Date/Time: Tue, 16 Jun 2026 02:49:37 +0000
need help .
View Count: 316
[2025-10-03 16:11:25]
User402726 - Posts: 9
i need help , is there something wrong with my settings?
Private File
[2025-10-03 16:46:17]
John - SC Support - Posts: 46708
You have "Lock Fill Space" enabled. Refer to the following:
Chart Menu: Lock Fill Space (Chart menu)
Also, there is a way to create a temporary "lock fill space" by holding the Control Key and scrolling. Even after releasing the CTRL key the fill space will stay locked until you scroll all the way to the right of the chart (to the current bar). Then you can scroll as usual after this.
[2025-10-03 18:06:19]
work ,thank you
another question ,
The trade information here is never display. whatever account i choose, the variety is not display correctly. Where is this setting problem?
Thank you
image微信图片_2025-10-04_020140_120.png / V - Attached On 2025-10-03 18:02:32 UTC - Size: 104.04 KB - 143 views
[2025-10-03 18:37:15]
The Statistics, like the other tabs in the Trade Activity Log, is only going to show information for the selected options as set in the "DisplaySettings". In particular, we see that you have the "Trade Activity Type" set to "Account Balance" in the DisplaySettings (this is noted in the Title Bar of the Trade Activity Log).
Change that selection to be "All Activity" and then you will see the statistics for the rest of the given settings.
