Date/Time: Sat, 12 Sep 2026 20:44:45 +0000
deleting old data chart that are not used.
View Count: 1803
| [2014-10-14 13:12:20] |
| dez - Posts: 45 |
Wish me a platform to do bad and occasionally loses connection. I guess it's reloaded data that do not use ... I have already two years Siera and continue using contract data,,, How do I delete given that I do not use and do not disrupt the work platform? thanks
| [2014-10-16 08:12:04] |
Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#DeletingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-10-16 08:54:43] |
| dez - Posts: 45 |
folder given me a 14 gb,, it's too,,, SCID have a lot of large files,,, I do not know whether it can be deleted without affecting the work chart ..kako can determine what can I delete and what not? thanks
| [2014-10-16 17:45:30] |
| vegasfoster - Posts: 444 |
You would simply delete the oldest contracts in the folder. SCID files are also highly compressible in Windows, so you could also open the folder and right click on the old files and select Properties>>Advanced>>Compress contents to save disk space. This will make each file significantly smaller and you can still access them the same as before.
| [2014-10-16 19:33:40] |
| dez - Posts: 45 |
thanks . my problem is that my most space occupied scid files even though they are still clenched velikejar them a lot ... my platform does not work well,, we spent a lot of cpu processor,,
