Date/Time: Sat, 12 Sep 2026 07:45:59 +0000
change color settings on line tool and chart calculator tool
View Count: 565
[2025-07-26 08:11:42]
Galmik - Posts: 44
Hi John!
Hope you are well. I was trying to change the default color settings on chart calculator and line tool but couldn't find how to do it. Usually i drag the chart calculator and then change the color from the chart drawing properties but i would like to know if there is a way to change the standard color of those settings.
Thank you
Michael
[2025-07-26 18:36:48]
Sierra_Chart Engineering - Posts: 24841
Yes. Refer to:
Chart Drawing Tools: Drawing Tool Configuration
