09:36:01.642 | Socket (4) | CloseSocket call. 2026-01-14 09:36:01.642 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:36:01.642 | Historical data download thread signaled to stop. 2026-01-14 09:36:01.643 | HD Request # 75 | Timestamp of first Intraday data file record written: 2026-01-14 09:34:24.593000. 2026-01-14 09:36:01.643 | HD Request # 75 | Received 1318 Intraday data records from 2026-01-14 09:34:24.023000 to 2026-01-14 09:35:56.387000 (92.4 seconds. Delay: 5.3 seconds) and wrote 1313 records for RTYH6.CME 2026-01-14 09:36:01.643 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:36:01.643 | Socket (4) | Closed. 2026-01-14 09:36:01.650 | HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:35:56.387000 2026-01-14 09:36:01.650 | Added 17 Time and Sales records to Intraday data file for RTYH6.CME after download. 2026-01-14 09:36:01.650 | HD Request # 75 | Completion time: 6s. 2026-01-14 09:36:01.650 | HD Request # 75 | Intraday data download complete for RTYH6.CME. Unique request ID: 1174 2026-01-14 09:36:01.650 | Removing historical data download ID 1174. 2026-01-14 09:36:01.650 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:36:01.650 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:36:01.650 | HD Request # 75 | Enabling Intraday chart updating for symbol. 2026-01-14 09:36:01.650 | 2026-01-14 09:36:01.650 | Triggering next historical data download in queue. 2026-01-14 09:36:01.650 | HD Request # 76 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:36:01.650 | HD Request # 76 | Download start date-time: 2026-01-14 09:34:24.000000. File last date-time: 2026-01-14 09:34:24.531000 2026-01-14 09:36:01.650 | HD Request # 76 | Using server: ds28.sierracharts.com port 10149 2026-01-14 09:36:01.650 | Socket (4) | Creating socket. 2026-01-14 09:36:01.650 | Socket (4) | New receive buffer size: 0 2026-01-14 09:36:01.650 | Socket (4) | Connecting to IP: 67.214.125.5. 2026-01-14 09:36:02.489 | HD Request # 76 | Setting DTC encoding to Binary VLS 2026-01-14 09:36:02.489 | HD Request # 76 | Sending historical data logon request message. 2026-01-14 09:36:02.727 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:36:02.813 | HD Request # 76 | Requesting Intraday data. Start date-time: 2026-01-14 09:34:24. Record interval: 0. Symbol: ESH26 2026-01-14 09:36:03.201 | HD Request # 76 | Decompressing data. 2026-01-14 09:36:03.208 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:36:03.208 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:36:03.208 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:36:03.208 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:36:03.253 | NTP Client | Received Packet | RoundTripDelay=0.044988155364990234, SystemClockOffset=-0.024539709091186523 2026-01-14 09:36:03.358 | HD Request # 76 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:34:24.023000 2026-01-14 09:36:03.392 | NTP Client | Received Packet | RoundTripDelay=0.18399763107299805, SystemClockOffset=-0.0260164737701416 2026-01-14 09:36:03.444 | NTP Client | Received Packet | RoundTripDelay=0.2359161376953125, SystemClockOffset=-0.05070924758911133 2026-01-14 09:36:03.509 | NTP Client | Received Packet | RoundTripDelay=0.301938533782959, SystemClockOffset=-0.07517409324645996 2026-01-14 09:36:03.629 | Socket (4) | CloseSocket call. 2026-01-14 09:36:03.629 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:36:03.630 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:36:03.630 | Socket (4) | Closed. 2026-01-14 09:36:03.635 | Historical data download thread signaled to stop. 2026-01-14 09:36:03.635 | HD Request # 76 | Timestamp of first Intraday data file record written: 2026-01-14 09:34:24.691000. 2026-01-14 09:36:03.635 | HD Request # 76 | Received 8943 Intraday data records from 2026-01-14 09:34:24.023000 to 2026-01-14 09:36:00.694000 (96.7 seconds. Delay: 2.9 seconds) and wrote 8911 records for ESH6.CME 2026-01-14 09:36:03.642 | HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:36:00.694000 2026-01-14 09:36:03.642 | Added 109 Time and Sales records to Intraday data file for ESH6.CME after download. 2026-01-14 09:36:03.642 | HD Request # 76 | Completion time: 2s. 2026-01-14 09:36:03.642 | HD Request # 76 | Intraday data download complete for ESH6.CME. Unique request ID: 1175 2026-01-14 09:36:03.642 | Removing historical data download ID 1175. 2026-01-14 09:36:03.642 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:36:03.642 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:36:03.642 | HD Request # 76 | Enabling Intraday chart updating for symbol. 2026-01-14 09:36:03.648 | 2026-01-14 09:36:03.648 | Triggering next historical data download in queue. 2026-01-14 09:36:03.648 | HD Request # 77 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:36:03.648 | HD Request # 77 | Download start date-time: 2026-01-14 09:34:24.000000. File last date-time: 2026-01-14 09:34:24.468000 2026-01-14 09:36:03.648 | HD Request # 77 | Using server: ds32.sierracharts.com port 10150 2026-01-14 09:36:03.648 | Socket (4) | Creating socket. 2026-01-14 09:36:03.648 | Socket (4) | New receive buffer size: 0 2026-01-14 09:36:03.648 | Socket (4) | Connecting to IP: 69.39.70.248. 2026-01-14 09:36:03.662 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.663 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:36:03.668 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.669 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:36:03.670 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.674 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:36:03.735 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.739 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:36:03.767 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.768 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:36:03.830 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.831 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:36:03.845 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:03.846 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:36:03.854 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:36:03.880 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:36:03.927 | + Loading additional symbol data. 2026-01-14 09:36:03.971 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:36:03.985 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:36:04.001 | + Loading additional symbol data. 2026-01-14 09:36:04.031 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:04.031 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:36:04.048 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:36:04.050 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:04.050 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:04.050 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:36:04.149 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:36:04.162 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:36:04.173 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:36:04.167 | NTP Client | Performed system clock adjustment of -38362.860679626465 microseconds. 2026-01-14 09:36:04.290 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:36:04.309 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:36:04.390 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:36:04.394 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:36:04.397 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:04.424 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:36:04.488 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:04.488 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:36:04.747 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:04.747 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:36:05.042 | + Loading additional symbol data. 2026-01-14 09:36:05.052 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:36:05.099 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:36:05.720 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:36:05.721 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:36:05.722 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:05.744 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:36:05.894 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:36:05.971 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:36:05.975 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:36:05.978 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:06.111 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:36:07.306 | HD Request # 77 | Setting DTC encoding to Binary VLS 2026-01-14 09:36:07.306 | HD Request # 77 | Sending historical data logon request message. 2026-01-14 09:36:07.698 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:36:07.733 | HD Request # 77 | Requesting Intraday data. Start date-time: 2026-01-14 09:34:24. Record interval: 0. Symbol: NQH26 2026-01-14 09:36:08.146 | HD Request # 77 | Decompressing data. 2026-01-14 09:36:08.174 | HD Request # 77 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:34:24.073000 2026-01-14 09:36:10.314 | Socket (4) | CloseSocket call. 2026-01-14 09:36:10.314 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-01-14 09:36:10.314 | Historical data download thread signaled to stop. 2026-01-14 09:36:10.315 | Socket (4) | Socket gracefully closed by remote side. 2026-01-14 09:36:10.315 | Socket (4) | Closed. 2026-01-14 09:36:10.315 | HD Request # 77 | Timestamp of first Intraday data file record written: 2026-01-14 09:34:24.592000. 2026-01-14 09:36:10.316 | HD Request # 77 | Received 6214 Intraday data records from 2026-01-14 09:34:24.073000 to 2026-01-14 09:36:06.765000 (102.7 seconds. Delay: 3.6 seconds) and wrote 6191 records for NQH6.CME 2026-01-14 09:36:10.322 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:36:06.765000 2026-01-14 09:36:10.322 | Added 21 Time and Sales records to Intraday data file for NQH6.CME after download. 2026-01-14 09:36:10.322 | HD Request # 77 | Completion time: 7s. 2026-01-14 09:36:10.322 | HD Request # 77 | Intraday data download complete for NQH6.CME. Unique request ID: 1176 2026-01-14 09:36:10.322 | Removing historical data download ID 1176. 2026-01-14 09:36:10.322 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:36:10.322 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:36:10.322 | HD Request # 77 | Enabling Intraday chart updating for symbol. 2026-01-14 09:36:10.328 | 2026-01-14 09:36:10.328 | No download requests in the queue to start downloads for. 2026-01-14 09:36:10.369 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.369 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:36:10.373 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.375 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:36:10.376 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.377 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:36:10.479 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:36:10.510 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:36:10.517 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:10.517 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:36:10.517 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.518 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:36:10.588 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.588 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:36:10.604 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:36:10.614 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:36:10.667 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.667 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:36:10.719 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:10.719 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:10.719 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:36:10.719 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:36:10.720 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:36:10.724 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:36:10.885 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:36:10.902 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:36:10.904 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:10.904 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:36:10.907 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:36:10.940 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:36:10.979 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:36:11.021 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:36:11.044 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:11.044 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:36:11.045 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:36:11.050 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:36:11.051 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:11.076 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:36:11.228 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:36:11.232 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:36:11.506 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:36:11.541 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:36:11.807 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:36:11.809 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:36:11.810 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:11.838 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:36:11.862 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:36:11.951 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:36:11.957 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:36:12.048 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:36:12.701 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:36:33.214 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:36:33.214 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:36:33.214 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:36:33.214 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:36:33.257 | NTP Client | Received Packet | RoundTripDelay=0.04398775100708008, SystemClockOffset=-0.026088476181030273 2026-01-14 09:36:33.388 | NTP Client | Received Packet | RoundTripDelay=0.17399883270263672, SystemClockOffset=-0.02329397201538086 2026-01-14 09:36:33.441 | NTP Client | Received Packet | RoundTripDelay=0.2265610694885254, SystemClockOffset=-0.048377275466918945 2026-01-14 09:36:33.442 | NTP Client | Received Packet | RoundTripDelay=0.22895383834838867, SystemClockOffset=-0.04101967811584473 2026-01-14 09:36:34.173 | NTP Client | Performed system clock adjustment of -33554.0771484375 microseconds. 2026-01-14 09:36:39.383 | NTP Client | Restarting NTP client. 2026-01-14 09:36:39.383 | NTP Client | Stop NTP Client. 2026-01-14 09:36:39.383 | NTPClient (5) | CloseSocket call. 2026-01-14 09:36:39.383 | NTPClient (6) | CloseSocket call. 2026-01-14 09:36:39.383 | NTPClient (7) | CloseSocket call. 2026-01-14 09:36:39.383 | NTPClient (8) | CloseSocket call. 2026-01-14 09:36:39.383 | NTPClient (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:36:39.383 | NTPClient (5) | Closed. 2026-01-14 09:36:39.383 | NTPClient (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:36:39.383 | NTPClient (6) | Closed. 2026-01-14 09:36:39.383 | NTPClient (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:36:39.383 | NTPClient (7) | Closed. 2026-01-14 09:36:39.383 | NTPClient (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:36:39.383 | NTPClient (8) | Closed. 2026-01-14 09:36:39.383 | NTPClient (5) | Socket gracefully closed by remote side. 2026-01-14 09:36:39.383 | NTPClient (6) | Socket gracefully closed by remote side. 2026-01-14 09:36:39.383 | NTPClient (7) | Socket gracefully closed by remote side. 2026-01-14 09:36:39.384 | NTPClient (8) | Socket gracefully closed by remote side. 2026-01-14 09:36:39.386 | NTP Client | Service successfully started. 2026-01-14 09:36:39.388 | NTPClient (4) | Creating socket. 2026-01-14 09:36:39.388 | NTPClient (4) | New receive buffer size: 0 2026-01-14 09:36:39.388 | NTPClient (4) | Connecting to IP: 139.199.215.251. 2026-01-14 09:36:39.389 | NTPClient (5) | Creating socket. 2026-01-14 09:36:39.389 | NTPClient (5) | New receive buffer size: 0 2026-01-14 09:36:39.389 | NTPClient (5) | Connecting to IP: 193.182.111.12. 2026-01-14 09:36:39.391 | NTPClient (6) | Creating socket. 2026-01-14 09:36:39.391 | NTPClient (6) | New receive buffer size: 0 2026-01-14 09:36:39.391 | NTPClient (6) | Connecting to IP: 185.209.85.222. 2026-01-14 09:36:39.393 | NTPClient (7) | Creating socket. 2026-01-14 09:36:39.393 | NTPClient (7) | New receive buffer size: 0 2026-01-14 09:36:39.393 | NTPClient (7) | Connecting to IP: 210.28.130.4. 2026-01-14 09:37:03.402 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:37:03.402 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:37:03.402 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:37:03.402 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:37:03.415 | NTP Client | Received Packet | RoundTripDelay=0.012980937957763672, SystemClockOffset=-0.008643865585327148 2026-01-14 09:37:03.435 | NTP Client | Received Packet | RoundTripDelay=0.03198385238647461, SystemClockOffset=-0.008454561233520508 2026-01-14 09:37:03.544 | NTP Client | Received Packet | RoundTripDelay=0.14151382446289062, SystemClockOffset=-0.0038738250732421875 2026-01-14 09:37:03.674 | NTP Client | Received Packet | RoundTripDelay=0.2709980010986328, SystemClockOffset=0.0033292770385742188 2026-01-14 09:37:04.398 | NTP Client | Performed system clock adjustment of -6164.193153381348 microseconds. 2026-01-14 09:37:09.011 | File >> Disconnect selected. 2026-01-14 09:37:09.019 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:37:09.020 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:37:09.020 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:09.020 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:37:09.020 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:37:09.020 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:09.020 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:37:09.020 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:37:09.021 | DTC Client socket (1) | Closed. 2026-01-14 09:37:09.021 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:37:09.021 | DTC Client socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:37:09.021 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:37:09.021 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:37:09.021 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:37:09.021 | DTC Client socket (9) | Closed. 2026-01-14 09:37:09.021 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:09.021 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:37:09.021 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:09.021 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:37:09.021 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:37:09.022 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:37:09.022 | DTC Client socket (3) | Closed. 2026-01-14 09:37:09.022 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:37:09.022 | DTC Client socket (2) | Closed. 2026-01-14 09:37:09.913 | 2026-01-14 09:37:09.913 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:37:09.913 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:37:09.913 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:37:09.916 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:37:09.916 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:37:09.916 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:37:09.920 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:37:09.920 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:37:09.920 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:37:09.920 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:37:11.471 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:37:11.472 | No download requests in the queue to start downloads for. 2026-01-14 09:37:11.473 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:37:11.473 | Using symbol data fast lookup vector 2026-01-14 09:37:11.473 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:37:11.473 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:37:11.473 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:37:11.473 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:37:11.473 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:37:11.473 | Triggering next historical data download in queue. 2026-01-14 09:37:11.473 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 1307 2026-01-14 09:37:11.474 | DTC Client socket (2) | Creating socket. 2026-01-14 09:37:11.474 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:37:11.474 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2026-01-14 09:37:11.477 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:37:11.477 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:37:11.477 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:37:11.477 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:37:11.477 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 1308 2026-01-14 09:37:11.477 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:37:11.477 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:37:11.477 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:37:11.477 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:37:11.477 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 1309 2026-01-14 09:37:11.477 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:37:11.477 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:37:11.477 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:37:11.477 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:37:11.477 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 1310 2026-01-14 09:37:11.479 | Delaying start of download for VOLX. 2026-01-14 09:37:11.479 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:37:11.479 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:37:11.480 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:37:11.511 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:37:11.511 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:37:11.512 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 10048 2026-01-14 09:37:11.512 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:37:11.512 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:37:11.512 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 6 Service code: cme 2026-01-14 09:37:11.512 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 6 2026-01-14 09:37:11.512 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:37:11.512 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:37:11.512 | Triggering next historical data download in queue. 2026-01-14 09:37:11.514 | DTC Client socket (3) | Creating socket. 2026-01-14 09:37:11.514 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:37:11.514 | DTC Client socket (3) | Connecting to IP: 69.39.70.249. 2026-01-14 09:37:11.526 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:37:11.526 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:37:11.526 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:37:11.574 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:37:11.574 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:37:11.574 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:37:11.574 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:37:11.574 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:37:11.574 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:37:11.574 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:37:11.574 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:37:11.574 | Triggering next historical data download in queue. 2026-01-14 09:37:11.618 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:37:11.618 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:37:11.618 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:37:11.618 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:37:11.618 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:37:11.618 | Triggering next historical data download in queue. 2026-01-14 09:37:12.507 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:37:12.507 | SC Data with Depth | Sending logon request message. 2026-01-14 09:37:12.507 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:37:12.507 | Denali Data Feed | Sending logon request message. 2026-01-14 09:37:13.316 | SC Data with Depth | Received logon response. 2026-01-14 09:37:13.316 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:37:13.316 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:37:13.316 | SC Data with Depth | Successfully connected. 2026-01-14 09:37:13.316 | SC Data with Depth | Trading is not supported. 2026-01-14 09:37:13.316 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:37:13.316 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:37:13.316 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:37:13.316 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:37:13.316 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:37:13.557 | Denali Data Feed | Received logon response. 2026-01-14 09:37:13.557 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:37:13.557 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:37:13.557 | Denali Data Feed | Successfully connected. 2026-01-14 09:37:13.557 | Denali Data Feed | Trading is not supported. 2026-01-14 09:37:13.557 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:37:13.557 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:37:13.557 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:37:13.557 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:37:13.557 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:37:13.557 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:37:14.512 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:37:14.512 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:37:14.512 | Triggering next historical data download in queue. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:37:14.512 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:37:14.512 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:37:14.512 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:37:14.512 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:37:14.512 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:37:14.512 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:37:14.512 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:37:14.512 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:37:14.512 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:37:14.512 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.512 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:37:14.513 | HD Request # 78 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:37:14.513 | HD Request # 78 | Download start date-time: 2026-01-14 09:37:09.020411. 2026-01-14 09:37:14.513 | HD Request # 78 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:37:14.513 | Socket (8) | Creating socket. 2026-01-14 09:37:14.513 | Socket (8) | New receive buffer size: 0 2026-01-14 09:37:14.513 | Socket (8) | Connecting to IP: 64.152.155.17. 2026-01-14 09:37:14.691 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:37:14.691 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:37:14.691 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:37:14.691 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:37:14.691 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:37:14.691 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:37:14.691 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:37:14.691 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:37:15.201 | HD Request # 78 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:15.201 | HD Request # 78 | Sending historical data logon request message. 2026-01-14 09:37:15.577 | HD Request # 78 | Requesting market depth data. Start date-time: 2026-01-14 09:37:09. Symbol: ESH26 2026-01-14 09:37:15.880 | HD Request # 78 | Decompressing data. 2026-01-14 09:37:15.885 | HD Request # 78 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:37:09.021000 2026-01-14 09:37:16.298 | Socket (8) | CloseSocket call. 2026-01-14 09:37:16.298 | Socket (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:16.299 | Socket (8) | Socket gracefully closed by remote side. 2026-01-14 09:37:16.299 | Socket (8) | Closed. 2026-01-14 09:37:16.371 | Historical data download thread signaled to stop. 2026-01-14 09:37:16.371 | HD Request # 78 | Timestamp of first market depth data file record written: 2026-01-14 09:37:09.021000. 2026-01-14 09:37:16.371 | HD Request # 78 | Received 6529 Market Depth data records from 2026-01-14 09:37:09.021000 to 2026-01-14 09:37:14.815000 (5.8 seconds. Delay: 1.6 seconds) and wrote 6529 records for ESH6.CME 2026-01-14 09:37:16.371 | HD Request # 78 | Completion time: 2s. 2026-01-14 09:37:16.371 | HD Request # 78 | Market Depth data download complete for ESH6.CME. Unique request ID: 1314 2026-01-14 09:37:16.371 | Removing historical data download ID 1314. 2026-01-14 09:37:16.371 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:37:16.378 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:37:16.378 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:16.378 | 2026-01-14 09:37:16.378 | Triggering next historical data download in queue. 2026-01-14 09:37:16.378 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:37:16.381 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:16.395 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:37:16.395 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:37:16.406 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:16.420 | HD Request # 79 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:37:16.420 | HD Request # 79 | Download start date-time: 2026-01-14 09:37:09.020562. 2026-01-14 09:37:16.420 | HD Request # 79 | Using server: ds28.sierracharts.com port 10149 2026-01-14 09:37:16.420 | Socket (8) | Creating socket. 2026-01-14 09:37:16.421 | Socket (8) | New receive buffer size: 0 2026-01-14 09:37:16.421 | Socket (8) | Connecting to IP: 67.214.125.5. 2026-01-14 09:37:16.424 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:37:16.427 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:16.429 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:37:16.440 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:16.441 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:37:16.451 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:16.512 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:37:16.515 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:16.515 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:37:16.516 | Denali Data Feed (Market Orders Data) | Connecting to the server ds32-2.sierracharts.com. Port 10060 2026-01-14 09:37:16.516 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:37:16.516 | DTC Client socket (9) | Creating socket. 2026-01-14 09:37:16.516 | DTC Client socket (9) | New receive buffer size: 0 2026-01-14 09:37:16.516 | DTC Client socket (9) | Connecting to IP: 69.39.70.249. 2026-01-14 09:37:16.547 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:37:16.547 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:37:16.547 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:37:16.685 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:37:16.688 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 1312, 2026-01-14 09:37:17.177 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:37:17.177 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:37:17.303 | HD Request # 79 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:17.303 | HD Request # 79 | Sending historical data logon request message. 2026-01-14 09:37:17.671 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:37:17.671 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:37:17.978 | HD Request # 79 | Requesting market depth data. Start date-time: 2026-01-14 09:37:09. Symbol: NQH26 2026-01-14 09:37:18.748 | HD Request # 79 | Decompressing data. 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:37:18.760 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:37:19.575 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:37:19.575 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:37:19.791 | HD Request # 80 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:37:19.791 | HD Request # 80 | Download start date-time: 2026-01-14 09:37:08.000000. File last date-time: 2026-01-14 09:37:08.143000 2026-01-14 09:37:19.792 | HD Request # 80 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:37:19.792 | Socket (10) | Creating socket. 2026-01-14 09:37:19.792 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:19.792 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:37:20.225 | HD Request # 79 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:37:09.021000 2026-01-14 09:37:20.410 | HD Request # 80 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:20.410 | HD Request # 80 | Sending historical data logon request message. 2026-01-14 09:37:20.760 | HD Request # 80 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:08. Record interval: 0. Symbol: VOLX 2026-01-14 09:37:21.043 | HD Request # 80 | Decompressing data. 2026-01-14 09:37:21.284 | HD Request # 80 | Receiving Intraday data for VOLX starting at 2026-01-14 09:37:08.143000 2026-01-14 09:37:21.285 | Socket (10) | CloseSocket call. 2026-01-14 09:37:21.285 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:21.285 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:21.285 | Socket (10) | Closed. 2026-01-14 09:37:21.341 | Historical data download thread signaled to stop. 2026-01-14 09:37:21.342 | HD Request # 80 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:09.870000. 2026-01-14 09:37:21.342 | HD Request # 80 | Received 10 Intraday data records from 2026-01-14 09:37:08.143000 to 2026-01-14 09:37:20.017000 (11.9 seconds. Delay: 1.3 seconds) and wrote 9 records for VOLX 2026-01-14 09:37:21.351 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:20.017000 2026-01-14 09:37:21.351 | HD Request # 80 | Completion time: 2s. 2026-01-14 09:37:21.351 | HD Request # 80 | Intraday data download complete for VOLX. Unique request ID: 1307 2026-01-14 09:37:21.351 | Removing historical data download ID 1307. 2026-01-14 09:37:21.352 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:37:21.352 | Intraday chart data file opened for VOLX 2026-01-14 09:37:21.352 | HD Request # 80 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:21.352 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 1307 has completed. 2026-01-14 09:37:21.352 | 2026-01-14 09:37:21.352 | Triggering next historical data download in queue. 2026-01-14 09:37:21.380 | HD Request # 81 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:37:21.380 | HD Request # 81 | Download start date-time: 2026-01-14 09:37:08.000000. File last date-time: 2026-01-14 09:37:08.210001 2026-01-14 09:37:21.380 | HD Request # 81 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:37:21.380 | Socket (10) | Creating socket. 2026-01-14 09:37:21.380 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:21.380 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:37:22.176 | HD Request # 81 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:22.176 | HD Request # 81 | Sending historical data logon request message. 2026-01-14 09:37:22.506 | HD Request # 81 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:08. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:37:22.795 | HD Request # 81 | Decompressing data. 2026-01-14 09:37:22.831 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:37:23.009 | HD Request # 81 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:37:08.000000 2026-01-14 09:37:23.009 | Socket (10) | CloseSocket call. 2026-01-14 09:37:23.009 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:23.010 | Historical data download thread signaled to stop. 2026-01-14 09:37:23.010 | HD Request # 81 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:09.000000. 2026-01-14 09:37:23.010 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:23.010 | HD Request # 81 | Received 15 Intraday data records from 2026-01-14 09:37:08.000000 to 2026-01-14 09:37:22.000000 (14.0 seconds. Delay: 1.0 seconds) and wrote 14 records for TICK-NYSE 2026-01-14 09:37:23.010 | Socket (10) | Closed. 2026-01-14 09:37:23.018 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:22.000000 2026-01-14 09:37:23.018 | HD Request # 81 | Completion time: 2s. 2026-01-14 09:37:23.018 | HD Request # 81 | Intraday data download complete for TICK-NYSE. Unique request ID: 1308 2026-01-14 09:37:23.018 | Removing historical data download ID 1308. 2026-01-14 09:37:23.018 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:37:23.018 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:37:23.018 | HD Request # 81 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:23.018 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 1308 has completed. 2026-01-14 09:37:23.018 | 2026-01-14 09:37:23.018 | Triggering next historical data download in queue. 2026-01-14 09:37:23.029 | HD Request # 82 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:37:23.029 | HD Request # 82 | Download start date-time: 2026-01-14 09:37:08.000000. File last date-time: 2026-01-14 09:37:08.210001 2026-01-14 09:37:23.029 | HD Request # 82 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:37:23.029 | Socket (10) | Creating socket. 2026-01-14 09:37:23.030 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:23.030 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:37:23.764 | HD Request # 82 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:23.764 | HD Request # 82 | Sending historical data logon request message. 2026-01-14 09:37:24.219 | HD Request # 82 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:08. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:37:24.595 | HD Request # 82 | Decompressing data. 2026-01-14 09:37:24.838 | HD Request # 82 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:37:08.000000 2026-01-14 09:37:24.839 | Socket (10) | CloseSocket call. 2026-01-14 09:37:24.839 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:24.839 | Historical data download thread signaled to stop. 2026-01-14 09:37:24.839 | HD Request # 82 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:09.000000. 2026-01-14 09:37:24.839 | HD Request # 82 | Received 14 Intraday data records from 2026-01-14 09:37:08.000000 to 2026-01-14 09:37:21.000000 (13.0 seconds. Delay: 3.8 seconds) and wrote 13 records for NISS-NYSE 2026-01-14 09:37:24.839 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:24.839 | Socket (10) | Closed. 2026-01-14 09:37:24.846 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:21.000000 2026-01-14 09:37:24.847 | Added 25 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:37:24.847 | HD Request # 82 | Completion time: 1s. 2026-01-14 09:37:24.847 | HD Request # 82 | Intraday data download complete for NISS-NYSE. Unique request ID: 1309 2026-01-14 09:37:24.847 | Removing historical data download ID 1309. 2026-01-14 09:37:24.847 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:37:24.847 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:37:24.847 | HD Request # 82 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:24.847 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 1309 has completed. 2026-01-14 09:37:24.847 | 2026-01-14 09:37:24.847 | Triggering next historical data download in queue. 2026-01-14 09:37:24.847 | HD Request # 83 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:37:24.847 | HD Request # 83 | Download start date-time: 2026-01-14 09:37:08.000000. File last date-time: 2026-01-14 09:37:08.210002 2026-01-14 09:37:24.847 | HD Request # 83 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:37:24.847 | Socket (10) | Creating socket. 2026-01-14 09:37:24.847 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:24.847 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:37:25.392 | HD Request # 83 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:25.392 | HD Request # 83 | Sending historical data logon request message. 2026-01-14 09:37:25.675 | HD Request # 83 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:08. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:37:26.008 | HD Request # 83 | Decompressing data. 2026-01-14 09:37:26.157 | HD Request # 83 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:37:08.000000 2026-01-14 09:37:26.158 | Socket (10) | CloseSocket call. 2026-01-14 09:37:26.158 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:26.158 | Historical data download thread signaled to stop. 2026-01-14 09:37:26.158 | HD Request # 83 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:09.000000. 2026-01-14 09:37:26.158 | HD Request # 83 | Received 17 Intraday data records from 2026-01-14 09:37:08.000000 to 2026-01-14 09:37:24.000000 (16.0 seconds. Delay: 2.2 seconds) and wrote 16 records for TRIN-NYSE 2026-01-14 09:37:26.158 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:26.158 | Socket (10) | Closed. 2026-01-14 09:37:26.165 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:24.000000 2026-01-14 09:37:26.166 | Added 20 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:37:26.166 | HD Request # 83 | Completion time: 2s. 2026-01-14 09:37:26.166 | HD Request # 83 | Intraday data download complete for TRIN-NYSE. Unique request ID: 1310 2026-01-14 09:37:26.166 | Removing historical data download ID 1310. 2026-01-14 09:37:26.166 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:37:26.166 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:37:26.166 | HD Request # 83 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:26.166 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 1310 has completed. 2026-01-14 09:37:26.166 | 2026-01-14 09:37:26.166 | Triggering next historical data download in queue. 2026-01-14 09:37:26.166 | HD Request # 84 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:37:26.166 | HD Request # 84 | Download start date-time: 2026-01-14 09:37:02.000000. File last date-time: 2026-01-14 09:37:02.823000 2026-01-14 09:37:26.166 | HD Request # 84 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:37:26.166 | Socket (10) | Creating socket. 2026-01-14 09:37:26.166 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:26.166 | Socket (10) | Connecting to IP: 69.39.70.248. 2026-01-14 09:37:27.171 | HD Request # 84 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:27.171 | HD Request # 84 | Sending historical data logon request message. 2026-01-14 09:37:27.666 | HD Request # 84 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:02. Record interval: 0. Symbol: NQH26 2026-01-14 09:37:27.840 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:37:27.840 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:37:27.840 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:37:28.178 | HD Request # 84 | Decompressing data. 2026-01-14 09:37:28.532 | HD Request # 84 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:37:02.058000 2026-01-14 09:37:29.947 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | Creating socket. Using TLS 1.2. 2026-01-14 09:37:29.948 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | New receive buffer size: 0 2026-01-14 09:37:29.948 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | Connecting to IP: 38.79.0.89. 2026-01-14 09:37:30.167 | Socket (10) | CloseSocket call. 2026-01-14 09:37:30.167 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:30.168 | Historical data download thread signaled to stop. 2026-01-14 09:37:30.168 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:30.168 | HD Request # 84 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:02.842000. 2026-01-14 09:37:30.168 | Socket (10) | Closed. 2026-01-14 09:37:30.168 | HD Request # 84 | Received 1142 Intraday data records from 2026-01-14 09:37:02.058000 to 2026-01-14 09:37:26.678003 (24.6 seconds. Delay: 3.5 seconds) and wrote 1104 records for NQH6.CME 2026-01-14 09:37:30.175 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:26.678003 2026-01-14 09:37:30.175 | HD Request # 84 | Completion time: 4s. 2026-01-14 09:37:30.175 | HD Request # 84 | Intraday data download complete for NQH6.CME. Unique request ID: 1311 2026-01-14 09:37:30.175 | Removing historical data download ID 1311. 2026-01-14 09:37:30.175 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:37:30.175 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:37:30.175 | HD Request # 84 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:30.175 | 2026-01-14 09:37:30.175 | Triggering next historical data download in queue. 2026-01-14 09:37:30.175 | HD Request # 85 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:37:30.175 | HD Request # 85 | Download start date-time: 2026-01-14 09:37:02.000000. File last date-time: 2026-01-14 09:37:02.870005 2026-01-14 09:37:30.175 | HD Request # 85 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:37:30.176 | Socket (10) | Creating socket. 2026-01-14 09:37:30.176 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:30.176 | Socket (10) | Connecting to IP: 64.152.155.17. 2026-01-14 09:37:30.179 | Socket (8) | CloseSocket call. 2026-01-14 09:37:30.179 | Socket (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:30.180 | Socket (8) | Socket gracefully closed by remote side. 2026-01-14 09:37:30.180 | Socket (8) | Closed. 2026-01-14 09:37:30.201 | Historical data download thread signaled to stop. 2026-01-14 09:37:30.201 | HD Request # 79 | Timestamp of first market depth data file record written: 2026-01-14 09:37:09.021000. 2026-01-14 09:37:30.201 | HD Request # 79 | Received 16628 Market Depth data records from 2026-01-14 09:37:09.021000 to 2026-01-14 09:37:16.471000 (7.5 seconds. Delay: 13.7 seconds) and wrote 16628 records for NQH6.CME 2026-01-14 09:37:30.201 | HD Request # 79 | Completion time: 14s. 2026-01-14 09:37:30.201 | HD Request # 79 | Market Depth data download complete for NQH6.CME. Unique request ID: 1316 2026-01-14 09:37:30.201 | Removing historical data download ID 1316. 2026-01-14 09:37:30.201 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:37:30.208 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:37:30.208 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:37:30.208 | 2026-01-14 09:37:30.208 | No download requests in the queue to start downloads for. 2026-01-14 09:37:30.233 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:37:30.314 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:37:30.319 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:37:30.356 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:37:30.385 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:37:30.446 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:37:30.462 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:37:30.545 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:30.545 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:30.545 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:37:30.580 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:30.580 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:37:30.613 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:37:30.649 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:37:30.684 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:37:30.699 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:37:30.707 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:37:30.819 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:37:30.820 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:30.820 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:37:30.895 | HD Request # 85 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:30.895 | HD Request # 85 | Sending historical data logon request message. 2026-01-14 09:37:30.960 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:37:30.965 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:37:30.966 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:30.993 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:37:31.246 | HD Request # 85 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:02. Record interval: 0. Symbol: ESH26 2026-01-14 09:37:31.488 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:37:31.491 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:37:31.492 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:31.523 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:37:31.623 | HD Request # 85 | Decompressing data. 2026-01-14 09:37:31.661 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:31.872 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:31.877 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:37:31.878 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:31.880 | HD Request # 85 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:37:02.009000 2026-01-14 09:37:31.881 | Socket (10) | CloseSocket call. 2026-01-14 09:37:31.881 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:31.881 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:31.881 | Socket (10) | Closed. 2026-01-14 09:37:31.904 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:31.922 | Historical data download thread signaled to stop. 2026-01-14 09:37:31.922 | HD Request # 85 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:02.916000. 2026-01-14 09:37:31.922 | HD Request # 85 | Received 1974 Intraday data records from 2026-01-14 09:37:02.009000 to 2026-01-14 09:37:28.893002 (26.9 seconds. Delay: 3.0 seconds) and wrote 1840 records for ESH6.CME 2026-01-14 09:37:31.929 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:28.893002 2026-01-14 09:37:31.929 | HD Request # 85 | Completion time: 1s. 2026-01-14 09:37:31.929 | HD Request # 85 | Intraday data download complete for ESH6.CME. Unique request ID: 1312 2026-01-14 09:37:31.929 | Removing historical data download ID 1312. 2026-01-14 09:37:31.929 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:37:31.929 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:37:31.929 | HD Request # 85 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:31.929 | 2026-01-14 09:37:31.929 | Triggering next historical data download in queue. 2026-01-14 09:37:31.929 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:31.930 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:37:31.935 | HD Request # 86 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:37:31.935 | HD Request # 86 | Download start date-time: 2026-01-14 09:37:02.000000. File last date-time: 2026-01-14 09:37:02.837001 2026-01-14 09:37:31.935 | HD Request # 86 | Using server: ds28.sierracharts.com port 10149 2026-01-14 09:37:31.935 | Socket (10) | Creating socket. 2026-01-14 09:37:31.936 | Socket (10) | New receive buffer size: 0 2026-01-14 09:37:31.936 | Socket (10) | Connecting to IP: 67.214.125.5. 2026-01-14 09:37:31.974 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:31.975 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:37:32.104 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:32.104 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:37:32.104 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:32.105 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:37:32.105 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:32.105 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:37:32.181 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:32.183 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:37:32.227 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:37:32.259 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:32.259 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:37:32.322 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:37:32.450 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:37:32.473 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:37:32.484 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:37:32.484 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:37:32.488 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:37:32.609 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:37:32.627 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:37:32.727 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:37:32.733 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:37:32.774 | HD Request # 86 | Setting DTC encoding to Binary VLS 2026-01-14 09:37:32.774 | HD Request # 86 | Sending historical data logon request message. 2026-01-14 09:37:32.796 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:37:32.799 | + Loading additional symbol data. 2026-01-14 09:37:32.843 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:37:32.843 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:37:32.843 | + Loading additional symbol data. 2026-01-14 09:37:32.933 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:37:32.935 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:32.935 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:32.935 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:37:32.950 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:37:32.955 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:37:32.958 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:32.984 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:37:32.988 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:33.061 | HD Request # 86 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:02. Record interval: 0. Symbol: RTYH26 2026-01-14 09:37:33.246 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:33.246 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:37:33.409 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:37:33.409 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:37:33.409 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:37:33.409 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:37:33.427 | NTP Client | Received Packet | RoundTripDelay=0.01798534393310547, SystemClockOffset=-0.019526958465576172 2026-01-14 09:37:33.430 | HD Request # 86 | Decompressing data. 2026-01-14 09:37:33.442 | NTP Client | Received Packet | RoundTripDelay=0.031986236572265625, SystemClockOffset=-0.022181034088134766 2026-01-14 09:37:33.525 | + Loading additional symbol data. 2026-01-14 09:37:33.568 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:37:33.615 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:37:33.682 | NTP Client | Received Packet | RoundTripDelay=0.2729988098144531, SystemClockOffset=-0.011815071105957031 2026-01-14 09:37:33.699 | HD Request # 86 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:37:02.018000 2026-01-14 09:37:33.699 | Socket (10) | CloseSocket call. 2026-01-14 09:37:33.699 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:33.699 | Historical data download thread signaled to stop. 2026-01-14 09:37:33.699 | HD Request # 86 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:02.871000. 2026-01-14 09:37:33.700 | HD Request # 86 | Received 384 Intraday data records from 2026-01-14 09:37:02.018000 to 2026-01-14 09:37:32.426001 (30.4 seconds. Delay: 1.3 seconds) and wrote 368 records for RTYH6.CME 2026-01-14 09:37:33.700 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:37:33.700 | Socket (10) | Closed. 2026-01-14 09:37:33.708 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:37:32.426001 2026-01-14 09:37:33.708 | HD Request # 86 | Completion time: 2s. 2026-01-14 09:37:33.708 | HD Request # 86 | Intraday data download complete for RTYH6.CME. Unique request ID: 1313 2026-01-14 09:37:33.708 | Removing historical data download ID 1313. 2026-01-14 09:37:33.708 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:37:33.708 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:37:33.708 | HD Request # 86 | Enabling Intraday chart updating for symbol. 2026-01-14 09:37:33.708 | 2026-01-14 09:37:33.708 | No download requests in the queue to start downloads for. 2026-01-14 09:37:33.890 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:37:33.892 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:37:33.892 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:33.916 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:37:33.916 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:33.920 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:37:33.973 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:34.012 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:34.303 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:34.309 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:37:34.394 | NTP Client | Performed system clock adjustment of -19526.958465576172 microseconds. 2026-01-14 09:37:34.422 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:37:37.833 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:37:49.940 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | Creating socket. Using TLS 1.2. 2026-01-14 09:37:49.940 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | New receive buffer size: 0 2026-01-14 09:37:49.940 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | Connecting to IP: 38.79.0.89. 2026-01-14 09:37:51.363 | File >> Disconnect selected. 2026-01-14 09:37:51.371 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:37:51.371 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:37:51.371 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:51.372 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:37:51.372 | DTC Client socket (1) | Closed. 2026-01-14 09:37:51.372 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:37:51.373 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:37:51.373 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:37:51.373 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:51.373 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:37:51.373 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:37:51.373 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:37:51.373 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:37:51.373 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:51.373 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:37:51.373 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:37:51.373 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:37:51.373 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:37:51.374 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:37:51.374 | DTC Client socket (3) | Closed. 2026-01-14 09:37:51.376 | DTC Client socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:37:51.376 | DTC Client socket (9) | Closed. 2026-01-14 09:37:51.377 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:37:51.377 | DTC Client socket (2) | Closed. 2026-01-14 09:37:52.267 | 2026-01-14 09:37:52.267 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:37:52.267 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:37:52.267 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:37:52.268 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:37:52.268 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:37:52.268 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:37:52.273 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:37:52.273 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:37:52.273 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:37:52.273 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:38:00.850 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:38:00.850 | No download requests in the queue to start downloads for. 2026-01-14 09:38:00.852 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:38:00.852 | Using symbol data fast lookup vector 2026-01-14 09:38:00.852 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:38:00.852 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-01-14 09:38:00.852 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:38:00.852 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:38:00.852 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:38:00.852 | Triggering next historical data download in queue. 2026-01-14 09:38:00.852 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 1612 2026-01-14 09:38:00.852 | DTC Client socket (2) | Creating socket. 2026-01-14 09:38:00.852 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:38:00.852 | DTC Client socket (2) | Connecting to IP: 64.152.155.113. 2026-01-14 09:38:00.855 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:38:00.855 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:38:00.855 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:38:00.855 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:38:00.855 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 1613 2026-01-14 09:38:00.855 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:38:00.855 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:38:00.855 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:38:00.855 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:38:00.855 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 1614 2026-01-14 09:38:00.855 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:38:00.855 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:38:00.855 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:38:00.855 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:38:00.855 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 1615 2026-01-14 09:38:00.858 | Delaying start of download for VOLX. 2026-01-14 09:38:00.858 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:38:00.858 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:38:00.858 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:38:00.879 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:38:00.879 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:38:00.879 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443 2026-01-14 09:38:00.879 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:38:00.879 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:38:00.879 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:38:00.879 | Triggering next historical data download in queue. 2026-01-14 09:38:00.879 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:38:00.879 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 6 Service code: cme 2026-01-14 09:38:00.879 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 6 2026-01-14 09:38:00.881 | DTC Client socket (3) | Creating socket. 2026-01-14 09:38:00.881 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:38:00.881 | DTC Client socket (3) | Connecting to IP: 64.152.155.20. 2026-01-14 09:38:00.891 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:38:00.891 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:38:00.891 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:38:00.891 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:38:00.891 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:38:00.891 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:38:00.891 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:38:00.891 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:38:00.902 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:38:00.902 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:38:00.902 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:38:01.120 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:38:01.120 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:38:01.120 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:38:01.120 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:38:01.120 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:38:01.120 | Triggering next historical data download in queue. 2026-01-14 09:38:01.897 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:38:01.897 | Denali Data Feed | Sending logon request message. 2026-01-14 09:38:02.941 | Denali Data Feed | Received logon response. 2026-01-14 09:38:02.941 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:38:02.941 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:38:02.941 | Denali Data Feed | Successfully connected. 2026-01-14 09:38:02.941 | Denali Data Feed | Trading is not supported. 2026-01-14 09:38:02.941 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:38:02.941 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:38:02.941 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:38:02.941 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:38:02.941 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:38:02.941 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:38:03.408 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:38:03.408 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:38:03.408 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:38:03.408 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:38:03.419 | NTP Client | Received Packet | RoundTripDelay=0.01098489761352539, SystemClockOffset=-0.023823022842407227 2026-01-14 09:38:03.446 | NTP Client | Received Packet | RoundTripDelay=0.03695201873779297, SystemClockOffset=-0.021344661712646484 2026-01-14 09:38:03.690 | NTP Client | Received Packet | RoundTripDelay=0.28099822998046875, SystemClockOffset=-0.016845226287841797 2026-01-14 09:38:03.938 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:38:03.938 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:38:03.938 | Triggering next historical data download in queue. 2026-01-14 09:38:03.938 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:38:03.939 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.939 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:38:03.940 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:38:03.940 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:38:03.940 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:38:03.940 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:38:03.940 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:38:03.940 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:38:03.940 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:38:03.940 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:38:03.940 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.940 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.941 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.942 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.943 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:38:03.944 | HD Request # 87 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:38:03.944 | HD Request # 87 | Download start date-time: 2026-01-14 09:37:51.372741. 2026-01-14 09:38:03.944 | HD Request # 87 | Using server: ds32.sierracharts.com port 10150 2026-01-14 09:38:03.944 | Socket (9) | Creating socket. 2026-01-14 09:38:03.944 | Socket (9) | New receive buffer size: 0 2026-01-14 09:38:03.944 | Socket (9) | Connecting to IP: 69.39.70.248. 2026-01-14 09:38:04.388 | NTP Client | Performed system clock adjustment of -21344.661712646484 microseconds. 2026-01-14 09:38:04.452 | HD Request # 87 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:04.452 | HD Request # 87 | Sending historical data logon request message. 2026-01-14 09:38:04.882 | HD Request # 87 | Requesting market depth data. Start date-time: 2026-01-14 09:37:51. Symbol: ESH26 2026-01-14 09:38:05.179 | HD Request # 87 | Decompressing data. 2026-01-14 09:38:05.196 | HD Request # 87 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:37:51.374000 2026-01-14 09:38:05.599 | Socket (9) | CloseSocket call. 2026-01-14 09:38:05.599 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:05.600 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:38:05.600 | Socket (9) | Closed. 2026-01-14 09:38:05.617 | Historical data download thread signaled to stop. 2026-01-14 09:38:05.617 | HD Request # 87 | Timestamp of first market depth data file record written: 2026-01-14 09:37:51.374000. 2026-01-14 09:38:05.617 | HD Request # 87 | Received 10123 Market Depth data records from 2026-01-14 09:37:51.374000 to 2026-01-14 09:38:01.634000 (10.3 seconds. Delay: 4.0 seconds) and wrote 10123 records for ESH6.CME 2026-01-14 09:38:05.617 | HD Request # 87 | Completion time: 2s. 2026-01-14 09:38:05.617 | HD Request # 87 | Market Depth data download complete for ESH6.CME. Unique request ID: 1619 2026-01-14 09:38:05.617 | Removing historical data download ID 1619. 2026-01-14 09:38:05.617 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:38:05.623 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:38:05.623 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.623 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.623 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.623 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.624 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.624 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.624 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:05.624 | 2026-01-14 09:38:05.624 | Triggering next historical data download in queue. 2026-01-14 09:38:05.679 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:38:05.682 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:05.682 | HD Request # 88 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:38:05.682 | HD Request # 88 | Download start date-time: 2026-01-14 09:37:51.371567. 2026-01-14 09:38:05.682 | HD Request # 88 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:38:05.682 | Socket (9) | Creating socket. 2026-01-14 09:38:05.682 | Socket (9) | New receive buffer size: 0 2026-01-14 09:38:05.682 | Socket (9) | Connecting to IP: 64.152.155.17. 2026-01-14 09:38:05.690 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:38:05.699 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:38:05.709 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:05.712 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:38:05.715 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:05.720 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:38:05.723 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:05.846 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:38:05.847 | Denali Data Feed (Market Orders Data) | Connecting to the server ds25.sierracharts.com. Port 10060 2026-01-14 09:38:05.847 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:38:05.849 | DTC Client socket (10) | Creating socket. 2026-01-14 09:38:05.849 | DTC Client socket (10) | New receive buffer size: 0 2026-01-14 09:38:05.849 | DTC Client socket (10) | Connecting to IP: 64.152.155.20. 2026-01-14 09:38:05.871 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:38:05.871 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:38:05.871 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:38:05.941 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:38:05.952 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:05.973 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:38:05.976 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:05.981 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:38:05.991 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 1617, 2026-01-14 09:38:06.364 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:38:06.472 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:38:06.472 | SC Data with Depth | Sending logon request message. 2026-01-14 09:38:06.717 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:38:06.717 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:38:07.265 | SC Data with Depth | Received logon response. 2026-01-14 09:38:07.265 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:38:07.265 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:38:07.265 | SC Data with Depth | Successfully connected. 2026-01-14 09:38:07.265 | SC Data with Depth | Trading is not supported. 2026-01-14 09:38:07.265 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:38:07.265 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:38:07.265 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:38:07.265 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:38:07.265 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:38:07.371 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:38:07.391 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:38:08.076 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:38:08.076 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:38:08.076 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:38:08.076 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:38:08.076 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:38:08.076 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:38:08.076 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:38:08.076 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:38:08.076 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:38:08.076 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:38:09.588 | HD Request # 88 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:09.588 | HD Request # 88 | Sending historical data logon request message. 2026-01-14 09:38:10.311 | HD Request # 88 | Requesting market depth data. Start date-time: 2026-01-14 09:37:51. Symbol: NQH26 2026-01-14 09:38:10.789 | HD Request # 88 | Decompressing data. 2026-01-14 09:38:10.799 | HD Request # 88 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:37:51.372000 2026-01-14 09:38:12.249 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | Creating socket. Using TLS 1.2. 2026-01-14 09:38:12.250 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | New receive buffer size: 0 2026-01-14 09:38:12.250 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | Connecting to IP: 38.79.0.89. 2026-01-14 09:38:13.781 | HD Request # 89 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:38:13.782 | HD Request # 89 | Download start date-time: 2026-01-14 09:37:48.000000. File last date-time: 2026-01-14 09:37:48.495000 2026-01-14 09:38:13.782 | HD Request # 89 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:38:13.782 | Socket (13) | Creating socket. 2026-01-14 09:38:13.782 | Socket (13) | New receive buffer size: 0 2026-01-14 09:38:13.782 | Socket (13) | Connecting to IP: 69.39.70.241. 2026-01-14 09:38:14.359 | HD Request # 89 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:14.359 | HD Request # 89 | Sending historical data logon request message. 2026-01-14 09:38:14.686 | HD Request # 89 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:48. Record interval: 0. Symbol: VOLX 2026-01-14 09:38:14.996 | HD Request # 89 | Decompressing data. 2026-01-14 09:38:15.257 | HD Request # 89 | Receiving Intraday data for VOLX starting at 2026-01-14 09:37:48.482000 2026-01-14 09:38:15.258 | Socket (13) | CloseSocket call. 2026-01-14 09:38:15.258 | Socket (13) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:15.264 | Socket (13) | Socket gracefully closed by remote side. 2026-01-14 09:38:15.264 | Socket (13) | Closed. 2026-01-14 09:38:15.280 | Historical data download thread signaled to stop. 2026-01-14 09:38:15.280 | HD Request # 89 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:51.570000. 2026-01-14 09:38:15.280 | HD Request # 89 | Received 27 Intraday data records from 2026-01-14 09:37:48.482000 to 2026-01-14 09:38:08.815000 (20.3 seconds. Delay: 6.5 seconds) and wrote 25 records for VOLX 2026-01-14 09:38:15.288 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:08.815000 2026-01-14 09:38:15.288 | Added 2 Time and Sales records to Intraday data file for VOLX after download. 2026-01-14 09:38:15.288 | HD Request # 89 | Completion time: 2s. 2026-01-14 09:38:15.288 | HD Request # 89 | Intraday data download complete for VOLX. Unique request ID: 1612 2026-01-14 09:38:15.288 | Removing historical data download ID 1612. 2026-01-14 09:38:15.288 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:38:15.288 | Intraday chart data file opened for VOLX 2026-01-14 09:38:15.288 | HD Request # 89 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:15.288 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 1612 has completed. 2026-01-14 09:38:15.288 | 2026-01-14 09:38:15.288 | Triggering next historical data download in queue. 2026-01-14 09:38:15.288 | HD Request # 90 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:38:15.288 | HD Request # 90 | Download start date-time: 2026-01-14 09:37:50.000000. File last date-time: 2026-01-14 09:37:50.704002 2026-01-14 09:38:15.288 | HD Request # 90 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:38:15.288 | Socket (13) | Creating socket. 2026-01-14 09:38:15.288 | Socket (13) | New receive buffer size: 0 2026-01-14 09:38:15.288 | Socket (13) | Connecting to IP: 64.152.155.113. 2026-01-14 09:38:16.101 | HD Request # 90 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:16.101 | HD Request # 90 | Sending historical data logon request message. 2026-01-14 09:38:16.457 | HD Request # 90 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:50. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:38:16.784 | HD Request # 90 | Decompressing data. 2026-01-14 09:38:16.989 | HD Request # 90 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:37:50.000000 2026-01-14 09:38:16.990 | Socket (13) | CloseSocket call. 2026-01-14 09:38:16.990 | Socket (13) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:16.990 | Historical data download thread signaled to stop. 2026-01-14 09:38:16.990 | HD Request # 90 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:51.000000. 2026-01-14 09:38:16.990 | Socket (13) | Socket gracefully closed by remote side. 2026-01-14 09:38:16.991 | HD Request # 90 | Received 27 Intraday data records from 2026-01-14 09:37:50.000000 to 2026-01-14 09:38:16.000000 (26.0 seconds. Delay: 1.0 seconds) and wrote 26 records for TICK-NYSE 2026-01-14 09:38:16.991 | Socket (13) | Closed. 2026-01-14 09:38:17.001 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:16.000000 2026-01-14 09:38:17.001 | Added 6 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:38:17.001 | HD Request # 90 | Completion time: 2s. 2026-01-14 09:38:17.001 | HD Request # 90 | Intraday data download complete for TICK-NYSE. Unique request ID: 1613 2026-01-14 09:38:17.001 | Removing historical data download ID 1613. 2026-01-14 09:38:17.001 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:38:17.001 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:38:17.001 | HD Request # 90 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:17.001 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 1613 has completed. 2026-01-14 09:38:17.001 | 2026-01-14 09:38:17.001 | Triggering next historical data download in queue. 2026-01-14 09:38:17.024 | HD Request # 91 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:38:17.024 | HD Request # 91 | Download start date-time: 2026-01-14 09:37:50.000000. File last date-time: 2026-01-14 09:37:50.704000 2026-01-14 09:38:17.024 | HD Request # 91 | Using server: ds12.sierracharts.com port 10150 2026-01-14 09:38:17.024 | Socket (13) | Creating socket. 2026-01-14 09:38:17.024 | Socket (13) | New receive buffer size: 0 2026-01-14 09:38:17.024 | Socket (13) | Connecting to IP: 69.39.70.241. 2026-01-14 09:38:17.779 | HD Request # 91 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:17.779 | HD Request # 91 | Sending historical data logon request message. 2026-01-14 09:38:17.897 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:38:17.898 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:38:18.288 | HD Request # 91 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:50. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:38:18.643 | HD Request # 91 | Decompressing data. 2026-01-14 09:38:19.057 | HD Request # 91 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:37:50.000000 2026-01-14 09:38:19.057 | Socket (13) | CloseSocket call. 2026-01-14 09:38:19.057 | Socket (13) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:19.057 | Historical data download thread signaled to stop. 2026-01-14 09:38:19.057 | HD Request # 91 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:51.000000. 2026-01-14 09:38:19.057 | HD Request # 91 | Received 28 Intraday data records from 2026-01-14 09:37:50.000000 to 2026-01-14 09:38:17.000000 (27.0 seconds. Delay: 2.1 seconds) and wrote 27 records for NISS-NYSE 2026-01-14 09:38:19.058 | Socket (13) | Socket gracefully closed by remote side. 2026-01-14 09:38:19.058 | Socket (13) | Closed. 2026-01-14 09:38:19.064 | HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:17.000000 2026-01-14 09:38:19.064 | Added 11 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:38:19.064 | HD Request # 91 | Completion time: 2s. 2026-01-14 09:38:19.064 | HD Request # 91 | Intraday data download complete for NISS-NYSE. Unique request ID: 1614 2026-01-14 09:38:19.065 | Removing historical data download ID 1614. 2026-01-14 09:38:19.065 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:38:19.065 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:38:19.065 | HD Request # 91 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:19.065 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 1614 has completed. 2026-01-14 09:38:19.065 | 2026-01-14 09:38:19.065 | Triggering next historical data download in queue. 2026-01-14 09:38:19.065 | HD Request # 92 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:38:19.065 | HD Request # 92 | Download start date-time: 2026-01-14 09:37:50.000000. File last date-time: 2026-01-14 09:37:50.704001 2026-01-14 09:38:19.065 | HD Request # 92 | Using server: ds4.sierracharts.com port 10149 2026-01-14 09:38:19.065 | Socket (13) | Creating socket. 2026-01-14 09:38:19.065 | Socket (13) | New receive buffer size: 0 2026-01-14 09:38:19.065 | Socket (13) | Connecting to IP: 64.152.155.113. 2026-01-14 09:38:19.720 | HD Request # 92 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:19.720 | HD Request # 92 | Sending historical data logon request message. 2026-01-14 09:38:20.070 | HD Request # 92 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:50. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:38:20.395 | HD Request # 92 | Decompressing data. 2026-01-14 09:38:20.646 | HD Request # 92 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:37:50.000000 2026-01-14 09:38:20.646 | Socket (13) | CloseSocket call. 2026-01-14 09:38:20.646 | Socket (13) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:20.646 | Historical data download thread signaled to stop. 2026-01-14 09:38:20.646 | HD Request # 92 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:51.000000. 2026-01-14 09:38:20.646 | HD Request # 92 | Received 29 Intraday data records from 2026-01-14 09:37:50.000000 to 2026-01-14 09:38:18.000000 (28.0 seconds. Delay: 2.6 seconds) and wrote 28 records for TRIN-NYSE 2026-01-14 09:38:20.647 | Socket (13) | Socket gracefully closed by remote side. 2026-01-14 09:38:20.647 | Socket (13) | Closed. 2026-01-14 09:38:20.654 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:18.000000 2026-01-14 09:38:20.654 | Added 26 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:38:20.654 | HD Request # 92 | Completion time: 1s. 2026-01-14 09:38:20.654 | HD Request # 92 | Intraday data download complete for TRIN-NYSE. Unique request ID: 1615 2026-01-14 09:38:20.654 | Removing historical data download ID 1615. 2026-01-14 09:38:20.654 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:38:20.654 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:38:20.654 | HD Request # 92 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:20.654 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 1615 has completed. 2026-01-14 09:38:20.654 | 2026-01-14 09:38:20.654 | Triggering next historical data download in queue. 2026-01-14 09:38:20.679 | HD Request # 93 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:38:20.679 | HD Request # 93 | Download start date-time: 2026-01-14 09:37:32.000000. File last date-time: 2026-01-14 09:37:32.416003 2026-01-14 09:38:20.680 | HD Request # 93 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:38:20.680 | Socket (13) | Creating socket. 2026-01-14 09:38:20.680 | Socket (13) | New receive buffer size: 0 2026-01-14 09:38:20.680 | Socket (13) | Connecting to IP: 67.214.125.5. 2026-01-14 09:38:21.147 | HD Request # 88 | Timestamp of first market depth data file record written: 2026-01-14 09:37:51.372000. 2026-01-14 09:38:21.521 | Socket (9) | CloseSocket call. 2026-01-14 09:38:21.522 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:21.522 | Historical data download thread signaled to stop. 2026-01-14 09:38:21.522 | HD Request # 88 | Received 36467 Market Depth data records from 2026-01-14 09:37:51.372000 to 2026-01-14 09:38:08.047000 (16.7 seconds. Delay: 13.5 seconds) and wrote 36467 records for NQH6.CME 2026-01-14 09:38:21.522 | HD Request # 88 | Completion time: 16s. 2026-01-14 09:38:21.522 | HD Request # 88 | Market Depth data download complete for NQH6.CME. Unique request ID: 1621 2026-01-14 09:38:21.522 | Removing historical data download ID 1621. 2026-01-14 09:38:21.522 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:38:21.522 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:38:21.522 | Socket (9) | Closed. 2026-01-14 09:38:21.533 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:38:21.533 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:38:21.533 | 2026-01-14 09:38:21.533 | No download requests in the queue to start downloads for. 2026-01-14 09:38:21.555 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:38:21.566 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.568 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:38:21.571 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.637 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:38:21.640 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.806 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:38:21.817 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.818 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:38:21.822 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.870 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:38:21.876 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.913 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:38:21.946 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:38:21.957 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 1616, 2026-01-14 09:38:21.972 | HD Request # 93 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:21.972 | HD Request # 93 | Sending historical data logon request message. 2026-01-14 09:38:22.148 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | CloseSocket call. 2026-01-14 09:38:22.148 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:22.148 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | Socket gracefully closed by remote side. 2026-01-14 09:38:22.148 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (8) | Closed. 2026-01-14 09:38:22.346 | HD Request # 93 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:32. Record interval: 0. Symbol: NQH26 2026-01-14 09:38:22.669 | HD Request # 93 | Decompressing data. 2026-01-14 09:38:22.906 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:38:22.906 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:38:22.961 | HD Request # 93 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:37:32.179000 2026-01-14 09:38:23.211 | Socket (13) | CloseSocket call. 2026-01-14 09:38:23.211 | Socket (13) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:23.212 | Historical data download thread signaled to stop. 2026-01-14 09:38:23.212 | HD Request # 93 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:32.564000. 2026-01-14 09:38:23.212 | HD Request # 93 | Received 1947 Intraday data records from 2026-01-14 09:37:32.179000 to 2026-01-14 09:38:20.752000 (48.6 seconds. Delay: 2.5 seconds) and wrote 1939 records for NQH6.CME 2026-01-14 09:38:23.212 | Socket (13) | Socket gracefully closed by remote side. 2026-01-14 09:38:23.212 | Socket (13) | Closed. 2026-01-14 09:38:23.221 | HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:20.752000 2026-01-14 09:38:23.221 | Added 30 Time and Sales records to Intraday data file for NQH6.CME after download. 2026-01-14 09:38:23.221 | HD Request # 93 | Completion time: 3s. 2026-01-14 09:38:23.221 | HD Request # 93 | Intraday data download complete for NQH6.CME. Unique request ID: 1616 2026-01-14 09:38:23.221 | Removing historical data download ID 1616. 2026-01-14 09:38:23.221 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:38:23.221 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:38:23.221 | HD Request # 93 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:23.226 | 2026-01-14 09:38:23.226 | Triggering next historical data download in queue. 2026-01-14 09:38:23.226 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.228 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:38:23.229 | HD Request # 94 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:38:23.229 | HD Request # 94 | Download start date-time: 2026-01-14 09:37:32.000000. File last date-time: 2026-01-14 09:37:32.494004 2026-01-14 09:38:23.229 | HD Request # 94 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:38:23.229 | Socket (8) | Creating socket. 2026-01-14 09:38:23.229 | Socket (8) | New receive buffer size: 0 2026-01-14 09:38:23.229 | Socket (8) | Connecting to IP: 69.39.70.248. 2026-01-14 09:38:23.293 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.293 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:38:23.309 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.309 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:38:23.313 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.313 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:38:23.341 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.342 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:38:23.344 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:38:23.416 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:38:23.446 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.447 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:38:23.494 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:38:23.509 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:23.510 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:38:23.526 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:38:23.537 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:38:23.555 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:23.555 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:38:23.648 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:23.648 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:23.648 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:38:23.676 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:38:23.711 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:38:23.822 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:38:23.839 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:38:23.860 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:38:23.864 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:38:23.866 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:23.892 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:38:23.938 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:38:23.939 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:23.939 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:38:23.949 | HD Request # 94 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:23.949 | HD Request # 94 | Sending historical data logon request message. 2026-01-14 09:38:23.951 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:38:23.969 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:23.969 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:38:24.054 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:24.054 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:38:24.084 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:38:24.119 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:38:24.307 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:38:24.446 | HD Request # 94 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:32. Record interval: 0. Symbol: ESH26 2026-01-14 09:38:24.497 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:38:24.500 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:38:24.500 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:24.527 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:38:24.527 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:24.561 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:24.589 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:24.802 | HD Request # 94 | Decompressing data. 2026-01-14 09:38:24.888 | HD Request # 94 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:37:32.032000 2026-01-14 09:38:24.914 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:24.921 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:38:24.922 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:24.976 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:25.138 | Socket (8) | CloseSocket call. 2026-01-14 09:38:25.138 | Socket (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:25.138 | Historical data download thread signaled to stop. 2026-01-14 09:38:25.138 | Socket (8) | Socket gracefully closed by remote side. 2026-01-14 09:38:25.138 | Socket (8) | Closed. 2026-01-14 09:38:25.139 | HD Request # 94 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:32.569000. 2026-01-14 09:38:25.139 | HD Request # 94 | Received 3709 Intraday data records from 2026-01-14 09:37:32.032000 to 2026-01-14 09:38:22.796006 (50.8 seconds. Delay: 2.3 seconds) and wrote 3679 records for ESH6.CME 2026-01-14 09:38:25.146 | HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:22.796006 2026-01-14 09:38:25.146 | Added 85 Time and Sales records to Intraday data file for ESH6.CME after download. 2026-01-14 09:38:25.146 | HD Request # 94 | Completion time: 2s. 2026-01-14 09:38:25.146 | HD Request # 94 | Intraday data download complete for ESH6.CME. Unique request ID: 1617 2026-01-14 09:38:25.146 | Removing historical data download ID 1617. 2026-01-14 09:38:25.146 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:38:25.146 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:38:25.146 | HD Request # 94 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:25.152 | 2026-01-14 09:38:25.152 | Triggering next historical data download in queue. 2026-01-14 09:38:25.152 | HD Request # 95 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:38:25.152 | HD Request # 95 | Download start date-time: 2026-01-14 09:37:32.000000. File last date-time: 2026-01-14 09:37:32.426001 2026-01-14 09:38:25.152 | HD Request # 95 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:38:25.152 | Socket (8) | Creating socket. 2026-01-14 09:38:25.152 | Socket (8) | New receive buffer size: 0 2026-01-14 09:38:25.152 | Socket (8) | Connecting to IP: 64.152.155.17. 2026-01-14 09:38:25.190 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.191 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:38:25.196 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.198 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:38:25.222 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.224 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:38:25.269 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.270 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:38:25.300 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:38:25.320 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:38:25.387 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.388 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:38:25.448 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.448 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:38:25.486 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:38:25.487 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:38:25.496 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:38:25.619 | + Loading additional symbol data. 2026-01-14 09:38:25.649 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:38:25.651 | HD Request # 95 | Setting DTC encoding to Binary VLS 2026-01-14 09:38:25.651 | HD Request # 95 | Sending historical data logon request message. 2026-01-14 09:38:25.664 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:38:25.672 | + Loading additional symbol data. 2026-01-14 09:38:25.679 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:25.679 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:38:25.690 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:38:25.706 | + Loading additional symbol data. 2026-01-14 09:38:25.750 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:38:25.800 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:38:25.802 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:25.802 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:25.802 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:38:25.941 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:38:25.946 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:38:25.948 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:25.974 | HD Request # 95 | Requesting Intraday data. Start date-time: 2026-01-14 09:37:32. Record interval: 0. Symbol: RTYH26 2026-01-14 09:38:25.974 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:38:26.002 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:38:26.083 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:38:26.231 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:26.231 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:38:26.341 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:26.341 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:38:26.353 | HD Request # 95 | Decompressing data. 2026-01-14 09:38:26.661 | + Loading additional symbol data. 2026-01-14 09:38:26.674 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:38:26.718 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:38:26.840 | HD Request # 95 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:37:32.266000 2026-01-14 09:38:26.840 | Socket (8) | CloseSocket call. 2026-01-14 09:38:26.841 | Socket (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:26.841 | Socket (8) | Socket gracefully closed by remote side. 2026-01-14 09:38:26.841 | Socket (8) | Closed. 2026-01-14 09:38:26.908 | Historical data download thread signaled to stop. 2026-01-14 09:38:26.908 | HD Request # 95 | Timestamp of first Intraday data file record written: 2026-01-14 09:37:32.883000. 2026-01-14 09:38:26.908 | HD Request # 95 | Received 494 Intraday data records from 2026-01-14 09:37:32.266000 to 2026-01-14 09:38:24.346000 (52.1 seconds. Delay: 2.6 seconds) and wrote 485 records for RTYH6.CME 2026-01-14 09:38:26.914 | HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:38:24.346000 2026-01-14 09:38:26.914 | Added 4 Time and Sales records to Intraday data file for RTYH6.CME after download. 2026-01-14 09:38:26.914 | HD Request # 95 | Completion time: 1s. 2026-01-14 09:38:26.914 | HD Request # 95 | Intraday data download complete for RTYH6.CME. Unique request ID: 1618 2026-01-14 09:38:26.914 | Removing historical data download ID 1618. 2026-01-14 09:38:26.914 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:38:26.914 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:38:26.914 | HD Request # 95 | Enabling Intraday chart updating for symbol. 2026-01-14 09:38:26.914 | 2026-01-14 09:38:26.914 | No download requests in the queue to start downloads for. 2026-01-14 09:38:27.401 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:38:27.403 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:38:27.403 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:27.428 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:38:27.444 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:27.528 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:27.535 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:38:27.538 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:38:27.639 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:38:27.714 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | CloseSocket call. 2026-01-14 09:38:27.714 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:27.715 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | Socket gracefully closed by remote side. 2026-01-14 09:38:27.715 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (11) | Closed. 2026-01-14 09:38:27.917 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:38:27.917 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:38:27.917 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:38:32.287 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | Creating socket. Using TLS 1.2. 2026-01-14 09:38:32.287 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | New receive buffer size: 0 2026-01-14 09:38:32.287 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | Connecting to IP: 38.79.0.89. 2026-01-14 09:38:33.392 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:38:33.392 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:38:33.392 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:38:33.392 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:38:33.404 | NTP Client | Received Packet | RoundTripDelay=0.010982036590576172, SystemClockOffset=-0.013427972793579102 2026-01-14 09:38:33.425 | NTP Client | Received Packet | RoundTripDelay=0.032979488372802734, SystemClockOffset=-0.012807130813598633 2026-01-14 09:38:33.669 | NTP Client | Received Packet | RoundTripDelay=0.2759990692138672, SystemClockOffset=-0.004037380218505859 2026-01-14 09:38:34.396 | NTP Client | Performed system clock adjustment of -12807.130813598633 microseconds. 2026-01-14 09:38:43.920 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | CloseSocket call. 2026-01-14 09:38:43.920 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:43.921 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | Socket gracefully closed by remote side. 2026-01-14 09:38:43.921 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (12) | Closed. 2026-01-14 09:38:52.252 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | Creating socket. Using TLS 1.2. 2026-01-14 09:38:52.252 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | New receive buffer size: 0 2026-01-14 09:38:52.252 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | Connecting to IP: 38.79.0.89. 2026-01-14 09:38:52.962 | File >> Disconnect selected. 2026-01-14 09:38:52.994 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:38:52.995 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:38:52.995 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:52.995 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:38:52.995 | DTC Client socket (10) | CloseSocket call. 2026-01-14 09:38:52.995 | DTC Client socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:52.995 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:38:52.996 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:38:52.996 | DTC Client socket (1) | Closed. 2026-01-14 09:38:52.996 | DTC Client socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:38:52.996 | DTC Client socket (10) | Closed. 2026-01-14 09:38:52.997 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:38:52.997 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:38:52.997 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:38:52.997 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:38:52.997 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:52.997 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:38:52.997 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:38:52.997 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:38:52.997 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:52.997 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:38:52.997 | DTC Client socket (3) | Closed. 2026-01-14 09:38:52.998 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:38:52.998 | DTC Client socket (2) | Closed. 2026-01-14 09:38:53.953 | 2026-01-14 09:38:53.953 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:38:53.953 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:38:53.953 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:38:53.953 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:38:53.953 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:38:53.953 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:38:53.958 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:38:53.958 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:38:53.958 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:38:53.958 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:38:55.823 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | CloseSocket call. 2026-01-14 09:38:55.823 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:55.824 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | Socket gracefully closed by remote side. 2026-01-14 09:38:55.824 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (8) | Closed. 2026-01-14 09:38:55.875 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:38:55.876 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:38:55.876 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2026-01-14 09:38:55.876 | Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-14 09:38:55.890 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:38:55.890 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:38:55.890 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:38:55.890 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-14 09:38:55.890 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:55.891 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:38:55.891 | DTC Client socket (1) | Closed. 2026-01-14 09:38:56.117 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | CloseSocket call. 2026-01-14 09:38:56.117 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:38:56.118 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | Socket gracefully closed by remote side. 2026-01-14 09:38:56.118 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (9) | Closed. 2026-01-14 09:38:59.887 | 2026-01-14 09:38:59.887 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:38:59.887 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:38:59.887 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:38:59.887 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-01-14 09:38:59.888 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:38:59.888 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2026-01-14 09:38:59.889 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:38:59.889 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:38:59.889 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:38:59.889 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:39:02.163 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:39:02.164 | No download requests in the queue to start downloads for. 2026-01-14 09:39:02.166 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:39:02.166 | Using symbol data fast lookup vector 2026-01-14 09:39:02.166 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:39:02.166 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:39:02.166 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:39:02.166 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:39:02.166 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:39:02.166 | Triggering next historical data download in queue. 2026-01-14 09:39:02.166 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 3455 2026-01-14 09:39:02.166 | DTC Client socket (2) | Creating socket. 2026-01-14 09:39:02.166 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:39:02.166 | DTC Client socket (2) | Connecting to IP: 69.39.70.241. 2026-01-14 09:39:02.169 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:39:02.169 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:39:02.169 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:39:02.169 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:39:02.169 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 3456 2026-01-14 09:39:02.169 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:39:02.169 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:39:02.169 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:39:02.169 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:39:02.169 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 3457 2026-01-14 09:39:02.169 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:39:02.169 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:39:02.169 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:39:02.169 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:39:02.169 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 3458 2026-01-14 09:39:02.172 | Delaying start of download for VOLX. 2026-01-14 09:39:02.172 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:39:02.172 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:39:02.172 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:02.209 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:39:02.209 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:39:02.209 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2026-01-14 09:39:02.209 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:39:02.209 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:39:02.209 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:39:02.209 | Triggering next historical data download in queue. 2026-01-14 09:39:02.210 | DTC Client socket (3) | Creating socket. 2026-01-14 09:39:02.210 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:39:02.210 | DTC Client socket (3) | Connecting to IP: 67.214.125.6. 2026-01-14 09:39:02.210 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:39:02.210 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 6 Service code: cme 2026-01-14 09:39:02.210 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 6 2026-01-14 09:39:02.219 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:39:02.219 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:39:02.219 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:39:02.219 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:39:02.219 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:39:02.219 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:39:02.219 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:39:02.219 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:39:02.230 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:39:02.230 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:39:02.230 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:02.587 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:39:02.587 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:39:02.587 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:39:02.587 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:39:02.587 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:39:02.587 | Triggering next historical data download in queue. 2026-01-14 09:39:02.906 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:39:02.906 | SC Data with Depth | Sending logon request message. 2026-01-14 09:39:02.912 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:39:02.912 | Denali Data Feed | Sending logon request message. 2026-01-14 09:39:03.393 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:39:03.393 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:39:03.393 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:39:03.393 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:39:03.403 | NTP Client | Received Packet | RoundTripDelay=0.009980201721191406, SystemClockOffset=-0.0026369094848632812 2026-01-14 09:39:03.425 | NTP Client | Received Packet | RoundTripDelay=0.03098917007446289, SystemClockOffset=-0.002526998519897461 2026-01-14 09:39:03.542 | NTP Client | Received Packet | RoundTripDelay=0.14540863037109375, SystemClockOffset=-0.0002493858337402344 2026-01-14 09:39:03.576 | SC Data with Depth | Received logon response. 2026-01-14 09:39:03.576 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:39:03.576 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:03.576 | SC Data with Depth | Successfully connected. 2026-01-14 09:39:03.576 | SC Data with Depth | Trading is not supported. 2026-01-14 09:39:03.576 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:39:03.576 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:39:03.576 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:39:03.576 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:39:03.576 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:39:03.663 | NTP Client | Received Packet | RoundTripDelay=0.26999855041503906, SystemClockOffset=0.009678363800048828 2026-01-14 09:39:03.917 | Denali Data Feed | Received logon response. 2026-01-14 09:39:03.917 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:39:03.917 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:03.917 | Denali Data Feed | Successfully connected. 2026-01-14 09:39:03.917 | Denali Data Feed | Trading is not supported. 2026-01-14 09:39:03.917 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:39:03.917 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:39:03.917 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:39:03.917 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:39:03.917 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:39:03.917 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:39:04.266 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:39:04.266 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:39:04.266 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:39:04.266 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:39:04.266 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:39:04.266 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:39:04.266 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:39:04.266 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:39:04.389 | NTP Client | Performed system clock adjustment of -1388.1921768188477 microseconds. 2026-01-14 09:39:07.167 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:39:07.169 | Denali Data Feed (Market Orders Data) | Connecting to the server ds28-2.sierracharts.com. Port 10060 2026-01-14 09:39:07.169 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:39:07.169 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:39:07.169 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:39:07.169 | Triggering next historical data download in queue. 2026-01-14 09:39:07.169 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:39:07.169 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:39:07.169 | HD Request # 96 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:39:07.169 | HD Request # 96 | Download start date-time: 2026-01-14 09:38:52.995505. 2026-01-14 09:39:07.169 | DTC Client socket (8) | Creating socket. 2026-01-14 09:39:07.169 | DTC Client socket (8) | New receive buffer size: 0 2026-01-14 09:39:07.169 | DTC Client socket (8) | Connecting to IP: 67.214.125.6. 2026-01-14 09:39:07.169 | HD Request # 96 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:39:07.169 | Socket (9) | Creating socket. 2026-01-14 09:39:07.169 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:07.169 | Socket (9) | Connecting to IP: 67.214.125.5. 2026-01-14 09:39:07.195 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:39:07.195 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:39:07.195 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:07.358 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:39:07.358 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:39:07.358 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:39:07.358 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:39:07.358 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:39:07.358 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:39:07.358 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:39:07.358 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:39:07.358 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:39:07.358 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:39:07.683 | HD Request # 96 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:07.683 | HD Request # 96 | Sending historical data logon request message. 2026-01-14 09:39:07.847 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:39:07.847 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:39:08.006 | HD Request # 96 | Requesting market depth data. Start date-time: 2026-01-14 09:38:52. Symbol: ESH26 2026-01-14 09:39:08.335 | HD Request # 96 | Decompressing data. 2026-01-14 09:39:08.341 | HD Request # 96 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:38:53.036000 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:39:08.713 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:39:08.751 | Socket (9) | CloseSocket call. 2026-01-14 09:39:08.751 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:08.752 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:08.752 | Socket (9) | Closed. 2026-01-14 09:39:08.766 | Historical data download thread signaled to stop. 2026-01-14 09:39:08.766 | HD Request # 96 | Timestamp of first market depth data file record written: 2026-01-14 09:38:53.036000. 2026-01-14 09:39:08.766 | HD Request # 96 | Received 13502 Market Depth data records from 2026-01-14 09:38:53.036000 to 2026-01-14 09:39:07.149000 (14.1 seconds. Delay: 1.6 seconds) and wrote 13502 records for ESH6.CME 2026-01-14 09:39:08.766 | HD Request # 96 | Completion time: 1s. 2026-01-14 09:39:08.766 | HD Request # 96 | Market Depth data download complete for ESH6.CME. Unique request ID: 3462 2026-01-14 09:39:08.766 | Removing historical data download ID 3462. 2026-01-14 09:39:08.766 | Real-time market depth file updates started for ESH6.CME 2026-01-14 09:39:08.773 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:39:08.773 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | ESH6.CME/MESH6.CME [CV][M] #3 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | ESH6.CME [CV][M] 30 Sec #6 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | ESH6.CME [CV][M] 30 Sec #5 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | ESH6.CME [CV][M] 30 Min #17 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:08.773 | 2026-01-14 09:39:08.773 | Triggering next historical data download in queue. 2026-01-14 09:39:08.774 | HD Request # 97 | Downloading Market Depth data for NQH6.CME. Service: cme.marketdepth. 2026-01-14 09:39:08.774 | HD Request # 97 | Download start date-time: 2026-01-14 09:38:52.995409. 2026-01-14 09:39:08.774 | HD Request # 97 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:39:08.774 | Socket (9) | Creating socket. 2026-01-14 09:39:08.774 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:08.774 | Socket (9) | Connecting to IP: 69.39.70.248. 2026-01-14 09:39:08.809 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:39:08.820 | ESH6.CME [CV][M] 30 Min #17 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:08.825 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:39:08.828 | ESH6.CME/MESH6.CME [CV][M] #3 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:08.837 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\ESH6.CME.2026-01-14.depth 2026-01-14 09:39:08.837 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:39:08.840 | ESH6.CME [CV][M] 30 Sec #5 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:09.046 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:39:09.057 | ESH6.CME [CV][M] 30 Sec #6 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:09.158 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:39:09.161 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:09.237 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:39:09.240 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:09.347 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:39:09.347 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:39:09.390 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:39:09.390 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:39:09.544 | HD Request # 97 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:09.544 | HD Request # 97 | Sending historical data logon request message. 2026-01-14 09:39:09.620 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:39:09.631 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Waiting for historical downloads to complete with the IDs: 3460, 2026-01-14 09:39:09.758 | HD Request # 98 | Downloading Intraday chart data for VOLX to the file VOLX.scid. Service: fxcm 2026-01-14 09:39:09.758 | HD Request # 98 | Download start date-time: 2026-01-14 09:38:50.000000. File last date-time: 2026-01-14 09:38:50.810000 2026-01-14 09:39:09.758 | HD Request # 98 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:39:09.758 | Socket (10) | Creating socket. 2026-01-14 09:39:09.758 | Socket (10) | New receive buffer size: 0 2026-01-14 09:39:09.758 | Socket (10) | Connecting to IP: 69.39.70.241. 2026-01-14 09:39:09.928 | HD Request # 97 | Requesting market depth data. Start date-time: 2026-01-14 09:38:52. Symbol: NQH26 2026-01-14 09:39:10.298 | HD Request # 97 | Decompressing data. 2026-01-14 09:39:10.301 | HD Request # 97 | Receiving market depth data for NQH6.CME starting at 2026-01-14 09:38:53.006000 2026-01-14 09:39:10.449 | HD Request # 98 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:10.449 | HD Request # 98 | Sending historical data logon request message. 2026-01-14 09:39:10.786 | HD Request # 98 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:50. Record interval: 0. Symbol: VOLX 2026-01-14 09:39:11.572 | HD Request # 98 | Decompressing data. 2026-01-14 09:39:11.612 | HD Request # 98 | Receiving Intraday data for VOLX starting at 2026-01-14 09:38:50.792000 2026-01-14 09:39:11.612 | Socket (10) | CloseSocket call. 2026-01-14 09:39:11.612 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:11.612 | Historical data download thread signaled to stop. 2026-01-14 09:39:11.612 | HD Request # 98 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:54.340000. 2026-01-14 09:39:11.612 | HD Request # 98 | Received 24 Intraday data records from 2026-01-14 09:38:50.792000 to 2026-01-14 09:39:08.768000 (18.0 seconds. Delay: 2.8 seconds) and wrote 22 records for VOLX 2026-01-14 09:39:11.613 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:39:11.613 | Socket (10) | Closed. 2026-01-14 09:39:11.621 | HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:08.768000 2026-01-14 09:39:11.621 | Added 2 Time and Sales records to Intraday data file for VOLX after download. 2026-01-14 09:39:11.621 | HD Request # 98 | Completion time: 2s. 2026-01-14 09:39:11.621 | HD Request # 98 | Intraday data download complete for VOLX. Unique request ID: 3455 2026-01-14 09:39:11.621 | Removing historical data download ID 3455. 2026-01-14 09:39:11.621 | Real-time Intraday chart data file updates started for VOLX 2026-01-14 09:39:11.621 | Intraday chart data file opened for VOLX 2026-01-14 09:39:11.621 | HD Request # 98 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:11.621 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Historical data download for additional symbol VOLX with ID 3455 has completed. 2026-01-14 09:39:11.621 | 2026-01-14 09:39:11.621 | Triggering next historical data download in queue. 2026-01-14 09:39:11.621 | HD Request # 99 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc 2026-01-14 09:39:11.621 | HD Request # 99 | Download start date-time: 2026-01-14 09:38:52.000000. File last date-time: 2026-01-14 09:38:52.451002 2026-01-14 09:39:11.622 | HD Request # 99 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:39:11.622 | Socket (10) | Creating socket. 2026-01-14 09:39:11.622 | Socket (10) | New receive buffer size: 0 2026-01-14 09:39:11.622 | Socket (10) | Connecting to IP: 64.152.155.113. 2026-01-14 09:39:11.781 | Socket (9) | CloseSocket call. 2026-01-14 09:39:11.781 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:11.781 | Historical data download thread signaled to stop. 2026-01-14 09:39:11.782 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:11.782 | Socket (9) | Closed. 2026-01-14 09:39:11.782 | HD Request # 97 | Timestamp of first market depth data file record written: 2026-01-14 09:38:53.006000. 2026-01-14 09:39:11.782 | HD Request # 97 | Received 23773 Market Depth data records from 2026-01-14 09:38:53.006000 to 2026-01-14 09:39:06.949000 (13.9 seconds. Delay: 4.8 seconds) and wrote 23773 records for NQH6.CME 2026-01-14 09:39:11.783 | HD Request # 97 | Completion time: 3s. 2026-01-14 09:39:11.783 | HD Request # 97 | Market Depth data download complete for NQH6.CME. Unique request ID: 3463 2026-01-14 09:39:11.783 | Removing historical data download ID 3463. 2026-01-14 09:39:11.783 | Real-time market depth file updates started for NQH6.CME 2026-01-14 09:39:11.792 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:39:11.792 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | NQH6.CME/MNQH6.CME [CV][M] #10 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | NQH6.CME [CV][M] 30 Sec #14 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | NQH6.CME [CV][M] 30 Sec #12 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | NQH6.CME [CV][M] 30 Min #18 | Flagging to reload Intraday data on market depth download completion. 2026-01-14 09:39:11.792 | 2026-01-14 09:39:11.792 | No download requests in the queue to start downloads for. 2026-01-14 09:39:11.817 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:39:11.828 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:11.859 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:39:11.870 | NQH6.CME [CV][M] 30 Min #18 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:11.873 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:39:11.876 | NQH6.CME/MNQH6.CME [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:11.879 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:39:11.882 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:11.890 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:39:11.893 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:11.934 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:39:11.946 | NQH6.CME [CV][M] 30 Sec #14 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:11.950 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:39:11.953 | NQH6.CME [CV][M] 30 Sec #12 | Waiting for historical downloads to complete with the IDs: 3459, 2026-01-14 09:39:12.358 | HD Request # 99 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:12.358 | HD Request # 99 | Sending historical data logon request message. 2026-01-14 09:39:12.759 | HD Request # 99 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:52. Record interval: 0. Symbol: TICK-NYSE 2026-01-14 09:39:12.972 | Opened cached Intraday file: D:\crypto\Data\VOLX.scid. Thread ID: 11112 2026-01-14 09:39:13.141 | HD Request # 99 | Decompressing data. 2026-01-14 09:39:13.400 | HD Request # 99 | Receiving Intraday data for TICK-NYSE starting at 2026-01-14 09:38:52.000000 2026-01-14 09:39:13.400 | Socket (10) | CloseSocket call. 2026-01-14 09:39:13.400 | Socket (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:13.400 | Historical data download thread signaled to stop. 2026-01-14 09:39:13.400 | HD Request # 99 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:53.000000. 2026-01-14 09:39:13.400 | HD Request # 99 | Received 21 Intraday data records from 2026-01-14 09:38:52.000000 to 2026-01-14 09:39:12.000000 (20.0 seconds. Delay: 1.4 seconds) and wrote 20 records for TICK-NYSE 2026-01-14 09:39:13.401 | Socket (10) | Socket gracefully closed by remote side. 2026-01-14 09:39:13.401 | Socket (10) | Closed. 2026-01-14 09:39:13.408 | HD Request # 99 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:12.000000 2026-01-14 09:39:13.408 | Added 3 Time and Sales records to Intraday data file for TICK-NYSE after download. 2026-01-14 09:39:13.408 | HD Request # 99 | Completion time: 2s. 2026-01-14 09:39:13.408 | HD Request # 99 | Intraday data download complete for TICK-NYSE. Unique request ID: 3456 2026-01-14 09:39:13.408 | Removing historical data download ID 3456. 2026-01-14 09:39:13.408 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:39:13.408 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:39:13.408 | HD Request # 99 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:13.408 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TICK-NYSE with ID 3456 has completed. 2026-01-14 09:39:13.408 | 2026-01-14 09:39:13.408 | Triggering next historical data download in queue. 2026-01-14 09:39:13.408 | HD Request # 100 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc 2026-01-14 09:39:13.408 | HD Request # 100 | Download start date-time: 2026-01-14 09:38:52.000000. File last date-time: 2026-01-14 09:38:52.451001 2026-01-14 09:39:13.408 | HD Request # 100 | Using server: ds12.sierracharts.com port 10149 2026-01-14 09:39:13.408 | Socket (9) | Creating socket. 2026-01-14 09:39:13.408 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:13.408 | Socket (9) | Connecting to IP: 69.39.70.241. 2026-01-14 09:39:14.107 | HD Request # 100 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:14.107 | HD Request # 100 | Sending historical data logon request message. 2026-01-14 09:39:14.379 | Opened cached Depth file: D:\crypto\Data\MarketDepthData\NQH6.CME.2026-01-14.depth 2026-01-14 09:39:14.564 | HD Request # 100 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:52. Record interval: 0. Symbol: NISS-NYSE 2026-01-14 09:39:14.948 | HD Request # 100 | Decompressing data. 2026-01-14 09:39:15.245 | HD Request # 100 | Receiving Intraday data for NISS-NYSE starting at 2026-01-14 09:38:52.000000 2026-01-14 09:39:15.246 | Socket (9) | CloseSocket call. 2026-01-14 09:39:15.246 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:15.247 | Historical data download thread signaled to stop. 2026-01-14 09:39:15.247 | HD Request # 100 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:53.000000. 2026-01-14 09:39:15.247 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:15.247 | HD Request # 100 | Received 22 Intraday data records from 2026-01-14 09:38:52.000000 to 2026-01-14 09:39:13.000000 (21.0 seconds. Delay: 2.2 seconds) and wrote 21 records for NISS-NYSE 2026-01-14 09:39:15.247 | Socket (9) | Closed. 2026-01-14 09:39:15.258 | HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:13.000000 2026-01-14 09:39:15.258 | Added 14 Time and Sales records to Intraday data file for NISS-NYSE after download. 2026-01-14 09:39:15.259 | HD Request # 100 | Completion time: 2s. 2026-01-14 09:39:15.259 | HD Request # 100 | Intraday data download complete for NISS-NYSE. Unique request ID: 3457 2026-01-14 09:39:15.259 | Removing historical data download ID 3457. 2026-01-14 09:39:15.259 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:39:15.259 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:39:15.259 | HD Request # 100 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:15.259 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol NISS-NYSE with ID 3457 has completed. 2026-01-14 09:39:15.259 | 2026-01-14 09:39:15.259 | Triggering next historical data download in queue. 2026-01-14 09:39:15.259 | HD Request # 101 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc 2026-01-14 09:39:15.259 | HD Request # 101 | Download start date-time: 2026-01-14 09:38:52.000000. File last date-time: 2026-01-14 09:38:52.451002 2026-01-14 09:39:15.259 | HD Request # 101 | Using server: ds4.sierracharts.com port 10150 2026-01-14 09:39:15.259 | Socket (9) | Creating socket. 2026-01-14 09:39:15.259 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:15.259 | Socket (9) | Connecting to IP: 64.152.155.113. 2026-01-14 09:39:15.819 | HD Request # 101 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:15.819 | HD Request # 101 | Sending historical data logon request message. 2026-01-14 09:39:16.066 | HD Request # 101 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:52. Record interval: 0. Symbol: TRIN-NYSE 2026-01-14 09:39:16.327 | HD Request # 101 | Decompressing data. 2026-01-14 09:39:16.539 | HD Request # 101 | Receiving Intraday data for TRIN-NYSE starting at 2026-01-14 09:38:52.000000 2026-01-14 09:39:16.540 | Socket (9) | CloseSocket call. 2026-01-14 09:39:16.540 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:16.541 | Historical data download thread signaled to stop. 2026-01-14 09:39:16.541 | HD Request # 101 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:53.000000. 2026-01-14 09:39:16.541 | HD Request # 101 | Received 23 Intraday data records from 2026-01-14 09:38:52.000000 to 2026-01-14 09:39:14.000000 (22.0 seconds. Delay: 2.5 seconds) and wrote 22 records for TRIN-NYSE 2026-01-14 09:39:16.541 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:16.542 | Socket (9) | Closed. 2026-01-14 09:39:16.549 | HD Request # 101 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:14.000000 2026-01-14 09:39:16.549 | Added 21 Time and Sales records to Intraday data file for TRIN-NYSE after download. 2026-01-14 09:39:16.549 | HD Request # 101 | Completion time: 1s. 2026-01-14 09:39:16.549 | HD Request # 101 | Intraday data download complete for TRIN-NYSE. Unique request ID: 3458 2026-01-14 09:39:16.549 | Removing historical data download ID 3458. 2026-01-14 09:39:16.549 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:39:16.549 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:39:16.549 | HD Request # 101 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:16.549 | ESH6.CME [CV][M] 30 Sec #5 | Historical data download for additional symbol TRIN-NYSE with ID 3458 has completed. 2026-01-14 09:39:16.549 | 2026-01-14 09:39:16.549 | Triggering next historical data download in queue. 2026-01-14 09:39:16.549 | HD Request # 102 | Downloading Intraday chart data for NQH6.CME to the file NQH6.CME.scid. Service: cme 2026-01-14 09:39:16.549 | HD Request # 102 | Download start date-time: 2026-01-14 09:38:48.000000. File last date-time: 2026-01-14 09:38:48.286000 2026-01-14 09:39:16.549 | HD Request # 102 | Using server: ds26.sierracharts.com port 10149 2026-01-14 09:39:16.549 | Socket (9) | Creating socket. 2026-01-14 09:39:16.550 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:16.550 | Socket (9) | Connecting to IP: 64.152.155.17. 2026-01-14 09:39:17.087 | HD Request # 102 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:17.087 | HD Request # 102 | Sending historical data logon request message. 2026-01-14 09:39:17.611 | HD Request # 102 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:48. Record interval: 0. Symbol: NQH26 2026-01-14 09:39:17.982 | Opened cached Intraday file: D:\crypto\Data\TICK-NYSE.scid. Thread ID: 11112 2026-01-14 09:39:17.983 | Opened cached Intraday file: D:\crypto\Data\NISS-NYSE.scid. Thread ID: 11112 2026-01-14 09:39:17.983 | Opened cached Intraday file: D:\crypto\Data\TRIN-NYSE.scid. Thread ID: 11112 2026-01-14 09:39:18.055 | HD Request # 102 | Decompressing data. 2026-01-14 09:39:18.185 | HD Request # 102 | Receiving Intraday data for NQH6.CME starting at 2026-01-14 09:38:48.020000 2026-01-14 09:39:18.185 | Socket (9) | CloseSocket call. 2026-01-14 09:39:18.186 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:18.186 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:18.186 | Socket (9) | Closed. 2026-01-14 09:39:18.186 | Historical data download thread signaled to stop. 2026-01-14 09:39:18.186 | HD Request # 102 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:48.421000. 2026-01-14 09:39:18.186 | HD Request # 102 | Received 1027 Intraday data records from 2026-01-14 09:38:48.020000 to 2026-01-14 09:39:16.740000 (28.7 seconds. Delay: 1.4 seconds) and wrote 1022 records for NQH6.CME 2026-01-14 09:39:18.194 | HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:16.740000 2026-01-14 09:39:18.194 | HD Request # 102 | Completion time: 2s. 2026-01-14 09:39:18.194 | HD Request # 102 | Intraday data download complete for NQH6.CME. Unique request ID: 3459 2026-01-14 09:39:18.194 | Removing historical data download ID 3459. 2026-01-14 09:39:18.194 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:39:18.194 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:39:18.194 | HD Request # 102 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:18.194 | 2026-01-14 09:39:18.194 | Triggering next historical data download in queue. 2026-01-14 09:39:18.194 | HD Request # 103 | Downloading Intraday chart data for ESH6.CME to the file ESH6.CME.scid. Service: cme 2026-01-14 09:39:18.194 | HD Request # 103 | Download start date-time: 2026-01-14 09:38:48.000000. File last date-time: 2026-01-14 09:38:48.200001 2026-01-14 09:39:18.194 | HD Request # 103 | Using server: ds28.sierracharts.com port 10150 2026-01-14 09:39:18.194 | Socket (9) | Creating socket. 2026-01-14 09:39:18.194 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:18.194 | Socket (9) | Connecting to IP: 67.214.125.5. 2026-01-14 09:39:18.200 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.200 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:39:18.219 | NQH6.CME [CV][M] 30 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.219 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:39:18.224 | NQH6.CME [CV][M] 30 Sec #12 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.224 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:39:18.229 | NQH6.CME/MNQH6.CME [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.231 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:39:18.340 | NQH6.CME [CV][M] 30 Min #18 | Reloading chart. 2026-01-14 09:39:18.356 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.358 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:39:18.364 | NQH6.CME/MNQH6.CME [CV][M] #10 | Reloading chart. 2026-01-14 09:39:18.369 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.369 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.369 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:39:18.390 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.390 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:39:18.404 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Reloading chart. 2026-01-14 09:39:18.452 | NQH6.CME [CV][M] 30 Sec #14 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:18.452 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:39:18.480 | NQH6.CME/MNQH6.CME [CV][M] #10 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:39:18.493 | NQH6.CME/MNQH6.CME [CV][M] #10 | Chart data loading complete. 2026-01-14 09:39:18.547 | NQH6.CME [CV][M] 30 Sec #12 | Reloading chart. 2026-01-14 09:39:18.566 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.566 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:39:18.657 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:39:18.723 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:39:18.799 | Chart #12 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.799 | Chart #12 has tagged chart #11 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.799 | NQH6.CME [CV][M] 30 Sec #12 | Chart data loading complete. 2026-01-14 09:39:18.801 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:39:18.806 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:39:18.807 | Chart #9 has tagged chart #10 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.841 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Chart data loading complete. 2026-01-14 09:39:18.850 | HD Request # 103 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:18.850 | HD Request # 103 | Sending historical data logon request message. 2026-01-14 09:39:18.871 | NQH6.CME [CV][M] 30 Min #18 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:39:18.873 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.873 | NQH6.CME [CV][M] 30 Min #18 | Chart data loading complete. 2026-01-14 09:39:18.909 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Reloading chart. 2026-01-14 09:39:18.934 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Reloading chart. 2026-01-14 09:39:18.941 | Chart #18 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:18.966 | NQH6.CME [CV][M] 30 Sec #14 | Reloading chart. 2026-01-14 09:39:19.085 | Chart #14 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:19.085 | NQH6.CME [CV][M] 30 Sec #14 | Chart data loading complete. 2026-01-14 09:39:19.154 | HD Request # 103 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:48. Record interval: 0. Symbol: ESH26 2026-01-14 09:39:19.183 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:39:19.218 | NQH6.CME/MNQH6.CME [CV][M] 800 Trades #11 | Chart data loading complete. 2026-01-14 09:39:19.503 | HD Request # 103 | Decompressing data. 2026-01-14 09:39:19.547 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:39:19.550 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:39:19.551 | Chart #8 has tagged chart #9 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:19.585 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #8 | Chart data loading complete. 2026-01-14 09:39:19.650 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:39:19.655 | NQH6.CME/MNQH6.CME [CV][M] 30 Min #9 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:39:19.680 | NQH6.CME/MNQH6.CME [CV][M] #10 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:39:19.767 | HD Request # 103 | Receiving Intraday data for ESH6.CME starting at 2026-01-14 09:38:48.200000 2026-01-14 09:39:19.768 | Socket (9) | CloseSocket call. 2026-01-14 09:39:19.768 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:19.768 | Historical data download thread signaled to stop. 2026-01-14 09:39:19.768 | HD Request # 103 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:48.422000. 2026-01-14 09:39:19.768 | HD Request # 103 | Received 1832 Intraday data records from 2026-01-14 09:38:48.200000 to 2026-01-14 09:39:16.783000 (28.6 seconds. Delay: 3.0 seconds) and wrote 1830 records for ESH6.CME 2026-01-14 09:39:19.769 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:19.769 | Socket (9) | Closed. 2026-01-14 09:39:19.776 | HD Request # 103 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:16.783000 2026-01-14 09:39:19.776 | HD Request # 103 | Completion time: 1s. 2026-01-14 09:39:19.776 | HD Request # 103 | Intraday data download complete for ESH6.CME. Unique request ID: 3460 2026-01-14 09:39:19.776 | Removing historical data download ID 3460. 2026-01-14 09:39:19.776 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:39:19.776 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:39:19.776 | HD Request # 103 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:19.776 | 2026-01-14 09:39:19.776 | Triggering next historical data download in queue. 2026-01-14 09:39:19.776 | HD Request # 104 | Downloading Intraday chart data for RTYH6.CME to the file RTYH6.CME.scid. Service: cme 2026-01-14 09:39:19.776 | HD Request # 104 | Download start date-time: 2026-01-14 09:38:47.000000. File last date-time: 2026-01-14 09:38:47.799004 2026-01-14 09:39:19.776 | HD Request # 104 | Using server: ds32.sierracharts.com port 10149 2026-01-14 09:39:19.776 | Socket (9) | Creating socket. 2026-01-14 09:39:19.776 | Socket (9) | New receive buffer size: 0 2026-01-14 09:39:19.776 | Socket (9) | Connecting to IP: 69.39.70.248. 2026-01-14 09:39:19.781 | ESH6.CME [CV][M] 30 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:19.782 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:39:19.787 | ESH6.CME/MESH6.CME [CV][M] #3 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:19.789 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:39:19.892 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | Creating socket. Using TLS 1.2. 2026-01-14 09:39:19.892 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | New receive buffer size: 0 2026-01-14 09:39:19.892 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | Connecting to IP: 38.79.0.89. 2026-01-14 09:39:19.906 | ESH6.CME [CV][M] 30 Min #17 | Reloading chart. 2026-01-14 09:39:19.927 | ESH6.CME/MESH6.CME [CV][M] #3 | Reloading chart. 2026-01-14 09:39:19.970 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:19.970 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:39:20.078 | ESH6.CME [CV][M] 30 Sec #6 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:20.080 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:39:20.095 | ESH6.CME [CV][M] 30 Sec #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:20.096 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:39:20.140 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:20.140 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:39:20.171 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Reloading chart. 2026-01-14 09:39:20.227 | ESH6.CME/MESH6.CME [CV][M] #3 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:39:20.239 | ESH6.CME/MESH6.CME [CV][M] #3 | Chart data loading complete. 2026-01-14 09:39:20.242 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. 2026-01-14 09:39:20.243 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:39:20.289 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:20.289 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:39:20.340 | + Loading additional symbol data. 2026-01-14 09:39:20.407 | ESH6.CME [CV][M] 30 Sec #5 | Reloading chart. 2026-01-14 09:39:20.418 | + Loading additional symbol data. 2026-01-14 09:39:20.485 | ESH6.CME [CV][M] 30 Sec #5 | StartDateTimeForLoadingOrderFills: 2025-01-07 00:00:00 2026-01-14 09:39:20.487 | Chart #5 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:20.487 | Chart #5 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:20.487 | ESH6.CME [CV][M] 30 Sec #5 | Chart data loading complete. 2026-01-14 09:39:20.581 | ESH6.CME [CV][M] 30 Sec #6 | Reloading chart. 2026-01-14 09:39:20.639 | HD Request # 104 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:20.639 | HD Request # 104 | Sending historical data logon request message. 2026-01-14 09:39:20.642 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | StartDateTimeForLoadingOrderFills: 2026-01-13 18:00:00 2026-01-14 09:39:20.647 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:39:20.650 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:20.677 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Chart data loading complete. 2026-01-14 09:39:20.677 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Reloading chart. 2026-01-14 09:39:20.831 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Reloading chart. 2026-01-14 09:39:20.869 | Chart #6 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:20.869 | ESH6.CME [CV][M] 30 Sec #6 | Chart data loading complete. 2026-01-14 09:39:20.995 | Chart #17 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:20.995 | ESH6.CME [CV][M] 30 Min #17 | Chart data loading complete. 2026-01-14 09:39:21.114 | HD Request # 104 | Requesting Intraday data. Start date-time: 2026-01-14 09:38:47. Record interval: 0. Symbol: RTYH26 2026-01-14 09:39:21.355 | HD Request # 104 | Decompressing data. 2026-01-14 09:39:21.545 | HD Request # 104 | Receiving Intraday data for RTYH6.CME starting at 2026-01-14 09:38:47.266000 2026-01-14 09:39:21.546 | Socket (9) | CloseSocket call. 2026-01-14 09:39:21.546 | Socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:21.546 | Historical data download thread signaled to stop. 2026-01-14 09:39:21.546 | HD Request # 104 | Timestamp of first Intraday data file record written: 2026-01-14 09:38:48.422000. 2026-01-14 09:39:21.546 | HD Request # 104 | Received 173 Intraday data records from 2026-01-14 09:38:47.266000 to 2026-01-14 09:39:18.636000 (31.4 seconds. Delay: 2.9 seconds) and wrote 163 records for RTYH6.CME 2026-01-14 09:39:21.546 | Socket (9) | Socket gracefully closed by remote side. 2026-01-14 09:39:21.546 | Socket (9) | Closed. 2026-01-14 09:39:21.556 | HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2026-01-14 14:39:18.636000 2026-01-14 09:39:21.556 | HD Request # 104 | Completion time: 2s. 2026-01-14 09:39:21.556 | HD Request # 104 | Intraday data download complete for RTYH6.CME. Unique request ID: 3461 2026-01-14 09:39:21.556 | Removing historical data download ID 3461. 2026-01-14 09:39:21.556 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:39:21.556 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:39:21.556 | HD Request # 104 | Enabling Intraday chart updating for symbol. 2026-01-14 09:39:21.556 | 2026-01-14 09:39:21.556 | No download requests in the queue to start downloads for. 2026-01-14 09:39:21.584 | + Loading additional symbol data. 2026-01-14 09:39:21.596 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:39:21.644 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Chart data loading complete. 2026-01-14 09:39:22.062 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | StartDateTimeForLoadingOrderFills: 18:00:00 2026-01-14 09:39:22.064 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:39:22.065 | Chart #1 has tagged chart #2 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:22.088 | ESH6.CME/MESH6.CME [CV][M] 30 Min #1 | Chart data loading complete. 2026-01-14 09:39:22.146 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:39:22.426 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:39:22.431 | ESH6.CME/MESH6.CME [CV][M] 30 Min #2 | Study: Google Sheets Importer | Making HTTP request. 2026-01-14 09:39:22.433 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: Discipline.Cht 2026-01-14 09:39:22.457 | ESH6.CME/MESH6.CME [CV][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: Discipline.Cht 2026-01-14 09:39:22.986 | Opened cached Intraday file: D:\crypto\Data\NQH6.CME.scid. Thread ID: 11112 2026-01-14 09:39:22.986 | Opened cached Intraday file: D:\crypto\Data\ESH6.CME.scid. Thread ID: 11112 2026-01-14 09:39:22.986 | Opened cached Intraday file: D:\crypto\Data\RTYH6.CME.scid. Thread ID: 11112 2026-01-14 09:39:23.545 | Rithmic Direct - DTC | Wrote file: D:\crypto\RithmicConnections.json. Size: 110576 2026-01-14 09:39:23.546 | Rithmic Direct - DTC | Processed connection points. Count: 474 2026-01-14 09:39:23.809 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | CloseSocket call. 2026-01-14 09:39:23.809 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:23.810 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | Socket gracefully closed by remote side. 2026-01-14 09:39:23.810 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (10) | Closed. 2026-01-14 09:39:24.965 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:39:24.967 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:39:24.972 | DTC Client socket (3) | Socket gracefully closed by remote side. 2026-01-14 09:39:24.975 | DTC Client socket (8) | Socket gracefully closed by remote side. 2026-01-14 09:39:24.980 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:39:24.980 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:39:24.980 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:24.980 | DTC Client socket (2) | Closed. 2026-01-14 09:39:24.980 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:39:24.980 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:39:24.981 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:24.981 | DTC Client socket (1) | Closed. 2026-01-14 09:39:24.981 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:39:24.981 | DTC Client socket (3) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:39:24.982 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:24.982 | DTC Client socket (3) | Closed. 2026-01-14 09:39:24.984 | DTC Client socket (8) | CloseSocket call. 2026-01-14 09:39:24.984 | DTC Client socket (8) | Signaling for receive thread to end. Bytes in receive buffer: 0 2026-01-14 09:39:24.985 | DTC Client socket (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:24.985 | DTC Client socket (8) | Closed. 2026-01-14 09:39:24.985 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:39:24.985 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:39:24.985 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-01-14 09:39:24.985 | Connection to the external service has been lost. 2026-01-14 09:39:24.996 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:39:24.996 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:39:24.996 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:39:24.996 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:39:24.996 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2026-01-14 09:39:24.999 | DTC Client socket (0) | CloseSocket call. 2026-01-14 09:39:25.000 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:39:25.000 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2026-01-14 09:39:26.997 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2026-01-14 09:39:26.998 | DTC Client socket (1) | Creating socket. 2026-01-14 09:39:26.998 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:39:26.998 | DTC Client socket (1) | Connecting to IP: 64.152.155.113. 2026-01-14 09:39:26.998 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:39:26.998 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:39:26.999 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:27.988 | Denali Data Feed | Connecting to the server ds27-2.sierracharts.com. Port 443 2026-01-14 09:39:27.992 | DTC Client socket (2) | Creating socket. 2026-01-14 09:39:27.992 | DTC Client socket (2) | New receive buffer size: 0 2026-01-14 09:39:27.992 | DTC Client socket (2) | Connecting to IP: 216.200.108.155. 2026-01-14 09:39:27.993 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:39:27.993 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:39:27.993 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:29.004 | 2026-01-14 09:39:29.005 | Rithmic Direct - DTC | Using server connection: LucidTrading-Chicago Area-Non-Aggregated 2026-01-14 09:39:29.005 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50569 2026-01-14 09:39:29.005 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50569 2026-01-14 09:39:29.006 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2026-01-14 09:39:29.006 | DTC Client socket (3) | New receive buffer size: 0 2026-01-14 09:39:29.006 | DTC Client socket (3) | Connecting to IP: 216.57.156.163. 2026-01-14 09:39:29.007 | Rithmic Direct - DTC | Network connection to server complete. 2026-01-14 09:39:29.007 | Rithmic Direct - DTC | Starting socket receive thread. 2026-01-14 09:39:29.007 | Rithmic Direct - DTC | Using fixed encoding of Binary 2026-01-14 09:39:29.007 | Rithmic Direct - DTC | Sending logon request message. 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Received logon response. 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Server Name: . 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Successfully connected. 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Trading is supported. 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Order cancel and replace is supported. 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | OCO Orders supported. 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2026-01-14 09:39:30.477 | Rithmic Direct - DTC | Connection to server complete. 2026-01-14 09:39:30.477 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:39:30.477 | DTC Client socket (2) | CloseSocket call. 2026-01-14 09:39:30.477 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:30.477 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:39:30.477 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:39:30.477 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:39:30.477 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:30.477 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:39:30.478 | No download requests in the queue to start downloads for. 2026-01-14 09:39:30.480 | Using Bid/Ask average for last trade price for VOLX 2026-01-14 09:39:30.480 | Using symbol data fast lookup vector 2026-01-14 09:39:30.480 | SC Data with Depth | Starting real-time market data updates for: VOLX. ID: 1 Service code: fxcm 2026-01-14 09:39:30.480 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 2026-01-14 09:39:30.480 | SC Data with Depth | Requesting security definition data for: VOLX. ID: 1 2026-01-14 09:39:30.480 | Added historical Intraday data request for VOLX to the queue. 2026-01-14 09:39:30.480 | Intraday data recording state for symbol VOLX is set to download 'Pending'. 2026-01-14 09:39:30.480 | Triggering next historical data download in queue. 2026-01-14 09:39:30.480 | ESH6.CME/MESH6.CME [CV][M] 1500 Trades #4 | Started historical data download for additional symbol VOLX. Download ID: 3464 2026-01-14 09:39:30.480 | DTC Client socket (8) | Creating socket. 2026-01-14 09:39:30.480 | DTC Client socket (8) | New receive buffer size: 0 2026-01-14 09:39:30.480 | DTC Client socket (8) | Connecting to IP: 69.39.70.241. 2026-01-14 09:39:30.483 | SC Data with Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 Service code: statscalc 2026-01-14 09:39:30.483 | SC Data with Depth | Requesting security definition data for: TICK-NYSE. ID: 2 2026-01-14 09:39:30.483 | Added historical Intraday data request for TICK-NYSE to the queue. 2026-01-14 09:39:30.483 | Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. 2026-01-14 09:39:30.483 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TICK-NYSE. Download ID: 3465 2026-01-14 09:39:30.483 | SC Data with Depth | Starting real-time market data updates for: NISS-NYSE. ID: 3 Service code: statscalc 2026-01-14 09:39:30.483 | SC Data with Depth | Requesting security definition data for: NISS-NYSE. ID: 3 2026-01-14 09:39:30.483 | Added historical Intraday data request for NISS-NYSE to the queue. 2026-01-14 09:39:30.483 | Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. 2026-01-14 09:39:30.483 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol NISS-NYSE. Download ID: 3466 2026-01-14 09:39:30.483 | SC Data with Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 4 Service code: statscalc 2026-01-14 09:39:30.483 | SC Data with Depth | Requesting security definition data for: TRIN-NYSE. ID: 4 2026-01-14 09:39:30.483 | Added historical Intraday data request for TRIN-NYSE to the queue. 2026-01-14 09:39:30.483 | Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. 2026-01-14 09:39:30.483 | ESH6.CME [CV][M] 30 Sec #5 | Started historical data download for additional symbol TRIN-NYSE. Download ID: 3467 2026-01-14 09:39:30.486 | SC Data with Depth | Failed connections: 1 2026-01-14 09:39:30.486 | DTC Client socket (8) | CloseSocket call. 2026-01-14 09:39:30.486 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:39:30.486 | SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. 2026-01-14 09:39:30.486 | Delaying start of download for VOLX. 2026-01-14 09:39:30.486 | DTC Client socket (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:30.489 | Mapping NQH6.CME to NQH26. Service code: cme 2026-01-14 09:39:30.489 | Denali Data Feed | Starting real-time market data updates for: NQH6.CME (NQH26). ID: 5 Service code: cme 2026-01-14 09:39:30.489 | Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10048 2026-01-14 09:39:30.489 | Denali Data Feed | Requesting security definition data for: NQH6.CME (NQH26). ID: 5 2026-01-14 09:39:30.490 | Added historical Intraday data request for NQH6.CME to the queue. 2026-01-14 09:39:30.490 | Intraday data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:39:30.490 | Triggering next historical data download in queue. 2026-01-14 09:39:30.491 | DTC Client socket (9) | Creating socket. 2026-01-14 09:39:30.491 | DTC Client socket (9) | New receive buffer size: 0 2026-01-14 09:39:30.491 | DTC Client socket (9) | Connecting to IP: 64.152.155.18. 2026-01-14 09:39:30.515 | Denali Data Feed | Network connection to server complete. 2026-01-14 09:39:30.515 | Denali Data Feed | Starting socket receive thread. 2026-01-14 09:39:30.515 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:30.515 | Mapping MNQH6.CME to MNQH26. Service code: cme 2026-01-14 09:39:30.515 | Denali Data Feed | Starting real-time market data updates for: MNQH6.CME (MNQH26). ID: 6 Service code: cme 2026-01-14 09:39:30.515 | Denali Data Feed | Requesting security definition data for: MNQH6.CME (MNQH26). ID: 6 2026-01-14 09:39:30.558 | Mapping ESH6.CME to ESH26. Service code: cme 2026-01-14 09:39:30.558 | Denali Data Feed | Starting real-time market data updates for: ESH6.CME (ESH26). ID: 7 Service code: cme 2026-01-14 09:39:30.558 | Denali Data Feed | Requesting security definition data for: ESH6.CME (ESH26). ID: 7 2026-01-14 09:39:30.558 | Mapping MESH6.CME to MESH26. Service code: cme 2026-01-14 09:39:30.558 | Denali Data Feed | Starting real-time market data updates for: MESH6.CME (MESH26). ID: 8 Service code: cme 2026-01-14 09:39:30.558 | Denali Data Feed | Requesting security definition data for: MESH6.CME (MESH26). ID: 8 2026-01-14 09:39:30.558 | Added historical Intraday data request for ESH6.CME to the queue. 2026-01-14 09:39:30.558 | Intraday data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:39:30.558 | Triggering next historical data download in queue. 2026-01-14 09:39:30.623 | Mapping RTYH6.CME to RTYH26. Service code: cme 2026-01-14 09:39:30.623 | Denali Data Feed | Starting real-time market data updates for: RTYH6.CME (RTYH26). ID: 9 Service code: cme 2026-01-14 09:39:30.623 | Denali Data Feed | Requesting security definition data for: RTYH6.CME (RTYH26). ID: 9 2026-01-14 09:39:30.623 | Added historical Intraday data request for RTYH6.CME to the queue. 2026-01-14 09:39:30.623 | Intraday data recording state for symbol RTYH6.CME is set to download 'Pending'. 2026-01-14 09:39:30.623 | Triggering next historical data download in queue. 2026-01-14 09:39:31.404 | Denali Data Feed | Setting DTC encoding to Binary VLS 2026-01-14 09:39:31.404 | Denali Data Feed | Sending logon request message. 2026-01-14 09:39:31.536 | DTC Client socket (1) | Socket gracefully closed by remote side. 2026-01-14 09:39:31.537 | DTC Client socket (1) | Closed. 2026-01-14 09:39:31.538 | DTC Client socket (2) | Socket gracefully closed by remote side. 2026-01-14 09:39:31.538 | DTC Client socket (2) | Closed. 2026-01-14 09:39:31.682 | DTC Client socket (8) | Socket gracefully closed by remote side. 2026-01-14 09:39:31.682 | DTC Client socket (8) | Closed. 2026-01-14 09:39:32.429 | Denali Data Feed | Received logon response. 2026-01-14 09:39:32.429 | Denali Data Feed | Server Name: SC Realtime Server. 2026-01-14 09:39:32.429 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:32.429 | Denali Data Feed | Successfully connected. 2026-01-14 09:39:32.429 | Denali Data Feed | Trading is not supported. 2026-01-14 09:39:32.429 | Denali Data Feed | MarketDepthIsSupported: 1 2026-01-14 09:39:32.429 | Denali Data Feed | Restarting real-time data updates for symbol: ESH6.CME -> ESH26 2026-01-14 09:39:32.429 | Denali Data Feed | Restarting real-time data updates for symbol: MESH6.CME -> MESH26 2026-01-14 09:39:32.429 | Denali Data Feed | Restarting real-time data updates for symbol: MNQH6.CME -> MNQH26 2026-01-14 09:39:32.429 | Denali Data Feed | Restarting real-time data updates for symbol: NQH6.CME -> NQH26 2026-01-14 09:39:32.429 | Denali Data Feed | Restarting real-time data updates for symbol: RTYH6.CME -> RTYH26 2026-01-14 09:39:32.493 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 2026-01-14 09:39:32.493 | DTC Client socket (1) | Creating socket. 2026-01-14 09:39:32.493 | DTC Client socket (1) | New receive buffer size: 0 2026-01-14 09:39:32.493 | DTC Client socket (1) | Connecting to IP: 64.152.155.113. 2026-01-14 09:39:32.494 | SC Data with Depth | Network connection to server complete. 2026-01-14 09:39:32.494 | SC Data with Depth | Starting socket receive thread. 2026-01-14 09:39:32.494 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:33.325 | Added historical Market Depth data request for ESH6.CME to the queue. 2026-01-14 09:39:33.325 | Market depth data recording state for symbol ESH6.CME is set to download 'Pending'. 2026-01-14 09:39:33.325 | Triggering next historical data download in queue. 2026-01-14 09:39:33.325 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.325 | Added historical Market Depth data request for NQH6.CME to the queue. 2026-01-14 09:39:33.325 | Market depth data recording state for symbol NQH6.CME is set to download 'Pending'. 2026-01-14 09:39:33.325 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.325 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.325 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Denali Data Feed | Setting external service identifier for symbol ESH6.CME to 42140878 2026-01-14 09:39:33.326 | Denali Data Feed | Received security definition for symbol ESH6.CME 2026-01-14 09:39:33.326 | Denali Data Feed | Setting external service identifier for symbol MESH6.CME to 42003800 2026-01-14 09:39:33.326 | Denali Data Feed | Received security definition for symbol MESH6.CME 2026-01-14 09:39:33.326 | Denali Data Feed | Setting external service identifier for symbol MNQH6.CME to 42004946 2026-01-14 09:39:33.326 | Denali Data Feed | Received security definition for symbol MNQH6.CME 2026-01-14 09:39:33.326 | Denali Data Feed | Setting external service identifier for symbol NQH6.CME to 42002475 2026-01-14 09:39:33.326 | Denali Data Feed | Received security definition for symbol NQH6.CME 2026-01-14 09:39:33.326 | Denali Data Feed | Setting external service identifier for symbol RTYH6.CME to 42005017 2026-01-14 09:39:33.326 | Denali Data Feed | Received security definition for symbol RTYH6.CME 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for ESH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | Historical Market Depth data request, start 00:00:00.000 , for NQH6.CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-01-14 09:39:33.326 | HD Request # 105 | Downloading Market Depth data for ESH6.CME. Service: cme.marketdepth. 2026-01-14 09:39:33.326 | HD Request # 105 | Download start date-time: 2026-01-14 09:39:25.000257. 2026-01-14 09:39:33.327 | HD Request # 105 | Using server: ds26.sierracharts.com port 10150 2026-01-14 09:39:33.327 | Socket (2) | Creating socket. 2026-01-14 09:39:33.327 | Socket (2) | New receive buffer size: 0 2026-01-14 09:39:33.327 | Socket (2) | Connecting to IP: 64.152.155.17. 2026-01-14 09:39:33.391 | NTP Client | Sending packet to 0.cn.pool.ntp.org:123 2026-01-14 09:39:33.391 | NTP Client | Sending packet to 1.cn.pool.ntp.org:123 2026-01-14 09:39:33.391 | NTP Client | Sending packet to 2.cn.pool.ntp.org:123 2026-01-14 09:39:33.391 | NTP Client | Sending packet to 3.cn.pool.ntp.org:123 2026-01-14 09:39:33.402 | NTP Client | Received Packet | RoundTripDelay=0.010987281799316406, SystemClockOffset=-0.008600711822509766 2026-01-14 09:39:33.422 | NTP Client | Received Packet | RoundTripDelay=0.030989646911621094, SystemClockOffset=-0.008732318878173828 2026-01-14 09:39:33.663 | NTP Client | Received Packet | RoundTripDelay=0.27199792861938477, SystemClockOffset=0.002562284469604492 2026-01-14 09:39:34.396 | NTP Client | Performed system clock adjustment of -8600.711822509766 microseconds. 2026-01-14 09:39:35.512 | Requesting market depth updates for: ESH6.CME if supported. NumLevels=120 2026-01-14 09:39:35.512 | Denali Data Feed (Market Orders Data) | Connecting to the server ds26-2.sierracharts.com. Port 10060 2026-01-14 09:39:35.513 | Requesting market depth updates for: NQH6.CME if supported. NumLevels=120 2026-01-14 09:39:35.514 | DTC Client socket (8) | Creating socket. 2026-01-14 09:39:35.514 | DTC Client socket (8) | New receive buffer size: 0 2026-01-14 09:39:35.514 | DTC Client socket (8) | Connecting to IP: 64.152.155.18. 2026-01-14 09:39:35.540 | Denali Data Feed (Market Orders Data) | Network connection to server complete. 2026-01-14 09:39:35.540 | Denali Data Feed (Market Orders Data) | Starting socket receive thread. 2026-01-14 09:39:35.540 | Denali Data Feed (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: high 2026-01-14 09:39:35.726 | SC Data with Depth | Setting DTC encoding to Binary VLS 2026-01-14 09:39:35.726 | SC Data with Depth | Sending logon request message. 2026-01-14 09:39:36.160 | Denali Data Feed | Clearing market depth for ESH6.CME 2026-01-14 09:39:36.160 | Denali Data Feed | Clearing market depth for NQH6.CME 2026-01-14 09:39:36.471 | Denali Data Feed (Market Orders Data) | Setting DTC encoding to Binary VLS 2026-01-14 09:39:36.471 | Denali Data Feed (Market Orders Data) | Sending logon request message. 2026-01-14 09:39:36.579 | HD Request # 105 | Setting DTC encoding to Binary VLS 2026-01-14 09:39:36.579 | HD Request # 105 | Sending historical data logon request message. 2026-01-14 09:39:36.882 | SC Data with Depth | Received logon response. 2026-01-14 09:39:36.882 | SC Data with Depth | Server Name: SC Realtime Server. 2026-01-14 09:39:36.882 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:36.882 | SC Data with Depth | Successfully connected. 2026-01-14 09:39:36.882 | SC Data with Depth | Trading is not supported. 2026-01-14 09:39:36.882 | SC Data with Depth | MarketDepthIsSupported: 1 2026-01-14 09:39:36.882 | SC Data with Depth | Restarting real-time data updates for symbol: NISS-NYSE 2026-01-14 09:39:36.882 | SC Data with Depth | Restarting real-time data updates for symbol: TICK-NYSE 2026-01-14 09:39:36.882 | SC Data with Depth | Restarting real-time data updates for symbol: TRIN-NYSE 2026-01-14 09:39:36.882 | SC Data with Depth | Restarting real-time data updates for symbol: VOLX 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Received logon response. 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Server Name: SC Realtime Server. 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Successfully connected. 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Trading is not supported. 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | MarketDepthIsSupported: 1 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: ESH26. MinimumMarketByOrderQuantity: 10. Service code: cme 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: ESH6.CME -> ESH26 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Starting market orders updates for: NQH26. MinimumMarketByOrderQuantity: 0. Service code: cme 2026-01-14 09:39:37.084 | Denali Data Feed (Market Orders Data) | Restarting market orders data for symbol: NQH6.CME -> NQH26 2026-01-14 09:39:37.511 | HD Request # 105 | Requesting market depth data. Start date-time: 2026-01-14 09:39:25. Symbol: ESH26 2026-01-14 09:39:37.704 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: ESH6.CME. Market orders request not authorized. 2026-01-14 09:39:37.704 | Denali Data Feed (Market Orders Data) | Market Orders data has been rejected for symbol: NQH6.CME. Market orders request not authorized. 2026-01-14 09:39:38.098 | SC Data with Depth | Setting external service identifier for symbol NISS-NYSE to 9 2026-01-14 09:39:38.098 | SC Data with Depth | Received security definition for symbol NISS-NYSE 2026-01-14 09:39:38.098 | SC Data with Depth | Setting external service identifier for symbol TICK-NYSE to 1 2026-01-14 09:39:38.098 | SC Data with Depth | Received security definition for symbol TICK-NYSE 2026-01-14 09:39:38.098 | SC Data with Depth | Setting external service identifier for symbol TRIN-NYSE to 4 2026-01-14 09:39:38.098 | SC Data with Depth | Received security definition for symbol TRIN-NYSE 2026-01-14 09:39:38.098 | SC Data with Depth | Setting external service identifier for symbol VOLX to 67 2026-01-14 09:39:38.098 | SC Data with Depth | Received security definition for symbol VOLX 2026-01-14 09:39:38.424 | HD Request # 105 | Decompressing data. 2026-01-14 09:39:38.433 | HD Request # 105 | Receiving market depth data for ESH6.CME starting at 2026-01-14 09:39:25.029000 2026-01-14 09:39:39.889 | Saved Chartbook: Discipline.Cht. Time: 0.0212 seconds. 2026-01-14 09:39:39.991 | Program is exiting. 2026-01-14 09:39:39.991 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2026-01-14 09:39:39.991 | DTC Client socket (3) | CloseSocket call. 2026-01-14 09:39:39.991 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:39.991 | Denali Data Feed (Market Orders Data) | Waiting for socket receive thread to end 2026-01-14 09:39:39.991 | DTC Client socket (8) | CloseSocket call. 2026-01-14 09:39:39.992 | DTC Client socket (8) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:39.992 | Denali Data Feed (Market Orders Data) | Disconnected from the server. 2026-01-14 09:39:39.992 | Denali Data Feed | Waiting for socket receive thread to end 2026-01-14 09:39:39.993 | DTC Client socket (9) | CloseSocket call. 2026-01-14 09:39:39.993 | Denali Data Feed | Disconnected from the server. 2026-01-14 09:39:39.993 | SC Data with Depth | Waiting for socket receive thread to end 2026-01-14 09:39:39.993 | DTC Client socket (9) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:39.993 | DTC Client socket (1) | CloseSocket call. 2026-01-14 09:39:39.993 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:39.993 | SC Data with Depth | Disconnected from the server. 2026-01-14 09:39:39.993 | Rithmic Direct - DTC | Disconnected. 2026-01-14 09:39:39.993 | Canceling queued historical data download request for TICK-NYSE Intraday data. 2026-01-14 09:39:39.993 | Removing historical data download ID 3465. 2026-01-14 09:39:39.993 | Real-time Intraday chart data file updates started for TICK-NYSE 2026-01-14 09:39:39.993 | Intraday chart data file opened for TICK-NYSE 2026-01-14 09:39:39.993 | Canceling queued historical data download request for NISS-NYSE Intraday data. 2026-01-14 09:39:39.993 | Removing historical data download ID 3466. 2026-01-14 09:39:39.993 | Real-time Intraday chart data file updates started for NISS-NYSE 2026-01-14 09:39:39.993 | Intraday chart data file opened for NISS-NYSE 2026-01-14 09:39:39.993 | Canceling queued historical data download request for TRIN-NYSE Intraday data. 2026-01-14 09:39:39.994 | Removing historical data download ID 3467. 2026-01-14 09:39:39.994 | Real-time Intraday chart data file updates started for TRIN-NYSE 2026-01-14 09:39:39.994 | Intraday chart data file opened for TRIN-NYSE 2026-01-14 09:39:39.994 | Canceling queued historical data download request for NQH6.CME Intraday data. 2026-01-14 09:39:39.994 | Removing historical data download ID 3468. 2026-01-14 09:39:39.994 | Real-time Intraday chart data file updates started for NQH6.CME 2026-01-14 09:39:39.994 | Intraday chart data file opened for NQH6.CME 2026-01-14 09:39:39.994 | Canceling queued historical data download request for ESH6.CME Intraday data. 2026-01-14 09:39:39.994 | Removing historical data download ID 3469. 2026-01-14 09:39:39.994 | Real-time Intraday chart data file updates started for ESH6.CME 2026-01-14 09:39:39.994 | Intraday chart data file opened for ESH6.CME 2026-01-14 09:39:39.994 | Canceling queued historical data download request for RTYH6.CME Intraday data. 2026-01-14 09:39:39.994 | Removing historical data download ID 3470. 2026-01-14 09:39:39.994 | Real-time Intraday chart data file updates started for RTYH6.CME 2026-01-14 09:39:39.994 | Intraday chart data file opened for RTYH6.CME 2026-01-14 09:39:39.994 | Canceling queued historical data download request for NQH6.CME Market Depth data. 2026-01-14 09:39:39.994 | Removing historical data download ID 3473. 2026-01-14 09:39:39.994 | HD Request # 105 | Active download canceled. 2026-01-14 09:39:39.994 | Historical data download thread signaled to stop. 2026-01-14 09:39:39.994 | Socket (2) | CloseSocket call. 2026-01-14 09:39:39.994 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-01-14 09:39:39.994 | HD Request # 105 | Timestamp of first market depth data file record written: 2026-01-14 09:39:25.029000. 2026-01-14 09:39:39.994 | HD Request # 105 | Received 1670 Market Depth data records from 2026-01-14 09:39:25.029000 to 2026-01-14 09:39:27.117000 (2.1 seconds. Delay: 12.9 seconds) and wrote 1670 records for ESH6.CME 2026-01-14 09:39:39.994 | HD Request # 105 | Completion time: 6s. 2026-01-14 09:39:39.994 | HD Request # 105 | Market Depth data download complete for ESH6.CME. Unique request ID: 3471 2026-01-14 09:39:39.994 | Removing historical data download ID 3471. 2026-01-14 09:39:39.994 | 2026-01-14 09:39:39.994 | No download requests in the queue to start downloads for. 2026-01-14 09:39:39.994 | NTP Client | Stop NTP Client. 2026-01-14 09:39:39.994 | NTPClient (4) | CloseSocket call. 2026-01-14 09:39:39.994 | NTPClient (5) | CloseSocket call. 2026-01-14 09:39:39.994 | NTPClient (6) | CloseSocket call. 2026-01-14 09:39:39.994 | NTPClient (7) | CloseSocket call. 2026-01-14 09:39:39.994 | NTPClient (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:39.994 | NTPClient (4) | Closed. 2026-01-14 09:39:39.994 | NTPClient (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:39.995 | NTP Client | Stop NTP Client. 2026-01-14 09:39:39.995 | NTPClient (5) | Closed. 2026-01-14 09:39:39.995 | NTPClient (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:39.995 | NTPClient (6) | Closed. 2026-01-14 09:39:39.995 | NTPClient (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2026-01-14 09:39:39.995 | NTPClient (7) | Closed. 2026-01-14 09:39:39.995 | NTPClient (4) | Socket gracefully closed by remote side. 2026-01-14 09:39:39.995 | Destroying Alert Manager child windows and window. 2026-01-14 09:39:39.995 | NTPClient (5) | Socket gracefully closed by remote side. 2026-01-14 09:39:39.995 | Destroying Alert Manager child windows and window. 2026-01-14 09:39:39.995 | NTPClient (6) | Socket gracefully closed by remote side. 2026-01-14 09:39:39.995 | NTPClient (7) | Socket gracefully closed by remote side. 2026-01-14 09:39:40.024 | This is the last line for the message log because it is being deleted in ExitInstance. |
| [2026-01-14 16:41:06] |
| John - SC Support - Posts: 44021 |
One of the main things we see are a lot of reconnections to Rithmic for some reason. Typically, when we see this it is due to what is described at the following link: Rithmic Trading Platform Service: Frequent Reconnections But, from what we can see, you are on a version of Sierra Chart in which we fixed this problem from occurring. Still, we think you should go through what is described in the above link and remove all symbols that are not proper for Rithmic. For instance, we see the symbol "VOLX" show up in the log - wherever this is being used it needs to be removed as Rithmic can not deal with it. We also see a few of these errors in the log: 2026-01-14 09:31:05.196 | Connection to the external service has been lost.
Which is indicating a lost connection to Rithmic. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-15 04:45:55] |
| Flowdity - Posts: 61 |
Thank you John I will try
