Date/Time: Wed, 17 Jun 2026 13:19:58 +0000
[Locked] - Good News: Chat, Remote Alerts, Screen Sharing now Should Work on Linux/Wine/Mac/Crossover
View Count: 2295
| [2025-09-04 02:51:36] |
| Sierra_Chart Engineering - Posts: 24053 |
It has been a known issue that the Chat functionality and all of the other related functionality: Chat and Communications Platform Has had an issue when Sierra Chart is run under Wine. You would need to use Wine when using Sierra Chart on Linux, or Crossover on a Mac. The problem is, when you open the chat window, the chat becomes nonresponsive and the whole program becomes nonresponsive. Like there is some kind of deadlock going on. We believe the problem always had to do with the fact that the chat runs on a separate thread. And there is some issue within Wine when another user interface within the program is running on another thread. There is now this option that is coming out in the next release that will be out September 4, 2025: Global Settings >> General Settings >> GUI >> Use Secondary Thread for Chat (Default and Recommended): Yes/No If you are using Wine you will want to set this to No and restart Sierra Chart after. A restart is necessary. Also screen sharing is being redeveloped by us, and is currently disabled. It should be out in about a week. So now users of Sierra Chart under Linux or Mac, you can now use the Chat functionality and remote alerts.: Chat and Communications Platform Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-09-04 03:03:01
| [2025-09-04 19:59:47] |
This is going to be version 2790, and will be released later this evening or overnight. We apologize for the delay.
| [2025-09-05 14:13:23] |
Prerelease 2790 is now released.
| [2025-09-11 00:58:04] |
Prerelease 2792 has now been released with all the latest updates related to this. It also supports direct peer to peer screen sharing (in other words from one user's computer to another user's computer). All of the connectivity options are under the Remote menu of the chat window. There is still some more work we need to do to ensure the best performance and the best colors. But it is now functional. Although we need to document this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-11-03 23:25:24] |
We are removing this thread from the top of the board because based on feedback, the change we made did not help. So we really do not know why the chat window freezes when using Wine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-11-03 23:25:31
| [2026-01-02 21:40:40] |
Regarding the chat window, and related functionality, not working on Linux, we thought we had that resolved, as explained in the first post, but we did not. We now know the reason for the problem. We are resolving this now. It has to do with how word wrap calculations were done. There was an OS function we were using, that was not working as expected under Wine. Still, the programming of the related code was not the best design, by the programmer who did this and we are developing a proper solid solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-06 20:54:28] |
In version 2855 and higher, the chat functionality, File >> Open Chat Window, now works properly on Linux/Wine. Documentation: Chat and Communications Platform We still have to resolve the problem with screen sharing under Wine, but that should be resolved by next week. We just need to detect that Wine is used, and use the GDI capture method, instead of the DirectX Desktop Duplication API. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-01-06 20:55:33
