Date/Time: Thu, 20 Aug 2026 00:40:46 +0000
Cannot move VWAP indicator; VWAP anchors at the same point for all stocks in watchlist
View Count: 715
[2025-08-15 01:19:13]
User794005 - Posts: 50
Hello.
Usually when I plot a fresh VWAP there is a grey-ish square right above the origin that helps me drag the VWAP forward and backward so I could anchor it somewhere. I have two issues with what I am facing: 1. The grey square is gone, not allowing me to be able to change it , 2. The VWAP shows up in every stock I have in the watch list and anchored at the same spot. For the point #2, if I would like to have VWAP independent for each stock in my watchlist.
imageScreenshot 2025-08-14 at 9.12.48 PM.png / V - Attached On 2025-08-15 01:14:24 UTC - Size: 252.54 KB - 262 views
imageScreenshot 2025-08-14 at 9.13.07 PM.png / V - Attached On 2025-08-15 01:14:28 UTC - Size: 212.81 KB - 213 views
imageScreenshot 2025-08-14 at 9.12.12 PM.png / V - Attached On 2025-08-15 01:14:34 UTC - Size: 192.81 KB - 188 views
[2025-08-15 13:57:16]
Sierra_Chart Engineering - Posts: 24606
Go to that chart and select Tools >> Manage Chart Drawings Window, do you see Drawing Type anchored VWAP listed?
We are checking on this.
Date Time Of Last Edit: 2025-08-15 13:58:18
