Date/Time: Thu, 25 Apr 2024 10:15:50 +0000
purchase?
View Count: 1412
[2013-05-12 08:34:11] |
Yes. This is very doable using our Simple Alert feature. Please refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html You will need package 1 or higher. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
