Date/Time: Thu, 25 Apr 2024 04:39:09 +0000
Selecting VbP
View Count: 888
[2014-10-06 12:17:45] |
joshtrader - Posts: 439 |
Sometimes I am unable to select a drawn volume profile on a chart, and other times I am able to. On one of my charts right now I draw it, and immediately try to select it and cannot. On another chart, I am able to. Obviously I have the option enabled in the SC settings. What would cause this behavior? I have noticed it off and on for some time, but using 1199 right now.
Date Time Of Last Edit: 2014-10-06 12:18:01
[2014-10-06 12:19:26] |
Actually as soon as I posted this I looked and noticed that "Hide chart drawings" was enabled, and when I disabled this, I was then able to select drawn profiles again. I have still had this problem before though, where a symbol change or bar period change would cause this problem, but it's not currently an issue. You can delete this thread if you like, sorry for the inconvenience.
Date Time Of Last Edit: 2014-10-06 12:20:03
[2014-10-06 17:06:27] |
We will be looking into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-10-06 17:07:32
