Date/Time: Sun, 19 Jul 2026 19:29:05 +0000
[User Discussion] - Testing of ARM version of study
View Count: 389
| [2025-09-10 20:44:53] |
| cmack1011 - Posts: 194 |
HI I just had this ARM-version of a custom study made, however, the developer cannot test the study as he does not have a MacOs with Parallels. Would you be able to test this study on your ARM system as I cannot get it to load on mine and the problem may be with my system and not the study itself. Thank you CNM |
Private File |
| [2025-09-10 21:30:02] |
| John - SC Support - Posts: 47247 |
If you are asking us - Sierra Chart, then the answer is that we do not have a MAC to test this on. If you are asking the community to see if someone could help you, then you need to make that more clear. We have set this as a User Discussion. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-09-11 01:46:36] |
| ForgivingComputers.com - Posts: 1232 |
I have a Mac you can test it on. Could you DM me your email, and I will do a Zoom session with you? Brad Houser |
| [2025-09-17 20:32:25] |
You didn't accept my DM request. I can be reached at: brad (at) forgivingcomputers (dot) com |
