Date/Time: Fri, 16 Jan 2026 00:35:09 +0000
Requesting Full Access to Trial Mode
View Count: 159
| [2025-11-08 03:17:51] |
| User225436 - Posts: 1 |
Hello, I am currently on the Sierra Chart trial and am unable to activate delayed data, I would like to request full trial access with the "SC Data – All Services" setting enabled, (I don't see this in settings drop down) so I can use delayed CME futures data (ES/MES) for evaluation and practice. Thank you. |
| [2025-11-09 10:39:04] |
| User135243 - Posts: 188 |
this are the symbols you can watch while you're on trail Sierra Chart Trial Account
| [2025-11-10 15:17:23] |
| John - SC Support - Posts: 44021 |
"SC Data - All Services" was changed to "SC Data" several months ago, so you should have your "Current Selected Service" set to "SC Data". If there is something in the documentation that states "SC Data - All Services" please let us know where, as we thought we had updated all of these awhile ago. And as User135243 points out, you have limited data on a trial. If you want access to all the delayed streaming data we have available, then you would need to change to a paid package. The "Base" packages are specifically meant for continued learning/training/development without the need for real-time data or connectivity to trading services. Otherwise, you would need to be on one of the "Integrated" packages. Refer to the following: Description of Service Packages and Pricing To change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
