Date/Time: Tue, 16 Jun 2026 02:47:03 +0000
[Programming Help] - Sierra Chart - ORDER_TYPE_STOP_LIMIT
View Count: 432
[2025-06-16 17:51:02]
stefkovic.m28 - Posts: 45
how can I correctly set my stop limit order in Sierra using DTC protocol?
I have there two prices, one Price1 and the second Price2, which is used for stop limit orders.
Do I have to set both of them or how should I tell the Sierra price borders?
Or in case of DTC do I have to use offsets?
Many thanks for the explanation.
regards
[2025-06-17 16:35:44]
Do you have an anser for me please? I need to set my price range all the time correct.
thanks
[2025-06-18 16:38:37]
does anyone other know the answer how to use correct stop limit order with DTC protocol?
thanks
[2025-06-18 21:52:02]
Sierra_Chart Engineering - Posts: 24034
In the case of the DTC protocol Price1 is the Stop price. And Price2 is the Limit price.
This is in the case of a Stop-Limit order. You need to use actual prices. These are not offsets. And they both must be set in the case of this order type.
Date Time Of Last Edit: 2025-06-18 21:52:43
[2025-06-19 06:28:27]
many thanks for the explanation, these info I haven“t found in documentation.
As for the break even I have to update my Limit price, also the Price2, correct?
thanks
[2025-06-19 17:47:48]
Yes update both prices.
