Date/Time: Sat, 20 Apr 2024 03:28:39 +0000
Ratio of The Value etc.
View Count: 1553
[2013-05-14 22:22:42] |
1. The source code is provided and you can modify it and build a new custom studies DLL. For more information, refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html 2. See: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s108 3. Yes, please see: http://www.sierrachart.com/index.php?l=doc_VolumeByPrice.html You are able to set the Volume bars to display numerically the Did Volume and Ask Volume. 4. Use the Horizontal Lines study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s113 5. Use the Bar Difference study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s56 6. Use the Countdown Timer: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s201 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
