Date/Time: Sat, 05 Sep 2026 17:40:23 +0000
Market Profile Blocks hides the rectangle drawings
View Count: 441
[2025-10-04 04:35:06]
yqz - Posts: 21
I tried using this option I saw on another thread: Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
...but when I merge the market profile blocks, the rectangle drawing still disappears...can I stop this? For example, when a new day starts, there's a new disconnected market profile. I'll then draw some rectangles on another chart to show highs/lows, and they'll be visible on the market profile chart also. However, once the profiles are merged, those rectangles are hidden away. Any solution? Thanks!
[2025-10-06 15:19:59]
John - SC Support - Posts: 47793
You can not copy drawings to a TPO profile chart. The TPO chart does not have the same concept of time as a regular chart, which is why you are having the problem you are.
