Date/Time: Mon, 05 Oct 2026 21:16:20 +0000
Automated strategy
View Count: 480
| [2025-09-17 07:17:35] |
| User781731 - Posts: 74 |
I’m writing a custom study which will execute an automated strategy. The study will be applied to the 1 Min chart but it has elements that require conditions being met on other timeframes e.g. 15 Min. Is this possible in ACSIL?
| [2025-09-17 15:04:47] |
| John - SC Support - Posts: 48107 |
Yes, this can be done in ACSIL. You can reference other charts from a custom study on one specific chart. Refer to the following: ACSIL Interface Members - Functions: sc.GetChartArray() You can also do this using the Alert functions by overlaying the information you want from the 15 minute chart to the 1 minute chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-18 20:48:18] |
| OctoPi - Posts: 51 |
Alternative to Johns answer: We have provisions for what you are asking and much more in Octopi plugin if you are more into execution than writing code. |
