Date/Time: Sat, 15 Nov 2025 15:02:10 +0000
Match TPO value area lines study with rth times
View Count: 143
[2025-10-03 13:45:01]
Twyxy - Posts: 1
Hello I need to know how I can match the Tpo value area lines study to my TPO chart because i use the rth times and now my VAH VAL and POC levels are not aligning how can i put my TPO VA lines study into RTH times?
[2025-10-03 15:56:36]
John - SC Support - Posts: 43003
Sorry, but we are not sure of the exact setup you are using and why you are using the "TPO Value Area Lines" study.
To begin with, if you have an RTH chart with the TPO study on it, then use the TPO Value Area and POC lines extension option. Refer to the following and the Input right below it:
Time Price Opportunity (TPO) Profile Charts: Extend Value Area
If you are using a Full Session chart with TPO and you want to see the RTH Value Area Lines on that TPO chart, then you need to start with a separate chart that just has the RTH session, and add the "TPO Value Area Lines" study to it. Then you can overlay the "TPO Value Area Lines" to the Full Session TPO Chart. Refer to the following:
Study/Price Overlay Study
Also, be aware of the following, which is why you need to do use the Study/Price Overlay:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
