Date/Time: Thu, 20 Aug 2026 00:44:19 +0000
MNQU5 - will not download any data, NQ is totally fine, every instrument is fine but this
View Count: 574
[2025-08-13 02:04:03]
HeyUgly - Posts: 275
scratching my head here
NQ micros will not download anything, no data at all. I closed every chartbook, reopened this single chartbook with the ticker and it will not download at all. Message log included, I do not know why it is doing this. Its only this ticker. Please help
imageMNQ1.PNG / V - Attached On 2025-08-13 02:03:32 UTC - Size: 108.64 KB - 215 views
imageMNQ2.PNG / V - Attached On 2025-08-13 02:03:38 UTC - Size: 50.78 KB - 219 views
[2025-08-13 19:15:40]
Sierra_Chart Engineering - Posts: 24606
We see you are using Rithmic data. We are not able to help with Rithmic data. However, check the Window >> Message Log for any errors related to this. Your broker will need to help.
We recommend using the Denali Exchange Data Feed which we can help with:
[2025-08-13 20:53:58]
i unfort cant use denali, i wish i could i trade with bucket shop props
[2025-08-13 22:16:28]
Fully re-download the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Only use this command from the Edit menu at the top of the main window or chart.
Or, in the case of a Continuous Futures Contract chart, follow these instructions:
After about a minute provide a copy of the Message Log following these instructions:
Date Time Of Last Edit: 2025-08-13 22:17:09
[2025-08-13 22:42:15]
hello
i sent in the log file but disregard
i switched over to SC feed, downloaded, then switched back to Rithmic, and finally it kicked in and started downloading
i know it shouldn't help because the symbols are different, but for some reason it worked for me.
Thank you
[2025-08-14 13:39:23]
Might have been a symbol settings issue:
