Date/Time: Sun, 15 Feb 2026 04:13:07 +0000
MES 1-Tick: MDHG has gaps/no data on bars, but MD Window displays 12 levels consistently
View Count: 193
[2025-10-23 09:28:18]
User778352 - Posts: 1
Hi SC Support,
On MES with a 1-Tick chart, the Market Depth Historical Graph shows blank/gap areas across bars (no depth blocks). On some ticks nothing is drawn, while File → Open Market Depth Window shows all 12 bid/ask levels in real time with existing consistent sizes and volume (see screenshot).
Setup: Version 2803, Feed Denali, Symbol MESZ25-CME, chart update in Milliseconds 20
Symbol Settings: Record Market Depth Data = Yes, Depth Levels = 12
Chart Settings → Market Depth: Max Depth Levels = 12, Combine Increment = 0
MDHG Inputs: Maximum Levels = 12, Combine Increment = 1, Minimum Volume Intensity Percent = 2%
Question
What exact configuration ensures a per-tick snapshot so all 12 levels are shown on every 1-Tick bar?
If relevant, please advise on any required flags (download/record/timestamp), suffixes (e.g., -BID_ASK_TRADE_SYNC), or storage interval settings.
Attachments: MDHG example with gaps; Market Depth Window (12 levels).
Thanks in advance.
imagescreenshot MDHG 2025-10-23 1102.png / V - Attached On 2025-10-23 09:23:35 UTC - Size: 77.58 KB - 45 views
[2025-10-23 21:57:11]
Sierra_Chart Engineering - Posts: 22859
Every single trade, is not going to have all 12 levels from the bid and ask side update at the same time. So it makes sense that there is less or no data displayed for a 1 trade bar. This is completely normal.
The only possible solution to this is to set this to Yes:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#StudyInputs_ExtendLastKnownDepthwhile
Date Time Of Last Edit: 2025-10-23 22:00:57
