Date/Time: Fri, 16 Jan 2026 00:29:06 +0000
Compact Chart Tools Values Window
View Count: 152
| [2025-11-08 16:44:29] |
| GreyLock58 - Posts: 172 |
Where do I go to modify what is shown on the Compact Chart Tools Values Window.? Thanks
| [2025-11-09 01:22:11] |
| Sierra_Chart Engineering - Posts: 22386 |
Refer to: Chart Settings: Chart Values Field Settings (Button) (Chart >> Chart Settings >> Display >> Chart Values menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-10 18:25:03] |
Thanks, Is there a different place to modify "Chart Values for Tools"?
| [2025-11-10 20:07:07] |
| John - SC Support - Posts: 44021 |
Refer to the following: Chart Drawing Tools: Customizing What Is Displayed in the Tool Values Window and the Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
