Date/Time: Thu, 14 May 2026 01:17:06 +0000
[User Discussion] - polynomial regression channel
View Count: 380
[2025-10-03 15:26:22]
User411320 - Posts: 376
by selecting "No" for Use Redraw (In:5), will this stop the indicator from repainting ?
imageScreenshot 2025-10-03 112436.png / V - Attached On 2025-10-03 15:24:57 UTC - Size: 15.86 KB - 111 views
[2025-10-03 16:25:42]
John - SC Support - Posts: 46122
Since that is not one of our studies, we do not know. We supply the User Contributed Studies without any support for them.
We also do not appear to have the source code for this, so you can not look to see what it does.
[2025-10-03 16:42:33]
Hello John,
Isn't the following the source code?
// PRC - Polynomial Regression Channel
// 20110329 - written by aslan
// 20100330 - added redraw option
SCSFExport scsf_PolynomialRegressionChannel(SCStudyInterfaceRef sc)
SCInputRef Input_PolyDegree = sc.Input[0];
SCInputRef Input_Period = sc.Input[1];
SCInputRef Input_StdDev1 = sc.Input[2];
SCInputRef Input_StdDev2 = sc.Input[3];
SCInputRef Input_Redraw = sc.Input[4];
SCSubgraphRef Subgraph_Fx = sc.Subgraph[0];
SCSubgraphRef Subgraph_Upper2 = sc.Subgraph[1];
SCSubgraphRef Subgraph_Upper1 = sc.Subgraph[2];
SCSubgraphRef Subgraph_Lower1 = sc.Subgraph[3];
SCSubgraphRef Subgraph_Lower2 = sc.Subgraph[4];
if (sc.SetDefaults)
sc.GraphName = "Polynomial Regression Channel";
sc.StudyDescription = "Polynomial Regression Channel";
Input_PolyDegree.Name = "Polynomial Degree (1-4)";
Input_PolyDegree.SetInt(3);
Input_PolyDegree.SetIntLimits(1, 4);
Input_Period.Name = "PRC Period";
Input_Period.SetInt(150);
Input_Period.SetIntLimits(1, 10000);
Input_StdDev1.Name = "Standard Deviation Level 1";
Input_StdDev1.SetFloat(1.618f);
Input_StdDev1.SetFloatLimits(0, 1000);
Input_StdDev2.Name = "Standard Deviation Level 2";
Input_StdDev2.SetFloat(2.0);
Input_StdDev2.SetFloatLimits(0, 1000);
Input_Redraw.Name = "Use Redraw";
Input_Redraw.SetYesNo(1);
Subgraph_Fx.Name = "Mid";
Subgraph_Fx.DrawZeros = false;
Subgraph_Fx.DrawStyle = DRAWSTYLE_LINE;
Subgraph_Fx.LineWidth = 1;
Subgraph_Fx.LineStyle = LINESTYLE_DOT;
Subgraph_Fx.PrimaryColor = COLOR_GRAY;
Subgraph_Upper2.Name = "Upper 2";
Subgraph_Upper2.DrawZeros = false;
Subgraph_Upper2.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_TOP;
Subgraph_Upper2.PrimaryColor = COLOR_RED;
Subgraph_Upper1.Name = "Upper 1";
Subgraph_Upper1.DrawZeros = false;
Subgraph_Upper1.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_BOTTOM;
Subgraph_Upper1.PrimaryColor = COLOR_RED;
Subgraph_Lower1.Name = "Lower 1";
Subgraph_Lower1.DrawZeros = false;
Subgraph_Lower1.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_TOP;
Subgraph_Lower1.PrimaryColor = COLOR_BLUE;
Subgraph_Lower2.Name = "Lower 2";
Subgraph_Lower2.DrawZeros = false;
Subgraph_Lower2.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_BOTTOM;
Subgraph_Lower2.PrimaryColor = COLOR_BLUE;
sc.AutoLoop = true;
sc.DrawZeros = false;
sc.GraphRegion = 0;
sc.GlobalDisplayStudySubgraphsNameAndValue = 0;
sc.DisplayStudyName = 0;
sc.DisplayStudyInputValues = 0;
return;
struct s_PRCData
double ai[10][10];
double b[10];
double x[10];
double sx[20];
int& lastIndex = sc.GetPersistentInt(1);
int& nn = sc.GetPersistentInt(2);
s_PRCData *p_PRCMemory = (s_PRCData *) sc.GetPersistentPointer(1);
if (sc.LastCallToFunction)
// This study is being removed from the chart or the chart is being closed - cleanup
if (p_PRCMemory != 0)
sc.FreeMemory(p_PRCMemory);
p_PRCMemory = 0;
sc.SetPersistentPointer(1, p_PRCMemory);
return;
if (sc.Index == 0)
lastIndex = -1;
sc.ValueFormat = sc.BaseGraphValueFormat;
p_PRCMemory = (s_PRCData*)sc.AllocateMemory(sizeof(s_PRCData));
sc.SetPersistentPointer(1,p_PRCMemory);
if (p_PRCMemory == 0)
return;
// set up static vars
s_PRCData& PRCData = *p_PRCMemory;
nn = Input_PolyDegree.GetInt() + 1;
//----------------------sx------------
PRCData.sx[1] = Input_Period.GetInt() + 1;
for(int i=1;i<=nn*2-2;i++) {
double sum = 0.0;
for(int n=0;n<=Input_Period.GetInt();n++) {
sum+=pow(static_cast<double>(n),i);
PRCData.sx[i+1]=sum;
// make sure we have enough bars to start
if (sc.Index < Input_Period.GetInt())
return;
// erase old data on new bar
if (sc.Index != lastIndex)
lastIndex = sc.Index;
if (Input_Redraw.GetYesNo())
Subgraph_Fx[sc.Index-Input_Period.GetInt()-1] = 0;
Subgraph_Upper2[sc.Index-Input_Period.GetInt()-1] = 0;
Subgraph_Upper1[sc.Index-Input_Period.GetInt()-1] = 0;
Subgraph_Lower1[sc.Index-Input_Period.GetInt()-1] = 0;
Subgraph_Lower2[sc.Index-Input_Period.GetInt()-1] = 0;
// now lets do the real work
return;
//----------------------syx-----------
for(int i=1;i<=nn;i++) {
double sum=0.0;
if(i==1) sum+=sc.Close[sc.Index-n];
else sum+=sc.Close[sc.Index-n]*pow(static_cast<double>(n),i-1);
PRCData.b[i]=sum;
//===============Matrix===============
for(int j=1;j<=nn;j++) {
for(int i=1; i<=nn; i++) {
int k=i+j-1;
PRCData.ai[i][j]=PRCData.sx[k]; // reset ai matrix
//===============Gauss================
for(int k=1; k<=nn-1; k++) {
int l=0;
double m=0.0;
for(int i=k; i<=nn; i++) {
if(abs(PRCData.ai[i][k])>m) {
m=abs(PRCData.ai[i][k]);
l=i;
if(l==0) return;
if (l!=k) {
double tt = 0.0;
for(int j=1; j<=nn; j++) {
tt=PRCData.ai[k][j];
PRCData.ai[k][j]=PRCData.ai[l][j];
PRCData.ai[l][j]=tt;
tt=PRCData.b[k];
PRCData.b[k]=PRCData.b[l];
PRCData.b[l]=tt;
for(int i=k+1;i<=nn;i++) {
double qq=PRCData.ai[i][k]/PRCData.ai[k][k];
if(j==k) PRCData.ai[i][j]=0;
else PRCData.ai[i][j]=PRCData.ai[i][j]-qq*PRCData.ai[k][j];
PRCData.b[i]=PRCData.b[i]-qq*PRCData.b[k];
PRCData.x[nn]=PRCData.b[nn]/PRCData.ai[nn][nn];
for(int i=nn-1;i>=1;i--) {
double tt=0.0;
for(int j=1;j<=nn-i;j++) {
tt=tt+PRCData.ai[i][i+j]*PRCData.x[i+j];
PRCData.x[i]=(1/PRCData.ai[i][i])*(PRCData.b[i]-tt);
double sum=0.0;
for(int k=1;k<=Input_PolyDegree.GetInt();k++) {
sum+=PRCData.x[k+1]*pow(static_cast<double>(n),k);
if (n==0 || Input_Redraw.GetYesNo())
Subgraph_Fx[sc.Index-n] = static_cast<float>(PRCData.x[1]+sum);
//-------------------Std--------------
double sq=0.0, sq1=0.0, sq2=0.0;
sq+=pow(sc.Close[sc.Index-n]-Subgraph_Fx[sc.Index-n],2);
sq=sqrt(sq/(Input_Period.GetInt()+1));
sq1=sq*Input_StdDev1.GetFloat();
sq2=sq*Input_StdDev2.GetFloat();
Subgraph_Upper1[sc.Index-n] = static_cast<float>(Subgraph_Fx[sc.Index-n]+sq1);
Subgraph_Lower1[sc.Index-n] = static_cast<float>(Subgraph_Fx[sc.Index-n]-sq1);
Subgraph_Upper2[sc.Index-n] = static_cast<float>(Subgraph_Fx[sc.Index-n]+sq2);
Subgraph_Lower2[sc.Index-n] = static_cast<float>(Subgraph_Fx[sc.Index-n]-sq2);
I'm not a coder, so I can be wrong
[2025-10-03 16:53:03]
Possibly - probably. Where did you find it? I did not see the "Polynomial Regression Analysis" listed in the list of contributed studies code at the following link (but I did not look into every file):
User Contributed Advanced Custom Study System Source Code
[2025-10-03 16:59:42]
Attached are images where I found it
imageScreenshot 2025-10-03 125541.png / V - Attached On 2025-10-03 16:59:14 UTC - Size: 35.89 KB - 100 views
imageScreenshot 2025-10-03 125825.png / V - Attached On 2025-10-03 16:59:20 UTC - Size: 20.53 KB - 111 views
[2025-10-03 17:49:11]
Then that would be the study source code. Thank you.
[2025-10-03 18:14:06]
I'm not a coder, so as I understand as long as I have the redraw option as "No", it won't repaint.
[2025-10-03 18:47:30]
If you add the study and toggle "Use Redraw" to "Yes" and "No" you will see that you get different results. So it is not just a matter of not re-painting the study.
We will not go into any further analysis of this.
